Results 1 to 4 of 4
Thread: 2013 Q7 J519 question
    Jul 2014
    Hi Everyone,
    I hope a simple question, I need to replace the J519 Onboard Supply Control Unit because of a supply loss to the R/H headlamp on T10a/4. What I need to know is if Component Protection will kick in on this unit?
    Regards HMC
    Tuesday,10,December,2019,13:07:14:00974
    VCDS Version: 19.6.2.0
    Dealer/Shop Name:
    VIN: WAUZZZ4L4ED014146   License Plate:
    Mileage: 145590km-90465mi   Repair Order:
    Chassis Type: 4L-AU56 (4F0)
    Scan: 01 02 03 05 08 09 10 15 16 17 18 19 34 3D 42 46 4F 52 55 56
              5F 62 6C 6D 6F 72
    VIN: WAUZZZ4L4ED014146   Mileage: 145590km-90465miles
    04-Steering Angle -- Status: Sporadic communication error 1000
    16-Steering wheel -- Status: Sporadic communication error 1000
    3D-Special Function -- Status: OK 0000
    Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
       Part No SW: 4L2 910 401 B    HW: 4L0 907 401 C
       Component: 3.0TDI EDC17  H41 0003
       Revision: 53H41---    Serial number:
       Coding: 2A2A4012A52701020000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0114L2910401B 001003
       ROD: EV_ECM30TDI0114L1910401H.rod
       VCID: 234100C42AD636579A-8076
    5456 - Unknown Error Code
              P06E9 00 [096] - -
    7249 - No Communications with Steering Angle Sender (G85)
              U0126 00 [032] - -
                        Mileage: 145595 km
                        Date: 2019.12.09
                        Time: 11:44:05
                        Engine speed: 713.50 /min
                        Normed load value: 36.1 %
                        Coolant temperature: 48 °C
                        Intake air temperature: 14 °C
                        Voltage terminal 30: 14.420 V
                        Cruise Control System (CCS): status-Bits 0-7: 44
                        selected gear-Bits 0-7: 0
    4714 - Steering Column Control Module
              U0212 00 [032] - No Communications
                        Mileage: 145595 km
                        Date: 2019.12.09
                        Time: 11:44:05
                        Voltage terminal 30: 14.400 V
    5619 - Engine Off Timer Performance
              P150A 00 [032] - -
       Part No SW: 0C8 927 750 AL    HW: 0C8 927 750 AL
       Component: AL1000 AISIN  002 2447
       Coding: 001578
       Shop #: WSC 56212 001 1048576
       ASAM Dataset: EV_TCMAL991031 002112
       ROD: EV_TCMAL991031_002.rod
       VCID: 76E70990C9C4F3FF8D-8022
    12812 - Steering Column Control Module
              U0212 00 [008] - No Communications
                        Reset counter: 190
                        Engine speed: 690.0 /min
                        Transmission input speed: 630 /min
                        Engine torque: -12 Nm
                        Transmission fluid temperature: 30 °C
                        Accelerator position: 0.0 %
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
                        Lock Up Clutch: Open
                        EOP failure status 2: Normalcy
                        EOP target revolution: 0 /min
                        EOP actual revolution: 65279 /min
                        Engine Speed signal Current: 65279 /min
                        EOP failure status with EOP without HV 1: Motor normal stop
                        EOP target current: 65278 mA
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
       Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
       Component: ESP ALLRAD MK25E1   0020
       Revision: 00H02001
       Coding: 2200689
       VCID: 3463F3985738A1EF73-8060
                        Reset counter: 153
                        Mileage: 145595 km
                        Date: 2019.12.09
                        Time: 11:44:18
                        Count: 128
                        Count: 833
                        Count: 297
                        Count: 47360
                        Reset counter: 153
                        Mileage: 145595 km
                        Date: 2019.12.09
                        Time: 11:44:05
                        Count: 8257
                        Count: 166
                        Count: 52224
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0200
       Revision: 00H08000    Serial number: 10603702086383
       Coding: 0000211
       VCID: 25451EDCECE2C867F4-8070
       Subsystem 1 - Part No: 4F0 910 132 E
       Component: FBSAUDIC6 EZS   H04 0020
       Component: FBSAUDIC6 IDG   H01 0054
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
       Component: KLIMA 4 ZONEN H15 0070
       Revision: 00---031    Serial number: 00000000394128
       Coding: 01009416
       VCID: 25451EDC2CE2C867F4-8070
       Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
