VW polo 6r key unlocking/locking not working
ib97
Croatia
C?ID=375363
After coding needle sweep and coming home function, key locking and unlocking is not working, on both keys.
coming home is not working, but not such a big deal. any help pleaase?
here is the auto scan
Saturday,07,December,2019,11:08:34:60999
VIN: WVWZZZ6RZFY078505   License Plate: KT305HB
Mileage: 47202km-29329mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFY078505   Mileage: 47202km-29329miles
Address 01: Engine (J623-CJZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
   Component: 1.2l R4 TSI   H21 7876
   Revision: R5H21---
   Coding: 01110012230411080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS01104E906027BB 001005
   ROD: EV_ECM12TFS01104E906027BB.rod
   VCID: 65964AABE5EF225F5A1-8030
   CAN Converter 01:
   Part No SW: 6C0 907 379     HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0002
   Serial number: 08511533140524
   Coding: 21DD2885492A33C8091910690056841492CC90080005C7090C00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
   VCID: 6C803F8F0605131705F-8038
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H02 0105
   Serial number:  1406051B-0132
   Coding: 200000001000100000
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1D66224B8D3F2A9FC21-8048
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 A    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H06 0046
   Serial number: 007278013822
   Coding: 000008404253005B4B844000400703880000580251010000000000000000
   ASAM Dataset: EV_BCMA0 004003
   ROD: EV_MQBA0.rod
   VCID: 2E04F587F099A1076BB-807A
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU021051441413454
   Coding: 0400A0
   Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU026051441464110
   Coding: 1400A0
   Subsystem 3 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU023051441433135
   Coding: 0400A0
   Subsystem 4 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8610
   Serial number: KU0KU026051441460870
   Coding: 1400A0
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag01B 001 0330
   Revision: --------    Serial number: 003LM002F3K0
   Coding: 88C0C000000000005C0000CA000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 313EEEFBE1A7BEFF769-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 821 405 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00C5154F2B1E3BZ
   Subsystem 2 - Part No SW: -----------    HW: 410 821 405 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00B51569C52801H
   Subsystem 3 - Part No SW: -----------    HW: 442 152 905 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00A715397B4C2FQ
   Subsystem 4 - Part No SW: -----------    HW: 442 152 905 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00A715397B1636A
   Part No SW: 6C0 920 740 A    HW: 6C0 920 740 A
   Component: KOMBI         211 0260
   Coding: 072509002180000801082A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009036
   VCID: 20181BBFBA4D0777E97-8074
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H06 0046
   Revision: --------    Serial number: 007278013822
   Coding: 030100046F0A560071000000000000010001000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   Subsystem 1 - Part No SW: 6C0 959 442     HW: 6C0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H03 0015
   Serial number: 1431411352301154AB1B
   Coding: 240000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 61148737112821301557
1282 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 222
                    Mileage: 46678 km
                    Date: 2019.11.19
                    Time: 12:46:12
                    Supply voltage: Terminal 30: 8.2 V
                    Terminal 15: On
   Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3211
   Serial number: PE6B1106
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 323CE1F7E4A185E70F3-8066
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 6C0 035 869 B    HW: 6C0 035 869 B
   Component: MU-E--ER      820 6180
   Serial number: 04061400010262
   Coding: 02620000BE00000041110001000000001F0000840000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001017
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 2A0CF997CC71CD27B73-807E
End----------(Elapsed Time: 00:38, VBatt start/end: 14.8V/12.2V)-----------
MartinsX
Riga, Latvia
C?ID=268515
Original coding/adaptation channel values before tweak attempts? Autoscan from state before?
What values, channels were changed? What happens if everything is reverted back to original state?
P.S. Use of enough powerful battery charger or power supply is strongly recommended while doing coding/adaptations!
ib97
Croatia
C?ID=375363
Yes, just needle sweep and coming home that didn't work.
If I revert back long coding code and adaptations Nothing changes.
ib97
Croatia
C?ID=375363
adplog:
Address 19,6C0 909 901 ,channel IDE08348-Start/stop start voltage limit,adapted from,7.6 V,to,12.1 V,Saturday,07,December,2019,11:18:39:60999
Address 09,6C0 937 089 A,channel IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,adapted from,Low beam ,to,Fog light ,Saturday,07,December,2019,11:21:06:60999
Address 09,6C0 937 089 A,channel IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,adapted from,Low beam ,to,Fog light ,Saturday,07,December,2019,11:21:27:60999
Address 09,6C0 937 089 A,channel IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,adapted from,not active ,to,10 seconds ,Saturday,07,December,2019,11:23:37:60999
Address 09,6C0 937 089 A,channel IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,adapted from,not active ,to,active ,Saturday,07,December,2019,11:23:45:60999
Address 09,6C0 937 089 A,channel IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,adapted from,not enabled ,to,Enabled ,Saturday,07,December,2019,11:24:25:60999
Address 09,6C0 937 089 A,channel IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,adapted from,Fog light ,to,Low beam ,Saturday,07,December,2019,11:29:16:60999
Address 09,6C0 937 089 A,channel IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,adapted from,Fog light ,to,Low beam ,Saturday,07,December,2019,11:29:33:60999
Address 09,6C0 937 089 A,channel IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,adapted from,Not Present ,to,manual ,Saturday,07,December,2019,11:29:48:60999
Address 09,6C0 937 089 A,channel IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,adapted from,10 seconds ,to,not active ,Saturday,07,December,2019,11:30:01:60999
Address 09,6C0 937 089 A,channel IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,adapted from,active ,to,not active ,Saturday,07,December,2019,11:30:08:60999
Address 09,6C0 937 089 A,channel IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,adapted from,Enabled ,to,not enabled ,Saturday,07,December,2019,11:30:39:60999
Address 09,6C0 937 089 A,channel IDE05142-ENG116706-Access control-Autounlock NAR,adapted from,not active ,to,active ,Saturday,07,December,2019,12:07:15:60999
Address 17,6C0 920 740 A,channel IDE06588-Ignition active message: actuator,adapted from,Driver door ,to,No display ,Saturday,07,December,2019,12:34:14:60999
codinglog
Address 09,6C0 937 089 A,recoded (Long Coding-exp),from,000008404253005B4B844000400703880000580251010000000000000000,to,000108404253005B4B844000400703880000580251010000000000000000,(131071/1023/2097151),Saturday,07,December,2019,11:17:33:60999
Address 17,6C0 920 740 A,recoded (Long Coding-exp),from,072509002180000801082A001000000000000000,to,073509002180000801082A001000000000000000,(00788/648/00255),Saturday,07,December,2019,12:33:41:60999
Address 17,6C0 920 740 A,recoded (Long Coding-exp),from,073509002180000801082A001000000000000000,to,072509002180000801082A001000000000000000,(00788/648/00255),Saturday,07,December,2019,12:33:58:60999
Address 09,6C0 937 089 A,recoded (Long Coding-exp),from,000008404253005B4B844000400703880000580251010000000000000000,to,000108404253005B4B844000400703880000580251010000000000000000,(12345/123/12345),Saturday,07,December,2019,12:51:51:60999
Address 09,6C0 937 089 A,recoded (Long Coding),from,000108404253005B4B844000400703880000580251010000000000000000,to,000108404253005B4B844000400703880000580251010000000000000000,(12345/123/12345),Saturday,07,December,2019,12:52:21:60999
Address 09,6C0 937 089 A,recoded (Long Coding-exp),from,000108404253005B4B844000400703880000580251010000000000000000,to,000008404253005B4B844000400703880000580251010000000000000000,(12345/123/12345),Saturday,07,December,2019,13:00:47:60999
DV52
C?ID=194404
^^^^ hmmm.........try reverting IDE05142-ENG116706-Access control-Autounlock NAR from your current value of active to not active - that is unless the good Mr Trump has made Croatia the 51st State of America!! ;)
ib97
Croatia
C?ID=375363
Still not working after changes.
Here is the new autoscan:
VIN: WVWZZZ6RZFY078505   Mileage: 47316km-29400miles
   Revision: R5H21---
   CAN Converter 01:
Readiness: 0000 0001
329475 - Motor for Fresh Air / Recirculated Air Flap
          B108B 13 [012] - Open Circuit
                    Reset counter: 59
                    Mileage: 47202 km
                    Date: 2019.12.07
                    Time: 13:05:26
                    Voltage terminal 30: 14.5 V
          B10CD 00 [012] - -
          [Funktionseinschränkung durch Energiemangement]
                    Reset counter: 59
                    Mileage: 47202 km
                    Date: 2019.12.07
                    Time: 13:01:58
                    Voltage terminal 30: 11.4 V
                    CAN input signal(s) status-Transport mode: OFF
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
   ROD: EV_MQBA0.rod
   Coding: 0400A0
   Coding: 1400A0
   Coding: 0400A0
   Coding: 1400A0
533013 - Databus
          [ELV_01 Datenbus fehlende Botschaft]
                    Reset counter: 59
                    Mileage: 47202 km
                    Date: 2019.12.07
                    Time: 12:51:44
538389 - Databus
          [Kessy_04 Datenbus fehlende Botschaft]
                    Reset counter: 59
                    Mileage: 47202 km
                    Date: 2019.12.07
                    Time: 12:51:44
   Coding: 240000
   Coding: 0007
End----------(Elapsed Time: 00:39, VBatt start/end: 12.1V/12.1V)-----------
Adaptation map of 09:
IDE00001-ENG130235-Production mode-Entry_control,not active ,3
IDE00001-ENG130233-Production mode-Exit_lights_Heading_time_15_s,not active ,3
IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3
IDE00001-ENG130234-Production mode-Window_regulator_kl_15_nr_2,not active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,9
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition ,9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,9
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active ,9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,not active ,9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,not activated ,9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp ,9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,9
IDE02152-Characteristics in production mode,0 ms,4
IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,32
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,2
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,2
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,2
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,3
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,3
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,3
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,3
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,3
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,3
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,3
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,3
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active ,3
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %,4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %,4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %,4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.50 °,13
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,13
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,13
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,13
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,13
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,13
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,180 °,13
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,13
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,120 °,13
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,13
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,13
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,combined ,4
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active ,4
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,4
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5 ,4
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS ,4
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled ,4
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active ,4
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active ,4
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.100 %,4
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,3.0 %,4
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h,14
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active ,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,255 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,manual ,5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,ignition ,5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0 ,5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,0.0 ,5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,not enabled ,5
IDE04926-ENG126569-Comfort illumination-lho_aktiviert,not active ,5
IDE04926-ENG126570-Comfort illumination-lho_zeit,not active ,5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,not active ,5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,not active ,5
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C,8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C,8
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,0.0 s,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,1
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,1
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,1
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,1
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,1
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,4
IDE05142-ENG116706-Access control-Autounlock NAR,active ,4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,4
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,4
IDE05142-ENG115755-Access control-Notschließfunktion,active ,4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
IDE05142-ENG115758-Access control-Valet Parking,not active ,4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,4
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34 ,560
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E ,560
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00 ,560
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00 ,560
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,38 ,560
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,42 ,560
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00 ,560
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00 ,560
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,00 ,560
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,00 ,560
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08 ,560
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18 ,560
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,35 ,560
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,09 ,560
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,19 ,560
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,29 ,560
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,0A ,560
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,1A ,560
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,00 ,560
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,0C ,560
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00 ,560
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,1B ,560
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00 ,560
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,3F ,560
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00 ,560
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00 ,560
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00 ,560
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00 ,560
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,00 ,560
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,3A ,560
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,44 ,560
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36 ,560
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40 ,560
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37 ,560
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41 ,560
IDE05145-ENG115018-Light configuration-Dimming_AB_0,100 ,560
IDE05145-ENG115037-Light configuration-Dimming_AB_1,100 ,560
IDE05145-ENG114999-Light configuration-Dimming_AB_10,0 ,560
IDE05145-ENG115193-Light configuration-Dimming_AB_11,100 ,560
IDE05145-ENG115212-Light configuration-Dimming_AB_12,100 ,560
IDE05145-ENG114958-Light configuration-Dimming_AB_13,100 ,560
IDE05145-ENG115233-Light configuration-Dimming_AB_14,100 ,560
IDE05145-ENG115252-Light configuration-Dimming_AB_15,100 ,560
IDE05145-ENG115271-Light configuration-Dimming_AB_16,100 ,560
IDE05145-ENG115290-Light configuration-Dimming_AB_17,100 ,560
IDE05145-ENG115309-Light configuration-Dimming_AB_18,100 ,560
IDE05145-ENG115328-Light configuration-Dimming_AB_19,100 ,560
IDE05145-ENG115056-Light configuration-Dimming_AB_2,100 ,560
IDE05145-ENG115347-Light configuration-Dimming_AB_20,100 ,560
IDE05145-ENG115366-Light configuration-Dimming_AB_21,100 ,560
IDE05145-ENG115385-Light configuration-Dimming_AB_22,100 ,560
IDE05145-ENG115404-Light configuration-Dimming_AB_23,60 ,560
IDE05145-ENG115423-Light configuration-Dimming_AB_24,60 ,560
IDE05145-ENG115442-Light configuration-Dimming_AB_25,100 ,560
IDE05145-ENG115461-Light configuration-Dimming_AB_26,100 ,560
IDE05145-ENG115480-Light configuration-Dimming_AB_27,100 ,560
IDE05145-ENG115499-Light configuration-Dimming_AB_28,100 ,560
IDE05145-ENG115518-Light configuration-Dimming_AB_29,100 ,560
IDE05145-ENG115075-Light configuration-Dimming_AB_3,100 ,560
IDE05145-ENG115537-Light configuration-Dimming_AB_30,100 ,560
IDE05145-ENG115556-Light configuration-Dimming_AB_31,0 ,560
IDE05145-ENG115575-Light configuration-Dimming_AB_32,0 ,560
IDE05145-ENG115594-Light configuration-Dimming_AB_33,0 ,560
IDE05145-ENG115613-Light configuration-Dimming_AB_34,0 ,560
IDE05145-ENG115094-Light configuration-Dimming_AB_4,100 ,560
IDE05145-ENG114977-Light configuration-Dimming_AB_5,100 ,560
IDE05145-ENG115115-Light configuration-Dimming_AB_6,100 ,560
IDE05145-ENG115134-Light configuration-Dimming_AB_7,100 ,560
IDE05145-ENG115153-Light configuration-Dimming_AB_8,100 ,560
IDE05145-ENG115172-Light configuration-Dimming_AB_9,100 ,560
IDE05145-ENG115022-Light configuration-Dimming_CD_0,0 ,560
IDE05145-ENG115041-Light configuration-Dimming_CD_1,0 ,560
IDE05145-ENG115003-Light configuration-Dimming_CD_10,0 ,560
IDE05145-ENG115197-Light configuration-Dimming_CD_11,0 ,560
IDE05145-ENG115216-Light configuration-Dimming_CD_12,0 ,560
IDE05145-ENG114962-Light configuration-Dimming_CD_13,0 ,560
IDE05145-ENG115237-Light configuration-Dimming_CD_14,0 ,560
IDE05145-ENG115256-Light configuration-Dimming_CD_15,0 ,560
IDE05145-ENG115275-Light configuration-Dimming_CD_16,0 ,560
IDE05145-ENG115294-Light configuration-Dimming_CD_17,0 ,560
IDE05145-ENG115313-Light configuration-Dimming_CD_18,0 ,560
IDE05145-ENG115332-Light configuration-Dimming_CD_19,0 ,560
IDE05145-ENG115060-Light configuration-Dimming_CD_2,0 ,560
IDE05145-ENG115351-Light configuration-Dimming_CD_20,0 ,560
IDE05145-ENG115370-Light configuration-Dimming_CD_21,0 ,560
IDE05145-ENG115389-Light configuration-Dimming_CD_22,0 ,560
IDE05145-ENG115408-Light configuration-Dimming_CD_23,0 ,560
IDE05145-ENG115427-Light configuration-Dimming_CD_24,0 ,560
IDE05145-ENG115446-Light configuration-Dimming_CD_25,0 ,560
IDE05145-ENG115465-Light configuration-Dimming_CD_26,0 ,560
IDE05145-ENG115484-Light configuration-Dimming_CD_27,0 ,560
IDE05145-ENG115503-Light configuration-Dimming_CD_28,0 ,560
IDE05145-ENG115522-Light configuration-Dimming_CD_29,0 ,560
IDE05145-ENG115079-Light configuration-Dimming_CD_3,0 ,560
IDE05145-ENG115541-Light configuration-Dimming_CD_30,0 ,560
IDE05145-ENG115560-Light configuration-Dimming_CD_31,0 ,560
IDE05145-ENG115579-Light configuration-Dimming_CD_32,0 ,560
IDE05145-ENG115598-Light configuration-Dimming_CD_33,0 ,560
IDE05145-ENG115617-Light configuration-Dimming_CD_34,0 ,560
IDE05145-ENG115098-Light configuration-Dimming_CD_4,0 ,560
IDE05145-ENG114981-Light configuration-Dimming_CD_5,0 ,560
IDE05145-ENG115119-Light configuration-Dimming_CD_6,0 ,560
IDE05145-ENG115138-Light configuration-Dimming_CD_7,0 ,560
IDE05145-ENG115157-Light configuration-Dimming_CD_8,0 ,560
IDE05145-ENG115176-Light configuration-Dimming_CD_9,0 ,560
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize ,560
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize ,560
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize ,560
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize ,560
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize ,560
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize ,560
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize ,560
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize ,560
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize ,560
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize ,560
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize ,560
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize ,560
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize ,560
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize ,560
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize ,560
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize ,560
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize ,560
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize ,560
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize ,560
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize ,560
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize ,560
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize ,560
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize ,560
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize ,560
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize ,560
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize ,560
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize ,560
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize ,560
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize ,560
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,maximize ,560
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,maximize ,560
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize ,560
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize ,560
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize ,560
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize ,560
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize ,560
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize ,560
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize ,560
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize ,560
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize ,560
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize ,560
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize ,560
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize ,560
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize ,560
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize ,560
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize ,560
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize ,560
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,maximize ,560
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize ,560
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize ,560
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize ,560
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize ,560
