Results 1 to 6 of 6
Thread: Audi A7 4G BOSE Retrofit - recoding old radio, intermittent back to DSP
    Sep 2018
    Hey,
    Some time ago I retrofitted BOSE in my A7 (USA version), but I've got 2 problems.
    1. Old radio show some fault codes related to lack of the speakers since they're now connected to the BOSE amplifier. I'm not sure how to recode it since there are no hints in LCode Helper. I posted my Auto Scan, I hope it will help.
    2. Sometimes the audio system starts with BOSE but sometimes with DSP (the old one). For 10 starts - 6/7 are DSP, the rest are BOSE. I have no idea what might be wrong.
    Any help will be greatly appreciated.
    Saturday,21,December,2019,12:39:27:18015
    VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
    VIN: WAUYGAFC9CN126609   License Plate:
    Mileage: 162273km-100831mi   Repair Order: 2
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
              53 55 56 5F 62 6C 6D 72 8F 90
    VIN: WAUYGAFC9CN126609   Mileage: 162273km-100831miles
    Address 01: Engine (J623-CGXB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0010
       Revision: --H07---
       Coding: 1A2A0032052600060000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
       ROD: EV_ECM30TFS0214G0907551A_003.rod
       VCID: 270BF8D81F6971CFA8D-8072
    6140 - Fan 1 Control Circuit
              P0691 00 [039] - Short to GND
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:32
                        Engine speed: 705.00 /min
                        Normed load value: 10.6 %
                        Coolant temperature: 85 ∞C
                        Intake air temperature: 39 ∞C
                        Voltage terminal 30: 14.523 V
                        Engine speed: actual: 672 /min
                        MAF_ENVD: 108.94117 mg/stroke
                        Coolant temperature (unfiltered): 85.50 ∞C
                        Engine: operating status: IS
                        Engine load: 10.546875 %
                        Vehicle speed: actual: 0 km/h
    Readiness: 1110 1101
       Part No SW: 4G0 927 158 P    HW: 0BK 927 156 AJ
       Component: 0BK 30TFSIUSA H16 1004
       Revision: --H16---
       Coding: 000002
       ASAM Dataset: EV_TCMAL551211 002018
       VCID: 3B2334A8F3E1C52FDC5-806E
       Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
       Component: ESP PREMIUM   H09 0361
       Coding: 44A70F0322E5F0C09B00
       VCID: 3635259CC8C3184723B-8062
       Part No SW: 4H0 907 064 BC    HW: 4H0 907 064 BC
       Component: BCM2 2.0      H31 0333
       Coding: 098A3000000000000000
       VCID: 6B83C4E8C38195AF0C5-803E
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000286108010
       Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
       Component: KLIMA 4 ZONEN H11 0062
       Serial number: 26041100040316
       Coding: 4682607800
       ASAM Dataset: EV_AirCondiComfoUDS 002033
    0315 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Sensor f¸r Luftfeuchte innen: kein Signal / Kommunikation]
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:24
                        Voltage terminal 30: 14.54 V
                        Outside air temperature: 11.5 ∞C
                        Engine speed: 694 /min
       Part No SW: 4H0 907 063 BP    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0111
       Revision: 11012002    Serial number: 00000001390239
       Coding: 0600A091063C9FE08100008380003928CF9CD308A2090141000004402000
       Shop #: WSC 00531 066 73451
       VCID: 77ABE8988FC9214FF8D-8022
       Component: WWS57X 120107  H35 0080
       Serial number:         120119041159
       Coding: 0045D7
       Serial number: 20478020
       Coding: 0200EE
       Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
       Component: E1 - LDS  H07 0044
       Serial number: 08 03 2012  00001660
       Serial number: 75A8CAB6000000000001
       Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
       Revision: 11001001    Serial number: 55901203001659
       Coding: 282104
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
       Component: Airbag10.43   H32 0032
       Revision: --------    Serial number: 003D8001RW42
       Coding: 303145313131303030314A55304C34473853
       VCID: 33331C88DBB10D6F045-8066
       Serial number: 3575HRB405311PN8B1F0
       Serial number: 3585HRB405311PN8DGBE
       Serial number: 3515JRB405L12QE6M0SS
       Serial number: 3525JRB405L12QE6IH3H
       Serial number: 3554VRB405F0GR36D8LW
       Serial number: 3564VRB405N0U2US88PZ
    9442816 - Front Passenger's Airbag Disabled Indicator Lamp
              B1016 00 [137] - -
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:26
    9445971 - Seat occupied recognition control module
              B1022 53 [009] - Deactivated
