Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Audi A4 CGLC limp mode
    Jun 2019
    Hi all
    Just had a fault crop up on my 2012 A4 CGLC Quattro where it drops into limp mode and throws the ESC Light on with a flashing Glow plug light.
    Plugged it in when I got home and seen there was a few fault codes on the Sensor Reference Voltage B - Open Circuit.
    When the fault comes on, either running or sat with ignition on, the revs increase to 1000rpm over standard 750rpm and the lights mentioned above illuminate. Theres also a change in engine note and engine is pretty shuddery when stopping. Upon restarting, it can often turn over a couple turns rather than firing up straight away.
    Only things done to the car is a ECU remap and a EGR blank (remapped due to EGR throwing codes up causing limp about 2 years ago and been perfect since)
    Ive included a full VCDS scan below for reference.
    Any help appreciated.
    Chris
    Sunday,08,December,2019,15:50:50:09611
    VCDS Version: 19.6.1.0
    VIN: WAUZZZ8K9Dxxxxx   License Plate: CHSSCFULL
    Mileage: 103950km-64591mi   Repair Order:
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72 77
    VIN: WAUZZZ8K9DA01xxxxx   Mileage: 103950km-64591miles
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 JH    HW: 03L 906 018 JL
       Component: R4 2,0L EDC   H25 2903
       Revision: 45H25---
       Coding: 0A194012242601080000
       Shop #: WSC 06324 000 00000
       ASAM Dataset: EV_ECM20TDI01103L906018JH 003003
       ROD: EV_ECM20TDI01103L906018JG.rod
       VCID: 79F303EDF8FCD987DE-802C
              U1113 00 [032] - -
                        Mileage: 103925 km
                        Date: 2019.12.08
                        Time: 13:20:13
                        Engine speed: 1778.50 /min
                        Normed load value: 5.5 %
                        Vehicle speed: 90 km/h
                        Coolant temperature: 85 °C
                        Intake air temperature: 12 °C
                        Voltage terminal 30: 14.700 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 129
                        Cruise Control System (CCS): status-Bits 0-7: 232
                        Cruise control switch-off: irreversible-Bits 0-7: 4
                        Cruise control switch-off: reversible-Bits 0-7: 15
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 16
    4124 - Sensor Reference Voltage B
              P0651 00 [032] - Open Circuit
                        Mileage: 103925 km
                        Date: 2019.12.08
                        Time: 13:20:12
                        Engine speed: 1745.00 /min
                        Normed load value: 60.8 %
                        Exh.gas temp.sen 1: 485.0 °C
                        Exh.gas temp.sen 2: -0.0 °C
                        Exh.gas temp.sen 3: 342.2 °C
                        Exh.gas temp.sen 4: 287.6 °C
                        Shut-off timer: last engine shut-off time: 719 s
    Readiness: 0 0 0 0 X
       Part No SW: 8K0 907 379 CJ    HW: 8K0 907 379 CJ
       Coding: 181544
       Shop #: WSC 06325 000 00000
       VCID: 030F61058230935784-8056
       Part No SW: 8K0 907 064 FE    HW: 8K0 907 064 FE
       Component: BCM2 2.0      H10 0602
       Coding: 03B10000000000000000
       VCID: 78F506E9CBF6C08FA1-802C
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0812000007530014
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Serial number: 2312000002761004
    00956 - Key 2
                        Reset counter: 234
                        Mileage: 102524 km
                        Date: 2019.10.06
                        Time: 09:57:04
       Part No SW: 8K2 820 043 AC    HW: 8K2 820 043 AC
       Component: KLIMA 3 ZONEN H04 0122
       Revision: D0000000    Serial number: 01310120121717
       Coding: 342402E000
       VCID: 6AD12CA1855A621F27-803E
                        Fault Status: 00101101
                        Fault Frequency: 14
                        Reset counter: 3
                        Mileage: 103925 km
                        Date: 2019.12.08
                        Time: 13:20:13