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize ,560
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize ,560
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize ,560
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize ,560
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize ,560
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize ,560
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,maximize ,560
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize ,560
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize ,560
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize ,560
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize ,560
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize ,560
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize ,560
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize ,560
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize ,560
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize ,560
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize ,560
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize ,560
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize ,560
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize ,560
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize ,560
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize ,560
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize ,560
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize ,560
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize ,560
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize ,560
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize ,560
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize ,560
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize ,560
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize ,560
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize ,560
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize ,560
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize ,560
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize ,560
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize ,560
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize ,560
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize ,560
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize ,560
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize ,560
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize ,560
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize ,560
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize ,560
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize ,560
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize ,560
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize ,560
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize ,560
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize ,560
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize ,560
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize ,560
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize ,560
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize ,560
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize ,560
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize ,560
IDE05145-ENG115026-Light configuration-Dimming_EF_0,0 ,560
IDE05145-ENG115045-Light configuration-Dimming_EF_1,0 ,560
IDE05145-ENG115007-Light configuration-Dimming_EF_10,0 ,560
IDE05145-ENG115201-Light configuration-Dimming_EF_11,0 ,560
IDE05145-ENG115220-Light configuration-Dimming_EF_12,0 ,560
IDE05145-ENG114966-Light configuration-Dimming_EF_13,0 ,560
IDE05145-ENG115241-Light configuration-Dimming_EF_14,0 ,560
IDE05145-ENG115260-Light configuration-Dimming_EF_15,0 ,560
IDE05145-ENG115279-Light configuration-Dimming_EF_16,0 ,560
IDE05145-ENG115298-Light configuration-Dimming_EF_17,0 ,560
IDE05145-ENG115317-Light configuration-Dimming_EF_18,0 ,560
IDE05145-ENG115336-Light configuration-Dimming_EF_19,0 ,560
IDE05145-ENG115064-Light configuration-Dimming_EF_2,0 ,560
IDE05145-ENG115355-Light configuration-Dimming_EF_20,0 ,560
IDE05145-ENG115374-Light configuration-Dimming_EF_21,0 ,560
IDE05145-ENG115393-Light configuration-Dimming_EF_22,0 ,560
IDE05145-ENG115412-Light configuration-Dimming_EF_23,0 ,560
IDE05145-ENG115431-Light configuration-Dimming_EF_24,0 ,560
IDE05145-ENG115450-Light configuration-Dimming_EF_25,0 ,560
IDE05145-ENG115469-Light configuration-Dimming_EF_26,0 ,560
IDE05145-ENG115488-Light configuration-Dimming_EF_27,0 ,560
IDE05145-ENG115507-Light configuration-Dimming_EF_28,0 ,560
IDE05145-ENG115526-Light configuration-Dimming_EF_29,0 ,560
IDE05145-ENG115083-Light configuration-Dimming_EF_3,0 ,560
IDE05145-ENG115545-Light configuration-Dimming_EF_30,0 ,560
IDE05145-ENG115564-Light configuration-Dimming_EF_31,0 ,560
IDE05145-ENG115583-Light configuration-Dimming_EF_32,0 ,560
IDE05145-ENG115602-Light configuration-Dimming_EF_33,0 ,560
IDE05145-ENG115621-Light configuration-Dimming_EF_34,0 ,560
IDE05145-ENG115102-Light configuration-Dimming_EF_4,0 ,560
IDE05145-ENG114985-Light configuration-Dimming_EF_5,0 ,560
IDE05145-ENG115123-Light configuration-Dimming_EF_6,0 ,560
IDE05145-ENG115142-Light configuration-Dimming_EF_7,0 ,560
IDE05145-ENG115161-Light configuration-Dimming_EF_8,0 ,560
IDE05145-ENG115180-Light configuration-Dimming_EF_9,0 ,560
IDE05145-ENG115030-Light configuration-Dimming_GH_0,0 ,560
IDE05145-ENG115049-Light configuration-Dimming_GH_1,0 ,560
IDE05145-ENG115011-Light configuration-Dimming_GH_10,0 ,560
IDE05145-ENG115205-Light configuration-Dimming_GH_11,0 ,560
IDE05145-ENG115224-Light configuration-Dimming_GH_12,0 ,560
IDE05145-ENG114970-Light configuration-Dimming_GH_13,0 ,560
IDE05145-ENG115245-Light configuration-Dimming_GH_14,0 ,560
IDE05145-ENG115264-Light configuration-Dimming_GH_15,0 ,560
IDE05145-ENG115283-Light configuration-Dimming_GH_16,0 ,560
IDE05145-ENG115302-Light configuration-Dimming_GH_17,0 ,560
IDE05145-ENG115321-Light configuration-Dimming_GH_18,0 ,560
IDE05145-ENG115340-Light configuration-Dimming_GH_19,0 ,560
IDE05145-ENG115068-Light configuration-Dimming_GH_2,0 ,560
IDE05145-ENG115359-Light configuration-Dimming_GH_20,0 ,560
IDE05145-ENG115378-Light configuration-Dimming_GH_21,0 ,560
IDE05145-ENG115397-Light configuration-Dimming_GH_22,0 ,560
IDE05145-ENG115416-Light configuration-Dimming_GH_23,0 ,560
IDE05145-ENG115435-Light configuration-Dimming_GH_24,0 ,560
IDE05145-ENG115454-Light configuration-Dimming_GH_25,0 ,560
IDE05145-ENG115473-Light configuration-Dimming_GH_26,0 ,560
IDE05145-ENG115492-Light configuration-Dimming_GH_27,0 ,560
IDE05145-ENG115511-Light configuration-Dimming_GH_28,0 ,560
IDE05145-ENG115530-Light configuration-Dimming_GH_29,0 ,560
IDE05145-ENG115087-Light configuration-Dimming_GH_3,0 ,560
IDE05145-ENG115549-Light configuration-Dimming_GH_30,0 ,560
IDE05145-ENG115568-Light configuration-Dimming_GH_31,0 ,560
IDE05145-ENG115587-Light configuration-Dimming_GH_32,0 ,560
IDE05145-ENG115606-Light configuration-Dimming_GH_33,0 ,560
IDE05145-ENG115625-Light configuration-Dimming_GH_34,0 ,560
IDE05145-ENG115106-Light configuration-Dimming_GH_4,0 ,560
IDE05145-ENG114989-Light configuration-Dimming_GH_5,0 ,560
IDE05145-ENG115127-Light configuration-Dimming_GH_6,0 ,560
IDE05145-ENG115146-Light configuration-Dimming_GH_7,0 ,560
IDE05145-ENG115165-Light configuration-Dimming_GH_8,0 ,560
IDE05145-ENG115184-Light configuration-Dimming_GH_9,0 ,560
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14 ,560
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15 ,560
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,00 ,560
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00 ,560
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,22 ,560
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,23 ,560
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00 ,560
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00 ,560
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,00 ,560
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,00 ,560
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16 ,560
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18 ,560
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,26 ,560
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,2B ,560
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,2D ,560
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C ,560
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,29 ,560
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,2A ,560
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,00 ,560
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,2E ,560
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08 ,560
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,32 ,560
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01 ,560
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,27 ,560
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07 ,560
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00 ,560
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00 ,560
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00 ,560
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,00 ,560
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,20 ,560
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,21 ,560
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A ,560
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B ,560
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C ,560
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D ,560
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always ,560
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always ,560
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always ,560
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always ,560
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always ,560
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always ,560
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always ,560
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always ,560
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always ,560
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always ,560
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always ,560
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always ,560
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always ,560
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always ,560
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always ,560
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always ,560
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always ,560
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always ,560
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always ,560
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always ,560
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always ,560
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always ,560
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always ,560
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always ,560
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always ,560
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always ,560
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always ,560
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always ,560
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,Always ,560
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always ,560
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always ,560
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always ,560
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always ,560
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always ,560
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always ,560
IDE05145-ENG115016-Light configuration-Light_Function_A_0,2 ,560
IDE05145-ENG115035-Light configuration-Light_Function_A_1,4 ,560
IDE05145-ENG114997-Light configuration-Light_Function_A_10,0 ,560
IDE05145-ENG115191-Light configuration-Light_Function_A_11,62 ,560
IDE05145-ENG115210-Light configuration-Light_Function_A_12,18 ,560
IDE05145-ENG114956-Light configuration-Light_Function_A_13,19 ,560
IDE05145-ENG115231-Light configuration-Light_Function_A_14,63 ,560
IDE05145-ENG115250-Light configuration-Light_Function_A_15,64 ,560
IDE05145-ENG115269-Light configuration-Light_Function_A_16,2 ,560
IDE05145-ENG115288-Light configuration-Light_Function_A_17,4 ,560
IDE05145-ENG115307-Light configuration-Light_Function_A_18,2 ,560
IDE05145-ENG115326-Light configuration-Light_Function_A_19,4 ,560
IDE05145-ENG115054-Light configuration-Light_Function_A_2,8 ,560
IDE05145-ENG115345-Light configuration-Light_Function_A_20,24 ,560
IDE05145-ENG115364-Light configuration-Light_Function_A_21,24 ,560
IDE05145-ENG115383-Light configuration-Light_Function_A_22,24 ,560
IDE05145-ENG115402-Light configuration-Light_Function_A_23,8 ,560
IDE05145-ENG115421-Light configuration-Light_Function_A_24,8 ,560
IDE05145-ENG115440-Light configuration-Light_Function_A_25,8 ,560
IDE05145-ENG115459-Light configuration-Light_Function_A_26,27 ,560
IDE05145-ENG115478-Light configuration-Light_Function_A_27,38 ,560
IDE05145-ENG115497-Light configuration-Light_Function_A_28,25 ,560
IDE05145-ENG115516-Light configuration-Light_Function_A_29,37 ,560
IDE05145-ENG115073-Light configuration-Light_Function_A_3,8 ,560
IDE05145-ENG115535-Light configuration-Light_Function_A_30,41 ,560
IDE05145-ENG115554-Light configuration-Light_Function_A_31,0 ,560
IDE05145-ENG115573-Light configuration-Light_Function_A_32,0 ,560
IDE05145-ENG115592-Light configuration-Light_Function_A_33,0 ,560
IDE05145-ENG115611-Light configuration-Light_Function_A_34,0 ,560
IDE05145-ENG115092-Light configuration-Light_Function_A_4,20 ,560
IDE05145-ENG114975-Light configuration-Light_Function_A_5,20 ,560
IDE05145-ENG115113-Light configuration-Light_Function_A_6,11 ,560
IDE05145-ENG115132-Light configuration-Light_Function_A_7,12 ,560
IDE05145-ENG115151-Light configuration-Light_Function_A_8,13 ,560
IDE05145-ENG115170-Light configuration-Light_Function_A_9,14 ,560
IDE05145-ENG115017-Light configuration-Light_Function_B_0,0 ,560
IDE05145-ENG115036-Light configuration-Light_Function_B_1,0 ,560
IDE05145-ENG114998-Light configuration-Light_Function_B_10,0 ,560
IDE05145-ENG115192-Light configuration-Light_Function_B_11,0 ,560
IDE05145-ENG115211-Light configuration-Light_Function_B_12,22 ,560
IDE05145-ENG114957-Light configuration-Light_Function_B_13,23 ,560
IDE05145-ENG115232-Light configuration-Light_Function_B_14,0 ,560
IDE05145-ENG115251-Light configuration-Light_Function_B_15,0 ,560
IDE05145-ENG115270-Light configuration-Light_Function_B_16,0 ,560
IDE05145-ENG115289-Light configuration-Light_Function_B_17,0 ,560
IDE05145-ENG115308-Light configuration-Light_Function_B_18,0 ,560
IDE05145-ENG115327-Light configuration-Light_Function_B_19,0 ,560
IDE05145-ENG115055-Light configuration-Light_Function_B_2,9 ,560
IDE05145-ENG115346-Light configuration-Light_Function_B_20,0 ,560
IDE05145-ENG115365-Light configuration-Light_Function_B_21,0 ,560
IDE05145-ENG115384-Light configuration-Light_Function_B_22,0 ,560
IDE05145-ENG115403-Light configuration-Light_Function_B_23,9 ,560
IDE05145-ENG115422-Light configuration-Light_Function_B_24,10 ,560
IDE05145-ENG115441-Light configuration-Light_Function_B_25,0 ,560
IDE05145-ENG115460-Light configuration-Light_Function_B_26,0 ,560
IDE05145-ENG115479-Light configuration-Light_Function_B_27,0 ,560
IDE05145-ENG115498-Light configuration-Light_Function_B_28,0 ,560
IDE05145-ENG115517-Light configuration-Light_Function_B_29,0 ,560
IDE05145-ENG115074-Light configuration-Light_Function_B_3,10 ,560
IDE05145-ENG115536-Light configuration-Light_Function_B_30,0 ,560
IDE05145-ENG115555-Light configuration-Light_Function_B_31,0 ,560
IDE05145-ENG115574-Light configuration-Light_Function_B_32,0 ,560
IDE05145-ENG115593-Light configuration-Light_Function_B_33,0 ,560
IDE05145-ENG115612-Light configuration-Light_Function_B_34,0 ,560
IDE05145-ENG115093-Light configuration-Light_Function_B_4,0 ,560
IDE05145-ENG114976-Light configuration-Light_Function_B_5,0 ,560
IDE05145-ENG115114-Light configuration-Light_Function_B_6,30 ,560
IDE05145-ENG115133-Light configuration-Light_Function_B_7,30 ,560
IDE05145-ENG115152-Light configuration-Light_Function_B_8,15 ,560
IDE05145-ENG115171-Light configuration-Light_Function_B_9,15 ,560
IDE05145-ENG115020-Light configuration-Light_Function_C_0,0 ,560
IDE05145-ENG115039-Light configuration-Light_Function_C_1,0 ,560
IDE05145-ENG115001-Light configuration-Light_Function_C_10,0 ,560
IDE05145-ENG115195-Light configuration-Light_Function_C_11,0 ,560
IDE05145-ENG115214-Light configuration-Light_Function_C_12,0 ,560
IDE05145-ENG114960-Light configuration-Light_Function_C_13,0 ,560
IDE05145-ENG115235-Light configuration-Light_Function_C_14,0 ,560
IDE05145-ENG115254-Light configuration-Light_Function_C_15,0 ,560
IDE05145-ENG115273-Light configuration-Light_Function_C_16,0 ,560
IDE05145-ENG115292-Light configuration-Light_Function_C_17,0 ,560
IDE05145-ENG115311-Light configuration-Light_Function_C_18,0 ,560
IDE05145-ENG115330-Light configuration-Light_Function_C_19,0 ,560
IDE05145-ENG115058-Light configuration-Light_Function_C_2,0 ,560
IDE05145-ENG115349-Light configuration-Light_Function_C_20,0 ,560
IDE05145-ENG115368-Light configuration-Light_Function_C_21,0 ,560
IDE05145-ENG115387-Light configuration-Light_Function_C_22,0 ,560
IDE05145-ENG115406-Light configuration-Light_Function_C_23,0 ,560
IDE05145-ENG115425-Light configuration-Light_Function_C_24,0 ,560
IDE05145-ENG115444-Light configuration-Light_Function_C_25,0 ,560
IDE05145-ENG115463-Light configuration-Light_Function_C_26,0 ,560
IDE05145-ENG115482-Light configuration-Light_Function_C_27,0 ,560
IDE05145-ENG115501-Light configuration-Light_Function_C_28,0 ,560
IDE05145-ENG115519-Light configuration-Light_Function_C_29,0 ,560
IDE05145-ENG115077-Light configuration-Light_Function_C_3,0 ,560
IDE05145-ENG115539-Light configuration-Light_Function_C_30,0 ,560
IDE05145-ENG115558-Light configuration-Light_Function_C_31,0 ,560
IDE05145-ENG115577-Light configuration-Light_Function_C_32,0 ,560
IDE05145-ENG115596-Light configuration-Light_Function_C_33,0 ,560
IDE05145-ENG115615-Light configuration-Light_Function_C_34,0 ,560
IDE05145-ENG115096-Light configuration-Light_Function_C_4,0 ,560
IDE05145-ENG114979-Light configuration-Light_Function_C_5,0 ,560
IDE05145-ENG115117-Light configuration-Light_Function_C_6,0 ,560
IDE05145-ENG115136-Light configuration-Light_Function_C_7,0 ,560
IDE05145-ENG115155-Light configuration-Light_Function_C_8,0 ,560
IDE05145-ENG115174-Light configuration-Light_Function_C_9,0 ,560
IDE05145-ENG115021-Light configuration-Light_Function_D_0,0 ,560
IDE05145-ENG115040-Light configuration-Light_Function_D_1,0 ,560
IDE05145-ENG115002-Light configuration-Light_Function_D_10,0 ,560
IDE05145-ENG115196-Light configuration-Light_Function_D_11,0 ,560
IDE05145-ENG115215-Light configuration-Light_Function_D_12,0 ,560
IDE05145-ENG114961-Light configuration-Light_Function_D_13,0 ,560
IDE05145-ENG115236-Light configuration-Light_Function_D_14,0 ,560
IDE05145-ENG115255-Light configuration-Light_Function_D_15,0 ,560
IDE05145-ENG115274-Light configuration-Light_Function_D_16,0 ,560
IDE05145-ENG115293-Light configuration-Light_Function_D_17,0 ,560
IDE05145-ENG115312-Light configuration-Light_Function_D_18,0 ,560
IDE05145-ENG115331-Light configuration-Light_Function_D_19,0 ,560
IDE05145-ENG115059-Light configuration-Light_Function_D_2,0 ,560
IDE05145-ENG115350-Light configuration-Light_Function_D_20,0 ,560
IDE05145-ENG115369-Light configuration-Light_Function_D_21,0 ,560
IDE05145-ENG115388-Light configuration-Light_Function_D_22,0 ,560
IDE05145-ENG115407-Light configuration-Light_Function_D_23,0 ,560
IDE05145-ENG115426-Light configuration-Light_Function_D_24,0 ,560
IDE05145-ENG115445-Light configuration-Light_Function_D_25,0 ,560
IDE05145-ENG115464-Light configuration-Light_Function_D_26,0 ,560
IDE05145-ENG115483-Light configuration-Light_Function_D_27,0 ,560
IDE05145-ENG115502-Light configuration-Light_Function_D_28,0 ,560
IDE05145-ENG115521-Light configuration-Light_Function_D_29,0 ,560
IDE05145-ENG115078-Light configuration-Light_Function_D_3,0 ,560
IDE05145-ENG115540-Light configuration-Light_Function_D_30,0 ,560
IDE05145-ENG115559-Light configuration-Light_Function_D_31,0 ,560
IDE05145-ENG115578-Light configuration-Light_Function_D_32,0 ,560
IDE05145-ENG115597-Light configuration-Light_Function_D_33,0 ,560
IDE05145-ENG115616-Light configuration-Light_Function_D_34,0 ,560
IDE05145-ENG115097-Light configuration-Light_Function_D_4,0 ,560
IDE05145-ENG114980-Light configuration-Light_Function_D_5,0 ,560
IDE05145-ENG115118-Light configuration-Light_Function_D_6,0 ,560
IDE05145-ENG115137-Light configuration-Light_Function_D_7,0 ,560
IDE05145-ENG115156-Light configuration-Light_Function_D_8,0 ,560
IDE05145-ENG115175-Light configuration-Light_Function_D_9,0 ,560
IDE05145-ENG115024-Light configuration-Light_Function_E_0,0 ,560
IDE05145-ENG115043-Light configuration-Light_Function_E_1,0 ,560
IDE05145-ENG115005-Light configuration-Light_Function_E_10,0 ,560
IDE05145-ENG115199-Light configuration-Light_Function_E_11,0 ,560
IDE05145-ENG115218-Light configuration-Light_Function_E_12,0 ,560
IDE05145-ENG114964-Light configuration-Light_Function_E_13,0 ,560
IDE05145-ENG115239-Light configuration-Light_Function_E_14,0 ,560
IDE05145-ENG115258-Light configuration-Light_Function_E_15,0 ,560
IDE05145-ENG115277-Light configuration-Light_Function_E_16,0 ,560
IDE05145-ENG115296-Light configuration-Light_Function_E_17,0 ,560
IDE05145-ENG115315-Light configuration-Light_Function_E_18,0 ,560
IDE05145-ENG115334-Light configuration-Light_Function_E_19,0 ,560
IDE05145-ENG115062-Light configuration-Light_Function_E_2,0 ,560
IDE05145-ENG115353-Light configuration-Light_Function_E_20,0 ,560
IDE05145-ENG115372-Light configuration-Light_Function_E_21,0 ,560
IDE05145-ENG115391-Light configuration-Light_Function_E_22,0 ,560
IDE05145-ENG115410-Light configuration-Light_Function_E_23,0 ,560
IDE05145-ENG115429-Light configuration-Light_Function_E_24,0 ,560
IDE05145-ENG115448-Light configuration-Light_Function_E_25,0 ,560
IDE05145-ENG115467-Light configuration-Light_Function_E_26,0 ,560
IDE05145-ENG115486-Light configuration-Light_Function_E_27,0 ,560
IDE05145-ENG115505-Light configuration-Light_Function_E_28,0 ,560
IDE05145-ENG115524-Light configuration-Light_Function_E_29,0 ,560
IDE05145-ENG115081-Light configuration-Light_Function_E_3,0 ,560
IDE05145-ENG115543-Light configuration-Light_Function_E_30,0 ,560
IDE05145-ENG115562-Light configuration-Light_Function_E_31,0 ,560
IDE05145-ENG115581-Light configuration-Light_Function_E_32,0 ,560
IDE05145-ENG115600-Light configuration-Light_Function_E_33,0 ,560
IDE05145-ENG115619-Light configuration-Light_Function_E_34,0 ,560
IDE05145-ENG115100-Light configuration-Light_Function_E_4,0 ,560
IDE05145-ENG114983-Light configuration-Light_Function_E_5,0 ,560
IDE05145-ENG115121-Light configuration-Light_Function_E_6,0 ,560
IDE05145-ENG115140-Light configuration-Light_Function_E_7,0 ,560
IDE05145-ENG115159-Light configuration-Light_Function_E_8,0 ,560
IDE05145-ENG115178-Light configuration-Light_Function_E_9,0 ,560
IDE05145-ENG115025-Light configuration-Light_Function_F_0,0 ,560
IDE05145-ENG115044-Light configuration-Light_Function_F_1,0 ,560
IDE05145-ENG115006-Light configuration-Light_Function_F_10,0 ,560
IDE05145-ENG115200-Light configuration-Light_Function_F_11,0 ,560
IDE05145-ENG115219-Light configuration-Light_Function_F_12,0 ,560
IDE05145-ENG114965-Light configuration-Light_Function_F_13,0 ,560
IDE05145-ENG115240-Light configuration-Light_Function_F_14,0 ,560
IDE05145-ENG115259-Light configuration-Light_Function_F_15,0 ,560
IDE05145-ENG115278-Light configuration-Light_Function_F_16,0 ,560
IDE05145-ENG115297-Light configuration-Light_Function_F_17,0 ,560
IDE05145-ENG115316-Light configuration-Light_Function_F_18,0 ,560
IDE05145-ENG115335-Light configuration-Light_Function_F_19,0 ,560
IDE05145-ENG115063-Light configuration-Light_Function_F_2,0 ,560
IDE05145-ENG115354-Light configuration-Light_Function_F_20,0 ,560
IDE05145-ENG115373-Light configuration-Light_Function_F_21,0 ,560
IDE05145-ENG115392-Light configuration-Light_Function_F_22,0 ,560
IDE05145-ENG115411-Light configuration-Light_Function_F_23,0 ,560
