Clear all DTCs not working
Detlef Trapp
World
C?ID=56993
This is the same car I had trouble with VCDS mobile, so now tried VCDS 19.6.2 but the 'Clear all DTCs' button did not work even though I tried several times, also tried running several complete Auto-Scans, also tried ignition off, but no success.
Ended up clearing the DTCs individually in each controller :-(
Monday,09,December,2019,17:28:34:10727
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WVWZZZ3CZDExxxxxx   License Plate:
Mileage: 210920km-131059mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 20 25 2E 37 42 44 46 4C 4F
          52 53 56 61 62 6C 72
VIN: WVWZZZ3CZDExxxxxx   Mileage: 210920km-131059miles
   Part No SW: 03L 906 018 PA    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H28 9978
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 001D0032046401080000
   Shop #: WSC 35475 184 00000
   ASAM Dataset: EV_ECM20TDI01103L906018PA 003009
   ROD: EV_ECM20TDI01103L906018PA.rod
   VCID: 78BC28FBC3FAAC8F9F-802C
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [032] - -
5286 - Throttle Position Sensor (G69)
          P0121 00 [104] - Implausible Signal
                    Fault Frequency: 60
                    Mileage: 206029 km
                    Date: 2019.09.24
                    Time: 09:02:15
                    Engine speed: 118.50 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 86 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 12.680 V
                    Air mass: actual value (mg/stroke): 448.7 mg/stroke
                    Throttle valve adapter: specified value: 0.00 %
                    Throttle valve adapter: actual value: 1.12 %
                    Throttle valve adapter: offset closed: -11.95 %
                    Throttle valve adapter: status-Bits 0-7: 0
                    Throttle valve adapter: status-Bits 0-7: 8
                    Throttle valve adapter: status-Bits 0-7: 55
                    Throttle valve adapter: status-Bits 0-7: 14
                    Throttle valve adapter: uncond voltage actual value: 977.4 mV
Readiness: 0 1 0 0 0
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3509
   Revision: 05551213    Serial number: 00001205101083
   Shop #: WSC 05311 000 00000
   VCID: 24042C8BE7F2186FE3-8070
   Part No SW: 3AA 614 109 BL    HW: 3AA 614 109 BL
   Component: J104   C2 450M VE2A 0024
   Revision: --H07---    Serial number: 00000005776183
   Coding: 0122291
   VCID: 78BC28FB0BFAAC8F9F-802C
02214 - Tire Pressure Warning
                    Reset counter: 80
                    Mileage: 207768 km
                    Date: 2014.03.16
                    Time: 18:16:15
                    Speed: 61.0 km/h
                    Hex Value: 0x0001
                    Bin. Bits: 00000000 00000000
                    Voltage: 13.25 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 AK    HW: 3AA 907 044 AK
   Component: Climatronic   H03 0202
   Revision: 00001K01
   Coding: 0011004803
   Shop #: WSC 00015 115 00000
   VCID: 79BA2DFFF8F0B587E0-802C
9474417 - Motor for Front Air Distribution Flap
          B1091 71 [008] - Actuator stuck
                    Reset counter: 75
                    Mileage: 209860 km
                    Date: 2019.11.16
                    Time: 17:26:54
9481988 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Fault Frequency: 119
                    Reset counter: 42
                    Mileage: 204858 km
                    Date: 2019.09.10
                    Time: 20:01:22
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 G    HW: 3AA 937 087 G
   Component: BCM PQ47 H    421 0464
   Revision: BB421001
   Coding: 0008000000000000009C00885400816403510088466D87606480C7200041
   VCID: 3E30FEE3A95E52BF95-806A
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 25041  10  0603
   Coding: 00B795
   Component: RLS 230512 05  54  0403
   Coding: 024D2A
03789 - Terminal 75 Limp Mode Active
                    Reset counter: 59
                    Mileage: 208757 km
                    Date: 2014.03.25
                    Time: 10:34:03
                        Term 15 On
                    Voltage: 12.65 V
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56261212900439
   Coding: 348306
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000.rod
   VCID: 44C48C0BCFB2386FC3-8010
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000548512
   Coding: 0010000
   VCID: 383CE8FB4B7A6C8F5F-806C
00532 - Supply Voltage B+
                    Fault Frequency: 22
                    Reset counter: 81
