Results 1 to 3 of 3
Thread: Audi A3 E-tron 2016 crash shut-down active
    Jun 2019
    Norway
    Hello
    I have 2016 A3 E-tron involved in a car crash. As a result of this the hybridbattery got an error "26623 crash shut-down active"
    I have tryed to reset this error to be abel to move the car.I have tried to log into Hybrid battery and use securety axsess code 20103. The modul acept this .
    I went into basic settings and trye to perform "IDE 06504 Reset of reversible crash shut-of" but the result is: "ERROR: conditions not correct or request sequence error"
    Anyone have some idea how to do this??
    Tore
     Sunday,08,December,2019,10:49:21:18625
    Workshop Code: 000 00000 008060
    VIN: WAUZZZ8V5GA174455   License Plate: KJ24273
    Mileage: 55803km-34674mi   Repair Order: etter rep bak
    Chassis Type: 8V-AU37 (5QE)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 23 2B 42 44 51 52 55 5F
              75 8C BB BC C6
    VIN: WAUZZZ8V5GA174455   Mileage: 55803km-34674miles
    8C-Hybrid Battery -- Status: Malfunction 0010
    C6-Batt. Chrg. -- Status: Malfunction 0010
    Address 01: Engine (J623-CUKB)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 023 AF    HW: 04E 907 309 F
       Component: 1.4l TFSI hy  H22 2660
       Revision: X3H22---
       Coding: 021D0012632401083000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM14TFS01104E906023AF 005006
       ROD: EV_ECM14TFS_005.rod
       VCID: 649150103EDF33374DF-8030
    4527 - Coolant Fan Control Circuit 1
              P0480 00 [039] - Electrical Malfunction
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:04:12
                        Coolant temperature: -2 °C
                        Intake air temperature: 0 °C
                        Voltage terminal 30: 10.820 V
                        Outside air temperature: -2 °C
                        Absolute intake pressure: 100 kPa abs
                        Engine torque: 0.0 Nm
                        Fuel level: 27.00 l
                        E-machine torque actual value: 0.0 Nm
                        Operating mode control expanded electrical driving: Correct result
                        Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 1
                        High-volt. battery: charge state: abs. value: 48.09 %
    17161 - Databus
              U1123 00 [038] - Received Error Message
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:07:12
                        Voltage terminal 30: 11.460 V
                        Acceleration: 0.000 m/s²
                        Cruise Control System (CCS): status-Bits 0-7: 2
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                        Drivetrain coordinator: brake fault status-Bits 0-7: 0
    Readiness: 1110 0001
       Part No SW: 0DD 300 045 K    HW: 0DD 927 770 B
       Component: GSG DQ400E    H31 1121
       Revision: 00031033    Serial number: TFK01603180017
       Shop #: WSC 12344 003 1048576
       ASAM Dataset: EV_TCMDQ400021 001001
       ROD: EV_TCMDQ400021_VW41.rod
       VCID: 2F3BEF3C2799C06F60D-807A
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 907 379 AK    HW: 5Q0 907 379 H
       Component: ESC           H31 0809
       Revision: 00000000    Serial number: 61296000000363
       Coding: 12F140A238273270017B060541C82948021C4C80608294F402A100788608
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
       ROD: EV_Brake1UDSContiMK100OMG_001_AU37.rod
       VCID: 05576D94D5A5AA3FFA1-8050
       Revision: 00021000    Serial number: 0404588406
       Coding: 030C0C
       VCID: 3A2DCE68ECDB15C7C73-806E
       Part No SW: 8V0 820 043 G    HW: 8V0 820 043 G
       Component: AC Automat    H06 0040
       Revision: 20011000    Serial number: 00000000917285
       Coding: 0300000000000000000000000000100001000000
       ASAM Dataset: EV_AirCondiFrontRDWAU37X 001015
       ROD: EV_AirCondiFrontRDWAU37X.rod
       VCID: 3635DA58D8C3F1A723B-8062
       Subsystem 1 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
       Component: J848 HV-PTC  H09 0206
       Serial number: LM161353003807000273
       Component: AQ_Hum_Sensor  H01 0003
       Serial number: 3A594228000000000001
       Subsystem 3 - Part No SW: 12E 820 803 E    HW: 12E 820 803 E
       Component: J842 eKK  H02 0005
    459030 - Implausible Data Received From Electric A/C Compressor
