Results 1 to 8 of 8
Thread: MK6 Jetta TDI - Rear Door Control Module - No access
    Dec 2019
    India
    Hi , Own a Jetta 2015 TDI , Highline Version . retrofitting door exit / warning lights , Front doors coding completed and its working good , However rear doors i am not getting access to 62 and 72 modules . Read the forum where it says access to rear doors might be from the front door modules. However when i tried to select the second module from drop down it gives error as below
    https://ibb.co/sjnZvLk
    https://ibb.co/mGKcH39
    Thanks,
    Ranjith
    We need you to post a full unedited Auto-Scan not just a screenshot.
  3. Likes Uwe liked this post
    Dec 2019
    India
    here you go
    Tuesday,10,December,2019,19:09:28:64981
    VIN: WVWF15168FA551268   License Plate:
    Mileage: 44930km-27918mi   Repair Order:
    Chassis Type: 16-VW32 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
              77
    VIN: WVWF15168FA551268   Mileage: 44930km-27918miles
    Address 01: Engine (J623-CLCB)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 TC    HW: 03L 907 309 R
       Component: R4 2.0l TDI   X25 9978
       Revision: 42X25---    Serial number: 00000000000000
       Coding: 001D0012042500080000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20TDI01103L906018TC 003005
       ROD: EV_ECM20TDI01103L906018TC.rod
       VCID: 7EA5FF391078A8A7BBB-802A
       Part No SW: 02E 300 062 B    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 4014
       Revision: 05653104    Serial number: 00001503230951
       Coding: 0000024
       VCID: 1471BD91027452F77DF-8040
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Revision: 00H46001
       Coding: A63B40F8092700FB650D02EA90210082A1100010
       Shop #: WSC 00047 000 00000
       VCID: 04518DD17E14C277EDF-8050
       Part No SW: 1K8 907 044 AJ    HW: 1K8 907 044 AJ
       Component: Climatronic   H05 0202
       Revision: 00001K02
       Coding: 001001A002
       Shop #: WSC 00047 000 00056
       ROD: EV_ClimaAutoBasis_VW32.rod
       VCID: 77ABEA1D3F4299EFF8D-8022
       Part No SW: 5K0 937 087 AC    HW: 5K0 937 087 AC
       Component: BCM PQ35 H+   122 0174
       Revision: BF122001
       Coding: 26000A3AD82F00D440080080240089EC0174000871A08120E4C400000040
       Shop #: WSC 00066 123 12345
       VCID: 76B5E71938C8E0E7E3B-8022
       Component: RLS 311014 05  54  0403
       Coding: 02300A
    00061 - Footwell Lights
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 7
                        Reset counter: 127
                        Mileage: 44891 km
                        Date: 2019.12.08
                        Time: 10:43:52
                        Voltage: 12.25 V
       Part No SW: 1K8 919 472 A    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0477
       Revision: --------    Serial number: 39391506500490
       Coding: 0001090011
       Shop #: WSC 00047 000 00051
       ASAM Dataset: EV_EPHVA18VW364GP00 001006
       VCID: 3537201565CEABFF2A1-8060
       Part No SW: 5C0 959 655 F    HW: 5C0 959 655 F
       Component: AirbagVW10    014 0613
       Serial number: 003JQM064DX/
       Coding: 00005047
       ROD: EV_AirbaVW10SMEVW360.rod
       Serial number: 3572MSME73770C4FZZZ5
       Serial number: 3582MSME27770C4FZZZ5
       Serial number: 3516KSME17525035ZZZH
       Serial number: 3526KSME7B395635ZZZ$
       Part No SW: 1K5 953 521 BL    HW: 5K0 953 569 AD
       Component: LENKS.MODUL   016 0162
       Revision: FF010042    Serial number: 20150311100173
       Coding: 0892440008
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 78A9E921325C9697F17-802C
       Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
       Serial number: 3311422565702344AC1B
       Coding: 290000
       Part No SW: 5C6 920 874 A    HW: 5C6 920 874 A
       Component: KOMBI         H05 0906
       Coding: 171F00
       VCID: 2D0708758D9EE33F521-8078
       Part No SW: 7N0 907 530 AP    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1653
       Revision:   H57       Serial number: 250514F1000346
       Coding: 351003
       VCID: 7EA5FF3910F8A8A7BBB-802A
       Component: IMMO          H05 0906
       VCID: 6A8DC3697CF03407773-803E
    Address 2E: Media Player 3
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Revision: 12110009    Serial number: 0009312858
       Coding: 0496F7
       Shop #: WSC 00047 123 00051
       VCID: 1C61D5B1E6241AB735F-8048
       Slave Driver:
       Subsystem 1 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Serial number: 14102586150211095945
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 70     3501
       Revision: 00H22000
       VCID: 392F2C2545564F9FCE9-806C
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Revision: 14110009    Serial number: 0009316476
       Coding: 0417F6
       VCID: 1D67D8B5FD3E13BFC21-8048
       Slave Passenger:
       Subsystem 1 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Serial number: 14102587150216065906
       Component: AFS-ECU       H04 0111
       Coding: 081600000B000200
       Shop #: WSC 01383 790 50316
       ROD: EV_HeadlRegulVWAFSPt_VW32.rod
       VCID: 372B2A1D7FC259EF38D-8062
       Subsystem 1 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
       Subsystem 2 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
       Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
       Component: MIB2-S-R-CN   036 0318
       Revision: -----001    Serial number: VWZ6Z2R7429649
       Coding: 16000441000006
       Shop #: WSC 00081 790 00118
       VCID: 46D557D908A83067B3B-8012
       Part No SW: 5N0 035 729 D    HW: 5N0 035 729 D
       Component: TELEFON       H07 0593
       Revision: 1B001001    Serial number: 00007670215596
       Coding: 0A01000080010101
       ROD: EV_UHVUMI.rod
       VCID: 313F140591A687DF769-8064
    9457427 - Left audio channel for speech/telephone
              B104F 13 [024] - Short to GND
              Intermittent - Confirmed - Not Tested Since Memory Clear
                        Reset counter: 123
                        Mileage: 44891 km
                        Date: 2019.12.08
                        Time: 09:50:01
    9457171 - Right audio channel for speech/telephone
              B104E 13 [024] - Short to GND
                        Reset counter: 123
                        Mileage: 44891 km
                        Date: 2019.12.08
                        Time: 09:50:01
    End----------(Elapsed Time: 01:00, VBatt start/end: 12.8V/12.6V)-----------
    Yep, the rear door modules are definitely sub-systems of the fronts.
       Coding: 0496F7
       Slave Driver:
       Coding: 0417F6
       Slave Passenger:
    I don't recall having seen a coding chart for those modules.
    Dec 2019
    India
    Can you please guide on what could be the option to turn on foot well lights at rear doors .
    Quote Originally Posted by ranjithrnair View Post
    Sorry, but I have no personal experience with such a retrofit.
    Dec 2019
    India
    A slight correction, it’s door exit lights I meant to say.
    Thanks ,
    Ranjith
  9. #8
    Feb 2018
    Just Code zur Front Doors ecu should be enough
