2016 Audi A3 Saloon - Backup/Rear Camera Retrofit
LukeLewis24
C?ID=271228
Hi I am trying to install a backup camera to the car.
I have wired it directly into the MMI and the car recognises that the camera is attached.
The cables I was given and have connected
Can Bus High - Entertainment
Can Bus Low - Entertainment
Black Wire from Camera into Blue connector in MMI #6
White Wire from Camera into Blue connector in MMI #12
7.5A Power Supply
Earth Connection
However I am unable to get the camera to appear on the screen when I select reverse gear.
Under Info Elect I have changed the following
- BAP-VPS_0x0B to activated
- BAP-VPS_ox0B_msg_bus to Comfort Data Bus
I have looked online and some people are using a reversing camera system control unit but the cables I was given go directly into the MMI?
Confused!
Can anyone help me with this?
Luke
Tuesday,10,December,2019,21:26:54:11660
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ8V1H1004756   License Plate:
Mileage: 34521km-21450mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F 6C BB BC
VIN: WAUZZZ8V1H1004756   Mileage: 34521km-21450miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BN    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H23 1197
   Revision: B5H23---
   Coding: 02190012032501082000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TDI01104L906026BN 002002
   ROD: EV_ECM20TDI01104L906026BN_002.rod
   VCID: 77FD8582CEE0C8F796-8022
17161 - Databus
   Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
   Component: ESC           H62 0636
   Revision: 00000000    Serial number: 61646000002924
   Coding: 13F18AA224200A70497E0E0541C929C8512450927082947202610078800802
   VCID: 7AFB9CB6FDF2D59FE9-802E
   Part No SW: 8V0 820 043 M    HW: 8V0 820 043 M
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000000966728
   Coding: 03100104002000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 3C775AAEB7462BAFBB-8068
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 7178453800PAG0MUFU03
   Serial number: 02001617001057
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EF390A6E1DAF9BFD5-802A
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 160529  043 0585
   Serial number:         160616075711
   Coding: 0A47F7
   Serial number: 61934651
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Serial number: 22 04 2016  00000038
   Serial number: 000000000ZY161301D3Z
   Serial number: 00000000000035705285
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0315
   Serial number: 003TDR1WJA05
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 102FDE1ECB4EFFCF37-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 001 706 16
   Serial number: 357000000008F6353C1P
   Subsystem 2 - Part No SW: -----------    HW: 480 001 706 16
   Serial number: 35800000000E05553C1I
   Subsystem 3 - Part No SW: -----------    HW: 480 402 106 16
   Serial number: 3510001C120FC483B855
   Subsystem 4 - Part No SW: -----------    HW: 480 402 106 16
   Serial number: 3520001C120FC481C43%
   Subsystem 5 - Part No SW: -----------    HW: 480 401 806 16
   Serial number: 3550002C7209E9E031EE
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 005 16
   Serial number: 2280002992057290A2B.
   Subsystem 7 - Part No SW: -----------    HW: 480 402 005 16
   Serial number: 2290002BB207634162B-
   Subsystem 8 - Part No SW: -----------    HW: 480 002 106 16
   Serial number: I0M00000000DA8253C18
   Subsystem 9 - Part No SW: -----------    HW: 480 002 106 16
   Serial number: I0N00000000785540C1/
   Part No SW: 8V0 953 521 JD    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 16061604400549
   Coding: A008
   VCID: 0501FF4A840CAA6794-8050
   Part No SW: 8V0 920 972 L    HW: 8V0 920 972 L
   Component: KOMBI         H03 8315
   Coding: 27AD19002B9026000100FE001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009054
   VCID: 479D3542FE80787726-8012
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 94
                    Mileage: 33702 km
                    Date: 2019.10.06
                    Time: 14:35:34
16776980 - Databus
                    Reset counter: 74
                    Mileage: 34521 km
                    Date: 2019.12.10
                    Time: 20:49:54
   Revision: --------    Serial number: 20061610800366
   Coding: 030100041F0873005B000248080B00000001010000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CF79AAEF7C6EBAFFB-8028
   Subsystem 2 - Part No SW: 81A 951 523     HW: 81A 951 523
   Component: J453 MFL  H04 0003
   Serial number: 20160610230608 02731
   Serial number: 75410803001606070553
131594 - Parallel Parking Assistance Control Module
          U104E 00 [008] - No communication
                    Reset counter: 114
                    Mileage: 33094 km
                    Date: 2019.10.01
                    Time: 23:46:31
                    Terminal 15: On