              U046C 00 [047] - -
              [EKK - unplausibles Signal]
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:04:15
                        Unlearning counter according OBD-OBD Parameter: 40
                        Compressor shut-off requirement: Compressor activation: malfunction in activation path
                        Compressor status: global-A/C compressor release status: transmitted
                        Compressor status: global-A/C compressor: target speed: 0 /min
                        Compressor status: global-A/C compressor: actual speed: Measured value not available
                        Compressor status: global-A/C compressor: function status: Air conditioner compressor off
                        Compressor status: global-A/C compressor error indicator: not active
                        Compressor status: global-A/C compressor: veh. elec. syst. volt.: OK
                        Compressor status: global-A/C compressor: inverter temperature: Measured value not available
       Serial number: 01061614403934
       Coding: 04051B46C25122F5438C5004001C07A80800000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 04517090DE9F9337EDF-8050
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 160428  043 0580
       Serial number:         160511072159
       Coding: 0A47F7
       Serial number: 61865063
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
       Serial number: 19 01 2016  00002118
    7 Faults Found:
    10506 - Bulb for Left Tail Light
              B12BE 15 [009] - Open or Short to Plus
                        Reset counter: 42
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:06:49
    10762 - Bulb for Right Tail Light
              B12BF 15 [009] - Open or Short to Plus
                        Reset counter: 42
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:06:48
    11018 - Bulb for Left Brake Light
              B12C2 15 [009] - Open or Short to Plus
                        Reset counter: 42
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:07:09
    11530 - Bulb for Right Brake Light
              B12C3 15 [009] - Open or Short to Plus
                        Reset counter: 42
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:07:08
    18698 - Left LED Module for DRL and Parking Lights
              B12EC F2 [009] - Voltage Supply Open or Short to Plus
                        Reset counter: 42
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:06:49
    19210 - Right LED Module for DRL and Parking Lights
              B12ED F2 [009] - Voltage Supply Open or Short to Plus
                        Reset counter: 42
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:06:48
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 42
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:23:06
       Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0054
       Revision: --------    Serial number: 39231614603376
       Coding: 0000040011
       ASAM Dataset: EV_EPHVA14AU3700000 002024
       VCID: 3C21C870E6EF2BF7D5F-8068
    1080083 - Rear Parking Aid Sensor(s)
              B107B 13 [008] - Open Circuit
                        Reset counter: 42
                        Mileage: 55803 km
                        Date: 2019.11.23
                        Time: 13:24:28
              U1400 00 [008] - -
              [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                        Reset counter: 82
                        Mileage: 55803 km
                        Date: 2019.10.21
                        Time: 19:38:33
       Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
       Component: AirbagVW20    010 0870
       Serial number: 003MFR0265C6
       Coding: 98CCC0000C2000009C5400CA004800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 50F98CC05A67BF97197-8004
       Subsystem 1 - Part No SW: -----------    HW: 480 002 705 16
       Serial number: 3570000000045D7CBB1-
       Subsystem 2 - Part No SW: -----------    HW: 480 002 705 16
       Serial number: 3580000000023D7CBB1X
       Subsystem 3 - Part No SW: -----------    HW: 480 402 405 16
       Serial number: 3510002A52057292C25T
       Subsystem 4 - Part No SW: -----------    HW: 480 402 405 16
       Serial number: 3520002A5205729321ET
       Subsystem 5 - Part No SW: -----------    HW: 480 401 604 16
       Serial number: 3550002A920178D4029.