IDE05145-ENG115430-Light configuration-Light_Function_F_24,0 ,560
IDE05145-ENG115449-Light configuration-Light_Function_F_25,0 ,560
IDE05145-ENG115468-Light configuration-Light_Function_F_26,0 ,560
IDE05145-ENG115487-Light configuration-Light_Function_F_27,0 ,560
IDE05145-ENG115506-Light configuration-Light_Function_F_28,0 ,560
IDE05145-ENG115525-Light configuration-Light_Function_F_29,0 ,560
IDE05145-ENG115082-Light configuration-Light_Function_F_3,0 ,560
IDE05145-ENG115544-Light configuration-Light_Function_F_30,0 ,560
IDE05145-ENG115563-Light configuration-Light_Function_F_31,0 ,560
IDE05145-ENG115582-Light configuration-Light_Function_F_32,0 ,560
IDE05145-ENG115601-Light configuration-Light_Function_F_33,0 ,560
IDE05145-ENG115620-Light configuration-Light_Function_F_34,0 ,560
IDE05145-ENG115101-Light configuration-Light_Function_F_4,0 ,560
IDE05145-ENG114984-Light configuration-Light_Function_F_5,0 ,560
IDE05145-ENG115122-Light configuration-Light_Function_F_6,0 ,560
IDE05145-ENG115141-Light configuration-Light_Function_F_7,0 ,560
IDE05145-ENG115160-Light configuration-Light_Function_F_8,0 ,560
IDE05145-ENG115179-Light configuration-Light_Function_F_9,0 ,560
IDE05145-ENG115028-Light configuration-Light_Function_G_0,0 ,560
IDE05145-ENG115047-Light configuration-Light_Function_G_1,0 ,560
IDE05145-ENG115009-Light configuration-Light_Function_G_10,0 ,560
IDE05145-ENG115203-Light configuration-Light_Function_G_11,0 ,560
IDE05145-ENG115222-Light configuration-Light_Function_G_12,0 ,560
IDE05145-ENG114968-Light configuration-Light_Function_G_13,0 ,560
IDE05145-ENG115243-Light configuration-Light_Function_G_14,0 ,560
IDE05145-ENG115262-Light configuration-Light_Function_G_15,0 ,560
IDE05145-ENG115281-Light configuration-Light_Function_G_16,0 ,560
IDE05145-ENG115300-Light configuration-Light_Function_G_17,0 ,560
IDE05145-ENG115319-Light configuration-Light_Function_G_18,0 ,560
IDE05145-ENG115338-Light configuration-Light_Function_G_19,0 ,560
IDE05145-ENG115066-Light configuration-Light_Function_G_2,0 ,560
IDE05145-ENG115357-Light configuration-Light_Function_G_20,0 ,560
IDE05145-ENG115376-Light configuration-Light_Function_G_21,0 ,560
IDE05145-ENG115395-Light configuration-Light_Function_G_22,0 ,560
IDE05145-ENG115414-Light configuration-Light_Function_G_23,0 ,560
IDE05145-ENG115433-Light configuration-Light_Function_G_24,0 ,560
IDE05145-ENG115452-Light configuration-Light_Function_G_25,0 ,560
IDE05145-ENG115471-Light configuration-Light_Function_G_26,0 ,560
IDE05145-ENG115490-Light configuration-Light_Function_G_27,0 ,560
IDE05145-ENG115509-Light configuration-Light_Function_G_28,0 ,560
IDE05145-ENG115528-Light configuration-Light_Function_G_29,0 ,560
IDE05145-ENG115085-Light configuration-Light_Function_G_3,0 ,560
IDE05145-ENG115547-Light configuration-Light_Function_G_30,0 ,560
IDE05145-ENG115566-Light configuration-Light_Function_G_31,0 ,560
IDE05145-ENG115585-Light configuration-Light_Function_G_32,0 ,560
IDE05145-ENG115604-Light configuration-Light_Function_G_33,0 ,560
IDE05145-ENG115623-Light configuration-Light_Function_G_34,0 ,560
IDE05145-ENG115104-Light configuration-Light_Function_G_4,0 ,560
IDE05145-ENG114987-Light configuration-Light_Function_G_5,0 ,560
IDE05145-ENG115125-Light configuration-Light_Function_G_6,0 ,560
IDE05145-ENG115144-Light configuration-Light_Function_G_7,0 ,560
IDE05145-ENG115163-Light configuration-Light_Function_G_8,0 ,560
IDE05145-ENG115182-Light configuration-Light_Function_G_9,0 ,560
IDE05145-ENG115029-Light configuration-Light_Function_H_0,0 ,560
IDE05145-ENG115048-Light configuration-Light_Function_H_1,0 ,560
IDE05145-ENG115010-Light configuration-Light_Function_H_10,0 ,560
IDE05145-ENG115204-Light configuration-Light_Function_H_11,0 ,560
IDE05145-ENG115223-Light configuration-Light_Function_H_12,0 ,560
IDE05145-ENG114969-Light configuration-Light_Function_H_13,0 ,560
IDE05145-ENG115244-Light configuration-Light_Function_H_14,0 ,560
IDE05145-ENG115263-Light configuration-Light_Function_H_15,0 ,560
IDE05145-ENG115282-Light configuration-Light_Function_H_16,0 ,560
IDE05145-ENG115301-Light configuration-Light_Function_H_17,0 ,560
IDE05145-ENG115320-Light configuration-Light_Function_H_18,0 ,560
IDE05145-ENG115339-Light configuration-Light_Function_H_19,0 ,560
IDE05145-ENG115067-Light configuration-Light_Function_H_2,0 ,560
IDE05145-ENG115358-Light configuration-Light_Function_H_20,0 ,560
IDE05145-ENG115377-Light configuration-Light_Function_H_21,0 ,560
IDE05145-ENG115396-Light configuration-Light_Function_H_22,0 ,560
IDE05145-ENG115415-Light configuration-Light_Function_H_23,0 ,560
IDE05145-ENG115434-Light configuration-Light_Function_H_24,0 ,560
IDE05145-ENG115453-Light configuration-Light_Function_H_25,0 ,560
IDE05145-ENG115472-Light configuration-Light_Function_H_26,0 ,560
IDE05145-ENG115491-Light configuration-Light_Function_H_27,0 ,560
IDE05145-ENG115510-Light configuration-Light_Function_H_28,0 ,560
IDE05145-ENG115529-Light configuration-Light_Function_H_29,0 ,560
IDE05145-ENG115086-Light configuration-Light_Function_H_3,0 ,560
IDE05145-ENG115548-Light configuration-Light_Function_H_30,0 ,560
IDE05145-ENG115567-Light configuration-Light_Function_H_31,0 ,560
IDE05145-ENG115586-Light configuration-Light_Function_H_32,0 ,560
IDE05145-ENG115605-Light configuration-Light_Function_H_33,0 ,560
IDE05145-ENG115624-Light configuration-Light_Function_H_34,0 ,560
IDE05145-ENG115105-Light configuration-Light_Function_H_4,0 ,560
IDE05145-ENG114988-Light configuration-Light_Function_H_5,0 ,560
IDE05145-ENG115126-Light configuration-Light_Function_H_6,0 ,560
IDE05145-ENG115145-Light configuration-Light_Function_H_7,0 ,560
IDE05145-ENG115164-Light configuration-Light_Function_H_8,0 ,560
IDE05145-ENG115183-Light configuration-Light_Function_H_9,0 ,560
IDE05145-ENG154373-Light configuration-Reserved_0,0 ,560
IDE05145-ENG101416-Light configuration-Reserved_1,0 ,560
IDE05145-ENG154318-Light configuration-Reserved_10,0 ,560
IDE05145-ENG99637-Light configuration-Reserved_11,0 ,560
IDE05145-ENG154355-Light configuration-Reserved_12,0 ,560
IDE05145-ENG154196-Light configuration-Reserved_13,0 ,560
IDE05145-ENG154298-Light configuration-Reserved_14,0 ,560
IDE05145-ENG154243-Light configuration-Reserved_15,0 ,560
IDE05145-ENG154297-Light configuration-Reserved_16,0 ,560
IDE05145-ENG154432-Light configuration-reserved_17,0 ,560
IDE05145-ENG154433-Light configuration-reserved_18,0 ,560
IDE05145-ENG154434-Light configuration-reserved_19,0 ,560
IDE05145-ENG99458-Light configuration-Reserved_2,0 ,560
IDE05145-ENG154435-Light configuration-reserved_20,0 ,560
IDE05145-ENG154436-Light configuration-reserved_21,0 ,560
IDE05145-ENG159603-Light configuration-reserved_22,0 ,560
IDE05145-ENG154437-Light configuration-reserved_23,0 ,560
IDE05145-ENG159604-Light configuration-reserved_24,0 ,560
IDE05145-ENG159605-Light configuration-reserved_25,0 ,560
IDE05145-ENG159606-Light configuration-reserved_26,0 ,560
IDE05145-ENG159607-Light configuration-reserved_27,0 ,560
IDE05145-ENG159608-Light configuration-reserved_28,0 ,560
IDE05145-ENG159609-Light configuration-reserved_29,0 ,560
IDE05145-ENG99668-Light configuration-Reserved_3,00 ,560
IDE05145-ENG159610-Light configuration-reserved_30,0 ,560
IDE05145-ENG159611-Light configuration-reserved_31,0 ,560
IDE05145-ENG114291-Light configuration-reserved_32,0 ,560
IDE05145-ENG184465-Light configuration-reserved_33,0 ,560
IDE05145-ENG159612-Light configuration-reserved_34,0 ,560
IDE05145-ENG154261-Light configuration-Reserved_4,0 ,560
IDE05145-ENG154330-Light configuration-Reserved_5,0 ,560
IDE05145-ENG154188-Light configuration-Reserved_6,0 ,560
IDE05145-ENG154256-Light configuration-Reserved_7,0 ,560
IDE05145-ENG154341-Light configuration-Reserved_8,0 ,560
IDE05145-ENG154185-Light configuration-Reserved_9,0 ,560
IDE05145-ENG115013-Light configuration-Type_Of_Load_0,Blinkleuchten ,560
IDE05145-ENG115032-Light configuration-Type_Of_Load_1,Blinkleuchten ,560
IDE05145-ENG114995-Light configuration-Type_Of_Load_10,not active ,560
IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115207-Light configuration-Type_Of_Load_12,allgemeine Scheinwerfer ,560
IDE05145-ENG114954-Light configuration-Type_Of_Load_13,allgemeine Scheinwerfer ,560
IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115266-Light configuration-Type_Of_Load_16,LED Blinkleuchten ,560
IDE05145-ENG115285-Light configuration-Type_Of_Load_17,LED Blinkleuchten ,560
IDE05145-ENG115304-Light configuration-Type_Of_Load_18,Blinkleuchten ,560
IDE05145-ENG115323-Light configuration-Type_Of_Load_19,Blinkleuchten ,560
IDE05145-ENG115051-Light configuration-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115342-Light configuration-Type_Of_Load_20,Bremsleuchten ,560
IDE05145-ENG115361-Light configuration-Type_Of_Load_21,Bremsleuchten ,560
IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte ,560
IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115437-Light configuration-Type_Of_Load_25,2* 5W ,560
IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeineGluehlampe12W ,560
IDE05145-ENG115070-Light configuration-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115532-Light configuration-Type_Of_Load_30,allgemeineGluehlampe12W ,560
IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active ,560
IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active ,560
IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active ,560
IDE05145-ENG115608-Light configuration-Type_Of_Load_34,not active ,560
IDE05145-ENG115089-Light configuration-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG114973-Light configuration-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Low beam ,560
IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Low beam ,560
IDE05145-ENG115148-Light configuration-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,560
IDE05145-ENG115167-Light configuration-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,560
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,6
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,6
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,6
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,6
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active ,6
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,6
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min,2
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0 ,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,5
IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
IDE08542-IDE02022-Access control 2-Comfort opening,active ,6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active ,6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No ,6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No ,6
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active ,6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active ,6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,6
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,active ,6
IDE08542-ENG115671-Access control 2-Regenschließen,not active ,6
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open ,6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,6
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,not active ,6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms,4
IDE08786-ENG142177-Assistance light functions-Assistance_lighting_sensitivity_adjustable,Not Present ,4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,not active ,4
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis ,4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,not active ,1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,36 ,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,40 ,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm ,7
MAS01490-Energy management,Energy management not active ,1
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed ,1
MAS08233-ENG126575-other-mute_mode_aktiv,not active ,1
MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed ,1
ENG124896-Adaptation_theft_protection,not active ,2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.0 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.0 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.0 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.0 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.0 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.0 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.0 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.0 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.0 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,100.0 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,100.0 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,100.0 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,100.0 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,100.0 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,0 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,0 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,0 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,0 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,0.0 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,0.0 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,0.0 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,0.0 ,10
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,Blinkleuchten ,16
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,0 ,16
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0 ,16
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize ,16
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize ,16
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize ,16
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0 ,16
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0 ,16
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,00 ,16
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00 ,16
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always ,16
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,not active ,16
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active ,16
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active ,16
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active ,16
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active ,16
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active ,16
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active ,16
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active ,16
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,not active ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,100 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,22 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,38 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,Nebellicht links ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,Abbiegelicht links ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,allgemeine Scheinwerfer ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,100 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,23 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,42 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,Nebellicht rechts ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,Abbiegelicht rechts ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,allgemeine Scheinwerfer ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,00 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,00 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED Blinkleuchten ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,00 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,00 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED Blinkleuchten ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100 ,16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0 ,16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize ,16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize ,16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize ,16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0 ,16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0 ,16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,18 ,16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,18 ,16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always ,16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken rechts Hellphase ,16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not active ,16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not active ,16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not active ,16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not active ,16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not active ,16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not active ,16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not active ,16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,Blinkleuchten ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,2B ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,09 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,Bremsleuchten ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,2D ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,19 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,Bremsleuchten ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,29 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,60 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,29 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,0A ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not active ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,60 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,2A ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,1A ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not active ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,00 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,00 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not active ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,2* 5W ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergestecktundRechtsverkehr ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,0 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,maximize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,0 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,26 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,35 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Parking light ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,Parking light left ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,not active ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,not active ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,not active ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeineGluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,0 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,00 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,00 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not active ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not active ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not active ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not active ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not active ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not active ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not active ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,0 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,maximize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,0 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,27 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,3F ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Parking light ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,Parking light right ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,not active ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,not active ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,not active ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,0 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,20 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,3A ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not active ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,not active ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,0 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,21 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,44 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not active ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,not active ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,0 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,ComingHome LeavingHome ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,not active ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,not active ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Low beam ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,0 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,ComingHome LeavingHome ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,not active ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,not active ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Low beam ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam ,16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam ,16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0 ,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10 ,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100 ,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150 ,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253 ,12
ENG130141-Patch_Code: Beifahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130136-Patch_Code: Fahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117299-Reversing_Threshold_Driver_Side_Rear,0 %,1
ENG117298-Reversing_Threshold_Passenger_Side_Front,0 %,1
ENG130135-Window_Regulator_Supplier_Settings_Driver_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130138-Window_Regulator_Supplier_Settings_Passener_Side_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130139-Window_Regulator_Supplier_Settings_Passener_Side_2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130140-Window_Regulator_Supplier_Settings_Passener_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,88
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ADP OF 17:
IDE00295-Oil temperature display,On ,1
IDE00301-Distance,47316 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,English ,1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,15 H,1
IDE00501-Minute,16 min,1
IDE00502-Year,2019 yr,2
IDE00503-Month,12 mon,1
IDE00504-Day,8 d,1
IDE00510-ESI: distance driven from inspection,1565 km,3
IDE00511-ESI: time from inspection,29 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,good oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,2200 km,2
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,2001 d,2
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02489-Display depiction,Not available ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
IDE03329-Driving profiled for range remaining,6.4 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
IDE03346-MAS02957-Units adjusted-Time,24h ,3
IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
IDE03348-MAS01456-Speed warning-Speed,190 ,2
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour ,2
IDE03348-Speed warning-,active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,365 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,1500 km,2
IDE03352-FIX: Time since last time-dependent inspection,29 d,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
IDE03867-Deactivate seat belt warning,No ,1
IDE04169-Display correction of consumption and operating range: gas,100 %,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,No display ,1
IDE06922-No-voltage display,Unknown (2),1
IDE07221-Cylinder shut-off,Display ,1
IDE08140-Driving profiled for range remaining CNG,6.0 kg/100 km,2
IDE08247-Driving profile for range remaining LPG,10.0 l/100km,2
MAS03685-Digital speedometer,Display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,35 l,1
