Results 1 to 4 of 4
Thread: 2007 Q7 4.2TDI DPF values reset
    Nov 2019
    Sheringham, England
    Good Evening Gentlemen.
    Really hoping for some help here... I have a fault code for a blocked dpf with limp mode. I have just removed both DPF's. Soaked them both overnight in some highly regarded professional cleaner, then pressure washed them thoroughly, dried and refitted.
    Unfortunately, The car still keeps producing the blocked dpf bank 1 fault code with limp mode. No matter how many times I delete the codes with VCDS. It comes back after 20 seconds.
    I have looked at the pressure sensors but they seem to be producing consistent values which are very similar under all conditions. Therefore I don't believe them to be at fault.
    I suspect that I need to use VCDS to reset the Dpf soot values. Or possibly force a regeneration using VCDS ( someone has previously mentioned here that this may be required to reset the system)
    Please can someone please shed some light on how to carry out this procedure using VCDS or point me in the right direction.
    Monday,09,December,2019,19:52:33:21534
    VIN: WAUZZZ4L97D103181   License Plate: OE07NKL
    Mileage: 189630   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 18 19 1E 34 36
              37 3C 42 46 47 4F 52 56 57 61 62 67 69 6C 6D 6F 72 76 77
    VIN: WAUZZZ4L97D103181   Mileage: 305110km-189586miles
    11-Engine II -- Status: Malfunction 0010
    31-Engine other -- Status: Malfunction 0010
       Part No SW: 4L0 910 409     HW: 4E1 907 409 B
       Component: 4.2L V8TDI  G000AGMª0020
       Revision: --H04---    Serial number:
       Coding: 0011779
       Shop #: WSC 31414 790 00001
       VCID: 678BBC8E436895DF68D-8032
    009263 - Diesel Particulate Filter (Bank 1)
                   P242F - 001 - Restricted/Clogged
                        Fault Status: 01110001
                        Mileage: 305116 km
                        Date: 2019.12.09
                        Time: 14:14:51
                        (no units): 54.0
                        (no units): 27.0
                        Pressure: 0 mbar
                        (no units): 53.0
                        (no units): 27.0
                        Pressure: 0 mbar
                        Temperature: 11.6°C
    Readiness: 0 0 0 1 1
    Address 02: Auto Trans        Labels: 09D-927-750.clb
       Part No SW: 09D 927 750 FE    HW: 09D 927 750 FE
       Component: AL 750 6A           1050
       Revision: 00H64000    Serial number:
       Coding: 0000504
       VCID: 76B5E1CA14C27C57E3B-8022
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
       Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
       Component: ESP ALLRAD MK25E1   0010
       Revision: 00H30001
       Coding: 0103585
       VCID: 290FFAB695FC63AFBE9-807C
                        Reset counter: 179
                        Mileage: 304484 km
                        Date: 2019.11.23
                        Time: 15:35:37
                        Count: 64
                        Count: 8261
                        Count: 128
                        Count: 42752
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100732192
       Coding: 0000151
       Shop #: WSC 00694 210 84841
       VCID: 6393A89EB750F9FFB45-8036
       Subsystem 1 - Part No: 4F0 910 131 G
       Component: FBSAUDIC6 EZS   H45 0080
       Subsystem 2 - Part No: 4F0 910 335
       Component: FBSAUDIC6 KSG   H27 0080
       Subsystem 3 - Part No: 4F0 910 220 K
       Component: FBSAUDIC6 IDG   H01 0040
    00191 - Passenger's Door Handle Touch Sensor (G416)
                        Fault Status: 01111011
                        Reset counter: 118
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 11:46:02
    00192 - Rear Left Door Handle Touch Sensor (G417)
                        Reset counter: 118
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 11:46:02
    00193 - Rear Right Door Handle Touch Sensor (G418)
                        Reset counter: 118
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 11:46:02
    00955 - Key 1
                        Fault Status: 00110010
                        Reset counter: 180
                        Mileage: 304995 km
                        Date: 2019.12.05
                        Time: 12:49:45
    Address 06: Seat Mem. Pass        Labels: None
       Part No SW: 4F0 910 760     HW: 4L0 959 760
       Component: Sitzmemory BFS  H01 0100
