Results 1 to 7 of 7
Thread: Need for help! in Passat 3B 2004
    Jul 2017
    Kosovo
    I replace heater radiator inside and now i get this problems.I prove to code Abs but code is not accept i prove in this way: Login 09597 and coding:04397
    Thanks !
    Monday,09,December,2019,16:22:06:44995
    VIN: WVWZZZ3BZ4E342382   License Plate:
    Mileage: 263970km-164023mi   Repair Order:
    Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    VIN: WVWZZZ3BZ4E342382   Mileage: 263970km-164023miles
    Address 02: Auto Trans        Labels: 01V-927-156.lbl
       Part No: 3B0 927 156 S
       Component: AG5 01V 1.9l-PD RdW 2224
       Coding: 00103
       Shop #: WSC 05311
       VCID: 36362F36615D818723B-5118
    Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
       Part No: 4B0 614 517 G
       Component: ABS/ESP front       1728
       Coding: 00000
       VCID: 2514F87ACCFBFA1F9A1-51A8
                66-10 - Not Matched - Intermittent
                35-00 - -
    Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
       Part No: 3B1 907 044 K
       Component: CLIMATRONIC B5GP    0010
       Coding: 17000
       Shop #: WSC 05311
       VCID: 290CF44AA0E3DE7FBE9-513C
    12 Faults Found:
    01296 - Sensor for Vent Temperature; Center (G191)
    01297 - Sensor for Vent Temperature; Footwell (G192)
    00787 - Temperature Sensor in Fresh Air intake duct (G89)
    00818 - Sensor for Evaporator Outlet Temperature (G263)
    00797 - Sunlight Photo Sensor (G107)
    00603 - Footwell/defroster Flap Positioning Motor (V85)
                35-10 - - - Intermittent
    01271 - Positioning Motor for Temperature Flap (V68)
    01272 - Positioning Motor for Central Flap (V70)
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
       Part No: 1C0 909 605 C
       Component: 0E AIRBAG VW61 04   0003
       Coding: 12357
       Shop #: WSC 05311
       VCID: 2412E57EC7C103178DF-50F4
                32-10 - Resistance Too High - Intermittent
    Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
       Part No: 1J0 907 487 A
       Component: Lenkradelektronik   0005
       Coding: 00118
       Shop #: WSC 05311
       VCID: 2F381A529E07B04F60D-513C
    Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
       Part No: 3B0 920 849 A
       Component: KOMBI+WEGFAHRSP VDO V04
       Coding: 23115
       VCID: 2616FF76B1FDF10793B-50F4
       WVWZZZ3BZ4E342382     VWZ7Z0D9686341
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 05311
       VCID: 70BAD92E43B9EFB7397-50F4
    Address 37: Navigation        Labels: 3B0-919-887.lbl
       Part No: 1J0 919 887 B
       Component: Navigation     BNO 0204
       Coding: 00000
       Shop #: WSC 05311
       VCID: 372822326657788F38D-4AC2
       Part No: 1C0 959 799 B
       Component: 7X Komfortgerát HLO 0004
       Coding: 00259
       Shop #: WSC 05311
       VCID: 36362F36615D818723B-4AC2
                37-10 - Faulty - Intermittent
                27-00 - Implausible Signal
       Part No: 4Z7 907 357
       Coding: 00007
       Shop #: WSC 05311
       VCID: 045285FE6701E317EDF-4B00
    Address 56: Radio        Labels: 3B0-035-186.lbl
       Part No: 1J0 035 152 G
       Component: Radio          BNO 0204
       Coding: 05407
       Shop #: WSC 05311
       VCID: 221EE366DDD50D27FF3-4AA4
    Address 76: Park Assist        Labels: 3B0-919-283.lbl
       Part No: 3B0 919 283
       Component: Parkingsyst. PA RDW D01
       Coding: 01114
       Shop #: WSC 05314
       VCID: 6594B87A8C7B3A1F5A1-5118
    End----(Elapsed Time: 04:32, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
    Nov 2017
    Latvia
    Does the car has engine installed?
  3. Likes Baholli liked this post
    Jul 2017
    Kosovo
    Yes Val but i remove for repair and now is in good condition
    Can g85 not leave me to coding and forget
    Yes, however, why is engine 0x01 scan missing on K line or Gateway on W-CAN in scan?
    Is it on blocks 125 in ABS, gateway,trans?
    Is tester number, WSC and importer number set in configuration OP?
    Yours is not non zero!