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:27
       Part No SW: 4H0 953 568 H    HW: 7P6 953 507 T
       Revision: --------    Serial number: 90815LL60002X
       Coding: 000C34
       Shop #: WSC 00046 123 12345
       VCID: 38292BA4C257EE37317-806C
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Serial number: 11 11 2014  10037129
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:22
       Part No SW: 4G8 920 982 M    HW: 4G8 920 982 M
       Component: TBenUsa       H79 0416
       Revision: 25460175    Serial number: 658250112592016
       Coding: 0BE501060B030008020100
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K_AU57.rod
       VCID: 3E253DBCE0F3D007FBB-806A
       Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0214
       Revision: --------    Serial number: 00000000382250
       Coding: 00C1033000
       ROD: EV_GatewUDS_AU57.rod
       VCID: 34311F94DEBF0A571DF-8060
       Serial number: 7139958401
       Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
       Component: KLIMA FOND    H08 0112
       Serial number: 06071500041372
       Coding: 20
    0116 - Temperature Sensor for Rear Right Seat
              B1114 15 [009] - Open or Short to Plus
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:24
    0119 - Temperature Sensor for Rear Left Seat
              B1113 15 [009] - Open or Short to Plus
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:24
    0124 - Rear Right Seat Heater
              B1118 15 [009] - Open or Short to Plus
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:24
    0127 - Rear Left Seat Heater
              B1117 15 [009] - Open or Short to Plus
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:24
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000022715198
       Coding: 0058130000002001000001010101102030303232203232
       Shop #: WSC 02311 785 00200
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0004
       Revision: --------    Serial number: EJ1BPA4200RT5I0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D070AF03D955B9F521-8078
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4G0 907 566 J    HW: 4G0 907 566
       Component: J769  SWA MasterH02 0040
       Revision: 00H02000    Serial number: 6PZ 010 287-08
       Coding: 0000003
       VCID: 3635259CC443184723B-8062
       Subsystem 1 - Part No: 4G0 907 568 J
       Component: J770  SWA Slave H02 0030
       Subsystem 2 - Serial number: 6PZ 010 287-28
       Subsystem 3 - Serial number: 5F16.01.1200H020003CZ20741ˇ
       Subsystem 4 - Serial number: Z20741ˇ
       Component: TSG FA        H04 0507
       Coding: 011F5E025E20628202080413
       VCID: 45D7525085A583DFBA1-8010
       Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
       Component: RCevo         H56 0202
       Revision: 00000001    Serial number: 0000895681
       Coding: 101000010000
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A2D31ACFCDBFC27C73-806E
       Revision: 00002001    Serial number: 0169055735
       Coding: 0126063A20FAB08482B00A80020100000000000000000000000000000000
       Subsystem 2 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
       Component: J245 PS40.039  H01 0008
       Serial number:     WOO14928143
       Coding: 101F00
       Subsystem 3 - Part No SW: 4G0 947 135 F    HW: 4G0 947 135
       Serial number: 0000000AP00011492381
       Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H09 0028
       Serial number: WA102902000000868163
       Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
       Component: BOSE-G3-C7    H07 0160
       Revision: CJ007000    Serial number: 00000000000098
       Coding: 030000
       Shop #: WSC 52563 001 1048576
       VCID: 1D67DA304DB5AB1FC21-8048
    02753 - Inside Microphone (R74)
                        Fault Status: 01101011
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:27
       Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
       Component: TSG BF        H04 0507
       Coding: 011F5E025E20628202080402
       VCID: 44D14F548E9FBAD7ADF-8010
       Revision: --------    Serial number: 00000000244661
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A0D01EC0C7B4CA7B73-807E
       Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
       Serial number: 120127-0001-117
       Coding: 1223A6101002A400
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C0107F4068F529745F-8078
       Part No SW: 4G0 035 082 C    HW: 4G0 035 082
       Component: Radio U SIRIU H53 0101
       Revision: AB001007    Serial number: 236BS0C7510167
       Coding: 000007020100000001
       VCID: 2019E3C47AC786F7E97-8074
    7 Faults Found:
    02617 - Satellite Antenna (R170)
                        Fault Status: 01101100
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:33