                        Temperature: 7.0°C
                        RPM: 1800 /min
                        Speed: 90.0 km/h
       Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 AG
       Component: BCM1 1.0      H14 0103
       Revision: 07014001    Serial number: 00000025901802
       Coding: 260000118034AFC00081400000001D0D401D030827090201000008000400030100000024000000
       Shop #: WSC 00783 210 84012
       VCID: 77F705D5C6E8CFF7A8-8022
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 250112  H06 0070
       Serial number: SWF12010250214
       Coding: 00FD11
       Component: G397_RLFS  H06 0001
       Serial number: 20131050
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001901123251
       Serial number: 87488C06000000000001
       Serial number: 003KFD90MJ6L
       Coding: 30534435363030303030554A3052384B3053
       Shop #: WSC 63301 000 1048576
       VCID: 4895B629F396700F11-801C
       Serial number: 6334MSME6A12397DO
       Serial number: 6344MSME6A133544A
       Serial number: 6352QSME56693146H
       Serial number: 6362QSME0B6A124CO
       Serial number: 63732SME17683C50+
       Serial number: 63832SME17683376+
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20120130001213
       Coding: 000016
       VCID: 4FA79D351EF8A73750-801A
       Component: E221 - MFL  H03 0003
       Part No SW: 8K0 920 982 B    HW: 8K0 920 982 B
       Component: KOMBIINSTR.   H16 0640
       Revision: 00100000    Serial number: M3B32GNDC
       Coding: 331D090002012600010001
       Shop #: WSC 06325 123 12345
       VCID: 336FF1C59210E3D754-8066
       Part No SW: 8R0 907 468 A    HW: 8R0 907 468 A
       Component: GW-BEM 5CAN   H10 0025
       Revision: 1V040013    Serial number: 1341V12118863C
       Coding: 00CF07FF00
       VCID: 3D7BD7FDA45425A7B2-8068
       Serial number: 7388956501
       Serial number: 12029000864021200410
                        Reset counter: 252
                        Mileage: 103355 km
                        Date: 2019.11.29
                        Time: 14:18:06
                        Bin. Bits:    10111
                        Voltage: 11.20 V
                        Count: 6
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020202
       VCID: 3973C3EDB07C19879E-806C
       Part No SW: 8T0 959 793 F    HW: 8T0 959 793 H
       Component: TSG FA        H09 0302
       Coding: 011002204001410001
       VCID: 4C9D8A39EFEE9C2F35-8018
       Component: RCEPS         H36 0507
       Revision: 00001000    Serial number: 0021322952
       Coding: 100000000001
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 346DF2D99F1EE4EF4D-8060
    16400 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 244
                        Mileage: 102164 km
                        Date: 2019.09.04
                        Time: 17:22:10
                        Write only channel
    2305 - Function Restriction due to Start Voltage Interruption
              U1410 00 [008] - -
                        Reset counter: 244
                        Mileage: 102164 km
                        Date: 2019.09.04
                        Time: 17:22:09
                        Write only channel
    2306 - Function Restriction due to Start Voltage Interruption
              U1410 00 [008] - -
                        Reset counter: 3
                        Mileage: 103370 km
                        Date: 2019.12.02
                        Time: 12:10:15
                        Write only channel
       Revision: 00002001    Serial number: 0168526440
       Coding: 011F062200B900408020013680000000
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
       Part No SW: 8T1 035 223     HW: 8T1 035 223
       Component: DSP Prem      H04 0040
       Revision: 00004001    Serial number: 94804001211301
       Coding: 0203010302
       VCID: 6CDD2AB98FAE7C2F55-8038
    02247 - Subwoofer (R148/R157)
                        Reset counter: 9
                        Mileage: 91922 km
                        Date: 2018.09.18
                        Time: 14:17:06
                        Voltage: 12.70 V
                        Temperature: 38.0°C