       Revision: 00000000    Serial number: 00000000896401
       Coding: 0078944
       VCID: 619FA296AD4CEBEFA69-8034
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
       Part No SW: 4L0 910 731 D    HW: 4E0 035 729 A
       Component: Interfacebox    H43 3450
       Revision: 00000000    Serial number: 387DS077547013
       Coding: 0002002
       Component: Bedienteil MMIC6H01 0060
       Subsystem 2 - Serial number: 00000001836152
       Subsystem 3 - Serial number: 0106.05.110000000100010535ÿ
       Subsystem 4 - Serial number: 010535ÿ
    02244 - Button in Control Head is Stuck
                        Reset counter: 153
                        Mileage: 304437 km
                        Date: 2019.11.21
                        Time: 08:58:37
                        Bin. Bits: 00000000
                        Bin. Bits:  0000000
                        Bin. Bits:      001
       Part No SW: 4L0 910 043     HW: 4L0 820 043 E
       Component: KLIMABETAETIGUNGH05 0060
       Revision: 00---012    Serial number: 00000000110632
       Coding: 0001048
    02508 - Temperature Sensor for Refrigerant (G454)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 118
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 11:41:05
                        Fault Frequency: 7
                        Reset counter: 186
                        Mileage: 304479 km
                        Date: 2019.11.22
                        Time: 15:23:03
                        Temperature: 90.0°C
                        Temperature: 20.0°C
                        Load: 0.0 %
                        Temperature: -55.0°C
                        RPM: 1600 /min
                        Absolute Pres.: 1.0 bar
                        Current: 0.000 A
                        Temperature: 14.0°C
       Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
       Component: ILM Fahrer      H17 0240
       Coding: 0111101
       VCID: 303917D2B6261267797-8064
       Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H08 0080
       Coding: 00064792
       Shop #: WSC 31414
       Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0090
       Coding: 00150059
       Shop #: WSC 31414
       Part No SW: 4L0 910 110 A    HW: 4L0 035 110
       Component: MP3-Changer     H43 0350
       Revision: 00043000    Serial number: AUZ5ZBG1055173
       VCID: 1D67DE66D1B48F0FC21-8048
    Address 0F: Digital Radio        Labels: None
       Part No SW: 4E0 910 563 C    HW: 4E0 035 563
       Component: DAB-Tuner       H41 0830
       Revision: 00000001    Serial number: KE1276V7100915
       Coding: 0000001
       VCID: 2411EB82F2DEBEC78DF-8070
       Component: 4.2L V8TDI  G000AGSª0020
       Coding: 0011779
       Shop #: WSC 95147 753 45725
                        Fault Status: 01100001
                        Mileage: 305116 km
                        Date: 2019.12.09
                        Time: 14:14:51
                        (no units): 54.0
                        (no units): 27.0
                        Pressure: 0 mbar
                        (no units): 53.0
                        (no units): 27.0
                        Pressure: 0 mbar
                        Temperature: 69.6°C
       Part No SW: 4L0 910 655 B    HW: 4L0 959 655
       Component: 31 AIRBAG AUDI8RH39 0120
       Revision: 06H39000    Serial number: 0037GD09BZPX
       Coding: 0013105
       VCID: 2C0103A29A0E768745F-8078
       Subsystem 1 - Serial number: 6332QSME216B1D01A
       Subsystem 2 - Serial number: 6342QSME28563119B
       Subsystem 3 - Serial number: 6352QSME2856264FP
       Subsystem 4 - Serial number: 6362QSME245A783FW
       Subsystem 5 - Serial number: 63734SME20647837
       Subsystem 6 - Serial number: 63834SME224B533B0
       Part No SW: 4F0 910 549     HW: 4F0 953 549 A
       Component: Lenksäulenmodul H08 0230
       Revision: 00H08000    Serial number: 90054071020272
       Coding: 0112142
       VCID: 6695B18A44628CD753B-8032
       Component: Lenkradmodul    H07 0090
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4L0 920 980 G
       Component: KOMBIINSTR. M73 H18 0170
       Revision: 00400000    Serial number: 5HJ14AH47
       Coding: 2593448
       Shop #: WSC 00011 888 96745
       VCID: 2313E89EF7D0B9FFF45-8076
    Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
       Part No SW: 4L0 910 105     HW: 4L0 815 071 D
       Component: Heizgeraet      H08 0080
       Revision: 0000000C    Serial number: 00000009014264
