Results 1 to 5 of 5
Thread: VW Golf 7.5 Facelift 2.0 TDI 150 PK 2 faults NO RETROFIT Orginal
    Jun 2016
    Hello All,
    Since today I am the proud owner of a VW Golf 7.5 facelift 2.0 TDI 150 pk Year 2017.
    I have scanned the car with my cable and see two errors.
    The car has extended warranty until 2022.
    So I would like to know what has happened more often that a software update is necessary on new cars, is this also the case with my car or is it
    a problem which the dealer must solve.
    I would like to receive feedback from you here.
    Monday,09,December,2019,14:09:27:42750
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWZZZAUZHW330832   License Plate:
    Chassis Type  AU-VW37 (3Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 18 19 3C 42 44 4B 52 5F A5
    VIN: WVWZZZAUZHW330832   Mileage: 60001km-37282miles
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-DCYA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 EK    HW: 04L 907 309 R
       Component: R4 2.0l TDI   H24 4029
       Revision: B5H24---
       Coding: 0125001A036405082000
       ASAM Dataset: EV_ECM20TDI01104L906026EK 004003
       ROD: EV_ECM20TDI01104L906026EK_004_VW37.rod
       VCID: 77D2B1B4CE6BBAF796-8022
       Part No SW: 0GC 300 040 T    HW: 0GC 927 711 G
       Component: GSG DQ381     H06 0705
       Revision: 00H06V07
       ROD: EV_TCMDQ381061_VW37.rod
       VCID: 354E7BBC94E788E744-8060
       Revision: 00000000    Serial number: 60567000000388
       Coding: 01FA62A12423096C477F060340C52980462490E26002947338625078C2A2430000000012121212B835351919323200
       Part No SW: 5G1 907 044 AC    HW: 5G1 907 044 AC
       Revision: 00001K08
       Coding: 00020114204111011105000C0010102A
       VCID: 69F6E7CC88DF1C0710-803C
       Air quality sensor:
    459526 - Databus
                        Reset counter: 41
                        Mileage: 60001 km
                        Date: 2019.12.09
                        Time: 14:02:01
       Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H34 0236
       Serial number: 02001705300925
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EDCA490E1518BBFD5-802A
       Component: WWS    170124  043 0551
       Serial number:         170204055822
       Component: RLHS  042 0105
       Serial number: S4Y17M03D02H19M51S30
       Coding: 00A8DD
       Serial number: 000000000ZY170321QM8
       Serial number: 00000000000068369376
       Sun Roof:
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST001FU3CP00000
       Coding: 181901
    939534 - Humidity sensor
              B1281 04 [009] - Internal System Fault
                        Reset counter: 41
                        Mileage: 60001 km
                        Date: 2019.12.09
                        Time: 14:00:06
       Part No SW: 5QA 919 294 A    HW: 5QA 919 294
       Component: PDC 8 KanalH07 0038
       Serial number: 000308418617058
       Coding: 0471155011
       ASAM Dataset: EV_EPHVA18AU3700000 009031
       VCID: 4AB43840ED19F71F39-801E
       Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
       Coding: 330067C15DFFC728949C810580400600000000000000000000
       VCID: 3C586E98B7CD59AFBB-8068
       Part No SW: 5Q0 959 655 AS    HW: 5Q0 959 655 AS
       Component: AirbagVW21    003 0317
       Serial number: 003TMR2MRH3N
       Coding: 98FCC0C0000000005C5400CF000800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 1106EF2CC0CF84C738-8044
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169667E23021740626
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169668E23021741286
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 002 502 17
       Serial number: 357000000003318CE12G
       Subsystem 4 - Part No SW: -----------    HW: 480 002 402 17
       Serial number: 35800000000DBAECB124
       Subsystem 5 - Part No SW: -----------    HW: 480 401 502 17
       Serial number: 3510001AF2537333839
       Subsystem 6 - Part No SW: -----------    HW: 480 401 702 17
       Serial number: 3520001BD2537332C2B%
       Subsystem 7 - Part No SW: -----------    HW: 480 402 102 17
       Serial number: 35500019F24542C5454%
       Part No SW: 5Q0 953 507 JD    HW: 5Q0 953 549 D
       Component: Lenks. Modul  004 0140
       Revision: --------    Serial number: 22021704400926
       Coding: 0C30
       VCID: 0126DF6C90AFF447A8-8054
       Part No SW: 5G1 920 791     HW: 5G1 920 791
       Component: KOMBI         408 2180
       Coding: 07A401086F8C000801886B0B5400000080000000
       Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
       Component: STH-MQB       008 0075
       Coding: 9309
       VCID: 3A546880BDF9679FA9-806E
       Component: R64 D208L  004 0401
       Serial number: 00000000000000193952
       Part No SW: 3Q0 907 530 C    HW: 3Q0 907 530 C
       Component: GW MQB High   418 4286
       Revision: --------    Serial number: 0005997816
       Coding: 030100045F086800FB00025E1C0F00010001050000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 2F4249D476BBB2370E-807A
       Serial number: 29170000424190027072
       Coding: 2FFFFF
       Serial number: 4113133204
       Serial number: 0430447012
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       Component: HRE_Slave  H12 0071
       Serial number: 0429724314
       Coding: 020111
       Serial number: 300117EAU14611
       Coding: 003B0220D000048000001000
       VCID: 43AA1564CA332657FA-8016
       Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000013604576
       Coding: 110000
       Coding: 9107
       ROD: EV_SteerAssisMQB_013.rod
    Address 4B: Multifunc. Module
    Interface not compatible.
       Serial number: 040217EB327884
       Coding: 003B0020DE00048000801000
       VCID: 42A41060D5292F5FF1-8016
       Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000013522770
       Coding: 090000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 5NA 035 042     HW: 5NA 035 042
       Component: MU-H-LN-EU    H51 0913
       Serial number: A847B0HB003164
       Coding: 02731001FF00000051110001000808101F0100F4012004009F
       VCID: 72C480A0A509DFDFA1-8026
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H40 9077
       Serial number: VWZ6ZFT0551156
       Subsystem 2 - Part No SW: V03 959 806 FN    HW: -----------
       Component: ECE 2020  --- 0184
       Component: Gracenote2  --- 1015
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 26021711P21435
       Coding: 0003070000000401002223548050A90098000E300040
       VCID: 3B5A6D84B2C35E97B2-806E
    End-------------------------(Elapsed Time: 03:53)--------------------------
    HVAC is upset about the humidity sensor, same as the BCM.
    Jun 2016
    Hello uwe,
    so a new humidity sensor must solve the problem? the car has been disconnected the battery for 1.5 months.
    it might just be that it goes away after a few days??
    Quote Originally Posted by barstanders View Post
    Since the BCM explicitly calls out an "internal fault" in the sensor, I would say the chances of this are good.
    I doubt it, but since you have a long warranty period remaining, there's not much downside to waiting a few days, right?
    Jun 2016
    Hello Uwe,
    Thank you verry much for your answer. i will wait 1 week.