                        Temperature: 39.0°C
                        Bin. Bits: 00000100
       Part No SW: 8T0 959 792 H    HW: 8T0 959 792 H
       Component: TSG BF        H08 0302
       Coding: 011002204C01410001
       VCID: 4D9B873D14F4952722-8018
       Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
       Component: EPB-4         H01 0001
       Revision: --------    Serial number: 00000000017259
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3669C8D18962F6FF73-8062
    721152 - Brake Pad Replacement Mode Active
              C1011 00 [000] - -
    464128 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 218
                        Mileage: 103925 km
                        Date: 2019.12.08
                        Time: 13:20:13
                        Voltage terminal 30: 14.9 V
                        Internal Fault ID: 187
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
                        Internal Parking Brake state: Dynamic
    464384 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 218
                        Mileage: 103950 km
                        Date: 2019.12.08
                        Time: 15:47:40
                        Voltage terminal 30: 11.8 V
                        Internal Fault ID: 188
                        Function light in parking brake button: On
                        Red operating lamp: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Status ParkingBrake left: Set
                        Status ParkingBrake right: Set
       Part No SW: 8R2 035 186 A    HW: 8R2 035 186 A
       Component: Concert3 DAB  H05 0440
       Revision: 00000005    Serial number: AUZ5Z6L1694807
       Coding: 0403008201018D00875B070800
       VCID: 346DF2D9971EE4EF4D-8060
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
                        Fault Frequency: 40
                        Reset counter: 252
                        Mileage: 99435 km
                        Date: 2019.04.06
                        Time: 13:13:59
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
       Part No SW: 8T0 959 795 H    HW: 8T0 959 795 H
       Component: TSG HL        H07 0302
       Coding: 010002204001210001
       VCID: 50A59E4903C6B8CF49-8004
       Component: TSG HR        H07 0302
       Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005465496
       Coding: 0010320
       VCID: 3D7BD7FD645425A7B2-8068
    End-------------------------(Elapsed Time: 03:45)--------------------------
    My guess is that limp mode is due to P0651 in the ECU, but that fault is flagged "Intermittent - Not Confirmed", which is usually an indication that the not the cause of any significant issues.
    There are a lot of old faults in this car. Suggestion: Please clear fault codes in all modules (do it one module at a time in each module that has fault codes if necessary), then let's see what comes back. This will give us a much better signal to noise ratio.
    Jun 2019
    Hi
    Thanks for your reply.
    Cleared the codes and the only ones to come back were the 2 in the engine module, the one in the ABS for fault in another module and also the same fault in the Auto HVAC module.
    I just cant see what would be causing it to trip out. Sometimes it will run ok, then other times it'll drop back into limp very quickly.
    Usually open circuits would show at least one sensor that would show as being open.
    Chris
    Hello Chris and welcome to the VCDS forum!
    Did you know I have found that many things have been reported to cause such codes and not just a sensor but a bad ground, feed power or terminal relay, load device running interference as a false positive DTC or just plain faulty harness?
    In cases like this did you know I first unplug engine side harness connector and see if DTC vacates in VCDS, this lets me know if DTC still exists I have issue st ECU or feed of ECU, than verify output ref voltage, further than verify I can manipulate DTC with decade box in VCDS as expected, than further use a load light to first qualify all tracks isolated?
    JPPSG
    Jun 2019
    I spied a video on youtube about a guy with a similiar issue....
