Results 1 to 10 of 14
Thread: 2016 Audi A3 Saloon - Backup/Rear Camera Retrofit
    Oct 2018
    Hi I am trying to install a backup camera to the car.
    I have wired it directly into the MMI and the car recognises that the camera is attached.
    The cables I was given and have connected
    Can Bus High - Entertainment
    Can Bus Low - Entertainment
    Black Wire from Camera into Blue connector in MMI #6
    White Wire from Camera into Blue connector in MMI #12
    7.5A Power Supply
    Earth Connection
    However I am unable to get the camera to appear on the screen when I select reverse gear.
    Under Info Elect I have changed the following
    - BAP-VPS_0x0B to activated
    - BAP-VPS_ox0B_msg_bus to Comfort Data Bus
    I have looked online and some people are using a reversing camera system control unit but the cables I was given go directly into the MMI?
    Confused!
    Can anyone help me with this?
    Luke
    Tuesday,10,December,2019,21:26:54:11660
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ8V1H1004756   License Plate:
    Mileage: 34521km-21450mi   Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F 6C BB BC
    VIN: WAUZZZ8V1H1004756   Mileage: 34521km-21450miles
    Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 BN    HW: 04L 907 309 R
       Component: R4 2,0L EDC   H23 1197
       Revision: B5H23---
       Coding: 02190012032501082000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TDI01104L906026BN 002002
       ROD: EV_ECM20TDI01104L906026BN_002.rod
       VCID: 77FD8582CEE0C8F796-8022
    17161 - Databus
       Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
       Component: ESC           H62 0636
       Revision: 00000000    Serial number: 61646000002924
       Coding: 13F18AA224200A70497E0E0541C929C8512450927082947202610078800802
       VCID: 7AFB9CB6FDF2D59FE9-802E
       Part No SW: 8V0 820 043 M    HW: 8V0 820 043 M
       Component: AC Automat    H03 0110
       Revision: 20001000    Serial number: 00000000966728
       Coding: 03100104002000011000000000001100
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
       VCID: 3C775AAEB7462BAFBB-8068
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H01 0005
       Serial number: 7178453800PAG0MUFU03
       Serial number: 02001617001057
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EF390A6E1DAF9BFD5-802A
       Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS371 160529  043 0585
       Serial number:         160616075711
       Coding: 0A47F7
       Serial number: 61934651
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Serial number: 22 04 2016  00000038
       Serial number: 000000000ZY161301D3Z
       Serial number: 00000000000035705285
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0315
       Serial number: 003TDR1WJA05
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 102FDE1ECB4EFFCF37-8044
       Subsystem 1 - Part No SW: -----------    HW: 480 001 706 16
       Serial number: 357000000008F6353C1P
       Subsystem 2 - Part No SW: -----------    HW: 480 001 706 16
       Serial number: 35800000000E05553C1I
       Subsystem 3 - Part No SW: -----------    HW: 480 402 106 16
       Serial number: 3510001C120FC483B855
       Subsystem 4 - Part No SW: -----------    HW: 480 402 106 16
       Serial number: 3520001C120FC481C43%
       Subsystem 5 - Part No SW: -----------    HW: 480 401 806 16
       Serial number: 3550002C7209E9E031EE
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 005 16
       Serial number: 2280002992057290A2B.