       Coding: 0000001
       VCID: 6099A792A646E2E7A97-8034
    Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
       Part No SW: 4L0 910 468     HW: 4L0 907 468 A
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0800D0732781C5
       Coding: F7DBFFDF747E02
       Shop #: WSC 00385 210 90017
       VCID: 6C81C3A25A8EB68705F-8038
    Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785     HW: 4E0 035 785
       Component: SG ext.Player H09 0170
       Revision: 00000000
       VCID: 6597B686B56487CF5A1-8030
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 C    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7660
       Revision: --H03001    Serial number: 15.1528-0096.2
       Coding: 0015520
       VCID: 2A0D05BA90FA68B7B73-807E
                        Reset counter: 158
                        Error Code: 13
    01577 - Turn-Off due to Over-Temp
                        Fault Status: 00100001
                        Fault Frequency: 8
                        Reset counter: 185
                        Mileage: 304473 km
                        Date: 2019.11.22
                        Time: 14:52:28
                        Error Code: 68
    01575 - Control Switched Off
                        Fault Status: 11100000
                        Reset counter: 146
                        Mileage: 305116 km
                        Date: 2019.12.09
                        Time: 10:16:18
                        Error Code: 69
       Component: Sitzmemory FS   H01 0100
       Coding: 0074858
       Part No SW: 4E0 910 887 T    HW: 4E0 919 887 M
       Component: MNS ECE         H49 1030
       Revision: 00000000    Serial number: 399D$077571393
       Shop #: WSC 00385 210 71556
       VCID: 3E2539EA7C72F417FBB-806A
    02927 - DVD Read Error
                        Reset counter: 160
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 14:06:29
                        Hex Value: 0x5DD7
                        Hex Value: 0xEBA0
                        Hex Value: 0x0401
                        Hex Value: 0x0000
    Address 3C: Lane Change        Labels: None
       Part No SW: 4L0 910 566 B    HW: 4L0 907 566 A
       Component: J0769_SWA_MasterH07 0070
       Revision: 00H07000    Serial number: 6PZ 009 014-00
       Coding: 0011101
       VCID: 2D070EA6A1147F8F521-8078
       Subsystem 1 - Part No: 4L0 910 568 B
       Component: J0770_SWA_Slave_H06 0070
       Subsystem 2 - Serial number: 6PZ 009 014-20
       Subsystem 3 - Serial number: 3F18.12.0600H0600000010121ÿ
       Subsystem 4 - Serial number: 010121ÿ
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0150
       Revision: 00-00000
       Coding: 0019163
       VCID: 2F3B14AEAB180D9F60D-807A
       Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
       Component: Komfortgeraet   H07 0040
       Revision: 0040 ---    Serial number: 01038117300000
       Coding: 7610619
       VCID: 333318DE4730297F045-8066
    03073 - Rear Lid Closed Sensor 1
                008 - Implausible Signal
                        Fault Status: 01101000
                        Fault Frequency: 35
                        Reset counter: 146
                        Mileage: 305011 km
                        Date: 2019.12.05
                        Time: 15:34:55
    Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
       Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
       Component: DSP-High AU716  H03 0150
       Revision: PROD_01     Serial number: 00000000027137
       Coding: 0000023
       VCID: 2809FFB28EF65AA7A17-807C
       Part No SW: 4F0 910 280     HW: 4F0 907 280 E
       Component: ILM Beifahrer   H10 0080
       Revision:             Serial number: 00000000044557
       Coding: 0011101
       VCID: 5EE5996A9C32D4179BB-800A
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
       Component: TSG BF          H12 0150
       Revision: 00-00000
       Coding: 0019163
       Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
       Component: TUNER EU/US/RDW H42 0620
       Revision: 00000000    Serial number: 388D4077617969
       Coding: 0000001
       VCID: 2E0509AAAC1204976BB-807A
    Address 57: TV Tuner        Labels: None
       Part No SW: 4E0 910 148 B    HW: 4E0 919 148
       Component: R0078 TVhybridTuner 0360
       Revision: R0H06000    Serial number: 76300800461501
       Coding: 0000303
       VCID: 221DED9AE8CAB0F7FF3-8076
