Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: ABS - No Connection issue 04 allroad Bosch 5.0
    New User
    Dec 2019
    Question ABS - No Connection issue 04 allroad Bosch 5.0
    Short version 04 allroad 4.2 doing a manual swap: Car has never communicated with ABS since I owned it. No ABS lights, or issues on the cluster. Pulled engine, did timing chain package, reinstalled the engine, still no issues, lights or beeps. Went to scan before pulling engine to look into coding changes for 6 speed swap. Cannot connect to ABS. Look through all previous scans none of them connected to ABS. I swap the module with a known good one (parts car) No connection and now LIGHTS and the three beeps.
    I read about the radio possibly being an issue. I remove radio still cannot connect, still 3 beeps. Previous owner modified the factory radio for aux in through CD Changer inputs.
    I check the voltage at the ODB2 K line (4 and 7) 10.31 V same at the ABS harness pin 28 Ground and 46 K line
    I am also seeing a sporadic connection issue to radio now.
    I'd really like to figure this out before I finish the assembly of the swap package and have the same issue but a car ready to drive and program.
    Thanks for any thoughts!
    Auto scan from Purchase
    Saturday,13,April,2019,12:20:08:16173
    VCDS Version: 18.9.1.0 (x64)
    VIN: WA1YL64B34N032078   License Plate:
    Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
              75 76 77
    Address 01: Engine        Labels: None
       Part No SW: 4D0 907 560 BE    HW: 8E0 907 560
       Component: 4.2L V8/5V      G   0020
       Coding: 0007755
       Shop #: WSC 02334 785 00200
       VCID: 6AD07B5E4640C41A63-5120
    17985 - Right Engine Mount Solenoid Valve (N145)
                P1577 - 004 - Open Circuit
    16815 - Warm Up Catalyst; Bank 2
                P0431 - 001 - Efficiency Below Threshold
    17738 - Knock-Control: Cylinder 6
                P1330 - 001 - Regulation Limit Exceeded - Intermittent
    17739 - Knock-Control: Cylinder 7
                P1331 - 001 - Regulation Limit Exceeded - Intermittent
    16395 - Bank 1: Camshaft A (Intake)
                P0011 - 008 - Retard Setpoint not Reached (Over-Advanced)
    Readiness: 0000 0001
       Part No: 4Z7 927 156 S
       Component: AG5 01V 4.2l5V  USA 1215
       Coding: 0001002
       VCID: 56A83FAEE23870FAD7-5120
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AR
       Component: A6-Klimavollautomat 0208
       Coding: 00110
       VCID: 6AD07B5E1640C41A63-2572
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4Z7 959 655 J
       Component: Airbag 8.4EP        3000
       Coding: 0000607
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 F
       Component: Lenkradelektronik   D01
       Coding: 01005
       Shop #: WSC 02334
       VCID: 2F66AA4AED22613274-5102
       Part No: 4B0 920 981 P
       Component: KOMBI+WEGFAHRS. VDO D14
       Coding: 06283
       Shop #: WSC 00222
       VCID: 336EA63A010A45D210-5120
       WA1YL64B34N032078     AUZ7Z0C2459363
    Address 34: Level Control        Labels: 4Z7-907-553.lbl
       Part No: 4Z7 907 553 F
       Component:  - 2C1A1          D060
       Coding: 25500
       Shop #: WSC 02334
       VCID: 4894E1D6688CD60A55-5120
    01575 - Control Switched Off
                35-00 -  -
    Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
       Part No: 4B0 962 258 M
       Component: Central Lock/Alarm  D38
       Coding: 15885
       Shop #: WSC 22122
       VCID: 336EA63A010A45D210-4ECA
                35-00 -  -
                35-00 -  -
    01559 - Drivers Door
                58-10 - Can't Lock - Intermittent
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0101
       Coding: 00001
       VCID: 2C5CBD46DC341A2A51-4B00
    Address 37: Navigation        Labels: 4B0-919-887-BNS4.lbl
       Part No: 4B0 919 887 E
       Component: BNS 4.2 H05    BNO 0050
       VCID: 356A98220F7E5BE23E-4ACE
                00-00 -  -
       Part No: 4Z7 907 357
       Coding: 00030
       Shop #: WSC 02334
       VCID: 040C35E61424326AF9-4B18
    Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
       Part No: 4B0 035 195 N
       Component: symphony II NP2    0400
       Coding: 02017
       Shop #: WSC 22016
       VCID: 2B5EBE5AD93A1D1258-5072
    00857 - CD Changer Unit (R41)
                49-00 - No Communications
    Address 75: Telematics        Labels: 8E0-035-616.lbl
       Part No SW: 8E0 035 616 B    HW: 8E0 035 616 B
       Component: Telematik USA1      1616
       Coding: 0002333
       Shop #: WSC 22122 444 01310
       VCID: 244C5566E4E4D26A99-5120
    01528 - Auxiliary Antenna for Telematic (R90)
    Address 76: Park Assist        Labels: 8Z0-919-283.lbl
       Part No: 8Z0 919 283
       Component: Parkingsyst. A6 RDW D08
       Coding: 01186
       Shop #: WSC 02334
       VCID: 020033FE0E303C5ACB-5120
    End-------------------------(Elapsed Time: 04:59)--------------------------
    Auto scan today (Ignore the faults engine / trans are out.