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,66 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,96 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,B4 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,05 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,0F ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,28 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0C ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,19 ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,29 ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,C8 ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,02 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,02 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,0E ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,19 ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,08 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,12 ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
ENG119874-Gas_functionality,not active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light ,1
ENG119882-init_fuel_algorithm,No ,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
ENG119876-Service_Key_Clear_All_Counter,Yes ,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,30 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
ADP MAP OF 5F:
IDE00346-Summertime-automatic,manual ,1
IDE00758-Base volume of telephone,50 %,1
IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02063-Time display for start screen,2.0 s,1
IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,30 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,30 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,30 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,30 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,30 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,30 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,30 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,30 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,30 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,30 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,30 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,30 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,30 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,30 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,30 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,30 ,49
IDE02502-Confirmation of installation change,C5 75 ,2
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
MAS00951-Bluetooth,On ,1
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15 ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,CAB_9 ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Comfort data bus ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Databus drivetrain ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Comfort data bus ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Comfort data bus ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Comfort data bus ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_9 ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Comfort data bus ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,CAB_9 ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,not activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Databus drivetrain ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Comfort data bus ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Comfort data bus ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Comfort data bus ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Not available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,13 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,35 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,70 %,12
ENG117808-p_HMI_Display,13 %,1
ib97
Croatia
C?ID=375363
Still not working after changes.
Here is the new autoscan:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFY078505   Mileage: 47316km-29400miles
Address 01: Engine (J623-CJZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
   Component: 1.2l R4 TSI   H21 7876
   Revision: R5H21---
   Coding: 01110012230411080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS01104E906027BB 001005
   ROD: EV_ECM12TFS01104E906027BB.rod
   VCID: 65964AABE5EF225F5A1-8030
   CAN Converter 01:
Readiness: 0000 0001
   Part No SW: 6C0 907 379     HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0002
   Serial number: 08511533140524
   Coding: 21DD2885492A33C8091910690056841492CC90080005C7090C00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
   VCID: 6C803F8F0605131705F-8038
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H02 0105
   Serial number:  1406051B-0132
   Coding: 200000001000100000
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1D66224B8D3F2A9FC21-8048
329475 - Motor for Fresh Air / Recirculated Air Flap
          B108B 13 [012] - Open Circuit
                    Reset counter: 59
                    Mileage: 47202 km
                    Date: 2019.12.07
                    Time: 13:05:26
                    Voltage terminal 30: 14.5 V
          B10CD 00 [012] - -
          [Funktionseinschränkung durch Energiemangement]
                    Reset counter: 59
                    Mileage: 47202 km
                    Date: 2019.12.07
                    Time: 13:01:58
                    Voltage terminal 30: 11.4 V
                    CAN input signal(s) status-Transport mode: OFF
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 A    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H06 0046
   Serial number: 007278013822
   Coding: 000008404253005B4B844000400703880000580251010000000000000000
   ASAM Dataset: EV_BCMA0 004003
   ROD: EV_MQBA0.rod
   VCID: 2E04F587F099A1076BB-807A
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU021051441413454
   Coding: 0400A0
   Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU026051441464110
   Coding: 1400A0
   Subsystem 3 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU023051441433135
   Coding: 0400A0
   Subsystem 4 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8610
   Serial number: KU0KU026051441460870
   Coding: 1400A0
533013 - Databus
          [ELV_01 Datenbus fehlende Botschaft]
                    Reset counter: 59
                    Mileage: 47202 km
                    Date: 2019.12.07
                    Time: 12:51:44
538389 - Databus
          [Kessy_04 Datenbus fehlende Botschaft]
                    Reset counter: 59
                    Mileage: 47202 km
                    Date: 2019.12.07
                    Time: 12:51:44
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag01B 001 0330
   Revision: --------    Serial number: 003LM002F3K0
   Coding: 88C0C000000000005C0000CA000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 313EEEFBE1A7BEFF769-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 821 405 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00C5154F2B1E3BZ
   Subsystem 2 - Part No SW: -----------    HW: 410 821 405 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00B51569C52801H
   Subsystem 3 - Part No SW: -----------    HW: 442 152 905 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00A715397B4C2FQ
   Subsystem 4 - Part No SW: -----------    HW: 442 152 905 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00A715397B1636A
   Part No SW: 6C0 920 740 A    HW: 6C0 920 740 A
   Component: KOMBI         211 0260
   Coding: 072509002180000801082A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009036
   VCID: 20181BBFBA4D0777E97-8074
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H06 0046
   Revision: --------    Serial number: 007278013822
   Coding: 030100046F0A560071000000000000010001000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   Subsystem 1 - Part No SW: 6C0 959 442     HW: 6C0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H03 0015
   Serial number: 1431411352301154AB1B
   Coding: 240000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 61148737112821301557
   Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3211
   Serial number: PE6B1106
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 323CE1F7E4A185E70F3-8066
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 6C0 035 869 B    HW: 6C0 035 869 B
   Component: MU-E--ER      820 6180
   Serial number: 04061400010262
   Coding: 02620000BE00000041110001000000001F0000840000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001017
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 2A0CF997CC71CD27B73-807E
End----------(Elapsed Time: 00:39, VBatt start/end: 12.1V/12.1V)-----------
Adaptation map of 09:
IDE00001-ENG130235-Production mode-Entry_control,not active ,3
IDE00001-ENG130233-Production mode-Exit_lights_Heading_time_15_s,not active ,3
IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3
IDE00001-ENG130234-Production mode-Window_regulator_kl_15_nr_2,not active ,3
IDE00001-ENG130231-Production mode-Window_regulator_nr_1,not active ,3
IDE00001-ENG130232-Production mode-Window_reversing_threshold,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,9
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition ,9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,9
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition,active ,9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,not active ,9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,not activated ,9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp ,9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,9
IDE02152-Characteristics in production mode,0 ms,4
IDE02200-Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,32
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,2
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active ,2
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active ,2
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,3
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,3
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,3
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,3
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,3
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,3
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,3
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,3
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active ,3
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %,4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %,4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %,4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.50 °,13
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,13
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,13
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,13
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,13
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,13
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,180 °,13
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,13
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,120 °,13
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,13
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,13
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,combined ,4
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken,not active ,4
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,4
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen,5 ,4
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS ,4
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2,not enabled ,4
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active ,4
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active ,4
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.100 %,4
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,3.0 %,4
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h,14
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht,active ,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren,not active ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,255 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,manual ,5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,ignition ,5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0 ,5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,0.0 ,5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,not enabled ,5
IDE04926-ENG126569-Comfort illumination-lho_aktiviert,not active ,5
IDE04926-ENG126570-Comfort illumination-lho_zeit,not active ,5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,not active ,5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,not active ,5
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C,8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C,8
IDE04927-ENG126613-Window heater-Aussenspiegelheizung,0.0 s,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,1
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,1
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,1
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,1
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,1
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,4
IDE05142-ENG116706-Access control-Autounlock NAR,active ,4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,4
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,4
IDE05142-ENG115755-Access control-Notschließfunktion,active ,4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
IDE05142-ENG115758-Access control-Valet Parking,not active ,4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,4
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0,34 ,560
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1,3E ,560
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10,00 ,560
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11,00 ,560
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12,38 ,560
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13,42 ,560
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14,00 ,560
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15,00 ,560
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16,00 ,560
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17,00 ,560
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18,08 ,560
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19,18 ,560
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2,35 ,560
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20,09 ,560
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21,19 ,560
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22,29 ,560
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23,0A ,560
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24,1A ,560
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25,00 ,560
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26,0C ,560
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27,00 ,560
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28,1B ,560
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29,00 ,560
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3,3F ,560
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30,00 ,560
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31,00 ,560
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32,00 ,560
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33,00 ,560
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34,00 ,560
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4,3A ,560
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5,44 ,560
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6,36 ,560
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7,40 ,560
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8,37 ,560
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9,41 ,560
IDE05145-ENG115018-Light configuration-Dimming_AB_0,100 ,560
IDE05145-ENG115037-Light configuration-Dimming_AB_1,100 ,560
IDE05145-ENG114999-Light configuration-Dimming_AB_10,0 ,560
IDE05145-ENG115193-Light configuration-Dimming_AB_11,100 ,560
IDE05145-ENG115212-Light configuration-Dimming_AB_12,100 ,560
IDE05145-ENG114958-Light configuration-Dimming_AB_13,100 ,560
IDE05145-ENG115233-Light configuration-Dimming_AB_14,100 ,560
IDE05145-ENG115252-Light configuration-Dimming_AB_15,100 ,560
IDE05145-ENG115271-Light configuration-Dimming_AB_16,100 ,560
IDE05145-ENG115290-Light configuration-Dimming_AB_17,100 ,560
IDE05145-ENG115309-Light configuration-Dimming_AB_18,100 ,560
IDE05145-ENG115328-Light configuration-Dimming_AB_19,100 ,560
IDE05145-ENG115056-Light configuration-Dimming_AB_2,100 ,560
IDE05145-ENG115347-Light configuration-Dimming_AB_20,100 ,560
IDE05145-ENG115366-Light configuration-Dimming_AB_21,100 ,560
IDE05145-ENG115385-Light configuration-Dimming_AB_22,100 ,560
IDE05145-ENG115404-Light configuration-Dimming_AB_23,60 ,560
IDE05145-ENG115423-Light configuration-Dimming_AB_24,60 ,560
IDE05145-ENG115442-Light configuration-Dimming_AB_25,100 ,560
IDE05145-ENG115461-Light configuration-Dimming_AB_26,100 ,560
IDE05145-ENG115480-Light configuration-Dimming_AB_27,100 ,560
IDE05145-ENG115499-Light configuration-Dimming_AB_28,100 ,560
IDE05145-ENG115518-Light configuration-Dimming_AB_29,100 ,560
IDE05145-ENG115075-Light configuration-Dimming_AB_3,100 ,560
IDE05145-ENG115537-Light configuration-Dimming_AB_30,100 ,560
IDE05145-ENG115556-Light configuration-Dimming_AB_31,0 ,560
IDE05145-ENG115575-Light configuration-Dimming_AB_32,0 ,560
IDE05145-ENG115594-Light configuration-Dimming_AB_33,0 ,560
IDE05145-ENG115613-Light configuration-Dimming_AB_34,0 ,560
IDE05145-ENG115094-Light configuration-Dimming_AB_4,100 ,560
IDE05145-ENG114977-Light configuration-Dimming_AB_5,100 ,560
IDE05145-ENG115115-Light configuration-Dimming_AB_6,100 ,560
IDE05145-ENG115134-Light configuration-Dimming_AB_7,100 ,560
IDE05145-ENG115153-Light configuration-Dimming_AB_8,100 ,560
IDE05145-ENG115172-Light configuration-Dimming_AB_9,100 ,560
IDE05145-ENG115022-Light configuration-Dimming_CD_0,0 ,560
IDE05145-ENG115041-Light configuration-Dimming_CD_1,0 ,560
IDE05145-ENG115003-Light configuration-Dimming_CD_10,0 ,560
IDE05145-ENG115197-Light configuration-Dimming_CD_11,0 ,560
IDE05145-ENG115216-Light configuration-Dimming_CD_12,0 ,560
IDE05145-ENG114962-Light configuration-Dimming_CD_13,0 ,560
IDE05145-ENG115237-Light configuration-Dimming_CD_14,0 ,560
IDE05145-ENG115256-Light configuration-Dimming_CD_15,0 ,560
IDE05145-ENG115275-Light configuration-Dimming_CD_16,0 ,560
IDE05145-ENG115294-Light configuration-Dimming_CD_17,0 ,560
IDE05145-ENG115313-Light configuration-Dimming_CD_18,0 ,560
IDE05145-ENG115332-Light configuration-Dimming_CD_19,0 ,560
IDE05145-ENG115060-Light configuration-Dimming_CD_2,0 ,560
IDE05145-ENG115351-Light configuration-Dimming_CD_20,0 ,560
IDE05145-ENG115370-Light configuration-Dimming_CD_21,0 ,560
IDE05145-ENG115389-Light configuration-Dimming_CD_22,0 ,560
IDE05145-ENG115408-Light configuration-Dimming_CD_23,0 ,560
IDE05145-ENG115427-Light configuration-Dimming_CD_24,0 ,560
IDE05145-ENG115446-Light configuration-Dimming_CD_25,0 ,560
IDE05145-ENG115465-Light configuration-Dimming_CD_26,0 ,560
IDE05145-ENG115484-Light configuration-Dimming_CD_27,0 ,560
IDE05145-ENG115503-Light configuration-Dimming_CD_28,0 ,560
IDE05145-ENG115522-Light configuration-Dimming_CD_29,0 ,560
IDE05145-ENG115079-Light configuration-Dimming_CD_3,0 ,560
IDE05145-ENG115541-Light configuration-Dimming_CD_30,0 ,560
IDE05145-ENG115560-Light configuration-Dimming_CD_31,0 ,560
IDE05145-ENG115579-Light configuration-Dimming_CD_32,0 ,560
IDE05145-ENG115598-Light configuration-Dimming_CD_33,0 ,560
IDE05145-ENG115617-Light configuration-Dimming_CD_34,0 ,560
IDE05145-ENG115098-Light configuration-Dimming_CD_4,0 ,560
IDE05145-ENG114981-Light configuration-Dimming_CD_5,0 ,560
IDE05145-ENG115119-Light configuration-Dimming_CD_6,0 ,560
IDE05145-ENG115138-Light configuration-Dimming_CD_7,0 ,560
IDE05145-ENG115157-Light configuration-Dimming_CD_8,0 ,560
IDE05145-ENG115176-Light configuration-Dimming_CD_9,0 ,560
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0,maximize ,560
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1,maximize ,560
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10,maximize ,560
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11,maximize ,560
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12,maximize ,560
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13,maximize ,560
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14,maximize ,560
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15,maximize ,560
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16,maximize ,560
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17,maximize ,560
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18,maximize ,560
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19,maximize ,560
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2,maximize ,560
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20,maximize ,560
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21,maximize ,560
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22,maximize ,560
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23,maximize ,560
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24,maximize ,560
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25,maximize ,560
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26,maximize ,560
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27,maximize ,560
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28,maximize ,560
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29,maximize ,560
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3,maximize ,560
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30,maximize ,560
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31,maximize ,560
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32,maximize ,560
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33,maximize ,560
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34,maximize ,560
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4,maximize ,560
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5,maximize ,560
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6,maximize ,560
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7,maximize ,560
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8,maximize ,560
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9,maximize ,560
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0,maximize ,560
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1,maximize ,560
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10,maximize ,560
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11,maximize ,560
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12,maximize ,560
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13,maximize ,560
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14,maximize ,560
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15,maximize ,560
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16,maximize ,560
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17,maximize ,560
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18,maximize ,560
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19,maximize ,560
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2,maximize ,560
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20,maximize ,560
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21,maximize ,560
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22,maximize ,560
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23,maximize ,560
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24,maximize ,560
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25,maximize ,560
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26,maximize ,560
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27,maximize ,560
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28,maximize ,560
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29,maximize ,560
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3,maximize ,560
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30,maximize ,560
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31,maximize ,560
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32,maximize ,560
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33,maximize ,560
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34,maximize ,560
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4,maximize ,560
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5,maximize ,560
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6,maximize ,560
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7,maximize ,560
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8,maximize ,560