                    Mileage: 206211 km
                    Date: 2014.02.20
                    Time: 08:20:57
                    Count: 92
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__107 VW10 HI   2118
   Revision: 24017000    Serial number: 003L7PAQC3L%
   Coding: 0012343
   VCID: 7CB434EB3FC280AFFB-8028
   Subsystem 1 - Serial number: 6332MTS639271282
   Subsystem 2 - Serial number: 6342MTS656441282
   Subsystem 3 - Serial number: 6351HTS6RL0N4BKJ
   Subsystem 4 - Serial number: 6361HTS6CABM3BKJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20120530201964
   Coding: 399AA50001
   VCID: 75A221CFD4E8D1E784-8020
   Component: E221__MFL-TK6  H07 0022
   Coding: E30000
   Part No SW: 3AA 920 870 J    HW: 3AA 920 870 J
   Component: KOMBI         H05 0705
   Coding: 161F01
   Shop #: WSC 05314 115 00000
   VCID: 393AEDFFB8707587A0-806C
   Part No SW: 7N0 907 530 AA    HW: 7N0 907 530 G
   Component: J533  Gateway H41 1632
   Revision:   H41       Serial number: 210512F1001621
   Coding: 462006
   Shop #: WSC 05314 000 00000
   VCID: 6FAE13A7BEB4EB374E-803A
   Part No SW: 5K0 857 511 C    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 01018E67727261565623393E01
   VCID: 2E10CEA3793EA23F05-807A
   Part No SW: 3AA 959 799 A    HW: 3AA 959 799 A
   Component:    IMMO         083 0402
   Revision: 00083000    Serial number: VWZCZ000000000
   Shop #: WSC 49646 001 1048576
   VCID: 46C09603318E0A7FDD-8012
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662676166
   Coding: 020100
   VCID: 2A18C2B345D6CE1FD9-807E
   Part No SW: 3C0 035 279 N    HW: 3C0 035 279 N
   Component: RNS315-EU   H52 0319
   Serial number: VWZAZ2M5913900
   Coding: 040004110400110000011301
   ASAM Dataset: EV_RNS315EUV2UDS 001705
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2E10CEA3713EA23F05-807A
   Component: EUR_W_0038  0038
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0005057512
   Coding: 0210B7
   Shop #: WSC 05311 115 00000
   VCID: 3522E1CF946891E744-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000002939625
   Coding: 010090
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [008] - Electrical Failure
                    Reset counter: 72
                    Mileage: 207552 km
                    Date: 2019.10.21
                    Time: 18:49:43
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.310 1101
   Revision: 1AH03735    Serial number: 00121390064901
   Coding: 0000258
   VCID: 3D32F9EF645849A78C-8068
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component: 02 KESSY PQ47   083 0346
   Coding: 0191020052C30E76340494157E004FCE705801030434B8
   Subsystem 4 - Component:       ViP n.mounted
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 245
                    Mileage: 201524 km
                    Date: 2013.11.09
                    Time: 16:16:38
   Part No SW: 7N0 907 532     HW: 7N0 907 530 G
   Component: EZE_2         H41 1632
   Coding: 00000008
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0005064612
   Coding: 0210B6
   VCID: 3620E6C3896E9AFF4D-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000002944470
   Coding: 010090
                    Fault Frequency: 17
                    Reset counter: 79
                    Mileage: 204631 km
                    Date: 2019.09.05
                    Time: 08:17:17
   Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
   Component: J540 EPB4  VW-86594 0010
   Revision:   H19       Serial number: 00000000238755
   Coding: 0022167
   VCID: 3620E6C3416E9AFF4D-8062
   Part No SW: 7N0 907 534     HW: 7N0 907 530 G
   Component: Batt.regelung H41 1632
   Coding: 030F1859
   VCID: 71AA15DFA880FDC758-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900464600
   Part No SW: 3C9 907 441     HW: 3C9 907 441
   Component: J772__Rearview      0020
   Revision: 00H11000    Serial number: 525PA8-J242575
   Coding: 0020007
   VCID: 689C78BB5B5A3C0F0F-803C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 162
                    Mileage: 201524 km
                        Term 15 On
                        Reverse OFF
                    Count: 3
End----(Elapsed Time: 01:40, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
As a general rule, a UDS ECU will not clear fault codes via the CAN broadcast. You have to explicitly clear faults in the ECU. If the tranny were UDS, it would also likely ignore the broadcast, and on the latest cars, there are other modules that will as well.
Before-and-after scans would be more telling with respect to what's going on.