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: -----------
       Component: PedP_Sensor_D  --- ----
       Serial number: -------------------$
       Subsystem 7 - Part No SW: -----------    HW: -----------
       Component: PedP_Sensor_P  --- ----
       Subsystem 8 - Part No SW: -----------    HW: -----------
       Component: PedPSensor_D2  --- ----
       Subsystem 9 - Part No SW: -----------    HW: -----------
       Component: PedPSensor_P2  --- ----
    6 Faults Found:
    9439002 - Igniter for Seat Belt Tensioner; Passenger's Side
              B1007 1A [137] - Resistance Too Low
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:00:41
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:00:41
    9450005 - Pedestrian Protection Crash Sensor (driver's side)
              B1032 15 [137] - Open or Short to Plus
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:00:43
    9450261 - Pedestrian Protection Crash Sensor (passenger's side)
              B1033 15 [137] - Open or Short to Plus
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:00:43
    9735445 - Pedestrian Protection Crash Sensor 2; Driver Side
              B148D 15 [137] - Open or Short to Plus
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:00:47
    9735701 - Pedestrian Protection Crash Sensor 2; Passenger Side
              B148E 15 [137] - Open or Short to Plus
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:00:47
       Part No SW: 8V0 953 521 FB    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 29051604400438
       Coding: A418
       VCID: 7F5BFF7CB779F0EFB0D-802A
       Part No SW: 8V0 920 872 J    HW: 8V0 920 872 J
       Component: KOMBI         H03 6423
       Coding: 07240C182B8000080103A8101200000000000000
       VCID: 44D1B0909E1F5337ADF-8010
    Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
       Part No SW: 5QE 907 530 E    HW: 5QE 907 530 A
       Component: GW MQB EV     312 3245
       Revision: --------    Serial number: 10051610802110
       Coding: 0201001726F200005B001208580000000001010100010000000000000000
       ASAM Dataset: EV_GatewEVConti 013020
       ROD: EV_GatewEVConti_013.rod
       VCID: 48C9A4A0A2377757417-801C
       Subsystem 1 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
       Serial number: 14 05 2016  D0042036
       Subsystem 2 - Part No SW: 5QE 915 181     HW: 5QE 915 181
       Serial number: 7709298203
    8526354 - Generator
              P1B01 00 [008] - Electrical Malfunction
                        Reset counter: 82
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:04:47
                        Supply voltage: Terminal 30: 10.7 V
                        Terminal 15: On
    8526361 - LV Energy Management
              B1802 F1 [008] - Warning Triggered
                        Reset counter: 82
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:03:18
                        Terminal 15: On
    Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
       Part No SW: 8S0 857 511 C    HW: 8S0 857 511 C
       Component: FLA           H09 0003
       Revision: AA001001
       Coding: 0202000700000000000001
       ASAM Dataset: EV_HighBeamAssisAU33X 001017
       ROD: EV_HighBeamAssisAU33X_VW37.rod
       VCID: 392FD164E9DD1EDFCE9-806C
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
       Component: EBKV          H14 0182
       Serial number:   085430010181
       Coding: 03720100331902030002050500
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
       ROD: EV_BrakeBoostBoschMQBOMG_003_AU37.rod
       VCID: 4FFB8FBC4759A06F00D-801A
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0152
       Serial number: 05802861250416183804
       Revision: 00000000    Serial number: 16000091266010
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3431E050CEBFE3B71DF-8060
       Serial number: 050516EE123163
       Coding: 00109F204000040000001002
       VCID: 43D3B38C9B11540F945-8016
       Component: EPS_MQB_ZFLS  128 1072
       Coding: C106
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 45D7AD9495256A3FBA1-8010
    11776 - Supply voltage
              [Warnung vor dauerhaft zu geringer Versorgungsspannung Anzeige von Unterspannung]
                        Reset counter: 82
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:06:34
                        Motor status: 00
                        Supply voltage: 10.50 V
                        Temperature: 9.0 °C
                        KFC: 2E
                        KFA: 00 00
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 10.70 V
                        uAdSensI_SwitchedKl30_xdu16: 10.72 V
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: not activated
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 5G0 907 080 D    HW: 5G0 907 080 D
       Component: VW370P3815010 H07 4492
       Revision: 00H07000
       Coding: C0020000000000000000
       ASAM Dataset: EV_DMCM09550115G0907080D 001018
       ROD: EV_DMCM09550115G0907080D.rod