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9,maximize ,560
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0,maximize ,560
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1,maximize ,560
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10,maximize ,560
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11,maximize ,560
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12,maximize ,560
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13,maximize ,560
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14,maximize ,560
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15,maximize ,560
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16,maximize ,560
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17,maximize ,560
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18,maximize ,560
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19,maximize ,560
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2,maximize ,560
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20,maximize ,560
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21,maximize ,560
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22,maximize ,560
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23,maximize ,560
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24,maximize ,560
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25,maximize ,560
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26,maximize ,560
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27,maximize ,560
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28,maximize ,560
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29,maximize ,560
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3,maximize ,560
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30,maximize ,560
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31,maximize ,560
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32,maximize ,560
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33,maximize ,560
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34,maximize ,560
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4,maximize ,560
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5,maximize ,560
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6,maximize ,560
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7,maximize ,560
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8,maximize ,560
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9,maximize ,560
IDE05145-ENG115026-Light configuration-Dimming_EF_0,0 ,560
IDE05145-ENG115045-Light configuration-Dimming_EF_1,0 ,560
IDE05145-ENG115007-Light configuration-Dimming_EF_10,0 ,560
IDE05145-ENG115201-Light configuration-Dimming_EF_11,0 ,560
IDE05145-ENG115220-Light configuration-Dimming_EF_12,0 ,560
IDE05145-ENG114966-Light configuration-Dimming_EF_13,0 ,560
IDE05145-ENG115241-Light configuration-Dimming_EF_14,0 ,560
IDE05145-ENG115260-Light configuration-Dimming_EF_15,0 ,560
IDE05145-ENG115279-Light configuration-Dimming_EF_16,0 ,560
IDE05145-ENG115298-Light configuration-Dimming_EF_17,0 ,560
IDE05145-ENG115317-Light configuration-Dimming_EF_18,0 ,560
IDE05145-ENG115336-Light configuration-Dimming_EF_19,0 ,560
IDE05145-ENG115064-Light configuration-Dimming_EF_2,0 ,560
IDE05145-ENG115355-Light configuration-Dimming_EF_20,0 ,560
IDE05145-ENG115374-Light configuration-Dimming_EF_21,0 ,560
IDE05145-ENG115393-Light configuration-Dimming_EF_22,0 ,560
IDE05145-ENG115412-Light configuration-Dimming_EF_23,0 ,560
IDE05145-ENG115431-Light configuration-Dimming_EF_24,0 ,560
IDE05145-ENG115450-Light configuration-Dimming_EF_25,0 ,560
IDE05145-ENG115469-Light configuration-Dimming_EF_26,0 ,560
IDE05145-ENG115488-Light configuration-Dimming_EF_27,0 ,560
IDE05145-ENG115507-Light configuration-Dimming_EF_28,0 ,560
IDE05145-ENG115526-Light configuration-Dimming_EF_29,0 ,560
IDE05145-ENG115083-Light configuration-Dimming_EF_3,0 ,560
IDE05145-ENG115545-Light configuration-Dimming_EF_30,0 ,560
IDE05145-ENG115564-Light configuration-Dimming_EF_31,0 ,560
IDE05145-ENG115583-Light configuration-Dimming_EF_32,0 ,560
IDE05145-ENG115602-Light configuration-Dimming_EF_33,0 ,560
IDE05145-ENG115621-Light configuration-Dimming_EF_34,0 ,560
IDE05145-ENG115102-Light configuration-Dimming_EF_4,0 ,560
IDE05145-ENG114985-Light configuration-Dimming_EF_5,0 ,560
IDE05145-ENG115123-Light configuration-Dimming_EF_6,0 ,560
IDE05145-ENG115142-Light configuration-Dimming_EF_7,0 ,560
IDE05145-ENG115161-Light configuration-Dimming_EF_8,0 ,560
IDE05145-ENG115180-Light configuration-Dimming_EF_9,0 ,560
IDE05145-ENG115030-Light configuration-Dimming_GH_0,0 ,560
IDE05145-ENG115049-Light configuration-Dimming_GH_1,0 ,560
IDE05145-ENG115011-Light configuration-Dimming_GH_10,0 ,560
IDE05145-ENG115205-Light configuration-Dimming_GH_11,0 ,560
IDE05145-ENG115224-Light configuration-Dimming_GH_12,0 ,560
IDE05145-ENG114970-Light configuration-Dimming_GH_13,0 ,560
IDE05145-ENG115245-Light configuration-Dimming_GH_14,0 ,560
IDE05145-ENG115264-Light configuration-Dimming_GH_15,0 ,560
IDE05145-ENG115283-Light configuration-Dimming_GH_16,0 ,560
IDE05145-ENG115302-Light configuration-Dimming_GH_17,0 ,560
IDE05145-ENG115321-Light configuration-Dimming_GH_18,0 ,560
IDE05145-ENG115340-Light configuration-Dimming_GH_19,0 ,560
IDE05145-ENG115068-Light configuration-Dimming_GH_2,0 ,560
IDE05145-ENG115359-Light configuration-Dimming_GH_20,0 ,560
IDE05145-ENG115378-Light configuration-Dimming_GH_21,0 ,560
IDE05145-ENG115397-Light configuration-Dimming_GH_22,0 ,560
IDE05145-ENG115416-Light configuration-Dimming_GH_23,0 ,560
IDE05145-ENG115435-Light configuration-Dimming_GH_24,0 ,560
IDE05145-ENG115454-Light configuration-Dimming_GH_25,0 ,560
IDE05145-ENG115473-Light configuration-Dimming_GH_26,0 ,560
IDE05145-ENG115492-Light configuration-Dimming_GH_27,0 ,560
IDE05145-ENG115511-Light configuration-Dimming_GH_28,0 ,560
IDE05145-ENG115530-Light configuration-Dimming_GH_29,0 ,560
IDE05145-ENG115087-Light configuration-Dimming_GH_3,0 ,560
IDE05145-ENG115549-Light configuration-Dimming_GH_30,0 ,560
IDE05145-ENG115568-Light configuration-Dimming_GH_31,0 ,560
IDE05145-ENG115587-Light configuration-Dimming_GH_32,0 ,560
IDE05145-ENG115606-Light configuration-Dimming_GH_33,0 ,560
IDE05145-ENG115625-Light configuration-Dimming_GH_34,0 ,560
IDE05145-ENG115106-Light configuration-Dimming_GH_4,0 ,560
IDE05145-ENG114989-Light configuration-Dimming_GH_5,0 ,560
IDE05145-ENG115127-Light configuration-Dimming_GH_6,0 ,560
IDE05145-ENG115146-Light configuration-Dimming_GH_7,0 ,560
IDE05145-ENG115165-Light configuration-Dimming_GH_8,0 ,560
IDE05145-ENG115184-Light configuration-Dimming_GH_9,0 ,560
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14 ,560
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15 ,560
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,00 ,560
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,00 ,560
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,22 ,560
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,23 ,560
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00 ,560
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,00 ,560
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,00 ,560
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,00 ,560
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,16 ,560
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,18 ,560
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,26 ,560
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,2B ,560
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,2D ,560
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,2C ,560
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,29 ,560
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,2A ,560
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,00 ,560
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,2E ,560
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,08 ,560
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,32 ,560
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,01 ,560
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,27 ,560
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,07 ,560
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00 ,560
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00 ,560
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,00 ,560
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,00 ,560
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,20 ,560
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,21 ,560
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A ,560
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B ,560
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,1C ,560
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,1D ,560
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0,Always ,560
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1,Always ,560
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10,Always ,560
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11,Always ,560
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12,Always ,560
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13,Always ,560
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14,Always ,560
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15,Always ,560
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16,Always ,560
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17,Always ,560
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18,Always ,560
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19,Always ,560
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2,Always ,560
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20,Always ,560
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21,Always ,560
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22,Always ,560
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23,Always ,560
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24,Always ,560
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25,Always ,560
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26,Always ,560
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27,Always ,560
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28,Always ,560
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29,Always ,560
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3,Always ,560
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30,Always ,560
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31,Always ,560
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32,Always ,560
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33,Always ,560
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34,Always ,560
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4,Always ,560
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5,Always ,560
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6,Always ,560
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7,Always ,560
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8,Always ,560
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9,Always ,560
IDE05145-ENG115016-Light configuration-Light_Function_A_0,2 ,560
IDE05145-ENG115035-Light configuration-Light_Function_A_1,4 ,560
IDE05145-ENG114997-Light configuration-Light_Function_A_10,0 ,560
IDE05145-ENG115191-Light configuration-Light_Function_A_11,62 ,560
IDE05145-ENG115210-Light configuration-Light_Function_A_12,18 ,560
IDE05145-ENG114956-Light configuration-Light_Function_A_13,19 ,560
IDE05145-ENG115231-Light configuration-Light_Function_A_14,63 ,560
IDE05145-ENG115250-Light configuration-Light_Function_A_15,64 ,560
IDE05145-ENG115269-Light configuration-Light_Function_A_16,2 ,560
IDE05145-ENG115288-Light configuration-Light_Function_A_17,4 ,560
IDE05145-ENG115307-Light configuration-Light_Function_A_18,2 ,560
IDE05145-ENG115326-Light configuration-Light_Function_A_19,4 ,560
IDE05145-ENG115054-Light configuration-Light_Function_A_2,8 ,560
IDE05145-ENG115345-Light configuration-Light_Function_A_20,24 ,560
IDE05145-ENG115364-Light configuration-Light_Function_A_21,24 ,560
IDE05145-ENG115383-Light configuration-Light_Function_A_22,24 ,560
IDE05145-ENG115402-Light configuration-Light_Function_A_23,8 ,560
IDE05145-ENG115421-Light configuration-Light_Function_A_24,8 ,560
IDE05145-ENG115440-Light configuration-Light_Function_A_25,8 ,560
IDE05145-ENG115459-Light configuration-Light_Function_A_26,27 ,560
IDE05145-ENG115478-Light configuration-Light_Function_A_27,38 ,560
IDE05145-ENG115497-Light configuration-Light_Function_A_28,25 ,560
IDE05145-ENG115516-Light configuration-Light_Function_A_29,37 ,560
IDE05145-ENG115073-Light configuration-Light_Function_A_3,8 ,560
IDE05145-ENG115535-Light configuration-Light_Function_A_30,41 ,560
IDE05145-ENG115554-Light configuration-Light_Function_A_31,0 ,560
IDE05145-ENG115573-Light configuration-Light_Function_A_32,0 ,560
IDE05145-ENG115592-Light configuration-Light_Function_A_33,0 ,560
IDE05145-ENG115611-Light configuration-Light_Function_A_34,0 ,560
IDE05145-ENG115092-Light configuration-Light_Function_A_4,20 ,560
IDE05145-ENG114975-Light configuration-Light_Function_A_5,20 ,560
IDE05145-ENG115113-Light configuration-Light_Function_A_6,11 ,560
IDE05145-ENG115132-Light configuration-Light_Function_A_7,12 ,560
IDE05145-ENG115151-Light configuration-Light_Function_A_8,13 ,560
IDE05145-ENG115170-Light configuration-Light_Function_A_9,14 ,560
IDE05145-ENG115017-Light configuration-Light_Function_B_0,0 ,560
IDE05145-ENG115036-Light configuration-Light_Function_B_1,0 ,560
IDE05145-ENG114998-Light configuration-Light_Function_B_10,0 ,560
IDE05145-ENG115192-Light configuration-Light_Function_B_11,0 ,560
IDE05145-ENG115211-Light configuration-Light_Function_B_12,22 ,560
IDE05145-ENG114957-Light configuration-Light_Function_B_13,23 ,560
IDE05145-ENG115232-Light configuration-Light_Function_B_14,0 ,560
IDE05145-ENG115251-Light configuration-Light_Function_B_15,0 ,560
IDE05145-ENG115270-Light configuration-Light_Function_B_16,0 ,560
IDE05145-ENG115289-Light configuration-Light_Function_B_17,0 ,560
IDE05145-ENG115308-Light configuration-Light_Function_B_18,0 ,560
IDE05145-ENG115327-Light configuration-Light_Function_B_19,0 ,560
IDE05145-ENG115055-Light configuration-Light_Function_B_2,9 ,560
IDE05145-ENG115346-Light configuration-Light_Function_B_20,0 ,560
IDE05145-ENG115365-Light configuration-Light_Function_B_21,0 ,560
IDE05145-ENG115384-Light configuration-Light_Function_B_22,0 ,560
IDE05145-ENG115403-Light configuration-Light_Function_B_23,9 ,560
IDE05145-ENG115422-Light configuration-Light_Function_B_24,10 ,560
IDE05145-ENG115441-Light configuration-Light_Function_B_25,0 ,560
IDE05145-ENG115460-Light configuration-Light_Function_B_26,0 ,560
IDE05145-ENG115479-Light configuration-Light_Function_B_27,0 ,560
IDE05145-ENG115498-Light configuration-Light_Function_B_28,0 ,560
IDE05145-ENG115517-Light configuration-Light_Function_B_29,0 ,560
IDE05145-ENG115074-Light configuration-Light_Function_B_3,10 ,560
IDE05145-ENG115536-Light configuration-Light_Function_B_30,0 ,560
IDE05145-ENG115555-Light configuration-Light_Function_B_31,0 ,560
IDE05145-ENG115574-Light configuration-Light_Function_B_32,0 ,560
IDE05145-ENG115593-Light configuration-Light_Function_B_33,0 ,560
IDE05145-ENG115612-Light configuration-Light_Function_B_34,0 ,560
IDE05145-ENG115093-Light configuration-Light_Function_B_4,0 ,560
IDE05145-ENG114976-Light configuration-Light_Function_B_5,0 ,560
IDE05145-ENG115114-Light configuration-Light_Function_B_6,30 ,560
IDE05145-ENG115133-Light configuration-Light_Function_B_7,30 ,560
IDE05145-ENG115152-Light configuration-Light_Function_B_8,15 ,560
IDE05145-ENG115171-Light configuration-Light_Function_B_9,15 ,560
IDE05145-ENG115020-Light configuration-Light_Function_C_0,0 ,560
IDE05145-ENG115039-Light configuration-Light_Function_C_1,0 ,560
IDE05145-ENG115001-Light configuration-Light_Function_C_10,0 ,560
IDE05145-ENG115195-Light configuration-Light_Function_C_11,0 ,560
IDE05145-ENG115214-Light configuration-Light_Function_C_12,0 ,560
IDE05145-ENG114960-Light configuration-Light_Function_C_13,0 ,560
IDE05145-ENG115235-Light configuration-Light_Function_C_14,0 ,560
IDE05145-ENG115254-Light configuration-Light_Function_C_15,0 ,560
IDE05145-ENG115273-Light configuration-Light_Function_C_16,0 ,560
IDE05145-ENG115292-Light configuration-Light_Function_C_17,0 ,560
IDE05145-ENG115311-Light configuration-Light_Function_C_18,0 ,560
IDE05145-ENG115330-Light configuration-Light_Function_C_19,0 ,560
IDE05145-ENG115058-Light configuration-Light_Function_C_2,0 ,560
IDE05145-ENG115349-Light configuration-Light_Function_C_20,0 ,560
IDE05145-ENG115368-Light configuration-Light_Function_C_21,0 ,560
IDE05145-ENG115387-Light configuration-Light_Function_C_22,0 ,560
IDE05145-ENG115406-Light configuration-Light_Function_C_23,0 ,560
IDE05145-ENG115425-Light configuration-Light_Function_C_24,0 ,560
IDE05145-ENG115444-Light configuration-Light_Function_C_25,0 ,560
IDE05145-ENG115463-Light configuration-Light_Function_C_26,0 ,560
IDE05145-ENG115482-Light configuration-Light_Function_C_27,0 ,560
IDE05145-ENG115501-Light configuration-Light_Function_C_28,0 ,560
IDE05145-ENG115519-Light configuration-Light_Function_C_29,0 ,560
IDE05145-ENG115077-Light configuration-Light_Function_C_3,0 ,560
IDE05145-ENG115539-Light configuration-Light_Function_C_30,0 ,560
IDE05145-ENG115558-Light configuration-Light_Function_C_31,0 ,560
IDE05145-ENG115577-Light configuration-Light_Function_C_32,0 ,560
IDE05145-ENG115596-Light configuration-Light_Function_C_33,0 ,560
IDE05145-ENG115615-Light configuration-Light_Function_C_34,0 ,560
IDE05145-ENG115096-Light configuration-Light_Function_C_4,0 ,560
IDE05145-ENG114979-Light configuration-Light_Function_C_5,0 ,560
IDE05145-ENG115117-Light configuration-Light_Function_C_6,0 ,560
IDE05145-ENG115136-Light configuration-Light_Function_C_7,0 ,560
IDE05145-ENG115155-Light configuration-Light_Function_C_8,0 ,560
IDE05145-ENG115174-Light configuration-Light_Function_C_9,0 ,560
IDE05145-ENG115021-Light configuration-Light_Function_D_0,0 ,560
IDE05145-ENG115040-Light configuration-Light_Function_D_1,0 ,560
IDE05145-ENG115002-Light configuration-Light_Function_D_10,0 ,560
IDE05145-ENG115196-Light configuration-Light_Function_D_11,0 ,560
IDE05145-ENG115215-Light configuration-Light_Function_D_12,0 ,560
IDE05145-ENG114961-Light configuration-Light_Function_D_13,0 ,560
IDE05145-ENG115236-Light configuration-Light_Function_D_14,0 ,560
IDE05145-ENG115255-Light configuration-Light_Function_D_15,0 ,560
IDE05145-ENG115274-Light configuration-Light_Function_D_16,0 ,560
IDE05145-ENG115293-Light configuration-Light_Function_D_17,0 ,560
IDE05145-ENG115312-Light configuration-Light_Function_D_18,0 ,560
IDE05145-ENG115331-Light configuration-Light_Function_D_19,0 ,560
IDE05145-ENG115059-Light configuration-Light_Function_D_2,0 ,560
IDE05145-ENG115350-Light configuration-Light_Function_D_20,0 ,560
IDE05145-ENG115369-Light configuration-Light_Function_D_21,0 ,560
IDE05145-ENG115388-Light configuration-Light_Function_D_22,0 ,560
IDE05145-ENG115407-Light configuration-Light_Function_D_23,0 ,560
IDE05145-ENG115426-Light configuration-Light_Function_D_24,0 ,560
IDE05145-ENG115445-Light configuration-Light_Function_D_25,0 ,560
IDE05145-ENG115464-Light configuration-Light_Function_D_26,0 ,560
IDE05145-ENG115483-Light configuration-Light_Function_D_27,0 ,560
IDE05145-ENG115502-Light configuration-Light_Function_D_28,0 ,560
IDE05145-ENG115521-Light configuration-Light_Function_D_29,0 ,560
IDE05145-ENG115078-Light configuration-Light_Function_D_3,0 ,560
IDE05145-ENG115540-Light configuration-Light_Function_D_30,0 ,560
IDE05145-ENG115559-Light configuration-Light_Function_D_31,0 ,560
IDE05145-ENG115578-Light configuration-Light_Function_D_32,0 ,560
IDE05145-ENG115597-Light configuration-Light_Function_D_33,0 ,560
IDE05145-ENG115616-Light configuration-Light_Function_D_34,0 ,560
IDE05145-ENG115097-Light configuration-Light_Function_D_4,0 ,560
IDE05145-ENG114980-Light configuration-Light_Function_D_5,0 ,560
IDE05145-ENG115118-Light configuration-Light_Function_D_6,0 ,560
IDE05145-ENG115137-Light configuration-Light_Function_D_7,0 ,560
IDE05145-ENG115156-Light configuration-Light_Function_D_8,0 ,560
IDE05145-ENG115175-Light configuration-Light_Function_D_9,0 ,560
IDE05145-ENG115024-Light configuration-Light_Function_E_0,0 ,560
IDE05145-ENG115043-Light configuration-Light_Function_E_1,0 ,560
IDE05145-ENG115005-Light configuration-Light_Function_E_10,0 ,560
IDE05145-ENG115199-Light configuration-Light_Function_E_11,0 ,560
IDE05145-ENG115218-Light configuration-Light_Function_E_12,0 ,560
IDE05145-ENG114964-Light configuration-Light_Function_E_13,0 ,560
IDE05145-ENG115239-Light configuration-Light_Function_E_14,0 ,560
IDE05145-ENG115258-Light configuration-Light_Function_E_15,0 ,560
IDE05145-ENG115277-Light configuration-Light_Function_E_16,0 ,560
IDE05145-ENG115296-Light configuration-Light_Function_E_17,0 ,560
IDE05145-ENG115315-Light configuration-Light_Function_E_18,0 ,560
IDE05145-ENG115334-Light configuration-Light_Function_E_19,0 ,560
IDE05145-ENG115062-Light configuration-Light_Function_E_2,0 ,560
IDE05145-ENG115353-Light configuration-Light_Function_E_20,0 ,560
IDE05145-ENG115372-Light configuration-Light_Function_E_21,0 ,560
IDE05145-ENG115391-Light configuration-Light_Function_E_22,0 ,560
IDE05145-ENG115410-Light configuration-Light_Function_E_23,0 ,560
IDE05145-ENG115429-Light configuration-Light_Function_E_24,0 ,560
IDE05145-ENG115448-Light configuration-Light_Function_E_25,0 ,560
IDE05145-ENG115467-Light configuration-Light_Function_E_26,0 ,560
IDE05145-ENG115486-Light configuration-Light_Function_E_27,0 ,560
IDE05145-ENG115505-Light configuration-Light_Function_E_28,0 ,560
IDE05145-ENG115524-Light configuration-Light_Function_E_29,0 ,560
IDE05145-ENG115081-Light configuration-Light_Function_E_3,0 ,560
IDE05145-ENG115543-Light configuration-Light_Function_E_30,0 ,560
IDE05145-ENG115562-Light configuration-Light_Function_E_31,0 ,560
IDE05145-ENG115581-Light configuration-Light_Function_E_32,0 ,560
IDE05145-ENG115600-Light configuration-Light_Function_E_33,0 ,560
IDE05145-ENG115619-Light configuration-Light_Function_E_34,0 ,560
IDE05145-ENG115100-Light configuration-Light_Function_E_4,0 ,560
IDE05145-ENG114983-Light configuration-Light_Function_E_5,0 ,560
IDE05145-ENG115121-Light configuration-Light_Function_E_6,0 ,560
IDE05145-ENG115140-Light configuration-Light_Function_E_7,0 ,560
IDE05145-ENG115159-Light configuration-Light_Function_E_8,0 ,560
IDE05145-ENG115178-Light configuration-Light_Function_E_9,0 ,560
IDE05145-ENG115025-Light configuration-Light_Function_F_0,0 ,560
IDE05145-ENG115044-Light configuration-Light_Function_F_1,0 ,560
IDE05145-ENG115006-Light configuration-Light_Function_F_10,0 ,560
IDE05145-ENG115200-Light configuration-Light_Function_F_11,0 ,560
IDE05145-ENG115219-Light configuration-Light_Function_F_12,0 ,560
IDE05145-ENG114965-Light configuration-Light_Function_F_13,0 ,560
IDE05145-ENG115240-Light configuration-Light_Function_F_14,0 ,560
IDE05145-ENG115259-Light configuration-Light_Function_F_15,0 ,560
IDE05145-ENG115278-Light configuration-Light_Function_F_16,0 ,560
IDE05145-ENG115297-Light configuration-Light_Function_F_17,0 ,560
IDE05145-ENG115316-Light configuration-Light_Function_F_18,0 ,560
IDE05145-ENG115335-Light configuration-Light_Function_F_19,0 ,560
IDE05145-ENG115063-Light configuration-Light_Function_F_2,0 ,560
IDE05145-ENG115354-Light configuration-Light_Function_F_20,0 ,560
IDE05145-ENG115373-Light configuration-Light_Function_F_21,0 ,560
IDE05145-ENG115392-Light configuration-Light_Function_F_22,0 ,560
IDE05145-ENG115411-Light configuration-Light_Function_F_23,0 ,560
IDE05145-ENG115430-Light configuration-Light_Function_F_24,0 ,560
IDE05145-ENG115449-Light configuration-Light_Function_F_25,0 ,560
IDE05145-ENG115468-Light configuration-Light_Function_F_26,0 ,560
IDE05145-ENG115487-Light configuration-Light_Function_F_27,0 ,560
IDE05145-ENG115506-Light configuration-Light_Function_F_28,0 ,560
IDE05145-ENG115525-Light configuration-Light_Function_F_29,0 ,560
IDE05145-ENG115082-Light configuration-Light_Function_F_3,0 ,560
IDE05145-ENG115544-Light configuration-Light_Function_F_30,0 ,560
IDE05145-ENG115563-Light configuration-Light_Function_F_31,0 ,560
IDE05145-ENG115582-Light configuration-Light_Function_F_32,0 ,560
