Results 1 to 2 of 2
Thread: Clear all DTCs not working
    Nov 2014
    World
    This is the same car I had trouble with VCDS mobile, so now tried VCDS 19.6.2 but the 'Clear all DTCs' button did not work even though I tried several times, also tried running several complete Auto-Scans, also tried ignition off, but no success.
    Ended up clearing the DTCs individually in each controller :-(
    Monday,09,December,2019,17:28:34:10727
    VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
    VIN: WVWZZZ3CZDExxxxxx   License Plate:
    Mileage: 210920km-131059mi   Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 20 25 2E 37 42 44 46 4C 4F
              52 53 56 61 62 6C 72
    VIN: WVWZZZ3CZDExxxxxx   Mileage: 210920km-131059miles
       Part No SW: 03L 906 018 PA    HW: 03L 907 309 AE
       Component: R4 2.0l TDI   H28 9978
       Revision: 41H28---    Serial number: 00000000000000
       Coding: 001D0032046401080000
       Shop #: WSC 35475 184 00000
       ASAM Dataset: EV_ECM20TDI01103L906018PA 003009
       ROD: EV_ECM20TDI01103L906018PA.rod
       VCID: 78BC28FBC3FAAC8F9F-802C
    5523 - Engine Start Blocked by Immobilizer
              P1570 00 [032] - -
    5286 - Throttle Position Sensor (G69)
              P0121 00 [104] - Implausible Signal
                        Fault Frequency: 60
                        Mileage: 206029 km
                        Date: 2019.09.24
                        Time: 09:02:15
                        Engine speed: 118.50 /min
                        Normed load value: 100.0 %
                        Coolant temperature: 86 C
                        Intake air temperature: 38 C
                        Voltage terminal 30: 12.680 V
                        Air mass: actual value (mg/stroke): 448.7 mg/stroke
                        Throttle valve adapter: specified value: 0.00 %
                        Throttle valve adapter: actual value: 1.12 %
                        Throttle valve adapter: offset closed: -11.95 %
                        Throttle valve adapter: status-Bits 0-7: 0
                        Throttle valve adapter: status-Bits 0-7: 8
                        Throttle valve adapter: status-Bits 0-7: 55
                        Throttle valve adapter: status-Bits 0-7: 14
                        Throttle valve adapter: uncond voltage actual value: 977.4 mV
    Readiness: 0 1 0 0 0
       Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 3509
       Revision: 05551213    Serial number: 00001205101083
       Shop #: WSC 05311 000 00000
       VCID: 24042C8BE7F2186FE3-8070
       Part No SW: 3AA 614 109 BL    HW: 3AA 614 109 BL
       Component: J104   C2 450M VE2A 0024
       Revision: --H07---    Serial number: 00000005776183
       Coding: 0122291
       VCID: 78BC28FB0BFAAC8F9F-802C
    02214 - Tire Pressure Warning
                        Reset counter: 80
                        Mileage: 207768 km
                        Date: 2014.03.16
                        Time: 18:16:15
                        Speed: 61.0 km/h
                        Hex Value: 0x0001
                        Bin. Bits: 00000000 00000000
                        Voltage: 13.25 V
                        Bin. Bits: 00011111
                        Count: 185
                        Hex Value: 0x0000
       Part No SW: 3AA 907 044 AK    HW: 3AA 907 044 AK
       Component: Climatronic   H03 0202
       Revision: 00001K01
       Coding: 0011004803
       Shop #: WSC 00015 115 00000
       VCID: 79BA2DFFF8F0B587E0-802C
    9474417 - Motor for Front Air Distribution Flap
              B1091 71 [008] - Actuator stuck
                        Reset counter: 75
                        Mileage: 209860 km
                        Date: 2019.11.16
                        Time: 17:26:54
    9481988 - Air Quality Sensor
              B10AF 04 [009] - Internal System Fault
                        Fault Frequency: 119
                        Reset counter: 42
                        Mileage: 204858 km
                        Date: 2019.09.10
                        Time: 20:01:22
       Part No SW: 3AA 937 087 G    HW: 3AA 937 087 G
       Component: BCM PQ47 H    421 0464
       Revision: BB421001
       Coding: 0008000000000000009C00885400816403510088466D87606480C7200041
       VCID: 3E30FEE3A95E52BF95-806A
       Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
       Component: Wischer 25041  10  0603
       Coding: 00B795
       Component: RLS 230512 05  54  0403
       Coding: 024D2A
    03789 - Terminal 75 Limp Mode Active
                        Reset counter: 59
                        Mileage: 208757 km
                        Date: 2014.03.25
                        Time: 10:34:03
                        Voltage: 12.65 V
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56261212900439
       Coding: 348306
       ASAM Dataset: EV_EPHVA2C000000000 002008
       ROD: EV_EPHVA2C000000000.rod
       VCID: 44C48C0BCFB2386FC3-8010
    Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
       Part No SW: 3AA 907 567 A    HW: 3AA 907 567
       Component: AC201  RDW A    036 0170
       Revision: 00036000    Serial number: 00000000548512
       Coding: 0010000
