Results 1 to 7 of 7
Thread: Tourage 7L fob sync
    Feb 2015
    Spain
    Tourage 7L fob sync
    Anyone know if I can sync/prog fob on 7L tourage, if so how, please
    Thanks
    Dec 2019
    Canada
    Is it a virgin key? or what's the story here.
    Not all 7L Touaregs are the same. Pre or post facelift? With Kessy or without? Please post an Auto-Scan for context.
    Feb 2015
    Spain
    Heres a full scan:
    VIN: WVGZZZ7LZ6D016072   License Plate:
    Mileage: 271950km-168981mi   Repair Order: v10 tourage
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGZZZ7LZ6D016072   Mileage: 271950km-168981miles
       Part No SW: 070 906 016 AA    HW: 028 101 148 1
       Component: V10 5,0L EDCG000AGMª6189
       Coding: 0010575
       Shop #: WSC 31414 000 00000
       VCID: 4FEE872BDF47E0376E-5160
    18009 - Relay for Supply Voltage Terminal 30 (J317)
                P1601 - 000 - Implausible Signal - Intermittent
                        Torque: -489.8 Nm
                        Load: 0.0 %
                        Voltage: 12.39 V
                        Bin. Bits: 00000000
                        Bin. Bits:        0
                        (no units): 0.0
    18253 - Please check DTC Memory of Steering Electronics (J527)
                P1845 - 000 -
                        RPM: 882 /min
                        Torque: 0.0 Nm
                        Load: 0.0 %
                        Voltage: 11.40 V
                        Bin. Bits: 00001100
                        Bin. Bits: 00000000
                        Bin. Bits: 00001100
    Readiness: 0 0 X X X
       Part No SW: 3D0 909 137     HW: 5WK 470 22
       Component: 08 Kessy            6700
       Revision: 67005514    Serial number: VWZ3Z0E3371531
       Coding: 0147688
       VCID: 64845887A6C1736F23-5160
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 N
       Component:                     3001
       Coding: 0111868
       VCID: 47DEAF0B3737387726-5160
    01117 - Generator Terminal DF Load Signal
                008 - Implausible Signal
       Component: V10 5,0L EDCG000AGSª6189
       Coding: 0010575
    Address 15: Airbags        Labels: 3D0-909-601.lbl
       Part No: 3D0 909 601 F
       Component: 0B Airbag 8.4E+ H11 1151
       Coding: 0012354
       VCID: 2600028F907DC17FFD-5160
    Address 16: Steering wheel        Labels: 7L6-953-549.lbl
       Part No: 7L6 953 549 D
       Component: Lenksäulenmodul     3301
       Coding: 0000032
       VCID: 40CCB41712190F4FE7-5160
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 881 B
       Component: KOMBIINSTRUMENT RB8 3135
       Coding: 0007111
       Shop #: WSC 22140 282 70448
       VCID: 373EDFCB47D748F756-5160
    01304 - Radio
    Address 18: Aux. Heat        Labels: 7L6-819-008.clb
       Part No: 7L6 815 071 C
       Component: Standheizung E1MAC
       Coding: 0000000
       VCID: 3228EEDFACB5ADDF61-5160
    02251 - Heater Unit Locked
       Part No: 6N0 909 901
       Component: Gateway K<>CAN      0101
       Coding: 0000006
       VCID: 70AC24D76239DFCF57-5160
    00463 - Control Module for Digital Sound Package (J525)
    01304 - Radio
    Address 36: Seat Mem. Drvr        Labels:
       VCID: 55E27543AC9B9AE7A4-5160
       Note: Excessive Comm Errors
    Address 47: Sound System        Labels:
    Address 68: Wiper Electr.        Labels: None
       Part No: 7L0 955 119 M
       Component: Front Wiper         4028
       Coding: 0000768
       VCID: 3E30CAEF68ED79BF95-5160
       Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 010  1010
       Coding: 00208933
    Address 76: Park Assist        Labels: Redir Fail!
       Part No: 7L0 919 283 F
       Component: 0D Einparkhilfe     1107
       VCID: 393AD9F371C35E87A0-5160
    Address 77: Telephone        Labels: Redir Fail!
       Part No SW: 7L6 035 729 F    HW: 7L6 035 729 F
       Component: FSE_275x        H18 0020
       Revision: 00000001    Serial number: 00000000265093
       Coding: 0000211
    02503 - Output Wire to Radio
                        Fault Status: 01101011
                        Reset counter: 21
                        Time Indication: 15
    01304 - Radio
                        Fault Status: 01110100
                        Reset counter: 21
                        Time Indication: 15
    End----(Elapsed Time: 10:17, VBatt start/end: 11.2V/11.1V. VIgn 0.0V)------
    Thanks
    In theory, on this one, I think it is possible, if you have the PIN code for the vehicle.
  6. #6
    Feb 2015
    Spain
    Thanks
    The owner of the vehicle says he can get the pin code no problem
  7. #7
    HQ
    This begs the question, if the owner can do that, why would they need any help in the first place. That is some higher level "kung fu". Let us know what they come up with.
    Jef
  8. Likes Uwe liked this post