  6. Likes Baholli liked this post
    Jul 2017
    Kosovo
    Hello Jack i replace new abs control unit with new G85 and again problem still i cant coding
    Tuesday,10,December,2019,17:26:27:44995
    Address 01: Engine        Labels: 038-906-019-AVF.lbl
       Part No: 038 906 019 KD
       Component: 1,9l R4 EDC G000AG  4897
       Coding: 00001
       Shop #: WSC 05314
       VCID: 6390A662824F442FB45-4AE0
    18057 - Powertrain Data Bus
                P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
    18043 - Powertrain Data Bus
                P1635 - 35-10 - Missing Message from A/C Controller - Intermittent
    18058 - Powertrain Data Bus
                P1650 - 35-00 - Missing Message from Instrument Cluster
                P1570 - 35-00 -
    18263 - Powertrain Data Bus
                P1855 - 35-00 - Software Version Monitoring
    Readiness: 0 0 0 1 1
       Coding: 00103
       Shop #: WSC 05311
       Coding: 12357
       Shop #: WSC 05311
       Coding: 00118
       Shop #: WSC 05311
       VCID: 2F381A529E07B04F60D-5160
       Coding: 23115
                49-00 - No Communications
       Coding: 00006
       Shop #: WSC 05311
       Coding: 00259
       Shop #: WSC 05311
       VCID: 36362F36615D818723B-4AE0
       Subsystem 1 - Part No: 1C1959801
       Component: 7X Tõrsteuer.FS KLO 0202
       Subsystem 2 - Part No: 1C1959802
       Component: 7X Tõrsteuer.BF KLO 0202
       Subsystem 3 - Part No: 1C0959811
       Component: 7X Tõrsteuer.HL KLO 0202
       Subsystem 4 - Part No: 1C0959812
       Component: 7X Tõrsteuer.HR KLO 0202
       Coding: 00007
       Shop #: WSC 05311
       Coding: 01114
       Shop #: WSC 05314
    Thanks !
    Should be 09557, no?
    Looks like you used login for GAS.
    http://wiki.ross-tech.com/wiki/index.php/VW_Passat_(3B)
    Vehicle Identification No. WVWZZZ3BZ4E342382
    Model passat squareback
    PA
    Date of production 12.05.2004
    Model year 2004
    Sales type 3B6265
    Engine Code AVF
    Transmission Code EYF
    Doesn't seem to be FOD for hardware!
    Why is ABS now offline in scan is there a problem with ignition switch?
    PART NUMBER DESCRIPTION REMARK
    4B0 998 375 repair kit 4B0 614 517 G
    4B0 614 517 J
    4B0 614 517 P
    Special editions E2R Exclusive
    Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0DE Installation differentiation for build status of vehicle class B5 (VW Passat)
    Emission standard 0GZ Emission standard EU3 diesel with EOBD
    Trailer hitch 1D0 without trailer towing
    airbag 4UF Airbag for driver and front passenger with front passenger airbag deactivation
    Automatic transmission indicator light 9FB Automatic transmission indicator light
    Aktivkohlebehälter / Ottopartikelfilter 1E0 Without activated charcoal canister
    Aerials 8L3 roof antenna
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SL Left exterior mirror, aspherical
    Right exterior mirror 5RQ Right exterior mirror: convex
    Drive type 1X0 Front-wheel drive
    Outside temperature display 9Y1 Outside temperature display
    "Multimedia"video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
    Equipment levels A8G sport-comfort version
    Brake type in rear 1KD Disc brakes in rear
    batteries J1D Battery 380 A (72 Ah)
    Brake type, front 1ZC Disc brakes in front (Geomet D)
    Controls (steering wheel/steering column) 4LF Controls for radio and cruise control system
    Beverage holders 4M5 Beverage holders
    Component part sets with country-specific design requirements B0F Component parts set, complying with vehicle type for Switzerland, various parts
    floor covering 3MQ Ibolours floor covering
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0XX Information kit in German (for export)
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QS CD ROM (Alps region)
    CD changer/CD player 7A2 CD changer
    Chrome package QJ0 Without aluminum/chrome work package
    General operating permit, alterations C11 Operating permit, alteration
    Shock absorption/suspension, chassis 1BA Federung/Daempfung, standard
    Roof rails/roof load rack 3S1 Bright roof rails
    Double DIN/dual-view display 2T1 Double-sized standard (DIN)
    Roof insert/convertible top 3FA roof without cut out
    Load-through hatch/ski bag 3X1 Load-through hatch with ski bag
    Insert for the filling up of unleaded fuel/fuel type 2G0 Without insert for the filling up of fuel
    Theft protection system 7AB Electronic immobilizer with anti-theft alarm system (for ROW)
    Inserts 5TX Decorative inserts for special edition
    Park distance control 7X1 Park distance control
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R3 Power windows with comfort operation
    fire extinguisher 6A0 without fire extinguisher
    Headlight activation 8K0 Without special driving light switching
    Antifreeze 1C1 Antifreeze up to -25 degree Celsius tolerance up to -30 degree C
    Alternators 8GL Alternator 120 A
    Transmission types/gearshift mechanisms 0G7 tiptronic
    Transmission shafts, rear axle 1YA Without transmission shafts f. rear axle
    Transmission shafts 1WD Transmission shaft for tripod joints
    Weight category rear axle 0YF Weight range 6 installation control only, no requirement forecast
    Weight category front axle 0JK Weight category front axle weight range 10
    Base engine T9J 4-cylinder diesel engine 1.9 l unit 038.K
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
    cruise control system 8T1 Cruise control system (CCS)
    Exterior noise suppression measures 2B1 additional noise dampener
    Garage door opener VC0 without Garage door opener
    Transmission specifications G0F 5-speed automatic transmission