131689 - Rear View Camera System Control Module
          U104C 00 [008] - No communication
                    Reset counter: 114
                    Mileage: 34521 km
                    Date: 2019.12.10
                    Time: 21:18:11
                    Terminal 15: OFF
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
                    Reset counter: 114
                    Mileage: 34521 km
                    Date: 2019.12.10
                    Time: 19:47:41
                    Terminal 15: OFF
66304 - Databus
          U1124 00 [008] - Additional Installations Detected
                    Reset counter: 114
                    Mileage: 34521 km
                    Date: 2019.12.10
                    Time: 20:43:26
                    Terminal 15: On
   Serial number: 010616EEV05263
   Coding: 001C8A204001040000001002
   VCID: 43852152CAB85457FA-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45813F4AC48C6A67D4-8010
   Serial number: 040616EF406237
   Coding: 001C82204C01040000001002
   VCID: 428B2456D5A25D5FF1-8016
65558 - Heated Exterior Mirror
          B11F8 14 [009] - Open or Short to Ground
                    Fault Frequency: 39
                    Reset counter: 69
                    Mileage: 33094 km
                    Date: 2019.10.01
                    Time: 23:55:29
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0226
   Coding: 0EDE00102B230200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E7350A6A15A39BF95-806A
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 81A 035 192     HW: 81A 035 192
   Component: MU-HS-LND-EU  045 0148
   Coding: 01730101FF00000011111101000A00102F002AC601F00100CE
   ASAM Dataset: EV_MUHigScl6C3DELP 001011
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 5EB3F026411A19BFF5-800A
   Subsystem 1 - Part No SW: V03 959 802 LE    HW: -----------
   Component: ECE 2019/2020  --- 0043
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY205UUG
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL113041600010048
   Component: RVC Compact   H15 0231
   Coding: 0273000102002001000040
   VCID: 397943BAB8741E87A0-806C
10489856 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 63
                    Time: 00:00:00
13705478 - Databus
                    Reset counter: 74
                    Mileage: 34521 km
                    Date: 2019.12.10
                    Time: 20:49:49
                    passive
   Serial number: 190516EEF04672
   Coding: 000C82204001040000001002
   Serial number: 190516EEF04678
End-------------------------(Elapsed Time: 03:46)--------------------------
kamold
Australia
C?ID=241363
In 5F you need to enable RVC.
Byte 19 bit 4 needs to enabled.
VPS is for highline RVC modules, you might need to change those back to disabled.
andyhud
C?ID=32695
The fact you can see it as 6C means its a highline version as it has can bus lines, not a low line, so you dont need to do Byte 19/Bit 4 in 5F
If you have enabled in Can Gateway installation list (as its showing in the list) your good.
Yes, the video wires should go into 6 + 12 in the back of the MMI, so you've done that right. There is no separate "control unit" box in the MLBEvo platform.
You've done the 2 Adaptation channels in 5F right but change this one to "Termainl 15"
BAP-VPS_ox0B_msg_bus > Set to Terminal 15
Go into Module 09, byte 38 and set bit2-3 to camera_variant_vps_installed
Reboot (3 finger reboot) the MMI and you should be good to go
Let us know
Andy
p.s. Get your VCDS Dongle upgraded to a Hex-Net or Hex-V2. Its why you cant see all the modules currently. RT do a trade-in upgrade I believe.
kamold
Australia
C?ID=241363
My apologies I only skimmed and didn't notice the RVC compact at 6C.
It has no basic settings so needs calibration, however it will still display the image when otherwise correctly configured.
DV52
C?ID=194404
7.5A Power Supply
Earth Connection
Confused!
Luke
Luke: Hi.
Below is a schematic of the hex6C arrangement that I have cobbled together from a number of pages in the A3 WD:
So, here's the thing - I'm confused too about the bits that I have highlighted in your post. No offense intended, but the coax wire from J772 to J794 may be reversed if what you have written is what you actually did!!
LukeLewis24
C?ID=271228
Let us know
Andy
Hi Guys,
thank you for your help so far! Checked the wiring and I had done it right but typed it wrong in the original post.
come across another little issue though,
I changed it to Terminal 15
but when i went into Module 9 - Central Electronics I came across this message
"Coding is NOT Supported by this module variant. Replacement control modules must be parameterized by using the factory tool and software-version management. Many relevent options (relating to retrofits/modifications) can be found by using the adaption function of the control module.
Any suggestions a way around this?
Thank you!
