Coding coasting function on skoda kodiaq
Roby_GTI
Italy
C?ID=351131
hello,
someone knows how to remove this annoying function on skoda kodiaq my2019?
Roby_GTI
Italy
C?ID=351131
Tuesday,19,November,2019,15:41:16:51983
VIN: TMBJJ7NS6L8006704   License Plate:
Mileage: 3718km-2310mi   Repair Order:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 42 44 52 5F 75 BB BC
VIN: TMBJJ7NS6L8006704   Mileage: 3718km-2310miles
Address 01: Engine (J623-DFGA)       Labels: None
   Part No SW: 04L 906 027 D    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H26 9615
   Revision: B4H26---
   Coding: 0125001203241D083000
   Shop #: WSC 00033 790 00188
   ASAM Dataset: EV_ECM20TDI01104L906027D 004005
   ROD: EV_ECM20TDI01104L906027D.rod
   VCID: AC148705C7C0B82FAB-80F8
   Part No SW: 0GC 300 044 G    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2401
   Revision: 00H06V07
   ROD: EV_TCMDQ381061_VW37.rod
   Part No SW: 5Q0 614 517 ER    HW: 5Q0 614 517 BN
   Component: ESC           H35 0190
   Revision: 00000000    Serial number: 61789000003278
   Coding: 60076A9F40200B72477E060062C749065602D0E2604692713061F078D2024A0B00002E64121A03102F35351919323200
   Shop #: WSC 00033 790 00111
   VCID: 854212A104EAA96714-80D0
   Part No SW: 3Q0 959 435 K    HW: 3Q0 959 435 K
   Component: VWKESSYMQB    027 1204
   Revision: 00027000    Serial number: 0518304434
   Coding: 000F0F0723
   VCID: C2C8C9BD55445E5F71-8096
   Part No SW: 565 907 044 CE    HW: 565 907 044 CE
   Component: Climatronic   H04 2202
   Revision: 00001K00
   Coding: 16010104000110011005000800101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006150
   VCID: E08C2335FB882C4F47-80B4
   Air quality sensor:
   Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 99490362
   Part No SW: 5Q0 937 086 CC    HW: 5Q0 937 086 BN
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: J53F10061900IO
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020_VW27.rod
   VCID: FDB27A416C3AE1A74C-80A8
   Subsystem 1 - Part No SW: 566 955 119     HW: 566 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS326 190606  051  0910
   Serial number: 887353F0401915703577
   Coding: 164DDD
   Component: RLHS  051  0205
   Serial number: S6Y19M06D19H01M58S11
   Coding: 00885D
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 P    HW: 5Q1 953 569 A
   Component: Lenks.Modul  H13  0170
   Serial number: 0100150620190C401092
   Part No SW: 3Q0 919 294 E    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H08 0046
   Serial number: 002405197498030
   Coding: 0071051011
   ASAM Dataset: EV_EPHBO18VW3260000 007021
   ROD: EV_EPHBO18VW3260000_007.rod
   VCID: BB36B45932AE2F9732-80EE
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 3204600158FF8728749C814500408700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003016
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: C3C6CCB94A5E57577A-8096
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Revision: --------    Serial number: 003Z2PC6HE5X
   Coding: 98CCC0C0000000005C5400CF000840000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 8B562499228EDF1742-80DE
   Subsystem 1 - Part No SW: -----------    HW: 454 000 406 19
   Serial number: 35700000000B14950C3H
   Subsystem 2 - Part No SW: -----------    HW: 454 000 406 19
   Serial number: 35800000000FE7BC0C34
   Subsystem 3 - Part No SW: -----------    HW: 454 800 206 19
   Serial number: 3510074D7E218000000M
   Subsystem 4 - Part No SW: -----------    HW: 454 800 206 19
   Serial number: 352009C97E018000000R
   Subsystem 5 - Part No SW: -----------    HW: 454 802 505 19
   Serial number: 355003D8F6B18000000Z
   Part No SW: 565 920 790 C    HW: 565 920 790 C
   Component: KOMBI         502 4191
   Coding: 04A4011C23800008018C62011001000880000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 9E705DCD817C5ABF35-80CA
   Component: GW MQB High   521 5388
   Serial number: 29061910522498
   Coding: 030100045F08730023100240100F00010001070000000000000000000000
   Shop #: WSC 00033 790 00141
   ROD: EV_GatewNF.rod
   VCID: F0AC53752B689CCFD7-80A4
   Component: 4-01-13-01-04
   Subsystem 2 - Part No SW: 3V0 919 719 F    HW: 3V0 919 719 F
   Component: E221__MFL-PR6  H03 0180
   Serial number: 000000000B1423150619
   Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Serial number: 75886103001905231BC8
   Serial number: 19000168207003
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
   VCID: B3269C791AFEE7D7EA-80E6
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0480
   Serial number: 0000379649271
   Coding: 00150120D000020000001100
   VCID: CDD2EA819C1A91279C-8098
   Subsystem 1 - Part No SW: 5Q0 959 407 A    HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000031227476
   Coding: 010200
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 954035 00
   Coding: 0100001000400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
   VCID: AB168419C2CEBF17A2-80FE
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0480
   Serial number: 0000379544576
   ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
   VCID: CCD4E7856700982F8B-8098
   Subsystem 1 - Part No SW: 5Q0 959 408 A    HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000031368579
   Coding: 190200
   Part No SW: 565 035 874     HW: 565 035 874
   Component: MU-S-ND-ER    H41 0477
   Serial number: SKZAZ2W0456054
   Coding: 03231601FF0000004111120100880A002F0208E401200400CE
   ROD: EV_MUStd4CTSAT_VW41.rod
   VCID: DBF614D9D2EE0F9712-808E
   Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: SKZ6ZHW1740157
   Subsystem 2 - Part No SW: 5L0 051 236 BA    HW: -----------
   Component: ECE AS 19/20  --- 1115
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 03231601EA421A0D3F1C9E000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: BD32BA412CBA21A70C-80E8
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 01:44, VBatt start/end: 12.2V/12.1V)-----------
hello,
Does it happen in all gearbox modes, or only ECO?
Have you tried the gearbox Sport mode?
Roby_GTI
Italy
C?ID=351131
in all mode!
with the selector lever in S I don't know
in all mode!
Since you don't know with the selector lever in S mode it sounds like you are confusing Drive Mode with Gearbox Mode - they are completely different.
Try with the selector lever in S mode and report back please :thanks:
Roby_GTI
Italy
C?ID=351131
in S mode the coasting is not active,
is there the possibility to remove it also in D?