    Cruise control system and speed limiter 6Y0 without speed warning system
    handle for hand brake lever 6PC handbrake lever grip (leather)
    Rear seats 3NW Rear seat bench/backrest, split folding with center armrest
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8BV Twin headlamps, for driving on the right, (gas discharge) with integrated high beam
    Instrument clusters U0C Instrument cluster with tachometer, clock and km/h speedometer
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8D Wagon/Avant
    Luggage compartment floor covering 6SL Luggage compartment floor covering in needle-punched nonwoven (velour)
    Cassette and CD storage unit 4W0 without cassette / CD tray
    Child seats QA0 without child seat
    headrest for seat, rear 3Q6 Three rear head restraints
    Head restraints 3J7 Tilt- and height-adjustable head restraints for front seats
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Body measures 5C0 Without special body measures
    Catalytic converter control 8KA without catalyst control
    Front license plate bracket 6W1 Front license plate carrier (large)
    Paint preservative/transit coating 5K1 Transit coating (wax)
    Paint coating FB3 Surface, interior trim, soft-touch paint
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S4 Two reading lights front, two rear
    steering 1N1 Power steering
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 2ZB Leather-wrapped multi-function steering wheel
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q3 Dynamic headlight range control (self-adjusting while driving)
    Center armrest 6E3 Center armrest in front
    Multi-function display/trip computer 9Q2 Multi-function display/trip computer with check control
    Engine cooling 8Z5 not hot country
    Engine specifications D3E 4-cyl. turbo diesel engine 1.9 l/96 kW TDI with unit-injector system base engine is T9J
    Left vanity mirror 4SD Vanity mirror, left, illuminated
    Right vanity mirror 4TD Vanity mirror, right, illuminated
    Navigation device 7Q5 Navigation system with black-and-white screen
    rear fog lamp 8TC Rear fog light for driving on the right
    Front fog lamp/additional headlamp 8WD Integrated front fog light
    Hubcaps 1NA Without hub caps
    Wheels CD5 Alloy wheels 7J x 17
    Radios 8AY Radio navigation system
    Smoker's/non-smoker's package 9JB Smoker's package, ashtrays in front and rear
    tire H6G Tires 225/45 ZR17 91Y
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G1 Space-saving spare wheel
    Restraint systems, front 3QT 3-point seat belts in front, with tensioner and height adjustment
    PH2 air conditioning system "Climatronic"
    PXA Swiss package (WW1, PM2, P15, PST, 8WD, 3X1)
    RLB radio/navigation system with monochrome display (MCD) 8 speakers
    WE1 technical equipment package
    WX1 "Exclusive" for Switzerland
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SB Labels in German
    Materials of low flammability 4Q1 Materials of low flammability
    Seat belt check 9P0 without press button buckle with warning contact
    Center rear seat belts 3C7 3-point seat belt for center rear seat
    Gearshift boot/cover 6R0 Gearshift boot for automatic transmission
    seat covers N2Z Seat trim covers for special editions
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A3 seat heating for front seats separat controlable
    Safety certificate 0LF With special labels safety certificates for Switzerland
    Side lights 8F2 side-mounted turn signals
    Voice enhancer VX0 Without voice enhancer
    Side and rear windows 4KF heat protective glass for door, side and rear windows, darkened from b-pillar
    Protective side molding 4B9 Body-colored protective side molding with trim stripe
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
    power outlet 7B3 12-volt outlet(s)
    Bumper 2JN Comfort bumpers with chrome-plated strip
    parking light warning lamp 8NA without parking light warning lamp
    Headlamp washer system 8X1 Headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N3 intermittent windscreen wiper with rain sensor
    Nameplate set 0NA Without nameplate set (without model designation)
    Special alarm systems 9A0 Without taxi alarm system
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Type approval countries/countries with special requirements B13 Type approval country Switzerland
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Partition 3CA without partition
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Assembly parts for engine (drive bearing) 1VG Assembly part for 4-cyl. engine
    Identification plates 1EX Special identification plate for EU
    First aid kit / warning triangle 1T2 warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Front seats Q4H Sports comfort seats in front
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W0 Without car phone preparation/ installation
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GH Windshield in heat-insulating glass with sunshield
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZB Bright decorative trims
    Additional body panels, side 6EP Additional stone guard body covers
    Additional child seat anchors 3B4 Child seat anchors for child seat system ISOFIX
    Duty-free tires 1V0 Without duty-free and cost-free tires
    Additional dust seals 6U0 Without additional seals outside
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  9. Likes Uwe, _Val, Dana liked this post
  10. #7
    Jul 2017
    Kosovo
    Hello Jack ,that was the problem at coding
    Thank you that was the problem Professor
  11. Likes Jack@European_Parts, Dana, Uwe liked this post