                        Voltage: 15.00 V
    00417 - Left Front DSP Mid-Bass Speaker (R101)
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:24
                        Voltage: 15.00 V
    00418 - Front Right DSP Mid-Bass Speaker (R102)
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:24
                        Voltage: 15.00 V
    02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:24
                        Voltage: 15.00 V
    02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:24
                        Voltage: 15.00 V
    02246 - Loudspeaker; Center
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:24
                        Voltage: 15.00 V
    03405 - Bass Loudspeaker
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:24
                        Voltage: 15.00 V
       Part No SW: 4G0 035 746 J    HW: 4G0 035 746
       Component: H-BNT-NA      H48 1034
       Revision: --------    Serial number: 031AM0C7527341
       Coding: 090100040103E1FF55108B4E00000003100001000100000202
       Shop #: WSC 70410 259 45725
       VCID: 2E050DFC301320876BB-807A
       Subsystem 1 - Part No: 8R0 060 884 FC
       Component: EUR 2018  2601
       Subsystem 2 - Part No SW: 4G0 919 605     HW: 4G0 919 605 B
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDB940116SJ
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
       Serial number: 90349LB3000O7
       Subsystem 4 - Part No: 8R0 060 961 B
       Component: CD-Database  3371
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:27
                        Text: DUA009,Front,M,0,0,6
    03175 - Invalid Data Set
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:25
                        Voltage: 14.90 V
    01524 - Antenna for Telephone
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:36
                        Voltage: 14.90 V
    03623 - Invalid Security/Release Code
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:25
                        Hex Value: 0x0004
                        Hex Value: 0x000B
                        Count: 6
       Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
       Coding: 010F1C024020628202080002
       VCID: 47CB5858BFA991CF48D-8012
       Part No SW: 4G0 907 441 C    HW: 4H0 907 441 B
       Component: SG Rueckfahrkamera  0161
       Revision: --H05---    Serial number: 525 PA8J1ZG2G9
       Coding: 1080013
       VCID: 270BF8D813E971CFA8D-8072
       Part No SW: 4G8 959 107 P    HW: 4G8 959 107 G
       Component: HDSG-Modul    H13 0039
       Revision: 12013001    Serial number: 005200695
       Coding: 0A3305C002
       ASAM Dataset: EV_HDSGAu573 001014
       ROD: EV_HDSGAu571.rod
       VCID: 42DD494C940BB4E79F3-8016
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
       Coding: 0006E008031F0300070308014244CA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313F168021AD3F7F769-8064
       Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 323D198C24AB04670F3-8066
    End----------(Elapsed Time: 02:16, VBatt start/end: 14.7V/14.8V)-----------
    Try setting Byte 4, Bit 1 to 0.
    In other words change:
    000007020100000001
    to:
    000007020000000001
  3. Likes kamil liked this post
    May 2017
    Also this one is one of the issues
                        Reset counter: 145
                        Mileage: 162273 km
                        Date: 2019.12.21
                        Time: 12:35:25
                        Voltage: 14.90 V
    Audis have been longer this way than rest of the VAG range. It is not enough you recode the unit, you also need to flash correct dataset for the BOSE system. It will never sound like it should without doing that.
    The dataset disables the main units DSP and passes un amplified signals to BOSE amp. Also I’m guessing you’re missing BOSE specific audio controls from the media unit as well?
    And no, this is not doable with vcds. And it’s out of official garages range as well
    Sep 2018
    Thanks @Uwe, will check.
    Not really, when BOSE turns on (instead of DSP) audio controls work correctly (including Surround speakers etc.) and the sound is much different than on standard DSP.
    I've got access to ODIS and to the online coding if that's the case. But I guess that won't help considering what you wrote.
    May 2017
    Officially it’s no go with ODIS online the DSP problem you’re having is most likely due to incorrect dataset.
    Sep 2018
    000007020100000001
    to:
    000007020000000001
    Unfortunately, it doesn't allow me to recode, it shows "Out of range". I'm wondering if it's even possible to recode it properly or maybe the only way is to replace the radio with the one that was along with the BOSE? Do they have component protection?
    That's a shame I'll keep trying to find a way to do it properly.
