Hi I am trying to install a backup camera to the car.
I have wired it directly into the MMI and the car recognises that the camera is attached.
The cables I was given and have connected
Can Bus High - Entertainment
Can Bus Low - Entertainment
Black Wire from Camera into Blue connector in MMI #6
White Wire from Camera into Blue connector in MMI #12
7.5A Power Supply
Earth Connection
However I am unable to get the camera to appear on the screen when I select reverse gear.
Under Info Elect I have changed the following
- BAP-VPS_0x0B to activated
- BAP-VPS_ox0B_msg_bus to Comfort Data Bus
I have looked online and some people are using a reversing camera system control unit but the cables I was given go directly into the MMI?
Confused!
Can anyone help me with this?
Thanks
Luke
7.5A Power Supply
Earth Connection
Confused!
Thanks
Luke
Tuesday,10,December,2019,21:26:54:11660
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ8V1H1004756 License Plate:
Mileage: 34521km-21450mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F 6C BB BC
VIN: WAUZZZ8V1H1004756 Mileage: 34521km-21450miles
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BN HW: 04L 907 309 R
Component: R4 2,0L EDC H23 1197
Revision: B5H23---
Coding: 02190012032501082000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TDI01104L906026BN 002002
ROD: EV_ECM20TDI01104L906026BN_002.rod
VCID: 77FD8582CEE0C8F796-8022
17161 - Databus
Part No SW: 5Q0 614 517 BJ HW: 5Q0 614 517 AG
Component: ESC H62 0636
Revision: 00000000 Serial number: 61646000002924
Coding: 13F18AA224200A70497E0E0541C929C8512450927082947202610078800802
VCID: 7AFB9CB6FDF2D59FE9-802E
Part No SW: 8V0 820 043 M HW: 8V0 820 043 M
Component: AC Automat H03 0110
Revision: 20001000 Serial number: 00000000966728
Coding: 03100104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
VCID: 3C775AAEB7462BAFBB-8068
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 7178453800PAG0MUFU03
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001617001057
ROD: EV_BCMBOSCH_017.rod
VCID: 7EF390A6E1DAF9BFD5-802A
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 160529 043 0585
Serial number: 160616075711
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 61934651
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Serial number: 22 04 2016 00000038
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY161301D3Z
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000035705285
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0315
Serial number: 003TDR1WJA05
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 102FDE1ECB4EFFCF37-8044
Subsystem 1 - Part No SW: ----------- HW: 480 001 706 16
Serial number: 357000000008F6353C1P
Subsystem 2 - Part No SW: ----------- HW: 480 001 706 16
Serial number: 35800000000E05553C1I
Subsystem 3 - Part No SW: ----------- HW: 480 402 106 16
Serial number: 3510001C120FC483B855
Subsystem 4 - Part No SW: ----------- HW: 480 402 106 16
Serial number: 3520001C120FC481C43%
Subsystem 5 - Part No SW: ----------- HW: 480 401 806 16
Serial number: 3550002C7209E9E031EE
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 402 005 16
Component: PedP_Sensor_D 001 6149
Serial number: 2280002992057290A2B.
Subsystem 7 - Part No SW: ----------- HW: 480 402 005 16
Component: PedP_Sensor_P 001 6149
Serial number: 2290002BB207634162B-
Subsystem 8 - Part No SW: ----------- HW: 480 002 106 16
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000DA8253C18
Subsystem 9 - Part No SW: ----------- HW: 480 002 106 16
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000785540C1/
Part No SW: 8V0 953 521 JD HW: 5Q0 953 549 E
Revision: -------- Serial number: 16061604400549
Coding: A008
VCID: 0501FF4A840CAA6794-8050
Part No SW: 8V0 920 972 L HW: 8V0 920 972 L
Component: KOMBI H03 8315
Coding: 27AD19002B9026000100FE001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009054
VCID: 479D3542FE80787726-8012
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Reset counter: 94
Mileage: 33702 km
Date: 2019.10.06
Time: 14:35:34
16776980 - Databus
Reset counter: 74
Mileage: 34521 km
Date: 2019.12.10
Time: 20:49:54
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 20061610800366
Coding: 030100041F0873005B000248080B00000001010000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 7CF79AAEF7C6EBAFFB-8028
Subsystem 2 - Part No SW: 81A 951 523 HW: 81A 951 523
Component: J453 MFL H04 0003
Serial number: 20160610230608 02731
Serial number: 75410803001606070553
131594 - Parallel Parking Assistance Control Module
U104E 00 [008] - No communication
Reset counter: 114
Mileage: 33094 km
Date: 2019.10.01
Time: 23:46:31
Terminal 15: On
131689 - Rear View Camera System Control Module
U104C 00 [008] - No communication
Reset counter: 114
Mileage: 34521 km
Date: 2019.12.10
Time: 21:18:11
Supply voltage: Terminal 30: 11.9 V
Terminal 15: OFF
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
Reset counter: 114
Mileage: 34521 km
Date: 2019.12.10
Time: 19:47:41
Terminal 15: OFF
66304 - Databus
U1124 00 [008] - Additional Installations Detected
Reset counter: 114
Mileage: 34521 km
Date: 2019.12.10
Time: 20:43:26
Terminal 15: On
Component: TSG FS 020 0041
Serial number: 010616EEV05263
Coding: 001C8A204001040000001002
VCID: 43852152CAB85457FA-8016
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45813F4AC48C6A67D4-8010
Component: TSG BFS 020 0041
Serial number: 040616EF406237
Coding: 001C82204C01040000001002
VCID: 428B2456D5A25D5FF1-8016
65558 - Heated Exterior Mirror
B11F8 14 [009] - Open or Short to Ground
Fault Frequency: 39
Reset counter: 69
Mileage: 33094 km
Date: 2019.10.01
Time: 23:55:29
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 8V0 907 357 A HW: 7P6 907 357 B
Component: MxB-ECU 001 0226
Coding: 0EDE00102B230200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
VCID: 3E7350A6A15A39BF95-806A
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 81A 035 192 HW: 81A 035 192
Component: MU-HS-LND-EU 045 0148
Coding: 01730101FF00000011111101000A00102F002AC601F00100CE
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP.rod
VCID: 5EB3F026411A19BFF5-800A
Subsystem 1 - Part No SW: V03 959 802 LE HW: -----------
Component: ECE 2019/2020 --- 0043
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY205UUG
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
Component: ControlUnit_B H50 0103
Serial number: ALJAL113041600010048
Component: RVC Compact H15 0231
Coding: 0273000102002001000040
VCID: 397943BAB8741E87A0-806C
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 63
Time: 00:00:00
13705478 - Databus
Reset counter: 74
Mileage: 34521 km
Date: 2019.12.10
Time: 20:49:49
passive
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 190516EEF04672
Coding: 000C82204001040000001002
Component: TSG HBFS 020 0041
Serial number: 190516EEF04678
End-------------------------(Elapsed Time: 03:46)--------------------------