    https://www.youtube.com/watch?v=OBQkQW0v6Ak
    That guy has a 2.0 CR (in a transporter) so probably very very similar engine and said theres a few components that share the same 5V regulated rail. Crank sensor (probably explains why it takes a few seconds to start occasionally) Fuel rail pressure sensor (not sure how I can link that one to engine running to begin) Intake air flap control actuator (probably explains the poor shutdown of engine if its the same valve that autodata describes...shut off valve), EGR actuator flap (thinking could be the issue due to EGR being crap on these engines), and the turbo vane position sensor (wastegate? again not got a link to that one yet)
    Jun 2019
    Latest scan. Now showing a G28 crank sensor no signal fault with the EML
    Monday,09,December,2019,11:53:58:09611
    Mileage: 103960km-64597mi   Repair Order:
    VIN: WAUZZZ8K9DA014743   Mileage: 103960km-64597miles
       Revision: 45H25---
              U1113 00 [047] - -
                        Mileage: 103958 km
                        Date: 2019.12.09
                        Time: 09:13:02
                        Engine speed: 1455.50 /min
                        Normed load value: 17.3 %
                        Vehicle speed: 50 km/h
                        Coolant temperature: 63 °C
                        Voltage terminal 30: 14.620 V
                        Cruise control switch-off: reversible-Bits 0-7: 255
              P0651 00 [175] - Open Circuit
                        Mileage: 103958 km
                        Date: 2019.12.09
                        Time: 09:13:02
                        Engine speed: 1450.50 /min
                        Normed load value: 75.7 %
                        Exh.gas temp.sen 1: 175.4 °C
                        Exh.gas temp.sen 3: 185.8 °C
                        Exh.gas temp.sen 4: 183.4 °C
                        Shut-off timer: last engine shut-off time: 1791 s
    4087 - Engine Speed Sensor (G28)
              P0322 00 [032] - No Signal
                        Mileage: 103958 km
                        Date: 2019.12.09
                        Time: 09:12:53
                        Engine speed: 1639.00 /min
                        Normed load value: 25.5 %
                        Vehicle speed: 54 km/h
                        Coolant temperature: 62 °C
                        Intake air temperature: 14 °C
                        Voltage terminal 30: 14.560 V
                        Engine start: start synchronization: EPM_MODE_BACKUP_CRS
                        Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 60
    Readiness: 1 1 0 0 X
    Address 03: ABS Brakes        Labels: None
       VCID: 55AB6F5DBC24DDE79A-FFFE
    No Faults Found
       Coding: 342402E000
                        Fault Status: 01101101
                        Reset counter: 218
                        Mileage: 103950 km
                        Date: 2019.12.08
                        Time: 16:04:37
                        Temperature: 7.0°C
                        RPM: 920 /min
       Coding: 00FD11
       Coding: 02005D
       Coding: 000016
       Coding: 00CF07FF00
       Revision: 00000000
       Coding: 020202
       Coding: 0203010302
              U1113 00 [009] - -
                        Reset counter: 218
                        Mileage: 103958 km
                        Date: 2019.12.09
                        Time: 09:13:02
                        Voltage terminal 30: 14.8 V
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
       Component: Display
       Coding: 0010320
    End-------------------------(Elapsed Time: 05:02)--------------------------
  7. #7
  8. #8
    Dec 2019
    Canada
    You have access to a scope? Tap into the ref and see if it's being pulled low, or directly to ground.
  9. Likes Uwe liked this post
  10. #9
    Jun 2019
    Quote Originally Posted by PIVOT View Post
    No access to a scope unfortunately...just a trust old multimeter. I think ive worked out what sensors are on the voltage B line (MAP, crank, EGR, ASV, turbo wastegate, fuel rail pressure) so need to probe them at the +5V pin to see if its getting the right voltage when the fault isnt active, and what sensor is pulling it down when the fault occurs.
    Not sure if the no signal from crank sensor may be a red herring though as if its connected on the same part of the loom with the voltage B side, then it might not be getting its signals back to the ECU, thus ECU throws a error for it.
    Jack - not sure why the ABS is offline. Maybe the module didnt close down properly when I last accessed it so needs to 'reboot' to stop the communication error.
  11. #10
    Did you know the DVOM is just fine & a Scope is unneeded for this test path?
    Did you know usually a faulty harness at junction is the cause/chafe point or sensor/consumer & that sometimes isn't on the listed track in WD, this is why I unplug everything and work my way back to the DTC & while verifying each component DTC in VCDS is reset?
    Then did you know VCDS blocks can indeed show this type of fault trace with aid of decade box or just clearing and checking for DTC?
    Did you know once you isolate the respective tracks you can qualify it further by changing the DTC to check the ECU from OPEN to short to ground or B+ with a decade box too, this way you don't change an ECU by false diagnosis?
    All kinds of interesting questions huh?
    Did you try communication with the ABS directly?
    You mean back probe as per RTFB and not make holes in wires or damage insulation right?