       Component: ILM Fahrer      H31 0400
       Coding: 0033121
       VCID: 6FE93CF47E9EC2374E-803A
       Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H13 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 153
                        Mileage: 145592 km
                        Date: 2019.12.10
                        Time: 12:59:00
    Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
       Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0011
       Revision: 11001001    Serial number: 55961325400998
       Coding: 24031F
       ASAM Dataset: EV_EPHVA18AU7160000 001001
       ROD: EV_EPHVA18AU7160000.rod
       VCID: 3463F3989F38A1EF73-8060
       Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
       Component: 71 AIRBAG AUDI8RH44 0230
       Revision: 05H44000    Serial number: 00399D0CY666
       Coding: 0014129
       VCID: 2E57E1F0B9148B3F05-807A
       Subsystem 1 - Serial number: 6332QSME0A364A56J
       Subsystem 2 - Serial number: 6342QSME0A364B74L
       Subsystem 3 - Serial number: 6352QSME0E36304AH
       Subsystem 4 - Serial number: 6362QSME413A4B7AS
       Subsystem 5 - Serial number: 63734SME7C3322760
       Subsystem 6 - Serial number: 63834SME78331F6EG
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
       Component: J0527               0830
       Revision: 00H09000    Serial number: 90026131790165
       Coding: 0102142
       VCID: 285B17E89BF0D50FCF-807C
       Component: E0221           H03 0040
    Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
       Part No SW: 4L0 920 985 N    HW: 4L0 920 985 N
       Component: KOMBIINSTR.   H35 0317
       Revision: 00000000    Serial number: VJ222EH9E
       Coding: 3356630400012600010404
       VCID: 3F89ACB4AE7E72B79E-806A
    Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
       Part No SW: 4L0 910 105     HW: 4L0 815 071 H
       Component: Heizgeraet      H10 0140
       Revision: 0000000A    Serial number: 00000009024928
       Coding: 0000101
       VCID: 60CB4FC8B3406D4FC7-8034
    00664 - Fuel gauge
                002 - Lower Limit Exceeded
       Part No SW: 4F0 907 468 R    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0058
       Revision: LB600036    Serial number: 3600L13827037D
       Coding: 00CF07
       VCID: 3E77D1B0A9747BBF95-806A
       Subsystem 1 - Part No SW: 8K0 915 181 D    HW: 8K0 915 181 D
       Component: J367-BDM  H07 0125
       Serial number: 30250K56184121958664
       Serial number: 13246003162011200181
                        Reset counter: 193
                        Mileage: 145595 km
                        Date: 2019.12.09
                        Time: 11:44:06
                        Bin. Bits:    11111
                        Voltage: 14.50 V
                        Count: 7
                        Bin. Bits:    10011
                        Time: 25.40 s
                        Reset counter: 193
                        Mileage: 145595 km
                        Date: 2019.12.09
                        Time: 11:44:07
                        Bin. Bits:    11111
                        Voltage: 14.50 V
                        Count: 7
                        Bin. Bits:    10011
                        Time: 25.40 s
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 L    HW: 4L0 907 553 E
       Component: LUFTFDR.-CDC    H04 7890
       Revision: --H04001    Serial number: 15.1528-0194.2
       Coding: 0015510
       Shop #: WSC 34288 001 1048576
       VCID: 3361F0845236A6D76A-8066
                        Reset counter: 193
                        Mileage: 145595 km
                        Date: 2019.12.09
                        Time: 11:44:06
                        Error Code: 118
    01316 - ABS Control Module
                013 - Check DTC Memory
                        Fault Status: 11101101
                        Reset counter: 153
                        Mileage: 145595 km
                        Date: 2019.12.10
                        Time: 12:59:25
                        Error Code: 98
    Address 3D: Special Function        Labels: 8K0-907-440.clb
       Part No SW: 8K0 907 440     HW: 8K0 907 440
       Component: STS             H04 0040
       Revision: S0H04000    Serial number: 00000000087249
       Coding: 01010101000000000001000202
       VCID: 6BD128E44A863E1762-803E
       Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000075606907
       Coding: 011F06205061440004
       VCID: 489BB768FBB0350F2F-801C
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H12 0130
       Revision: 0130 ---    Serial number: 01938344360000
       Coding: 4071931
       VCID: 387BC7A84B50458F5F-806C
       Part No SW: 4F0 910 280     HW: 4F0 907 280 E
       Component: ILM Beifahrer   H16 0100