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000020235
       VCID: 6491AB82B25EFEC74DF-8030
       Subsystem 1 - Part No: 4E0 915 105 A
       Component: von VA0  205VA03B78
       Coding: 344530393135313035412056413032303556413033423738
       Shop #: WSC 00011 888 06946
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 11:41:00
                        Reset counter: 158
                        Mileage: 304470 km
                        Date: 2019.11.22
                        Time: 11:41:00
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Component: TSG HL          H21 0050
       Coding: 0018442
       VCID: 313F12D6BD2C1B6F769-8064
    Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
       Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
       Component: SDS 3502 UK     H45 0630
       Revision: 00000000    Serial number: 00000703300389
       Shop #: WSC 12336 024 394758
       VCID: 363521CA54423C5723B-8062
    Address 69: Trailer        Labels: 4E0-910-383.lbl
       Part No SW: 4E0 910 383 C    HW: 4E0 907 383 C
       Component: ANHAENGERELEKTR 004 0060
       Coding: 0000001
       Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J7342AL
       Coding: 1031001
       Part No SW: 4L0 910 945     HW: 4L0 827 851 B
       Component: ValeoHeckdeckel H21 0280
       Revision: --H21001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       Subsystem 3 - Serial number: RD19.04.07--H21001001B0258ÿ
       Subsystem 4 - Serial number: 1B0258ÿ
       Component: ILM HINTEN 2    H05 0060
       Revision: AAH05061    Serial number: 002658822-----
       Coding: 0003587
       VCID: 2615F18A84E24CD793B-8072
       Subsystem 1 - Part No: 4L0 910 591
       Component: J_245_EE15_SKB09H10 0180
       Subsystem 2 - Part No: 4L0 910 591
       Component: J_394_EE15_SKB09H10 0180
       Subsystem 3 - Part No: 4L0 910 591
       Component: J_392_EE15_SKB09H10 0180
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
       Component: TSG HR          H21 0050
       Coding: 0018442
       Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
       Component: Parkhilfe 8-Kan H12 0060
       Revision: 00H12000    Serial number: 06330710004718
       Coding: 0231146
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H16 1130
       Revision: 00000000    Serial number: 00000007652521
       Coding: 0010900
    End----(Elapsed Time: 02:37, VBatt start/end: 11.4V/11.9V. VIgn 11.8V)-----
    Thanks Chaps.
    Regards, Ben.
    What and after a plugged DPF, hey did you verify you can change a reading with a DVOM and regulated PSI air at each DPF sensor?
    Did you try clearing faults multiple times or in OBD2 mode and quickly?
    Did you try re-coding the controller to default it with a battery capacitor discharge and reboot?
    Doesn't DTC have to be vacated before a regen or reset can take place, right?
    Isn't a firmware update needed & wouldn't it be wise to access the master and slave controllers simultaneously in VCDS or under broadcast to do a combined reset?
    Nov 2019
    Sheringham, England
    Morning Jack. Many thanks for giving me some pointers here. I will see if I can get anywhere using the information you have given me.
    Nov 2019
    Sheringham, England
    FIXED!
    Finally managed to get the “dpf bank 1 blocked” fault code with limp mode Fixed. Just thought I’d post the solution in order for others to benefit.
    Given that I was unable to work out how to use vcds to reset/clear the fault code+limp mode after chemical cleaning and that no solution could be found here I decided to bite the bullet and take the car to a VAG specialist
    What they did was firstly try VCDS as this was “usually quick and easy” however the specialist found (as have I!) that VCDS and a 2007 Q7 4.2tdi engine control modules don’t seem to get on very well! And couldn’t get anywhere...
    Next They got out an old VAS main dealer diagnostics computer. With this they were able to reset both DPF adaptions and reset both DPF pressure sensor adaptions. There was lots of holding the revs high with foot on throttle for 5 minutes at a time too, instructed by VAS (Possible manual cleaning) Fault code gone. Limp mode gone.
    Since then I have monitored the pre-dpf temperatures and the DPF pressure drops whilst driving (using VCDS) and all is normal and healthy.
    Thanks to anyone that posted on my thread.
    Regards, Ben.
  5. Likes Jack@European_Parts, NZDubNurd liked this post
