Results 1 to 10 of 10
Thread: A3 8P RVC retro problem
    Jun 2016
    Hi guys, I've just stuck an R8 RVC module on my 8p 04 plate, however I still have a problem. When I put in reverse RNS-E screen flickers and image from RVC comes up for a few seconds, and then RNS-E gets back to function screen. RVC module throws 02283 - Video Connection to Output [End Unit] 011 - Open Circuit fault. Sticking in reverse again won't bring the RVC screen unless I go thought iginition cycle or clear the DTC with VCDS, but again it appears for few sec and comes back to function. Over and over again. I've triple checked the loom, and camera signal cable, all seems to be good (worked flawlessly on my previous 8P). Anyone has an idea where the problem could be? What is indicated as End Unit as per DTC? RNS-E?
    Please post a FULL UNEDITED Auto-Scan showing the fault code.
  3. Likes Uwe liked this post
    Jun 2016
    Here's the full scan. A/V fault is due to unplugged camera from the module
    Thursday,12,December,2019,12:08:10:60351
    VCDS Version: 19.6.2.0 (x64)
    Dealer/Shop Name: Dash Solutions
    VIN: WAUZZZ8P44A039450   License Plate:
    Chassis Type: 8P (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 47 52 56 6C 7D
    VIN: WAUZZZ8P44A039450   Mileage: 332560km-206643miles
    6C-Back-up Cam. -- Status: Malfunction 1010
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 016 FF    HW: 028 101 136 4
       Component: R4 2,0L EDC G000SG  7364
       Revision: 12345678    Serial number: AUX7Z0C6FN80AP
       Coding: 0000072
       Shop #: WSC 00046 000 00000
       VCID: 6CD7A1BA4F60482F6B-8038
    16497 - Intake Air Temp. Sensor (G42)
                P0113 - 000 - Signal too High
                        RPM: 2184 /min
                        Torque: 4.0 Nm
                        Speed: 72.0 km/h
                        Load: 0.0 %
                        Voltage: 13.98 V
                        Temperature: 17.1C
                        Temperature: 84.6C
                        Temperature: 84.6C
       Part No: 1K0 907 379 D
       Coding: 0055942
       Shop #: WSC 06435 000 00000
       VCID: 33657AC652DED7D76A-8066
       Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
       Component: KlimavollautomatH09 0180
       Revision: 000355      Serial number: 8P0820043BM
       VCID: 78FF8DEA0B38F48F9F-802C
    00483 - Control Module for Auxiliary Air Heater
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 99
                        Mileage: 332139 km
                        Date: 2019.12.06
                        Time: 13:56:52
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 K    HW: 8P0 907 279 K
       Component: Bordnetz-SG     H54 2501
       Revision: 00H54000    Serial number: 00000007412374
       Coding: F5885F06821410001F000000000000000009FE0F5C01022E000000000000
       Shop #: WSC 06314 122 00001
       VCID: 4581341E0C4A5967D4-8010
       Subsystem 1 - Part No: 8P1 955 119   Labels: 1TX-955-119.CLB
       Component: Wischer WWS Audi350 0130
       Coding: 15925264
       Shop #: WSC 06314
       Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH10 0040
       Coding: 00216109
       Shop #: WSC 06314
    Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
       Part No SW: 5P0 919 475 B    HW: 5P0 919 475
       Component: PARKHILFE 4K  H07 0008
       Revision: --------    Serial number: 89320931800356
       Coding: 300004
       Shop #: WSC 00046 123 12345
       VCID: 3A7B57E2B5B4269FA9-806E
    Address 15: Airbags        Labels: 8P0-959-655-84.lbl
       Part No SW: 8P0 959 655 F    HW: 8P0 959 655 F
       Component: Airbag 8.4ED    H01 0130
       Coding: 0010602
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0002042
       Shop #: WSC 00046 412 16384
       VCID: 4189200E18627547E8-8014
       Component: E0221           H03 0030
       Part No SW: 8P0 920 932 S    HW: 8P0 920 932 S
       Component: KOMBIINSTR. VDO H03 0380
       Revision: D0H03005    Serial number: 2247L005012630
       Coding: 0260128
       Shop #: WSC 50741 143 61874
       VCID: 4487291A0770606FC3-8010
       Part No SW: 7N0 907 530 BJ    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1682
       Revision:   H58       Serial number: 270813F2000634
       Coding: 350100
       Shop #: WSC 61064 064 61064
       VCID: 79F988EEF032ED87E0-802C
                        Fault Status: 00110100
                        Reset counter: 147
                        Mileage: 332507 km
                        Date: 2019.12.10
                        Time: 15:38:07
       Revision: D0H03005    Serial number: AUX7Z0C6FN80AP
       Shop #: WSC 00137 211 56823
       Part No SW: 8E0 035 193 A    HW: 8E0 035 193 A
       Component: RNS-E PU EU     H06 0220
       Revision: 0000011S    Serial number: AUZBZ7KD205532
       Coding: 0225115
       VCID: 23458A86E23E47579A-8076
    02261 - Data Medium
                        Fault Status: 00101110
                        Reset counter: 149
                        Mileage: 332496 km
                        Date: 2019.12.10
                        Time: 12:51:04
                        Mileage: 332550 km
                        Count: 1212