       Revision:             Serial number: 00000000338719
       Coding: 0011101
       VCID: 5EB7713089345BBFF5-800A
       Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000075626491
       VCID: 4799B454F6AE3A7726-8012
       Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
       Serial number: 130913-0001-028
       Coding: 11476F1010000500
       ROD: EV_HeadlRegulBasic.rod
       VCID: 428FA540D58C1F5FF1-8016
    392714 - Positioning Motor for Headlight Range Left
              C1085 15 [008] - Open or Short to Plus
                        Reset counter: 193
                        Mileage: 145594 km
                        Date: 2019.11.27
                        Time: 12:55:58
    392970 - Positioning Motor for Headlight Range Right
              C1086 15 [008] - Open or Short to Plus
                        Reset counter: 193
                        Mileage: 145594 km
                        Date: 2019.11.27
                        Time: 12:42:22
       Part No SW: 4G0 035 061 L    HW: 4G0 035 061
       Component: Radio U DAB   H60 0133
       Revision: AB001007    Serial number: 109I70D7706949
       Coding: 010103020100000000
       VCID: 264719D051E4C37FFD-8072
       Part No SW: 4L2 035 670 H    HW: 4L2 035 670 D
       Component: H-BNT-EU      H46 0739
       Revision: --------    Serial number: 220IT0D7516413
       Coding: 180101060004D3EF010003556F632003040000000100000000
       VCID: 2F69FCF47E1E82370E-807A
       Subsystem 1 - Part No: 8R0 060 884 BC
       Component: EUR 2013/2014  1603
       Component: DU7 High  H42 0104
       Serial number: A130IR0D2821246
       Subsystem 3 - Part No SW: 4L0 919 614 B    HW: 4L0 919 614 B
       Component: E0380 Bedient  H01 0060
       Serial number: 00000002125826
       Component: CD-Database  5298
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000075599901
       Coding: 010E06204061230004
       VCID: 4687B950F1A4237FDD-8012
       Part No SW: 4L0 910 441 B    HW: 4L0 907 441 B
       Component: J772__Rearview      0030
       Revision: --H08---    Serial number: 525PA8-J38429X
       Coding: 1021001
                        Reset counter: 193
                        Mileage: 145595 km
                        Date: 2019.12.09
                        Time: 11:44:06
                            Term 15 On
                            Reverse OFF
                        Count: 3
                        Reset counter: 193
                        Mileage: 145595 km
                        Date: 2019.12.09
                        Time: 11:44:06
                            Term 15 On
                            Reverse OFF
                        Count: 3
       Part No SW: 4L0 910 945     HW: 4L0 827 851 E
       Component: ValeoHeckdeckel H57 0500
       Revision: --H57001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6CD32BF84F88392F6B-8038
       Subsystem 2 - Serial number: +
    ó
       Subsystem 3 - Serial number: RD14.09.13--H57001002G0273˙
       Subsystem 4 - Serial number: 2G0273˙
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 0074920173----
       Coding: 0003587
       VCID: 264719D091E4C37FFD-8072
       Component: J_245_EE16_SKB10H14 0220
       Subsystem 2 - Part No: 4L0 910 591 A
       Component: J_394_EE16_SKB10H14 0220
       Subsystem 3 - Part No: 4L0 910 591 A
       Component: J_392_EE16_SKB10H14 0220
    01512 - Control Module for Sliding Roof
                        Reset counter: 193
                        Mileage: 145595 km
                        Date: 2019.12.09
                        Time: 11:50:43
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000075599900
    End-------------------------(Elapsed Time: 04:47)--------------------------
    Address 34: DTCs cleared
    Address 03: DTCs cleared
    Address 55: DTCs cleared
    PART NUMBER DESCRIPTION REMARK MODEL
    * 4F0 910 279 AH Onboard supply control unit Steuergeraet 1 PR-2C5
    Dropped: Feb 1, 2017 (EKZ: L)
    Supersession
    4F0 910 279 AG Onboard supply control unit
    Vehicle intelligent genuine part.
    Order only with additional instructions.
  3. Likes HMC liked this post
    HQ
    I think we have a forum rule that if you can answer via meme, then you must....
    Jef
  5. Likes Jack@European_Parts, Uwe, HMC liked this post
    Jul 2014
    Thanks Jack, Jeff and Uwe for fixing the code tags (I forgot exactly how to do it, nor could I find the instructions),
    Looks like I will have to give this one a miss, it's from another garage anyway.
    TPS the official VAG trade parts supplier in the UK, want extra forms signed before they will order it and refuse to give part numbers!
    Nice MEME Jeff. On the 50th anniversary of the start of Monty Python I am glad you like our whacky humour.
    Regards HMC
  7. Likes Uwe liked this post