IDE05145-ENG115601-Light configuration-Light_Function_F_33,0 ,560
IDE05145-ENG115620-Light configuration-Light_Function_F_34,0 ,560
IDE05145-ENG115101-Light configuration-Light_Function_F_4,0 ,560
IDE05145-ENG114984-Light configuration-Light_Function_F_5,0 ,560
IDE05145-ENG115122-Light configuration-Light_Function_F_6,0 ,560
IDE05145-ENG115141-Light configuration-Light_Function_F_7,0 ,560
IDE05145-ENG115160-Light configuration-Light_Function_F_8,0 ,560
IDE05145-ENG115179-Light configuration-Light_Function_F_9,0 ,560
IDE05145-ENG115028-Light configuration-Light_Function_G_0,0 ,560
IDE05145-ENG115047-Light configuration-Light_Function_G_1,0 ,560
IDE05145-ENG115009-Light configuration-Light_Function_G_10,0 ,560
IDE05145-ENG115203-Light configuration-Light_Function_G_11,0 ,560
IDE05145-ENG115222-Light configuration-Light_Function_G_12,0 ,560
IDE05145-ENG114968-Light configuration-Light_Function_G_13,0 ,560
IDE05145-ENG115243-Light configuration-Light_Function_G_14,0 ,560
IDE05145-ENG115262-Light configuration-Light_Function_G_15,0 ,560
IDE05145-ENG115281-Light configuration-Light_Function_G_16,0 ,560
IDE05145-ENG115300-Light configuration-Light_Function_G_17,0 ,560
IDE05145-ENG115319-Light configuration-Light_Function_G_18,0 ,560
IDE05145-ENG115338-Light configuration-Light_Function_G_19,0 ,560
IDE05145-ENG115066-Light configuration-Light_Function_G_2,0 ,560
IDE05145-ENG115357-Light configuration-Light_Function_G_20,0 ,560
IDE05145-ENG115376-Light configuration-Light_Function_G_21,0 ,560
IDE05145-ENG115395-Light configuration-Light_Function_G_22,0 ,560
IDE05145-ENG115414-Light configuration-Light_Function_G_23,0 ,560
IDE05145-ENG115433-Light configuration-Light_Function_G_24,0 ,560
IDE05145-ENG115452-Light configuration-Light_Function_G_25,0 ,560
IDE05145-ENG115471-Light configuration-Light_Function_G_26,0 ,560
IDE05145-ENG115490-Light configuration-Light_Function_G_27,0 ,560
IDE05145-ENG115509-Light configuration-Light_Function_G_28,0 ,560
IDE05145-ENG115528-Light configuration-Light_Function_G_29,0 ,560
IDE05145-ENG115085-Light configuration-Light_Function_G_3,0 ,560
IDE05145-ENG115547-Light configuration-Light_Function_G_30,0 ,560
IDE05145-ENG115566-Light configuration-Light_Function_G_31,0 ,560
IDE05145-ENG115585-Light configuration-Light_Function_G_32,0 ,560
IDE05145-ENG115604-Light configuration-Light_Function_G_33,0 ,560
IDE05145-ENG115623-Light configuration-Light_Function_G_34,0 ,560
IDE05145-ENG115104-Light configuration-Light_Function_G_4,0 ,560
IDE05145-ENG114987-Light configuration-Light_Function_G_5,0 ,560
IDE05145-ENG115125-Light configuration-Light_Function_G_6,0 ,560
IDE05145-ENG115144-Light configuration-Light_Function_G_7,0 ,560
IDE05145-ENG115163-Light configuration-Light_Function_G_8,0 ,560
IDE05145-ENG115182-Light configuration-Light_Function_G_9,0 ,560
IDE05145-ENG115029-Light configuration-Light_Function_H_0,0 ,560
IDE05145-ENG115048-Light configuration-Light_Function_H_1,0 ,560
IDE05145-ENG115010-Light configuration-Light_Function_H_10,0 ,560
IDE05145-ENG115204-Light configuration-Light_Function_H_11,0 ,560
IDE05145-ENG115223-Light configuration-Light_Function_H_12,0 ,560
IDE05145-ENG114969-Light configuration-Light_Function_H_13,0 ,560
IDE05145-ENG115244-Light configuration-Light_Function_H_14,0 ,560
IDE05145-ENG115263-Light configuration-Light_Function_H_15,0 ,560
IDE05145-ENG115282-Light configuration-Light_Function_H_16,0 ,560
IDE05145-ENG115301-Light configuration-Light_Function_H_17,0 ,560
IDE05145-ENG115320-Light configuration-Light_Function_H_18,0 ,560
IDE05145-ENG115339-Light configuration-Light_Function_H_19,0 ,560
IDE05145-ENG115067-Light configuration-Light_Function_H_2,0 ,560
IDE05145-ENG115358-Light configuration-Light_Function_H_20,0 ,560
IDE05145-ENG115377-Light configuration-Light_Function_H_21,0 ,560
IDE05145-ENG115396-Light configuration-Light_Function_H_22,0 ,560
IDE05145-ENG115415-Light configuration-Light_Function_H_23,0 ,560
IDE05145-ENG115434-Light configuration-Light_Function_H_24,0 ,560
IDE05145-ENG115453-Light configuration-Light_Function_H_25,0 ,560
IDE05145-ENG115472-Light configuration-Light_Function_H_26,0 ,560
IDE05145-ENG115491-Light configuration-Light_Function_H_27,0 ,560
IDE05145-ENG115510-Light configuration-Light_Function_H_28,0 ,560
IDE05145-ENG115529-Light configuration-Light_Function_H_29,0 ,560
IDE05145-ENG115086-Light configuration-Light_Function_H_3,0 ,560
IDE05145-ENG115548-Light configuration-Light_Function_H_30,0 ,560
IDE05145-ENG115567-Light configuration-Light_Function_H_31,0 ,560
IDE05145-ENG115586-Light configuration-Light_Function_H_32,0 ,560
IDE05145-ENG115605-Light configuration-Light_Function_H_33,0 ,560
IDE05145-ENG115624-Light configuration-Light_Function_H_34,0 ,560
IDE05145-ENG115105-Light configuration-Light_Function_H_4,0 ,560
IDE05145-ENG114988-Light configuration-Light_Function_H_5,0 ,560
IDE05145-ENG115126-Light configuration-Light_Function_H_6,0 ,560
IDE05145-ENG115145-Light configuration-Light_Function_H_7,0 ,560
IDE05145-ENG115164-Light configuration-Light_Function_H_8,0 ,560
IDE05145-ENG115183-Light configuration-Light_Function_H_9,0 ,560
IDE05145-ENG154373-Light configuration-Reserved_0,0 ,560
IDE05145-ENG101416-Light configuration-Reserved_1,0 ,560
IDE05145-ENG154318-Light configuration-Reserved_10,0 ,560
IDE05145-ENG99637-Light configuration-Reserved_11,0 ,560
IDE05145-ENG154355-Light configuration-Reserved_12,0 ,560
IDE05145-ENG154196-Light configuration-Reserved_13,0 ,560
IDE05145-ENG154298-Light configuration-Reserved_14,0 ,560
IDE05145-ENG154243-Light configuration-Reserved_15,0 ,560
IDE05145-ENG154297-Light configuration-Reserved_16,0 ,560
IDE05145-ENG154432-Light configuration-reserved_17,0 ,560
IDE05145-ENG154433-Light configuration-reserved_18,0 ,560
IDE05145-ENG154434-Light configuration-reserved_19,0 ,560
IDE05145-ENG99458-Light configuration-Reserved_2,0 ,560
IDE05145-ENG154435-Light configuration-reserved_20,0 ,560
IDE05145-ENG154436-Light configuration-reserved_21,0 ,560
IDE05145-ENG159603-Light configuration-reserved_22,0 ,560
IDE05145-ENG154437-Light configuration-reserved_23,0 ,560
IDE05145-ENG159604-Light configuration-reserved_24,0 ,560
IDE05145-ENG159605-Light configuration-reserved_25,0 ,560
IDE05145-ENG159606-Light configuration-reserved_26,0 ,560
IDE05145-ENG159607-Light configuration-reserved_27,0 ,560
IDE05145-ENG159608-Light configuration-reserved_28,0 ,560
IDE05145-ENG159609-Light configuration-reserved_29,0 ,560
IDE05145-ENG99668-Light configuration-Reserved_3,00 ,560
IDE05145-ENG159610-Light configuration-reserved_30,0 ,560
IDE05145-ENG159611-Light configuration-reserved_31,0 ,560
IDE05145-ENG114291-Light configuration-reserved_32,0 ,560
IDE05145-ENG184465-Light configuration-reserved_33,0 ,560
IDE05145-ENG159612-Light configuration-reserved_34,0 ,560
IDE05145-ENG154261-Light configuration-Reserved_4,0 ,560
IDE05145-ENG154330-Light configuration-Reserved_5,0 ,560
IDE05145-ENG154188-Light configuration-Reserved_6,0 ,560
IDE05145-ENG154256-Light configuration-Reserved_7,0 ,560
IDE05145-ENG154341-Light configuration-Reserved_8,0 ,560
IDE05145-ENG154185-Light configuration-Reserved_9,0 ,560
IDE05145-ENG115013-Light configuration-Type_Of_Load_0,Blinkleuchten ,560
IDE05145-ENG115032-Light configuration-Type_Of_Load_1,Blinkleuchten ,560
IDE05145-ENG114995-Light configuration-Type_Of_Load_10,not active ,560
IDE05145-ENG115188-Light configuration-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115207-Light configuration-Type_Of_Load_12,allgemeine Scheinwerfer ,560
IDE05145-ENG114954-Light configuration-Type_Of_Load_13,allgemeine Scheinwerfer ,560
IDE05145-ENG115228-Light configuration-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115247-Light configuration-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,560
IDE05145-ENG115266-Light configuration-Type_Of_Load_16,LED Blinkleuchten ,560
IDE05145-ENG115285-Light configuration-Type_Of_Load_17,LED Blinkleuchten ,560
IDE05145-ENG115304-Light configuration-Type_Of_Load_18,Blinkleuchten ,560
IDE05145-ENG115323-Light configuration-Type_Of_Load_19,Blinkleuchten ,560
IDE05145-ENG115051-Light configuration-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115342-Light configuration-Type_Of_Load_20,Bremsleuchten ,560
IDE05145-ENG115361-Light configuration-Type_Of_Load_21,Bremsleuchten ,560
IDE05145-ENG115380-Light configuration-Type_Of_Load_22,LEDdritteBremsleuchte ,560
IDE05145-ENG115399-Light configuration-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115418-Light configuration-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115437-Light configuration-Type_Of_Load_25,2* 5W ,560
IDE05145-ENG115456-Light configuration-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115475-Light configuration-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,560
IDE05145-ENG115494-Light configuration-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115513-Light configuration-Type_Of_Load_29,allgemeineGluehlampe12W ,560
IDE05145-ENG115070-Light configuration-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,560
IDE05145-ENG115532-Light configuration-Type_Of_Load_30,allgemeineGluehlampe12W ,560
IDE05145-ENG115551-Light configuration-Type_Of_Load_31,not active ,560
IDE05145-ENG115570-Light configuration-Type_Of_Load_32,not active ,560
IDE05145-ENG115589-Light configuration-Type_Of_Load_33,not active ,560
IDE05145-ENG115608-Light configuration-Type_Of_Load_34,not active ,560
IDE05145-ENG115089-Light configuration-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG114973-Light configuration-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,560
IDE05145-ENG115110-Light configuration-Type_Of_Load_6,Low beam ,560
IDE05145-ENG115129-Light configuration-Type_Of_Load_7,Low beam ,560
IDE05145-ENG115148-Light configuration-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,560
IDE05145-ENG115167-Light configuration-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,560
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,6
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,6
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,6
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,6
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active ,6
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,6
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration,0 min,2
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts,0 ,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,5
IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
IDE08542-IDE02022-Access control 2-Comfort opening,active ,6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active ,6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No ,6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,No ,6
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active ,6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active ,6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,6
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel,active ,6
IDE08542-ENG115671-Access control 2-Regenschließen,not active ,6
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,Open ,6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,6
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,not active ,6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms,4
IDE08786-ENG142177-Assistance light functions-Assistance_lighting_sensitivity_adjustable,Not Present ,4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,not active ,4
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis ,4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,not active ,1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE10286-ENG130228-Configuration of light collective diagnostic line 1: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC,36 ,7
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0,not active ,7
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1,not active ,7
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10,not active ,7
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11,not active ,7
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12,not active ,7
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13,not active ,7
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14,not active ,7
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15,not active ,7
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16,not active ,7
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17,not active ,7
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18,not active ,7
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19,not active ,7
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2,not active ,7
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20,not active ,7
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21,not active ,7
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22,not active ,7
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23,not active ,7
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24,not active ,7
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25,not active ,7
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26,not active ,7
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27,not active ,7
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28,not active ,7
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29,not active ,7
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3,not active ,7
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30,not active ,7
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31,not active ,7
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32,not active ,7
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33,not active ,7
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34,not active ,7
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4,not active ,7
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5,not active ,7
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6,not active ,7
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7,not active ,7
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8,not active ,7
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9,not active ,7
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand,150_Ohm ,7
IDE10288-ENG130228-Configuration of light collective diagnostic line 2: instance 1-Defektbit,Licht_vorne_01 Byte 5 ,7
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC,40 ,7
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0,not active ,7
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1,not active ,7
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10,not active ,7
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11,not active ,7
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12,not active ,7
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13,not active ,7
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14,not active ,7
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15,not active ,7
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16,not active ,7
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17,not active ,7
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18,not active ,7
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19,not active ,7
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2,not active ,7
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20,not active ,7
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21,not active ,7
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22,not active ,7
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23,not active ,7
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24,not active ,7
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25,not active ,7
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26,not active ,7
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27,not active ,7
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28,not active ,7
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29,not active ,7
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3,not active ,7
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30,not active ,7
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31,not active ,7
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32,not active ,7
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33,not active ,7
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34,not active ,7
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4,not active ,7
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5,not active ,7
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6,not active ,7
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7,not active ,7
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8,not active ,7
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9,not active ,7
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand,150_Ohm ,7
MAS01490-Energy management,Energy management not active ,1
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter,closed ,1
MAS08233-ENG126575-other-mute_mode_aktiv,not active ,1
MAS08233-ENG125011-other-pa_Funktion_2aus3,not installed ,1
ENG124896-Adaptation_theft_protection,not active ,2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.0 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.0 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.0 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.0 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.0 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.0 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.0 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.0 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.0 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,100.0 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,100.0 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,100.0 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,100.0 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,100.0 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.0 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.0 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.0 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.0 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,0 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,0 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,0 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,0 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,0.0 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,0.0 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,0.0 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,0.0 ,10
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0,100 ,16
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0,0 ,16
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize ,16
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize ,16
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize ,16
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0,0 ,16
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0,0 ,16
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14 ,16
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34 ,16
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always ,16
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase ,16
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0,not active ,16
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0,not active ,16
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0,not active ,16
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0,not active ,16
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0,not active ,16
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0,not active ,16
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0,not active ,16
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0,Blinkleuchten ,16
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10,0 ,16
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10,0 ,16
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize ,16
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize ,16
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize ,16
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10,0 ,16
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10,0 ,16
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,00 ,16
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00 ,16
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always ,16
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10,not active ,16
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active ,16
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active ,16
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active ,16
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active ,16
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active ,16
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active ,16
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active ,16
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10,not active ,16
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100 ,16
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0 ,16
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize ,16
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize ,16
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize ,16
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0 ,16
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0 ,16
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00 ,16
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00 ,16
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always ,16
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster ,16
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active ,16
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active ,16
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active ,16
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active ,16
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active ,16
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active ,16
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active ,16
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12,100 ,16
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12,0 ,16
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize ,16
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize ,16
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize ,16
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12,0 ,16
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12,0 ,16
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,22 ,16
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12,38 ,16
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12,Always ,16
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12,Nebellicht links ,16
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12,Abbiegelicht links ,16
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12,not active ,16
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12,not active ,16
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12,not active ,16
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12,not active ,16
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12,not active ,16
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12,not active ,16
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12,allgemeine Scheinwerfer ,16
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13,100 ,16
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13,0 ,16
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize ,16
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize ,16
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize ,16
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13,0 ,16
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13,0 ,16
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,23 ,16
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13,42 ,16
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13,Always ,16
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13,Nebellicht rechts ,16
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13,Abbiegelicht rechts ,16
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13,not active ,16
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13,not active ,16