       VCID: 2809042002779757A17-807C
       Serial number: 080516EE717088
       Coding: 001097204000040000001002
       VCID: 42DDB688840B5D079F3-8016
       Coding: 011A000001000000
       VCID: 75B71D548545BABFEA1-8020
    5276949 - Positioning Motor for Headlight Range Left
              C1085 15 [137] - Open or Short to Plus
                        Reset counter: 42
    5277205 - Positioning Motor for Headlight Range Right
              C1086 15 [137] - Open or Short to Plus
                        Reset counter: 42
       Part No SW: 8V0 035 842 C    HW: 8V0 035 842 B
       Component: MU-S-D-ER     042 0461
       Serial number: A7E01904160151
       Coding: 01730300FF0A000011111101000A02002F0001040100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE.rod
       VCID: 372BD75CDFC908AF38D-8062
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9GY30JCSE
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
       Serial number: ALJAL123031600020051
       Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
       Component: OCULowMQBEU   012 0715
       Coding: 0173930110949A0100F800000000
       ROD: EV_OCULowMQB.rod
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 5Q0 915 182 E    HW: 5Q0 915 182 C
       Component: BECM          H05 1101
       Serial number: U1180034
       Coding: 00000000
       ASAM Dataset: EV_BECM09620115Q0915182 006042
       ROD: EV_BECM09620115Q0915182.rod
       VCID: 3537DD54C5C5FABF2A1-8060
       Battery Junction Box:
       Subsystem 1 - Part No SW: 5Q0 915 250 D    HW: 5Q0 915 250 D
       Component: BJB  H27 0240
       Cell module: control module 1:
       Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D1  H14 0481
       Serial number: V013C1612630390
       Cell module: control module 2:
       Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D2  H14 0481
       Serial number: V013C1612630386
       Cell module: control module 3:
       Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D3  H14 0481
       Serial number: V013C1612630392
       Cell module: control module 4:
       Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D4  H14 0481
       Serial number: V013C1612630385
       Cell module: control module 5:
       Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D5  H14 0481
       Serial number: V013C1612630209
       Cell module: control module 6:
       Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D6  H14 0481
       Serial number: V013C1612630389
       Cell module: control module 7:
       Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D7  H14 0481
       Serial number: V013C1612630268
       Cell module: control module 8:
       Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D8  H14 0481
       Serial number: V013C1612630396
    26623 - Crash Shut-Down Activated
              P1609 00 [167] - -
              [Diag_F_Crash_ShutOff_CAN]
                        Mileage: 55802 km
                        Date: 2019.09.20
                        Time: 15:51:12
                        Pack Voltage: 352.0 V
                        Pack Current: -0.10 A
                        Isolation Resistance: 5080 kOhm
                        Maxumum charge current limit: 0 A
                        Maximum discharge current limit: 0.0 A
                        Contactor Voltage: 328 V
                        OBD unlearned counter: 40
                        Crash status: 01
                        Pilot Line Status: 00
                        Fuse Status: 00
                        (Minus) Contactor Status: 00
                        (Plus) Contactor Status: 00
                        Terminal 15 status: 01
                        Max Cell Temperature: 17 °C
                        Min Cell Temperature: 16 °C
                        Air inlet temperature: 23 °C
                        Air outlet temperature: 21 °C
                        LV Battery Voltage: 15.1 V
                        Min.cell voltage: 3.668 V
                        Max.cell Voltage: 3.674 V
                        Max.cell SOC: 48 %
                        Min.cell SOC: 47 %
                        Hybrid Battery Pack Remaining Life: 47.8 %
                        Max Charge Pack Current(10s duration): 73 A
                        Max Discharge Pack Current(10s duration): 40.5 A
                        Max Pack Voltage(10s duration): 360 V
                        Min Pack Voltage(10s duration): 344 V
                        Max.cell Voltage(10s duration): 3.760 V
                        Min.cell Voltage(10s duration): 3.599 V
                        Accelerator Pedal Position D: 14.5 %
                        Calculated LOAD Value: 0.0 %
                        Engine coolant temperature: 77 °C
                        Engine RPM: 0.00 /min
                        Vehicle Speed Sensor: 30 km/h
                        Ambient Air Temperature: 215 °C
                        Hybrid Battery Pack Remaining Life: 47.84 %
