Bosch battery uds codes Touareg 2013 no bem code sticker
ogall
C?ID=370381
Hi
Im replacing battery and have seen closed thread on bosch vender code but if anyone could help with which is the part number to add to vcd in uds. the numbers on the battery are below with the first set etched into battery which has manufacture date code of april 2019 I think
Its a S5 A15 Bosch
Z5A920071 0389
605 901 095
0 092 S5A 150
4047025244374
19-CAN Gateway has Adaptation Channels for:
Battery adaptation - Serial number
Battery adaptation - Manufacturer
Battery adaptation - Size
Make sure the size in Ah is correct and change one digit of the serial number that's in there, or ask Bosch which of those numbers on the label is the serial number and use as much of it as practical. Serial number has no functional effect except that a change to it tells the car that a new battery has been installed.
ogall
C?ID=370381
Bosch Battery Date codes
ogall
C?ID=370381
I only had to find all this out about manufacture dates as one of the largest U.K battery suppliers sold me an out of use by date Varta battery followed by a Second Varta that was 19 months past is manufacture date, I didn't trust them and contacted Varta batteries uk via the parent company CLARIOS.COM who I gave the battery code and they said it should NOT be fitted to my car.
Bosch Battery Date codes, can only Find in Russian but I’m sure you can work it out!
ogall
C?ID=370381
10 digit code (0 092 S5A 150 ) from list on first page is serial/Part number to be added to battery adaptation serial number in uds
Dana
Western PA, USA
In the event that it helps someone in the future, this is stored in my husband's 2017 Gas 7P T'reg 19-CAN Gateway module with the factory (Varta) battery:
IDE03256-IDE00010-Battery adaptation-Serial number
VAO3GC1063​
IDE03256-MAS03159-Battery adaptation-Manufacturer​
VAO​
IDE03256-MAS04490-Battery adaptation-Size​
110 Ah​
That doesn't help with the Bosch specific topic but the formatting (10 digit serial number) may help someone reading this at a later date. Additionally, this T'reg uses a CAN Gateway that's nearly identical to the 4G chassis at the end of the video on this page so the procedure would be the same: Battery Replacement > 19-CAN Gateway using (UDS/ODX)