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13,not active ,16
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13,not active ,16
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13,not active ,16
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13,not active ,16
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13,allgemeine Scheinwerfer ,16
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15,100 ,16
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15,0 ,16
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize ,16
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize ,16
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize ,16
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15,0 ,16
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15,0 ,16
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00 ,16
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00 ,16
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always ,16
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED ,16
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15,not active ,16
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15,not active ,16
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15,not active ,16
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15,not active ,16
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15,not active ,16
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15,not active ,16
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15,not active ,16
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose ,16
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16,100 ,16
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16,0 ,16
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize ,16
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize ,16
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize ,16
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16,0 ,16
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16,0 ,16
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,00 ,16
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16,00 ,16
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always ,16
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase ,16
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16,not active ,16
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16,not active ,16
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16,not active ,16
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16,not active ,16
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16,not active ,16
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16,not active ,16
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16,not active ,16
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16,LED Blinkleuchten ,16
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17,100 ,16
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17,0 ,16
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize ,16
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize ,16
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize ,16
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17,0 ,16
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17,0 ,16
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,00 ,16
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,00 ,16
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always ,16
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase ,16
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17,not active ,16
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17,not active ,16
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17,not active ,16
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17,not active ,16
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17,not active ,16
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17,not active ,16
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17,not active ,16
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17,LED Blinkleuchten ,16
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18,100 ,16
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18,0 ,16
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize ,16
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize ,16
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize ,16
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18,0 ,16
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18,0 ,16
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16 ,16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08 ,16
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always ,16
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase ,16
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18,not active ,16
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18,not active ,16
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18,not active ,16
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18,not active ,16
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18,not active ,16
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18,not active ,16
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18,not active ,16
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten ,16
ENG124880-ENG115328-Leuchte19BLK HRC8-Dimming_AB_19,100 ,16
ENG124880-ENG115332-Leuchte19BLK HRC8-Dimming_CD_19,0 ,16
ENG124880-ENG115333-Leuchte19BLK HRC8-Dimming_Direction_CD_19,maximize ,16
ENG124880-ENG115337-Leuchte19BLK HRC8-Dimming_Direction_EF_19,maximize ,16
ENG124880-ENG115341-Leuchte19BLK HRC8-Dimming_Direction_GH_19,maximize ,16
ENG124880-ENG115336-Leuchte19BLK HRC8-Dimming_EF_19,0 ,16
ENG124880-ENG115340-Leuchte19BLK HRC8-Dimming_GH_19,0 ,16
ENG124880-ENG126594-Leuchte19BLK HRC8-Fehlerort_mittleres_Byte_DTC-DFCC_19,18 ,16
ENG124880-ENG115785-Leuchte19BLK HRC8-Lampendefektbit_Position_19,18 ,16
ENG124880-ENG115329-Leuchte19BLK HRC8-Light_Control_HD_AB_19,Always ,16
ENG124880-ENG115326-Leuchte19BLK HRC8-Light_Function_A_19,Blinken rechts Hellphase ,16
ENG124880-ENG115327-Leuchte19BLK HRC8-Light_Function_B_19,not active ,16
ENG124880-ENG115330-Leuchte19BLK HRC8-Light_Function_C_19,not active ,16
ENG124880-ENG115331-Leuchte19BLK HRC8-Light_Function_D_19,not active ,16
ENG124880-ENG115334-Leuchte19BLK HRC8-Light_Function_E_19,not active ,16
ENG124880-ENG115335-Leuchte19BLK HRC8-Light_Function_F_19,not active ,16
ENG124880-ENG115338-Leuchte19BLK HRC8-Light_Function_G_19,not active ,16
ENG124880-ENG115339-Leuchte19BLK HRC8-Light_Function_H_19,not active ,16
ENG124880-ENG115323-Leuchte19BLK HRC8-Type_Of_Load_19,Blinkleuchten ,16
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1,100 ,16
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1,0 ,16
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize ,16
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize ,16
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize ,16
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1,0 ,16
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1,0 ,16
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15 ,16
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E ,16
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always ,16
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase ,16
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1,not active ,16
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1,not active ,16
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1,not active ,16
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1,not active ,16
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1,not active ,16
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1,not active ,16
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1,not active ,16
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1,Blinkleuchten ,16
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20,100 ,16
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20,0 ,16
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize ,16
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize ,16
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize ,16
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20,0 ,16
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20,0 ,16
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,2B ,16
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20,09 ,16
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20,Always ,16
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20,Brake light ,16
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20,not active ,16
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20,not active ,16
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20,not active ,16
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20,not active ,16
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20,not active ,16
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20,not active ,16
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20,not active ,16
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20,Bremsleuchten ,16
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21,100 ,16
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21,0 ,16
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize ,16
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize ,16
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize ,16
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21,0 ,16
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21,0 ,16
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,2D ,16
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21,19 ,16
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21,Always ,16
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21,Brake light ,16
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21,not active ,16
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21,not active ,16
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21,not active ,16
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21,not active ,16
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21,not active ,16
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21,not active ,16
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21,not active ,16
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21,Bremsleuchten ,16
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22,100 ,16
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22,0 ,16
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize ,16
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize ,16
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize ,16
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22,0 ,16
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22,0 ,16
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C ,16
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22,29 ,16
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22,Always ,16
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22,Brake light ,16
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22,not active ,16
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22,not active ,16
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22,not active ,16
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22,not active ,16
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22,not active ,16
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22,not active ,16
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22,not active ,16
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte ,16
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23,60 ,16
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23,0 ,16
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize ,16
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize ,16
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize ,16
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23,0 ,16
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23,0 ,16
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,29 ,16
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23,0A ,16
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always ,16
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23,Parking light ,16
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23,Parking light left ,16
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23,not active ,16
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23,not active ,16
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23,not active ,16
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23,not active ,16
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23,not active ,16
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23,not active ,16
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineGluehlampe6W:auchH6W ,16
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24,60 ,16
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24,0 ,16
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize ,16
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize ,16
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize ,16
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24,0 ,16
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24,0 ,16
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,2A ,16
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24,1A ,16
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always ,16
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24,Parking light ,16
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24,Parking light right ,16
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24,not active ,16
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24,not active ,16
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24,not active ,16
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24,not active ,16
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24,not active ,16
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24,not active ,16
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineGluehlampe6W:auchH6W ,16
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25,100 ,16
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25,0 ,16
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize ,16
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize ,16
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize ,16
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25,0 ,16
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25,0 ,16
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,00 ,16
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25,00 ,16
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always ,16
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25,Parking light ,16
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25,not active ,16
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25,not active ,16
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25,not active ,16
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25,not active ,16
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25,not active ,16
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25,not active ,16
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25,not active ,16
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25,2* 5W ,16
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26,100 ,16
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26,0 ,16
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize ,16
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize ,16
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize ,16
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26,0 ,16
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26,0 ,16
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E ,16
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26,0C ,16
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26,Always ,16
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergestecktundRechtsverkehr ,16
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26,not active ,16
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26,not active ,16
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26,not active ,16
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26,not active ,16
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26,not active ,16
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26,not active ,16
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26,not active ,16
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27,100 ,16
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27,0 ,16
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize ,16
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize ,16
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize ,16
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27,0 ,16
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27,0 ,16
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08 ,16
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00 ,16
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always ,16
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer ,16
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27,not active ,16
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27,not active ,16
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27,not active ,16
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27,not active ,16
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27,not active ,16
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27,not active ,16
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27,not active ,16
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose ,16
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28,100 ,16
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28,0 ,16
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize ,16
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize ,16
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize ,16
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28,0 ,16
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28,0 ,16
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32 ,16
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28,1B ,16
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28,Always ,16
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht ,16
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28,not active ,16
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28,not active ,16
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28,not active ,16
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28,not active ,16
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28,not active ,16
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28,not active ,16
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28,not active ,16
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29,100 ,16
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29,0 ,16
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize ,16
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize ,16
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize ,16
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29,0 ,16
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29,0 ,16
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01 ,16
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00 ,16
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always ,16
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G ,16
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29,not active ,16
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29,not active ,16
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29,not active ,16
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29,not active ,16
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29,not active ,16
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29,not active ,16
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29,not active ,16
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W ,16
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2,100 ,16
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2,0 ,16
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize ,16
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2,maximize ,16
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize ,16
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2,0 ,16
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2,0 ,16
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,26 ,16
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2,35 ,16
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always ,16
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2,Parking light ,16
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2,Parking light left ,16
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2,not active ,16
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2,not active ,16
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2,not active ,16
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2,not active ,16
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2,not active ,16
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2,not active ,16
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2,allgemeineGluehlampe6W:auchH6W ,16
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30,100 ,16
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30,0 ,16
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize ,16
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize ,16
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize ,16
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30,0 ,16
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30,0 ,16
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07 ,16
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00 ,16
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always ,16
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light ,16
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active ,16
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active ,16
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active ,16
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active ,16
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active ,16
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active ,16
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active ,16
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeineGluehlampe12W ,16
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31,0 ,16
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31,0 ,16
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize ,16
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize ,16
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize ,16
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31,0 ,16
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31,0 ,16
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00 ,16
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00 ,16
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always ,16
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31,not active ,16
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31,not active ,16
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31,not active ,16
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31,not active ,16
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31,not active ,16
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31,not active ,16
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31,not active ,16
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31,not active ,16
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31,not active ,16
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32,0 ,16
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32,0 ,16
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize ,16
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize ,16
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize ,16
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32,0 ,16