                        Clock: 09:05
    00856 - Radio Antenna
                        Fault Status: 01101011
                        Reset counter: 103
                        Mileage: 332432 km
                        Date: 2019.12.08
                        Time: 15:23:40
                        Mileage: 332430 km
                        Count: 812
                        Clock: 15:23
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 103
                        Mileage: 332432 km
                        Date: 2019.12.08
                        Time: 15:23:37
                        Mileage: 332430 km
                        Count: 812
                        Clock: 15:23
    02454 - Microphone Unit (in Front Roof Module) (R164)
                        Fault Frequency: 72
                        Reset counter: 110
                        Mileage: 332432 km
                        Date: 2019.12.08
                        Time: 15:23:21
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
       Part No: 8P0 959 801 A
       Component: Tuersteuerger.  H09 0010
       Coding: 0000120
       VCID: 397948EE70B22D87A0-806C
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 239    3501
       Revision: 00H17000
    Address 46: Central Conv.        Labels: 8P0-959-433.lbl
       Part No: 8P0 959 433 J
       Component:    KSG          H11 0080
       Coding: 1880222002487F00870FC08A0167
       Shop #: WSC 08224 085 73347
       VCID: 43852A06027E6757FA-8016
       Part No SW: 8P3 035 382     HW: 8P3 035 382
       Component: AB2 SUBWOOFERBOXH27 0160
       Revision: 00005       Serial number: 30659630294399
       VCID: 70EFB5CA6348ACCF57-8024
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
       Part No: 8P0 959 802 A
       Coding: 0000120
       VCID: 3A7B57E275B4269FA9-806E
    00106 - Signal Central Locking SAVE/LOCK Passenger Side
       Coding: 0225115
    02261 - Data Medium
                        Reset counter: 149
                        Mileage: 332496 km
                        Date: 2019.12.10
                        Time: 12:51:04
                        Mileage: 332550 km
                        Count: 1212
                        Clock: 09:05
                        Reset counter: 103
                        Mileage: 332432 km
                        Date: 2019.12.08
                        Time: 15:23:40
                        Mileage: 332430 km
                        Count: 812
                        Clock: 15:23
                        Reset counter: 103
                        Mileage: 332432 km
                        Date: 2019.12.08
                        Time: 15:23:37
                        Mileage: 332430 km
                        Count: 812
                        Clock: 15:23
                        Fault Frequency: 72
                        Reset counter: 110
                        Mileage: 332432 km
                        Date: 2019.12.08
                        Time: 15:23:21
    Address 6C: Back-up Cam.        Labels: 420-910-441.clb
       Part No SW: 420 910 441 A    HW: 7L6 907 441 C
       Component: J772__Rearview      0010
       Revision: --H13---    Serial number: 525PA8-JA3600O
       Coding: 1020712
       Shop #: WSC 98765 666 38681
       VCID: 0A1BC72265D4F61FF9-805E
                        Reset counter: 107
                        Reset counter: 107
                        Mileage: 332507 km
                        Date: 2019.12.10
                        Time: 15:24:26
                            Term 15 On
                            Reverse ON
                        Count: 4
    02203 - Audio / Video Input 1
                        Reset counter: 107
                        Mileage: 332507 km
                            Term 15 On
                            Reverse ON
                        Count: 9
    Address 7D: Aux. Heat
    End-------------------------(Elapsed Time: 02:00)--------------------------
    Jun 2016
    Anyone knows what it stands for? RNS-E? "Video Connection to Output [End Unit]"
    Jan 2015
    Bosnia and Herzegovina
    Quote Originally Posted by Oski View Post
    this means that either a cable is broken or pins are wrongly pinned hence open circuit, so check cable behind rns e, sometimes there is a break or bad connection on these cables especially if it's removed and reinstalled.
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  7. Likes Oski liked this post
    Jun 2016
    Wiring must be good as video comes up for a few seconds, and then switches off and fault comes up
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier 007 - Short to Ground
    Is the RNS-E a retrofit from a Symphony II+?
    I wonder if this is the problem?
    Reset counter: 107
    Jun 2016
    It seems like, can't say though as I bought it with rnse onboard
    It ain't mate. I had this set on my previous 8p, and this fault wasn't affecting camera itself
  11. #9
    Jan 2015
    well either module or wiring from module to rns e is causing problem, just in case check wiring if ok try replacing module?
    GOOD CHEAP FAST
  12. #10
    Jun 2016
    Quote Originally Posted by m87a View Post
    either module
    This is what I am afraid of....