                        control module system voltage: 15.111 V
                        absolute load: 0.0 %
                        Time After Engine Start: 474 s
    26624 - Crash Shut-Down Activated
              P1609 00 [175] - -
              [Diag_F_Crash_ShutOff_HW]
                        Mileage: 55802 km
                        Date: 2019.09.20
                        Time: 15:51:12
                        Pack Voltage: 352.4 V
                        Pack Current: 6.70 A
                        Isolation Resistance: 4140 kOhm
                        Maxumum charge current limit: 126 A
                        Maximum discharge current limit: 292.5 A
                        Contactor Voltage: 352 V
                        Crash status: 00
                        Fuse Status: 00
                        (Minus) Contactor Status: 01
                        (Plus) Contactor Status: 01
                        LV Battery Voltage: 14.5 V
                        Max.cell SOC: 48 %
                        Min.cell SOC: 47 %
                        Vehicle Speed Sensor: 22 km/h
                        control module system voltage: 14.541 V
    26721 - Proximity Sensing
              P0D59 00 [175] - Short to Plus
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:04:15
                        Pack Voltage: 350.9 V
                        Pack Current: 0.10 A
                        Contactor Voltage: 22 V
                        Crash status: 01
                        Fuse Status: 00
                        Max Cell Temperature: 0 °C
                        Min Cell Temperature: -1 °C
                        Air inlet temperature: 0 °C
                        Air outlet temperature: 0 °C
                        LV Battery Voltage: 10.7 V
                        Min.cell voltage: 3.654 V
                        Max.cell Voltage: 3.660 V
                        Max.cell SOC: 49 %
                        Min.cell SOC: 48 %
                        Max Charge Pack Current(10s duration): 0 A
                        Max Discharge Pack Current(10s duration): 0.0 A
                        Max Pack Voltage(10s duration): 350 V
                        Min Pack Voltage(10s duration): 350 V
                        Max.cell Voltage(10s duration): 3.660 V
                        Min.cell Voltage(10s duration): 3.653 V
                        Engine coolant temperature: -2 °C
                        Vehicle Speed Sensor: 0 km/h
                        control module system voltage: 10.716 V
                        Time After Engine Start: 0 s
    27146 - Position Sensor for Battery Charger Coupling Lock
              P0DA1 00 [167] - Short to Plus
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:06:52
                        Pack Current: -0.00 A
                        Crash status: 01
                        Fuse Status: 00
                        LV Battery Voltage: 11.4 V
                        Max.cell Voltage: 3.659 V
                        Max.cell SOC: 49 %
                        Min.cell SOC: 48 %
                        control module system voltage: 11.489 V
       Serial number: 250416EDN09456
       Coding: 000097204000040000001002
       Serial number: 250416EDN01144
    Address C6: Batt. Chrg. (J1050)       Labels:* None
       Part No SW: 5QE 915 682 AA    HW: 5QE 915 682 AA
       Component: OBC KOSTAL    H61 3018
       Revision: --------    Serial number: 0804160D5000AW
       Coding: 115068203000
       ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
       ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
       VCID: 0C4158B0F6CFDB77A5F-8058
    1054722 - Charging Socket A; Plug Locking Detection
              P31D5 00 [009] - Electrical Malfunction
              [Socket_A_Lock_Check_short_circuit_high]
                        Fault Frequency: 7
                        Reset counter: 42
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:06:51
    14749440 - Charging Cover A; Locking Control Circuit
              P31CD 00 [009] - Electrical Malfunction
              [Socket_A_Lock_2_Check_disconnected]
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:23:11
    1055490 - Charging Socket A
              P33E1 00 [009] - Electrical Malfunction
                        Reset counter: 42
                        Mileage: 55803 km
                        Date: 2019.11.29
                        Time: 15:04:14
    End----------(Elapsed Time: 01:49, VBatt start/end: 14.2V/14.1V)-----------
    Speculation: Is it possible that some of the other hard faults in the battery module need to be addressed first?
  3. Likes PetrolDave liked this post
    Jun 2019
    Norway
    Sorry about late replay
    I have don som investigation about the problem.
    Error. 26721 and 27146 was trigged when i disconnected the cabel from HV charcher and chargerport.
    I reconnected the cabel and tryed to erase this errorcodes without any luck use vcds.
    I had to use ODIS to fix the problem.