       Subsystem 7 - Part No SW: -----------    HW: 480 402 005 16
       Serial number: 2290002BB207634162B-
       Subsystem 8 - Part No SW: -----------    HW: 480 002 106 16
       Serial number: I0M00000000DA8253C18
       Subsystem 9 - Part No SW: -----------    HW: 480 002 106 16
       Serial number: I0N00000000785540C1/
       Part No SW: 8V0 953 521 JD    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 16061604400549
       Coding: A008
       VCID: 0501FF4A840CAA6794-8050
       Part No SW: 8V0 920 972 L    HW: 8V0 920 972 L
       Component: KOMBI         H03 8315
       Coding: 27AD19002B9026000100FE001000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009054
       VCID: 479D3542FE80787726-8012
    16777018 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Reset counter: 94
                        Mileage: 33702 km
                        Date: 2019.10.06
                        Time: 14:35:34
    16776980 - Databus
                        Reset counter: 74
                        Mileage: 34521 km
                        Date: 2019.12.10
                        Time: 20:49:54
       Revision: --------    Serial number: 20061610800366
       Coding: 030100041F0873005B000248080B00000001010000000000000000000000
       ROD: EV_GatewConti_013.rod
       VCID: 7CF79AAEF7C6EBAFFB-8028
       Subsystem 2 - Part No SW: 81A 951 523     HW: 81A 951 523
       Component: J453 MFL  H04 0003
       Serial number: 20160610230608 02731
       Serial number: 75410803001606070553
    131594 - Parallel Parking Assistance Control Module
              U104E 00 [008] - No communication
                        Reset counter: 114
                        Mileage: 33094 km
                        Date: 2019.10.01
                        Time: 23:46:31
                        Terminal 15: On
    131689 - Rear View Camera System Control Module
              U104C 00 [008] - No communication
                        Reset counter: 114
                        Mileage: 34521 km
                        Date: 2019.12.10
                        Time: 21:18:11
                        Terminal 15: OFF
    66052 - Infotainment CAN Bus (SAE Bus E)
              U0065 00 [008] - Performance
                        Reset counter: 114
                        Mileage: 34521 km
                        Date: 2019.12.10
                        Time: 19:47:41
                        Terminal 15: OFF
    66304 - Databus
              U1124 00 [008] - Additional Installations Detected
                        Reset counter: 114
                        Mileage: 34521 km
                        Date: 2019.12.10
                        Time: 20:43:26
                        Terminal 15: On
       Serial number: 010616EEV05263
       Coding: 001C8A204001040000001002
       VCID: 43852152CAB85457FA-8016
       Component: EPS_MQB_ZFLS  128 1072
       Coding: 8107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 45813F4AC48C6A67D4-8010
       Serial number: 040616EF406237
       Coding: 001C82204C01040000001002
       VCID: 428B2456D5A25D5FF1-8016
    65558 - Heated Exterior Mirror
              B11F8 14 [009] - Open or Short to Ground
                        Fault Frequency: 39
                        Reset counter: 69
                        Mileage: 33094 km
                        Date: 2019.10.01
                        Time: 23:55:29
       Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0226
       Coding: 0EDE00102B230200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
       VCID: 3E7350A6A15A39BF95-806A
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 81A 035 192     HW: 81A 035 192
       Component: MU-HS-LND-EU  045 0148
       Coding: 01730101FF00000011111101000A00102F002AC601F00100CE
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP.rod
       VCID: 5EB3F026411A19BFF5-800A
       Subsystem 1 - Part No SW: V03 959 802 LE    HW: -----------
       Component: ECE 2019/2020  --- 0043
       Component: DU High  H49 0014
       Serial number: AUZ8Z9GY205UUG
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
       Component: ControlUnit_B  H50 0103
       Serial number: ALJAL113041600010048
       Component: RVC Compact   H15 0231
       Coding: 0273000102002001000040
       VCID: 397943BAB8741E87A0-806C
    10489856 - No Basic Setting
              B2010 00 [009] - -
                        Reset counter: 63
                        Time: 00:00:00
    13705478 - Databus
                        Reset counter: 74
                        Mileage: 34521 km
                        Date: 2019.12.10
                        Time: 20:49:49
                        passive
       Serial number: 190516EEF04672
       Coding: 000C82204001040000001002
       Serial number: 190516EEF04678
    End-------------------------(Elapsed Time: 03:46)--------------------------
    Mar 2015
    Australia
    In 5F you need to enable RVC.
    Byte 19 bit 4 needs to enabled.
    VPS is for highline RVC modules, you might need to change those back to disabled.
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
    Mar 2016
    The fact you can see it as 6C means its a highline version as it has can bus lines, not a low line, so you dont need to do Byte 19/Bit 4 in 5F
    If you have enabled in Can Gateway installation list (as its showing in the list) your good.
    Yes, the video wires should go into 6 + 12 in the back of the MMI, so you've done that right. There is no separate "control unit" box in the MLBEvo platform.