DV52
C?ID=194404
Luke: quite correct - your BCM has a zero code string (see your auto-scan) - all of the software switches that were in long coding in previous modules have been transferred to adaptation channels. I wasn't aware that the BCM ever had a "Byte 38", but I can't find an adaptation channel in my database with a name approaching "camera_variant_vps_installed" - perhaps andy can confirm instruction?
further suggestion: hex5F module IDE03471-ENG126143-Vehicle configuration-RVC_video_input check setting FBAS
andyhud
C?ID=32695
Yep, make sure that 5f Adaptation is on FBAS - Good spot @DV52
Thats odd on Module 09 - What VCDS dongle are you using? HexCANUSB? or HEx-Net / Hex-V2? You may need the latter. I can certainly access a 2016 A3 Module 09 fine on a Hex-Net interface
Regarding this "camera_variant_rvc_installed" - its a drop down list, but will only show a drop down list on the newer interfaces... so otherwise go into Module 09, Long Coding, Byte 38 and Tick Bit 2 for the same result.
Sorry, above I put "camera_variant_vps_installed" which is wrong. Thats for 360Degree Cameras.
LukeLewis24
C?ID=271228
Hello!
I have the old version of the HEX cable and I think this is why I am having issues. Seen on RT that it supports up to 2015.
Ordered a HEX NET and will give this a go when it arrives in a few days and I shall let you guys know I get on!
vastechnics
C?ID=143747
This is the right way do to this:
In 5F set vps activated and vps bus to terminal 15. Also set the pdc to activated and treshold also to activated. Then reset mmi and voila! No coding in bcm is needed. This because I see that the car dont have PDC it needs to be triggered...
So bcm coding byte 38 is no needed. This is only for a4 a5 q5 q7 models no need audi a3.
Try and report
LukeLewis24
C?ID=271228
Hi Guys!
Really great help and thank you!
All seems to be working now.
Coding wise, as above, I tried this and changed the PDC to activated and the threshold to activated in the adaptations for 5F.
Again thank you all and I will be trying it out over the next few days, been a great help!
Thanks,
Luke
andyhud
C?ID=32695
Hi Guys!
Thanks,
Luke
Good stuff Luke, let us know how it goes...
Whereabouts in UK are you?
Ed O S5
C?ID=335734
Guys, hoping someone can help a newby with camera wire connections 2012 S5. I bought the harness from Kufatec, but directions are not the best. I need to connect the twisted pair into the Canbus connector to the right of the glove box. I finally figured out the pink slide latch to allow connector to come free from the dash. How do I release the gray electrical plug from its black housing? I know it slides out, but I don't want to damage it. thanks Ed
Johan1
C?ID=359010
hello guys
here is the point , try to retrofit a rear cam on my audi a3.bought the cam from ebay and its a high version and ordered cable from eurocars ...the cable have 6 wires black and white in the blue connector behind the mib .Black in 6 and white in 12 right?
after this i have 4 wires over .....red is to connect to voltage and brown is ground Right ? and then 2 wires over black and ornge i connected the orange in number 10 in the gateway and the black in number 20 in the gateway.
after all this the cam is NOT recognized while i enabled it in cangateway list.
the big cuastion what im doing wrong?
Apreciate ur help
DV52
C?ID=194404
@Johan1: Hi and thanks for the PM. I'm not familiar with the eurocarupgrade version of the RVC, but the wire colors mentioned in your post are NOT OEM. So I cannot confirm the designations albeit I would suggest that you might reconsider the "black and white in the blue connector behind the mib MMI" (MIB is used in VW cars, not Audi). If you read @LukeLewis24 response in post #6 above, he says:
So, I think that you will find that his colors for the video coaxial cable are the wrong way around. On my WD in post #5 above, note that the Black wire is connected to pin #12 on the MMI (which is J794). Again, I don't know about the eurocarupgrade colors, but make sure that the screen (the copper outer mesh) on the coaxial cable is connected to pin #12 - which is black on the OEM wiring loom and which is electrically connected to earth.
I'm not sure that making this change will fix the problem of not being able to register the hex6C module in the CAN Gateway installation list. This sounds more like a CAN signal polarization error - maybe you have the CAN high/low wires reversed on the Gateway connector? Or maybe you have mixed-up the Brown and Black wires - maybe Brown is CAN low and Black is power supply earth? But I'm guessing
When you purchased the camera kit - wasn't an instruction manual included? If so, what was the manufacturer's instructions for the wire colors?
PS: Admin: are the TLA s "OEM" and "MMI" sufficiently commonly-understood to warrant inclusion into the forum lexicon?
Johan1
C?ID=359010
Thanks DV52
i will check later maybe you re right i have to switch between brown and black in the gateway cause the cam is not yet reached in the vcds.
Black and white in the mmi thats a fact of getting video on screen
i will update later
Thanks in advance
Johan1
C?ID=359010
Hello guyys,
Job is done and the problem was in the color of the wires so like DV52 says black is for ground instead of brown the coding is done all work
thanks to the comunity thanks for you guys especialy for DV52 you are genius
thanks a lot