       VCID: 383CE8FB4B7A6C8F5F-806C
    00532 - Supply Voltage B+
                        Fault Frequency: 22
                        Reset counter: 81
                        Mileage: 206211 km
                        Date: 2014.02.20
                        Time: 08:20:57
                        Count: 92
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__107 VW10 HI   2118
       Revision: 24017000    Serial number: 003L7PAQC3L%
       Coding: 0012343
       VCID: 7CB434EB3FC280AFFB-8028
       Subsystem 1 - Serial number: 6332MTS639271282
       Subsystem 2 - Serial number: 6342MTS656441282
       Subsystem 3 - Serial number: 6351HTS6RL0N4BKJ
       Subsystem 4 - Serial number: 6361HTS6CABM3BKJ
       Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
       Revision: FF010041    Serial number: 20120530201964
       Coding: 399AA50001
       VCID: 75A221CFD4E8D1E784-8020
       Coding: E30000
       Part No SW: 3AA 920 870 J    HW: 3AA 920 870 J
       Coding: 161F01
       Shop #: WSC 05314 115 00000
       VCID: 393AEDFFB8707587A0-806C
       Part No SW: 7N0 907 530 AA    HW: 7N0 907 530 G
       Component: J533  Gateway H41 1632
       Revision:   H41       Serial number: 210512F1001621
       Coding: 462006
       Shop #: WSC 05314 000 00000
       VCID: 6FAE13A7BEB4EB374E-803A
       Part No SW: 5K0 857 511 C    HW: 8P0 857 511 C
       Component: FLA           H04 0006
       Revision: AA001002
       Coding: 01018E67727261565623393E01
       VCID: 2E10CEA3793EA23F05-807A
       Part No SW: 3AA 959 799 A    HW: 3AA 959 799 A
       Component:    IMMO         083 0402
       Revision: 00083000    Serial number: VWZCZ000000000
       Shop #: WSC 49646 001 1048576
       VCID: 46C09603318E0A7FDD-8012
       Component: SG EXT.PLAYER H18 0530
       Revision: A1001003    Serial number: 7662676166
       Coding: 020100
       VCID: 2A18C2B345D6CE1FD9-807E
       Part No SW: 3C0 035 279 N    HW: 3C0 035 279 N
       Component: RNS315-EU   H52 0319
       Serial number: VWZAZ2M5913900
       Coding: 040004110400110000011301
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 2E10CEA3713EA23F05-807A
       Component: EUR_W_0038  0038
       Component: TUER-SG FT    002 0533
       Revision: 12110009    Serial number: 0005057512
       Coding: 0210B7
       Shop #: WSC 05311 115 00000
       VCID: 3522E1CF946891E744-8060
       Slave Driver:
       Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0501
       Serial number: 00000002939625
       Coding: 010090
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [008] - Electrical Failure
                        Reset counter: 72
                        Mileage: 207552 km
                        Date: 2019.10.21
                        Time: 18:49:43
       Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.310 1101
       Revision: 1AH03735    Serial number: 00121390064901
       Coding: 0000258
       VCID: 3D32F9EF645849A78C-8068
    Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
       Component: 02 KESSY PQ47   083 0346
       Coding: 0191020052C30E76340494157E004FCE705801030434B8
       Subsystem 4 - Component:       ViP n.mounted
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 245
                        Mileage: 201524 km
                        Date: 2013.11.09
                        Time: 16:16:38
       Part No SW: 7N0 907 532     HW: 7N0 907 530 G
       Component: EZE_2         H41 1632
       Coding: 00000008
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
       Component: TUER-SG BT    002 0533
       Revision: 14110009    Serial number: 0005064612
       Coding: 0210B6
       VCID: 3620E6C3896E9AFF4D-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0501
       Serial number: 00000002944470
       Coding: 010090
                        Fault Frequency: 17
                        Reset counter: 79
                        Mileage: 204631 km
                        Date: 2019.09.05
                        Time: 08:17:17
       Revision:   H19       Serial number: 00000000238755
       Coding: 0022167
       VCID: 3620E6C3416E9AFF4D-8062
       Part No SW: 7N0 907 534     HW: 7N0 907 530 G
       Component: Batt.regelung H41 1632
       Coding: 030F1859
       VCID: 71AA15DFA880FDC758-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900464600
       Part No SW: 3C9 907 441     HW: 3C9 907 441
       Component: J772__Rearview      0020
       Revision: 00H11000    Serial number: 525PA8-J242575
       Coding: 0020007
       VCID: 689C78BB5B5A3C0F0F-803C
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 162
                        Mileage: 201524 km
                            Reverse OFF
                        Count: 3
    End----(Elapsed Time: 01:40, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
    As a general rule, a UDS ECU will not clear fault codes via the CAN broadcast. You have to explicitly clear faults in the ECU. If the tranny were UDS, it would also likely ignore the broadcast, and on the latest cars, there are other modules that will as well.
    Before-and-after scans would be more telling with respect to what's going on.
  3. Likes PetrolDave liked this post