    You've done the 2 Adaptation channels in 5F right but change this one to "Termainl 15"
    BAP-VPS_ox0B_msg_bus > Set to Terminal 15
    Go into Module 09, byte 38 and set bit2-3 to camera_variant_vps_installed
    Reboot (3 finger reboot) the MMI and you should be good to go
    Let us know
    Andy
    p.s. Get your VCDS Dongle upgraded to a Hex-Net or Hex-V2. Its why you cant see all the modules currently. RT do a trade-in upgrade I believe.
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dynamic Pack | Matrix Lights | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | N-Vision | BOSE | DVD Changer | Homelink | Soft Door Close | Heat+Sound Ins Glass | Priv Glass | Heated Windscreen | Heated Steer Wheel | Adv Key | Elec Boot Cover | Side Assist | Air Suspension | Ambient Lighting | Heated+Fold Mirrors | Park Assist Pack | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap
  4. Likes Uwe liked this post
    Mar 2015
    Australia
    My apologies I only skimmed and didn't notice the RVC compact at 6C.
    It has no basic settings so needs calibration, however it will still display the image when otherwise correctly configured.
    Quote Originally Posted by LukeLewis24 View Post
    7.5A Power Supply
    Earth Connection
    Confused!
    Luke
    Luke: Hi.
    Below is a schematic of the hex6C arrangement that I have cobbled together from a number of pages in the A3 WD:
    So, here's the thing - I'm confused too about the bits that I have highlighted in your post. No offense intended, but the coax wire from J772 to J794 may be reversed if what you have written is what you actually did!!
  7. Likes Uwe liked this post
    Oct 2018
    Quote Originally Posted by andyhud View Post
    Let us know
    Andy
    Hi Guys,
    thank you for your help so far! Checked the wiring and I had done it right but typed it wrong in the original post.
    come across another little issue though,
    I changed it to Terminal 15
    but when i went into Module 9 - Central Electronics I came across this message
    "Coding is NOT Supported by this module variant. Replacement control modules must be parameterized by using the factory tool and software-version management. Many relevent options (relating to retrofits/modifications) can be found by using the adaption function of the control module.
    Any suggestions a way around this?
    Thank you!
    Luke: quite correct - your BCM has a zero code string (see your auto-scan) - all of the software switches that were in long coding in previous modules have been transferred to adaptation channels. I wasn't aware that the BCM ever had a "Byte 38", but I can't find an adaptation channel in my database with a name approaching "camera_variant_vps_installed" - perhaps andy can confirm instruction?
    further suggestion: hex5F module IDE03471-ENG126143-Vehicle configuration-RVC_video_input check setting FBAS
  10. Likes Uwe liked this post
  11. #8
    Mar 2016
    Yep, make sure that 5f Adaptation is on FBAS - Good spot @DV52
    Thats odd on Module 09 - What VCDS dongle are you using? HexCANUSB? or HEx-Net / Hex-V2? You may need the latter. I can certainly access a 2016 A3 Module 09 fine on a Hex-Net interface
    Regarding this "camera_variant_rvc_installed" - its a drop down list, but will only show a drop down list on the newer interfaces... so otherwise go into Module 09, Long Coding, Byte 38 and Tick Bit 2 for the same result.
    Sorry, above I put "camera_variant_vps_installed" which is wrong. Thats for 360Degree Cameras.
  12. #9
    Oct 2018
    Hello!
    I have the old version of the HEX cable and I think this is why I am having issues. Seen on RT that it supports up to 2015.
    Ordered a HEX NET and will give this a go when it arrives in a few days and I shall let you guys know I get on!
  13. #10
    May 2016
    This is the right way do to this:
    In 5F set vps activated and vps bus to terminal 15. Also set the pdc to activated and treshold also to activated. Then reset mmi and voila! No coding in bcm is needed. This because I see that the car dont have PDC it needs to be triggered...
    So bcm coding byte 38 is no needed. This is only for a4 a5 q5 q7 models no need audi a3.
    Try and report
  14. Likes andyhud liked this post
