Results 1 to 10 of 20
Thread: Headlight Range (J431), Can someone decipher these codes for me?
    Jul 2019
    Malaysia
    Hi I got these codes which won't go away and the adaptive light in the dashboard is always on.
    The two codes relating to this headlight range fall under 2 addresses:
    1. Address 09: Cent. Elect. (J519)
    01771 - Control Module for Headlight Range (J431)
    013 - Check DTC Memory
    Fault Status: 01101101
    Reset counter: 33
    Mileage: 167382 km
    Date: 2019.11.29
    Time: 17:28:00
    2. Address 55: Headlight Range (J431)
    0061 - Function Restriction due to Implausible Message(s)
    U1112 00 [137] - -
    [Fehlerhafter DLC der CAN-Messages Kamera_Status (0x318)]
    Reset counter: 33
    Mileage: 167382 km
    Date: 2019.11.29
    Time: 17:28:52
    Can someone tell me what is these codes are trying to say. It hard for me since no faulty parts is mentioned. Most of the 01771 codes I've read will show some faulty parts (like the level sender) to be replaced. This adaptive light in the instrument cluster has been an eye sore for months. Your help is appreciated. The full scan is below.
    Friday,29,November,2019,17:32:50:34670
    VIN: WAUZZZ4G9BN031X10   License Plate:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 52 53 55
              56 5F 62 6C 72 85 8F 90
    VIN: WAUZZZ4G9BN031X10   Mileage: 167382km-104006miles
    Address 01: Engine (J623-CGWB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 907 551     HW: 4H0 907 551
       Component: 3.0l V6 TFSI  H05 0007
       Revision: --H05---
       Coding: 0A250034052701020000
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TFS0214G0907551 002010
       ROD: EV_ECM30TFS0214G0907551_002.rod
       VCID: 6695B5FFE8EFBBD753B-8032
    Readiness: 0110 0001
       Part No SW: 4G0 927 156 M    HW: 0B5 927 156 F
       Component: 0B5 30TFSIRdW H10 0024
       Revision: --H10---    Serial number: 0000000785
       Coding: 000001
       Shop #: WSC 04940 001 00001
       ASAM Dataset: EV_TCMDL501 A02196
       ROD: EV_TCMDL501.rod
       VCID: 363525BFF8CF0B5723B-8062
       Part No SW: 4G0 907 379     HW: 4G0 907 379
       Component: ESP PREMIUM   H08 0190
       Coding: 44A687002265E100DB00
       ASAM Dataset: EV_ESPPremiAU57X 003013
       ROD: EV_ESPPremiAU57X_003.rod
       VCID: 6E85CDDFC01F73972BB-803A
       Part No SW: 4H0 907 064 AP    HW: 4H0 907 064 AP
       Component: BCM2 2.0      H24 0217
       Coding: 05B82F00000000000000
       VCID: 77ABE8BBBFC5325FF8D-8022
       Serial number: 2311000097450009
       Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
       Component: KLIMA 4 ZONEN H11 0056
       Serial number: 06051100040574
       Coding: 6621007824
       ASAM Dataset: EV_AirCondiComfoUDS 002029
       VCID: 270BF8FB2F6562DFA8D-8072
    0379 - Supply Voltage Terminal 30 for Coolant Pump
              B11D5 01 [009] - Electrical Failure
                        Reset counter: 33
                        Mileage: 167382 km
                        Date: 2019.11.29
                        Time: 17:28:49
                        Voltage terminal 30: 12.45 V
                        Outside air temperature: 32.5 °C
                        Interior temperature: 35.37 °C
       Part No SW: 4H0 907 063 N    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0092
       Revision: 20012002    Serial number: 00000001044197
       Coding: 0200201050B49FE0C181008380001908CF9DC3082F080101000008402100
       VCID: 33331CABEB3D1E7F045-8066
       Component: WWS57X 110404  H35 0051
       Serial number:         110407090850
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11418017
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 22 04 2011  00000235
       Serial number: 5228C6A5000000000001
                        Reset counter: 33
                        Mileage: 167382 km
                        Date: 2019.11.29
                        Time: 17:28:00
       Part No SW: 4H0 919 475 J    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0032
       Revision: 11001001    Serial number: 55901107004778
       Coding: 300306
       Shop #: WSC 00097 210 98728
       ASAM Dataset: EV_EPHVA18AU57X0000 001002
       ROD: EV_EPHVA18AU57X0000_001.rod
       VCID: 392F2E83C9D1E42FCE9-806C
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG002BRPH
       Coding: 30323436313330303631554A305234473053
       Serial number: 3575HRB404T0HM766GDR
       Serial number: 3585HRB405H0H0LUC8R2
       Serial number: 3515JRB405D0H4DU9P4N
       Serial number: 3525JRB405F0G944N0G$
       Serial number: 3554VRB40630GR36HOS5
       Serial number: 3564VRB405D0GR36IHD.