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32,0 ,16
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00 ,16
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00 ,16
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always ,16
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32,not active ,16
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32,not active ,16
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32,not active ,16
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32,not active ,16
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32,not active ,16
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32,not active ,16
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32,not active ,16
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32,not active ,16
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32,not active ,16
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33,0 ,16
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33,0 ,16
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize ,16
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize ,16
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize ,16
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33,0 ,16
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33,0 ,16
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00 ,16
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00 ,16
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always ,16
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33,not active ,16
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33,not active ,16
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33,not active ,16
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33,not active ,16
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33,not active ,16
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33,not active ,16
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33,not active ,16
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33,not active ,16
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33,not active ,16
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34,0 ,16
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34,0 ,16
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize ,16
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize ,16
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize ,16
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34,0 ,16
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34,0 ,16
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,00 ,16
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,00 ,16
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always ,16
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34,not active ,16
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34,not active ,16
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34,not active ,16
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34,not active ,16
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34,not active ,16
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34,not active ,16
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34,not active ,16
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34,not active ,16
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34,not active ,16
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3,100 ,16
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3,0 ,16
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize ,16
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3,maximize ,16
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize ,16
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3,0 ,16
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3,0 ,16
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,27 ,16
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3,3F ,16
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always ,16
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3,Parking light ,16
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3,Parking light right ,16
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3,not active ,16
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3,not active ,16
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3,not active ,16
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3,not active ,16
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3,not active ,16
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3,not active ,16
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3,allgemeineGluehlampe6W:auchH6W ,16
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4,100 ,16
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4,0 ,16
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize ,16
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize ,16
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize ,16
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4,0 ,16
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4,0 ,16
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,20 ,16
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4,3A ,16
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always ,16
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights ,16
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4,not active ,16
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4,not active ,16
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4,not active ,16
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4,not active ,16
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4,not active ,16
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4,not active ,16
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4,not active ,16
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5,100 ,16
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5,0 ,16
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize ,16
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize ,16
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize ,16
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5,0 ,16
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5,0 ,16
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,21 ,16
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5,44 ,16
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always ,16
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights ,16
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5,not active ,16
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5,not active ,16
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5,not active ,16
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5,not active ,16
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5,not active ,16
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5,not active ,16
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5,not active ,16
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5,allgemeineGluehlampe27W:auchH15-TFL ,16
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6,100 ,16
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6,0 ,16
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize ,16
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize ,16
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize ,16
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6,0 ,16
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6,0 ,16
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A ,16
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6,36 ,16
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always ,16
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links ,16
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6,ComingHome LeavingHome ,16
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6,not active ,16
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6,not active ,16
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6,not active ,16
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6,not active ,16
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6,not active ,16
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6,not active ,16
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6,Low beam ,16
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7,100 ,16
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7,0 ,16
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize ,16
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize ,16
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize ,16
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7,0 ,16
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7,0 ,16
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B ,16
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7,40 ,16
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always ,16
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts ,16
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7,ComingHome LeavingHome ,16
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7,not active ,16
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7,not active ,16
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7,not active ,16
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7,not active ,16
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7,not active ,16
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7,not active ,16
ENG124868-ENG115129-Leuchte7ABL RB5-Type_Of_Load_7,Low beam ,16
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8,100 ,16
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8,0 ,16
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize ,16
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize ,16
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize ,16
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8,0 ,16
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8,0 ,16
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C ,16
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8,37 ,16
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8,Always ,16
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8,Left high beam ,16
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher ,16
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8,not active ,16
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8,not active ,16
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8,not active ,16
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8,not active ,16
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8,not active ,16
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8,not active ,16
ENG124869-ENG115148-Leuchte8FL LB42-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung ,16
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9,100 ,16
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9,0 ,16
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize ,16
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize ,16
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize ,16
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9,0 ,16
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9,0 ,16
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D ,16
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9,41 ,16
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9,Always ,16
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9,Right high beam ,16
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher ,16
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9,not active ,16
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9,not active ,16
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9,not active ,16
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9,not active ,16
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9,not active ,16
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9,not active ,16
ENG124870-ENG115167-Leuchte9FL RB7-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung ,16
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100 ,16
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0 ,16
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize ,16
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize ,16
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize ,16
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0 ,16
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0 ,16
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00 ,16
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00 ,16
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always ,16
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED ,16
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active ,16
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active ,16
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active ,16
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active ,16
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active ,16
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active ,16
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active ,16
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose ,16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0 ,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10 ,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100 ,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150 ,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253 ,12
ENG130141-Patch_Code: Beifahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130136-Patch_Code: Fahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117299-Reversing_Threshold_Driver_Side_Rear,0 %,1
ENG117298-Reversing_Threshold_Passenger_Side_Front,0 %,1
ENG130135-Window_Regulator_Supplier_Settings_Driver_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130138-Window_Regulator_Supplier_Settings_Passener_Side_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130139-Window_Regulator_Supplier_Settings_Passener_Side_2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG130140-Window_Regulator_Supplier_Settings_Passener_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG130137-Window_Regulator_VW_Settings_Passenger_Side,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,88
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,650
ADP OF 17:
IDE00295-Oil temperature display,On ,1
IDE00301-Distance,47316 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,English ,1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,15 H,1
IDE00501-Minute,16 min,1
IDE00502-Year,2019 yr,2
IDE00503-Month,12 mon,1
IDE00504-Day,8 d,1
IDE00510-ESI: distance driven from inspection,1565 km,3
IDE00511-ESI: time from inspection,29 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,good oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,2200 km,2
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,2001 d,2
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02489-Display depiction,Not available ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
IDE03329-Driving profiled for range remaining,6.4 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
IDE03346-MAS02957-Units adjusted-Time,24h ,3
IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
IDE03348-MAS01456-Speed warning-Speed,190 ,2
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour ,2
IDE03348-Speed warning-,active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,365 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,1500 km,2
IDE03352-FIX: Time since last time-dependent inspection,29 d,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
IDE03867-Deactivate seat belt warning,No ,1
IDE04169-Display correction of consumption and operating range: gas,100 %,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,No display ,1
IDE06922-No-voltage display,Unknown (2),1
IDE07221-Cylinder shut-off,Display ,1
IDE08140-Driving profiled for range remaining CNG,6.0 kg/100 km,2
IDE08247-Driving profile for range remaining LPG,10.0 l/100km,2
MAS03685-Digital speedometer,Display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,35 l,1
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,66 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,96 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,B4 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,05 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,0F ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,28 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0C ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,19 ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,29 ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,C8 ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,02 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,02 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,0E ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,19 ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,08 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,12 ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
ENG119874-Gas_functionality,not active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light ,1
ENG119882-init_fuel_algorithm,No ,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
ENG119876-Service_Key_Clear_All_Counter,Yes ,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,30 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
ADP MAP OF 5F:
IDE00346-Summertime-automatic,manual ,1
IDE00758-Base volume of telephone,50 %,1
IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02063-Time display for start screen,2.0 s,1
IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,30 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,30 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,30 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,30 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,30 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,30 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,30 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,30 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,30 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,30 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,30 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,30 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,30 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,30 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,30 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,30 ,49
IDE02502-Confirmation of installation change,C5 75 ,2
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
MAS00951-Bluetooth,On ,1
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15 ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,CAB_9 ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Comfort data bus ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Databus drivetrain ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Comfort data bus ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Comfort data bus ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Comfort data bus ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_9 ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Comfort data bus ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,CAB_9 ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,not activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Databus drivetrain ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Comfort data bus ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Comfort data bus ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Comfort data bus ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Not available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,13 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,35 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,70 %,12
ENG117808-p_HMI_Display,13 %,1
TBAx
C?ID=287144
Your ADPMAP says:
IDE05142-ENG116706-Access control-Autounlock NAR,active ,4
You haven't performed the change Don suggested.
ib97
Croatia
C?ID=375363
did it, norhing happened.
DV52
C?ID=194404
^^^ib97: As I understand, the NAR channel will unlock the doors when the car is put unto park on automatic cars or when the key is pulled in manual cars - but it seems most incongruous for a car that is driven in Croatia to be programmed for NAR autounlock (unless, of course you particularly want this "yankee" feature)!!
As you can see from your AdpLog.CSV file - this channel was correctly set at the factory as not active and for some reason it was changed to active.
I"ve looked at the code-string on your BCM in your CodingLog.CSV file and if I compare the earliest "from" value to the latest "to" value - I get this:
Name	from		        to
Byte	Hex	Binary	        Hex	Binary
0	00	00000000	00	00000000
1	00	00000000	00	00000000
2	08	00001000	08	00001000
3	40	01000000	40	01000000
4	42	01000010	42	01000010
5	53	01010011	53	01010011
6	00	00000000	00	00000000
7	5B	01011011	5B	01011011
8	4B	01001011	4B	01001011
9	84	10000100	84	10000100
10	40	01000000	40	01000000
11	00	00000000	00	00000000
12	40	01000000	40	01000000
13	07	00000111	07	00000111
14	03	00000011	03	00000011
15	88	10001000	88	10001000
16	00	00000000	00	00000000
17	00	00000000	00	00000000
18	58	01011000	58	01011000
19	02	00000010	02	00000010
20	51	01010001	51	01010001
21	01	00000001	01	00000001
22	00	00000000	00	00000000
23	00	00000000	00	00000000
24	00	00000000	00	00000000
25	00	00000000	00	00000000
26	00	00000000	00	00000000
27	00	00000000	00	00000000
28	00	00000000	00	00000000
29	00	00000000	00	00000000
As you can see - the values align.
Now, the other records in the CodingLog.CSV file indicate that Btye 1 Bit 0 was changed and then reverted. I don't have the Byte/Bit descriptors for your particular BCM - but my database of MQB BCMs suggests that Byte 1, Bit 0 is the software switch that tells the BCM that KESSY is installed in the car (keyless ignition). But, your auto-scan suggests that the car doesn't have a hex05 module. Please check the long coding helper screen says about Byte 1 on your BCM - perhaps changing this software switch needs the "factory reset" facility in the MENU to be activated (under no circumstances use the factory reset function for adaptation channels in VCDS)- I'm completely guessing?
ib97
Croatia
C?ID=375363
Sooo, only factory reset in the cars menu is needed, in your opinion?
iichel
Netherlands, eastern part
C?ID=284912
Just a small remark, this is a Polo 6C and not a 6R. The Polo 6C is the facelifted 6R, introduced in 2014. It shares the same platework but the electrics are completely new. The 6R is based on the PQ25 platform which is sort of... old. The 6C on the other hand is MQB based, the platform is PQ26 but it is not even remotely the same as PQ25.
ib97
Croatia
C?ID=375363
After going to factory settings and then hitting reset button, no changes. It is still not working.
While long holding unlock button, windows are going down. So it is only about locking/unlocking.
Any other ideas, please?
DV52
C?ID=194404
ib97: hmm........ bummer, but I did say that I was guessing!!
Another long-shot - have you tried synchronizing the keys using the procedure that is sometimes needed after replacing the battery in the fob? This procedure should be described in the manual for a Polo 6C - but if it's the same as a Golf mk7, remove the plastic cap on the driver door handle that hides the key lock. Press and hold the unlock button on the fob and unlock the driver door with the physical key. Within 60 seconds of unlocking the driver door - insert the key in the ignition lock and turn-on the ignition.
ib97
Croatia
C?ID=375363
Yeah, no problem with guessing. :)
I tried with key already on ignition and then unlocking with another key. Will try this one tomorrow.
ib97
Croatia
C?ID=375363
Connected it with ODIS. Vehicle can not be found.
It says that communication hardware is deleted. Only official VW can fix that and that should be very costly.
Does anyone know the prices?
ib97
Croatia
C?ID=375363
Or a way to fix that?
Since VCDS can talk to this car no problem, that sounds more like a problem with your ODIS installation than with the car, no?
ib97
Croatia
C?ID=375363
Everything is installed correctly, both odis and vcds. There is a missing communication with the car and key. And it can not be reprogrammed with the method mentioned above.
