Tourage 7L fob sync
Liteace1
Spain
C?ID=90243
Anyone know if I can sync/prog fob on 7L tourage, if so how, please
PIVOT
Canada
C?ID=200803
Is it a virgin key? or what's the story here.
Not all 7L Touaregs are the same. Pre or post facelift? With Kessy or without? Please post an Auto-Scan for context.
Liteace1
Spain
C?ID=90243
Heres a full scan:
VIN: WVGZZZ7LZ6D016072   License Plate:
Mileage: 271950km-168981mi   Repair Order: v10 tourage
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ6D016072   Mileage: 271950km-168981miles
   Part No SW: 070 906 016 AA    HW: 028 101 148 1
   Component: V10 5,0L EDCG000AGMª6189
   Coding: 0010575
   Shop #: WSC 31414 000 00000
   VCID: 4FEE872BDF47E0376E-5160
18009 - Relay for Supply Voltage Terminal 30 (J317)
            P1601 - 000 - Implausible Signal - Intermittent
                    Torque: -489.8 Nm
                    Voltage: 12.39 V
                    Bin. Bits: 00000000
                    Bin. Bits:        0
                    (no units): 0.0
18253 - Please check DTC Memory of Steering Electronics (J527)
            P1845 - 000 -
                    RPM: 882 /min
                    Torque: 0.0 Nm
                    Voltage: 11.40 V
                    Bin. Bits: 00001100
                    Bin. Bits: 00000000
                    Bin. Bits: 00001100
Readiness: 0 0 X X X
   Part No SW: 3D0 909 137     HW: 5WK 470 22
   Component: 08 Kessy            6700
   Revision: 67005514    Serial number: VWZ3Z0E3371531
   Coding: 0147688
   VCID: 64845887A6C1736F23-5160
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3001
   Coding: 0111868
   VCID: 47DEAF0B3737387726-5160
01117 - Generator Terminal DF Load Signal
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG000AGSª6189
   Coding: 0010575
   Part No: 3D0 909 601 F
   Component: 0B Airbag 8.4E+ H11 1151
   Coding: 0012354
   VCID: 2600028F907DC17FFD-5160
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000032
   VCID: 40CCB41712190F4FE7-5160
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 881 B
   Component: KOMBIINSTRUMENT RB8 3135
   Coding: 0007111
   Shop #: WSC 22140 282 70448
   VCID: 373EDFCB47D748F756-5160
01304 - Radio
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 815 071 C
   Component: Standheizung E1MAC
   Coding: 0000000
   VCID: 3228EEDFACB5ADDF61-5160
02251 - Heater Unit Locked
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70AC24D76239DFCF57-5160
01304 - Radio
Address 36: Seat Mem. Drvr        Labels:
   VCID: 55E27543AC9B9AE7A4-5160
   Note: Excessive Comm Errors
Address 47: Sound System        Labels:
Address 68: Wiper Electr.        Labels: None
   Part No: 7L0 955 119 M
   Component: Front Wiper         4028
   Coding: 0000768
   VCID: 3E30CAEF68ED79BF95-5160
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00208933
   Part No: 7L0 919 283 F
   Component: 0D Einparkhilfe     1107
   VCID: 393AD9F371C35E87A0-5160
Address 77: Telephone        Labels: Redir Fail!
   Part No SW: 7L6 035 729 F    HW: 7L6 035 729 F
   Component: FSE_275x        H18 0020
   Revision: 00000001    Serial number: 00000000265093
   Coding: 0000211
02503 - Output Wire to Radio
                    Reset counter: 21
                    Time Indication: 15
01304 - Radio
                    Fault Status: 01110100
                    Reset counter: 21
                    Time Indication: 15
End----(Elapsed Time: 10:17, VBatt start/end: 11.2V/11.1V. VIgn 0.0V)------
In theory, on this one, I think it is possible, if you have the PIN code for the vehicle.
Liteace1
Spain
C?ID=90243
The owner of the vehicle says he can get the pin code no problem :facepalm:
Jef
HQ
This begs the question, if the owner can do that, why would they need any help in the first place. That is some higher level "kung fu". :confused: Let us know what they come up with.