    Tuesday,10,December,2019,14:45:46:16173
    VCDS Version: 19.6.2.0 (x64)
              75 76 77
       Coding: 0007755
       VCID: 6AD07B5E4640C41F19-5120
    8 Faults Found:
    17951 - Angle Sensor 1 for Throttle Actuator (G187)
                P1543 - 002 - Signal too Small
    17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
                P1172 - 002 -
    17987 - Throttle Actuator (J338)
                P1579 - 001 - Adaptation Not Started
    18320 - Pressure Sensor for Brake Boost (G294)
                P1912 - 001 - Short to Plus - Intermittent
    16497 - Intake Air Temp. Sensor (G42)
                P0113 - 002 - Signal too High
    18080 - Coolant Fan Control 1
                P1672 - 004 - Open or Short to Ground
    18308 - Coolant Fan Control 2
                P1900 - 004 - Open or Short to Ground
    Readiness: 0110 1101
       Coding: 0001002
       VCID: 56A83FAEE23870FFAD-5120
    17090 - Transmission Range Sensor (F125)
                P0706 - 003 - Implausible Signal
    17094 - Transmission Fluid Temp Sensor (G93)
                P0710 - 003 - Malfunction
    18265 - Load Signal
                P1857 - 003 - Error Message from ECU
    18155 - Transmission Solenoid Power Relay
                P1747 - 003 - Open or Short to Ground
    18158 - Supply Voltage
                P1750 - 003 - too Low - Intermittent
       Coding: 00110
       VCID: 6AD07B5E1640C41F19-256C
                30-00 - Open or Short to Plus
                27-00 - Implausible Signal
       Coding: 0000607
       Coding: 01005
       Shop #: WSC 02334
       VCID: 2F66AA4AED2261370E-5120
    01304 - Radio
       Coding: 06283
       Shop #: WSC 00222
       VCID: 336EA63A010A45D76A-5120
    01304 - Radio
       Coding: 25500
       Shop #: WSC 02334
       VCID: 4894E1D6688CD60F2F-5120
    01316 - ABS Control Module
       Coding: 15885
       Shop #: WSC 22122
       VCID: 336EA63A010A45D76A-4ECA
                58-00 - Can't Lock
       Coding: 00001
       VCID: 2C5CBD46DC341A2F2B-4AE6
       VCID: 55AA38A2AC3E7BE7A4-4AB4
       Note: Excessive Comm Errors
       Coding: 00030
       Shop #: WSC 02334
       VCID: 040C35E61424326F83-4B18
    00532 - Supply Voltage B+
       Coding: 02017
       Shop #: WSC 22016
       VCID: 2B5EBE5AD93A1D1722-5072
    00856 - Radio Antenna
                36-00 - Open Circuit
                37-10 - Faulty - Intermittent
       Coding: 0002333
       VCID: 244C5566E4E4D26FE3-5120
       Coding: 01186
       Shop #: WSC 02334
       VCID: 020033FE0E303C5FB1-5102
    End-------------------------(Elapsed Time: 05:34)--------------------------
    Have you checked continuity of K-line to the connector at the ABS module?
    Have you checked power at relevant pins of ABS module?
    Have you tried installing a known good ABS module, one that communicates in a different car?
    New User
    Dec 2019
    Continuity from ODB2 pin 7 and 46 of ABS Yes
    I Have power at pin 1 for ABS.
    Just found I might need power at pin 50, which does not. both fuses that serve that appear to be good. Trying to find a better wiring diagram for the Bosch ABS 5.0
    I have swapped another module from my parts car. Still no connection.
    New User
    Dec 2019
    Turns out the first info I got was wrong https://workshop-manuals.com/audi/a4...ctrical_check/, it is actually #51 per another wiring diagram I found. I do have power at #51 also. So tested two Modules, 1 known good from another car scan and neither of them work. Is the voltage too high on the K line?
    Quote Originally Posted by cu52 View Post
    Does either of the ABS modules communicate when installed in the other (parts) car?
    When inactive, the K-line is floating, and the voltage is determined by leakage current from various modules. Since you can talk to other modules just fine, I think we can safely assume that the K-line is not stuck.
  6. #6
    New User
    Dec 2019
    The other ABS module did connect in the parts car. I currently cannot test it there again. I grabbed another module today (condition unknown) to test.
    Should I be seeing CAN voltage to the ABS module when not connected? I tried to get CAN voltage and I could not get any. The Radio had CAN H voltage but was higher and CAN L was lower than research told me it should be. I know nothing about CAN!
  7. #7
    New User
    Dec 2019
    Still have no connection to ABS. Tried 3 different modules. Not sure what I need to do now or what other troubleshooting I can do. CEL shows no connection to Stering angle sensor or ABS module.
  8. #8
    Can you connect to the engine and trans - or are they still out?
    Maybe the K-line to the ABS is broken somewhere in the loom - have you checked it out with a DVOM?
  9. #9
    New User
    Dec 2019
    Engine and trans back in. I can connect to both with no issue, but have removed TCU (6 MT swap). I have K line voltage at the ABS module. last scan attached (TCU unplugged and front clip not attached, headlights, fans etc)
    Monday,30,December,2019,22:24:11:16173
              75 76 77
       Coding: 0007755
    18034 - Powertrain Data Bus
                P1626 - 008 - Missing Message from TCU
       Coding: 00110
       VCID: 6AD07B5E1640C41F19-2572
       Coding: 0000607
       Coding: 01005
       Shop #: WSC 02334
    01304 - Radio
       Coding: 06283
       Shop #: WSC 00222
       Coding: 25500
       Shop #: WSC 02334
       Coding: 15885
       Shop #: WSC 22122
       Coding: 00001
       VCID: 55AA38A2AC3E7BE7A4-4ACE
       Coding: 00030
       Shop #: WSC 02334
       Coding: 0002333
       Coding: 01186
       Shop #: WSC 02334
    End-------------------------(Elapsed Time: 05:58)--------------------------
  10. #10
    Have you checked continuity using the DVOM in Ohms mode?