       Revision: 00000000    Serial number: 20110505000939
       Coding: 000034
       VCID: 303913A71A2B2567797-8064
       Component: E221 - MFL  H07 0009
       Part No SW: 4G8 920 981 A    HW: 4G8 920 981 A
       Component: TBenGb        H34 0312
       Revision: 19100074    Serial number: 658020411593026
       Coding: 33A709000B012600010000
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K_AU57.rod
       VCID: 313F16A311A12C6F769-8064
       Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0204
       Revision: --------    Serial number: 00000000141378
       Coding: 00CD073000
       ROD: EV_GatewUDS_AU57.rod
       VCID: 303913A71AAB2567797-8064
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650387009
       Voltage stabilizer:
       Serial number: 11130001538021200181
       Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
       Component: KLIMA FOND    H07 0056
       Serial number: 06051100040012
       Coding: 02
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
       VCID: 2F3B10DB07953A9F60D-807A
       Component: MEM-FS        H03 0153
       Revision: AA000000    Serial number: 00000006129999
       Coding: 00781B0000006001000001010101102030303232203232
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0004
       Revision: --------    Serial number: EJ1BPA4200UA850
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D070AD30D99488F521-8078
       Part No SW: 4G8 959 793 C    HW: 4G8 959 793 A
       Component: TSG FA        H04 0210
       Coding: 011F16205E01628002080002
       Shop #: WSC 02312 785 00200
       VCID: 40D94367AA8BB5E7897-8014
       Component: RCEPS         H33 0010
       Revision: 00001000    Serial number: 0010073316
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323D19AF14A717770F3-8066
       Revision: 00002001    Serial number: 0149428872
       Coding: 011B0E2200B9048183300804080100000000000000000000000000000000
    01134 - Alarm Horn (H12)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 33
                        Mileage: 167382 km
                        Date: 2019.11.29
                        Time: 17:28:50
       Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
       Component: TSG BF        H04 0210
       VCID: 3FDB409BD775CA1FF0D-806A
       Revision: --------    Serial number: 00000000070722
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A0D01CF3C775FB7B73-807E
    Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
       Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
       Component: ....AFS13.... H01 0012
       Serial number: 110502-0004-033
       Coding: 1121A633F918EB00
       ASAM Dataset: EV_AdvanFrontSyste 005001
       ROD: EV_AdvanFrontSyste_AU21.rod
    H02 0008
       Coding: 1D0000
    H02 0008
       Coding: 1D0000
              U1112 00 [137] - -
                        Reset counter: 33
                        Mileage: 167382 km
                        Date: 2019.11.29
                        Time: 17:28:52
       Part No SW: 4G0 035 056 A    HW: 4G0 035 056
       Component: Radio U STD   H52 0050
       Revision: AB001007    Serial number: 051EY0B7516476
       Coding: 010003020100000001
       VCID: 1F1BE01B77B5AA1FD0D-804A
       Part No SW: 4G0 035 670 B    HW: 4G0 035 670
       Component: H-BNT-EU      H46 0239
       Revision: --------    Serial number: 428EX0B7514227
       Coding: 050101000003E1EF45108B3E000000030000010000000000
       VCID: 221DE9EF44C787F7FF3-8076
       Subsystem 1 - Part No: 8R0 060 884 N
       Component: EUR 2011  1205
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Serial number: AUZ8ZDB1300QPJ1
       Subsystem 3 - Part No SW: 4G2 919 612 L    HW: 4G2 919 612 L
       Component: E380 BDT C7  H08 0120
       Serial number: 90349KDT0007U
       Component: CD-Database  2712
       Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
       Component: TSG HL        H03 0210
       Coding: 010F14204001628002080002
       VCID: 42DD496FA487A7F79F3-8016
       Part No SW: 4G0 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0050
       Revision: --H04---    Serial number: 525 PA8J14F0S1
       Coding: 1020004
       VCID: 2517F2F359E970CF9A1-8070
       Component: TSG HR        H03 0210
       Part No SW: 4G0 907 217     HW: 4H0 907 217 A
       Component: DPC-SG        H24 0034
       Coding: 64040000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 6597B2F315E9B0CF5A1-8030
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 00060000031F030000030800424CDA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 6FBBD0DBC7157A9F20D-803A
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70B9D3A7DA2B6567397-8024
    End----------(Elapsed Time: 02:06, VBatt start/end: 12.5V/12.5V)-----------
    Thank you.
