Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 2000 Audi TT Quattro 1.8T Brake Controller Replaced Says Incorrect Coding
    Verified VCDS-Lite User
    Dec 2019
    Original brake controller stopped communicating, sent it away to a shop in Cali still came back not communicating. They sent me a used unit reprogrammed and now I have communication but dash lights still on and says incorrect coding. The people from Ross-Tech said there was one other car with my same ABS and ECU part numbers and they had the same coding. They asked me to post here for ideas. I can post pic of tag in trunk, vin, tire size etc if necessary. Thanks DC
    Monday, 02 December 2019, 16:03:51:1374
    Chassis Type: 8N - Audi TT
    Scan: 01,02,03,08,15,17,22,35,37,45,55,56,76,77
    Address 01: Engine       Labels: Redir Fail!
       Controller: 8N0 906 018 S
       Component: 1.8L R4/5VT     G   0007
       Coding: 06600
       Shop #: WSC 01236
       VCID: 41F5C3595891
    18057 -  Powertrain Data Bus: Missing Message from ABS Controller
                P1649 - 35-10 -   - - Intermittent
    17840 -  Secondary Air Injection Solenoid Valve (N112): Open Circuit
                P1432 - 35-00 -   -
    16490 -  Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
                P0106 - 35-00 -   -
    16622 -  Manifold Pressure / Boost Sensor (G31): Signal too High
                P0238 - 35-00 -   -
    Readiness: 0010 0101
    Address 03: ABS Brakes       Labels: None
       Controller: 8N0 907 379 E
       Component: ESP     20    CAN  V005
       Coding: 18446
       Shop #: WSC 01236
       VCID: 3E0FB8A5296F
    9 Faults Found:
    00283 -  ABS Wheel Speed Sensor; Front Left (G47)
                35-00 -   -
    00285 -  ABS Wheel Speed Sensor; Front Right (G45)
                35-00 -   -
    01044 -  Control Module Incorrectly Coded
                35-00 -   -
    01312 -  Powertrain Data Bus
                37-00 -  Faulty
    00812 -  Brake Pressure Release Solenoid (F84)
                35-00 -   -
    00778 -  Steering Angle Sensor (G85)
                62-00 -  No or Incorrect Adjustment
                49-00 -  No Communications
    01276 -  ABS Hydraulic Pump (V64)
                16-10 -  Signal Outside Specifications - Intermittent
    00814 -  Solenoid for Brake Pressure (N247)
    Address 08: Auto HVAC       Labels: 8N0-820-043.LBL
       Controller: 8N0 820 043 A
       Component: TT-KLIMAVOLLAUTOMAT D03
       Coding: 00140
       Shop #: WSC 01236
       VCID: 28237EFDDBEB
    00779 -  Outside Air Temp Sensor (G17)
                30-00 -  Open or Short to Plus
    Address 15: Airbags       Labels: 8N8-909-601.LBL
       Controller: 8N8 909 601
       Component: Airbag Front+Seite 0005
       Coding: 10102
       Shop #: WSC 01236
       VCID: F781ED81C6D5
    Address 17: Instruments       Labels: 8Nx-919-xxx-17.LBL
       Controller: 8N1 919 930 B
       Component: KOMBI+WEGFAHRS. M73 D30
       Coding: 06244
       Shop #: WSC 25061
       VCID: 3803AEBD0B4B
    Address 22: AWD       Labels: 02D-900-554.LBL
       Controller: 02D 900 554 B
       Component: HALDEX LSC  ECC     0006
       VCID: 1F3165218EA5
    01316 -  ABS Control Module
    Address 35: Centr. Locks       Labels: None
       Controller: 8N
       Component: Zentralverrieg.     D04
       Coding: 00000
       VCID: 867F9045B13F
    01559 -  Drivers Door
                61-00 -  Won't De-Safe
    01560 -  Passenger Door
    Address 45: Inter. Monitor       Labels: 8E0-951-177.LBL
       Controller: 8N8 951 177 A
       Component: Innenraumueberw.    D09
       Coding: 00001
       VCID: 3D0DBFA92469
    Address 55: Xenon Range       Labels: 4B0-907-357-AUT.LBL
       Controller: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D003
       Coding: 00010
       Shop #: WSC 01236
       VCID: E5BDB7C96C79
    End
    Welcome to the VCDS forum OP!
    They did, what's your VIN number OP please?
    Let's root out FOD using JPPSG guidelines okay?
    Dec 2019
    VIN TRUUC28N6Y1015859
    Vehicle Identification No. TRUUC28N6Y1015859
    Model Audi TT Coupe 1,8 qu.
    ATT
    Date of production 08.08.1999
    Model year 2000
    Sales type 8N355N
    Engine Code ATC
    Transmission Code DXW
    Emission standard 0GL Emission standard TLEV
    PART NUMBER FOD! DESCRIPTION REMARK MODEL
    8N0907375E Control unit for ABS LEGACY
    8N0907379C
    quattro
    Dec 2019
    Control Module Incorrectly Coded So what does above mean please?
    WRONG MODULE INSTALLED SIR CANT YOU SEE THE AFOREMENTIONED?
  7. #7
    Dec 2019
    No sorry Im not a mechanic. But i think you might be saying 8N0907375E is correct module??? Not 8N0907379C
  8. #8
    FOD WINS!
    You have the wrong module installed sir, don't you see that and the replacement part number or possible legacy in green color are in bold aforementioned?
  9. Likes Oswaldusa liked this post
  10. #9
    Dec 2019
    awesome thank you so much for your help....
  11. #10
  12. Likes Uwe liked this post