    A6 C7 4G 3.0 TFSI
    The 55- Headlight Range module is unhappy about something with 85 - On Board Cam. (J852), but it is not clear what.
    ^^^^ coconutaudi: Hi. If I might add to Uwe's observation - perhaps look at the records in CodingLog.CSV and AdpLog.CSV files in the C:\Ross-Tech\VCDS\Debug directory on the laptop that you use for VCDS for any changes that were made to the car on 29th November 2019 @ about 5:30 PM.
    Jul 2019
    Malaysia
    Uwe, up until now, I don't even realize that I have an onboard camera in my car, especially since I don't have this lane departure warning system or any system that uses an onboard camera. Not to my limited knowledge at least. So it is baffling as to how these two J431 and J852 are related. Maybe we can explore further from this info.
    Nevertheless thank you for the info.
    Jul 2019
    Malaysia
    Hi Don, no changes was made on the 29th Nov @ 5.30pm. The only change I've made was on 27th Nov when I changed the battery serial number because I've replaced the battery. And this headlight range problem has been bugging me for months.
    Well if you didn't NIX the VIN we could of checked that.
    WAUZZZ4G9BN031X10 <<<<<<<<<<< INVAILD
  7. #7
    Verified VCDS User Gremling's Avatar
    Dec 2017
    Norway, Nordland
    Hi, In your service folder, first page(s), in the rows with many 3 letter/numbers, does one combo say 8Q3?
    I think the cam is used by the Auto dimming/full light function (AFS).
    Have you checked wiring to level sensors on drivetrain pressune left side front and rear? Also check fuse 8 in fuseholder C, this is J745 control module for corn light and headlight range control. Which also has CAN hi&lo
    Regards
    Gremling
  8. #8
    Jul 2019
    Malaysia
    Noted. Thank you.
  9. #9
    Jul 2019
    Malaysia
    Quote Originally Posted by Gremling View Post
    Regards
    Gremling
    Hi Gremling,
    I've checked and my options didn't include 8Q3. I found the list in the spare tire compartment. But I noticed my car has AFS13 stated in address 55 along with EV_AdvanFrontSyste, if indeed they are the same thing as the AFS you've mentioned. As suggested I will check fuse 8 in fuseholder C along with the fuse for the onboard camera (fuse 11 on fuseholder B) as there might be problem as pointed out by Uwe. As for the level sensors, I will check them too once I can get the car lifted.
    Thank you for the suggestions. I will update you guys.
    Thank you.
  10. #10
    Jul 2019
    Malaysia
    So I've checked the followings
    1. the fuse for the headlight range control J431 and it is good (fuse 8 in fuseholder C passenger side)
    2. the fuse for the onboard camera which is also ok (fuse 11 on fuseholder B driver side)
    3. the front left level sender (G78). No corrosion, wires are intact, no water ingress
    4. the rear left level sender (G76). No corrosion, wires are intact, no water ingress
    Those are the things which I have ruled out as being the source of the problem.
    What is the next step? I'm thinking of replacing the headlight range control unit J431 next. My questions are:
    1. Can I just swap the new J431 with the old one (part no 4H4 907 357 A)?
    2. Do I need to code the new J431 unit and how do I go about it using the VCDS.
    3. I've noticed that under address 55 there is Coding: 1121A633F918EB00. Is this the code we need to enter to the new unit?
    Thanks a lot in advance.
    Regards
