JDM import B6 A4 Avant 5.7ABS CODING INFO
PIVOT
Canada
C?ID=200803
Hoping this forum can reach someone with more info on this type of thing than I. Have this JDM imported 03 A4 2.0L N/A CVT/FWD which has presented an odd problem. Two modules were gifted to me with instructions to "make it work". Neither module has any softcoding present (00000), and so far aside from vcds, I've attempted coding with vas5052, auto logic..... The login codes/coding I've tried have resulted in no coding being saved. I can't post autoscan now, but only two faults are the obvious: module incorrectly coded and g85 no/incorrect basic settings.
Any help is appreciated!!
VIN: WAUZZZ8E64A111246   License Plate:
Mileage: 98860km-61428mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E64A111246   Mileage: 98860km-61428miles
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 8E0 910 155 E    HW: 01J 927 156 JK
   Component: V30 01J 2.0l 5V RdW 3120
   Revision: 00000008    Serial number: 00000002102755
   Coding: 0000001
   Shop #: WSC 63016 001 1048576
   VCID: 275D03BB95E0A977C6-5140
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      3429
   Coding: 00000
   VCID: 26430EBFC2EAB07FFD-5140
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
            30-00 - Open or Short to Plus
18256 - Please check DTC Memory of Engine Controller
            P1848 - 35-10 -  - Intermittent
            66-10 - Not Matched - Intermittent
            35-00 - -
   Part No: 8E0 820 043 AC
   Component:   A4 Klimaautomat   1424
   Coding: 00000
   Shop #: WSC 79800
   VCID: 62CB52AFEE420C5FD1-5122
01273 - Fresh Air Blower (V2)
00532 - Supply Voltage B+
01312 - Powertrain Data Bus
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  RDW 0517
   Coding: 00011
   VCID: 3561D9F30F4CCBE744-4B02
            57-00 - Electric Circuit Failure
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 B
   Component: Airbag 8.4EP        3002
   Coding: 0010702
   Shop #: WSC 63251 000 00000
   VCID: 3663DEFF424AC0FF4D-5140
   Part No: 8E0 953 549 S
   Component: Lenksáulenmodul     0611
   Coding: 01012
   Shop #: WSC 63251
   VCID: 4385B72B51986557FA-4B02
   Part No: 8E0 920 900 L
   Component: KOMBI+WEGFAHRS. RB4 D37
   Coding: 02500
   Shop #: WSC 60462
   VCID: 2D51F193E71C83273C-5140
   WAUZZZ8E64A111246     AUZ6Z0C0283970
01039 - Coolant Temperature Sensor (G2)
01316 - ABS Control Module
01304 - Radio
            49-00 - No Communications
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1411
   Coding: 07104
   Shop #: WSC 07130
   VCID: 72EB22EF3EA29CDFA1-4B02
   Subsystem 1 - Part No: 8E2959802
   Component: Tõrsteuer.FS BRM 0003
   Subsystem 2 - Part No: 8E2959801
   Component: Tõrsteuer.BF BRM 0003
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0004
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0004
7 Faults Found:
00956 - Key 2
            35-00 - -
01705 - Selection Switch for Mirror-Adjust (E48)
   Part No: 4Z7 907 357
   Coding: 00060
   Shop #: WSC 63251
   VCID: 040774371416A26F83-4B34
End-------------------------(Elapsed Time: 05:53)--------------------------
Welcome to the VCDS forum.
OP could you please post a complete auto-scan and part numbers of what it is you are doing?
Did you follow the RTFB or wiki procedure?
Sure sounds like FOD huh?
PIVOT
Canada
C?ID=200803
I'll add the ABS module info ASAP.
If the routine coding procedures had worked, I wouldn't be posting this!
Clever acronyms aside Jack, I'm simply looking for help from users regarding a login as VCDS only lists NAR options for login this vehicle (if i'm assuming correctly).
AutoScan will be added momentarily; note module in autoscan is original
Vehicle Identification No.WAUZZZ8E64A111246
Modelaudi a4 av. 2.0
A4
Date of production06.10.2003
Model year2004
Sales type8E50BH
Engine CodeALT
Transmission CodeGHV
Emission standard7GEEmission standard EU4 for Japan
PART NUMBERDESCRIPTIONREMARKMODEL
8H0998375
repair kit8E0614517
8E0614517L
LEGACY
fr.wheel drv-------------------------------------------------------------------------------
PIVOT
Canada
C?ID=200803
A4
Model year2004
Sales type8E50BH
Engine CodeALT
8H0998375
repair kit8E0614517
8E0614517L
LEGACY
I'm not quite sure how this is helping.....
It should help considering you have the wrong part number installed in your scan & the correct part numbers have been given to you including legacy numbers, no?
How does this not help you?
Are you saying you are looking to retrofit a wrong module?
Why is the engine config missing from the scan?
PIVOT
Canada
C?ID=200803
The module that is currently installed is without a suffix as earlier stated, part number 8EO614517. Autoscan was performed with the "module that was originally installed" according to the owner (obviously not).
Again, with the run of the mill login/coding module will not accept coding with any of the login codes I've used, and the vehicle RPO sticker is missing (par for the course). You're not aware of any login codes that pertain to the Japanese market vehicles? I dont see why they would be any different, as EU vehicles were equipped with the same options.
EDIT: My apologies, i did not add the info in the original reply notifying that the module installed in the vehicle RIGHT NOW is a 8E0 614517
Again, could you please post a complete auto-scan and including the correct part numbers and engine ECU which is currently vacant in the aforementioned vehicle scan?
Is your true location Canada or Japan and indeed you know I am aware, I'm just not sharing & until you comport with basic procedures, isn't that fair?
Did you JPPSG yet?
Agreed, however, why purport to perpetuate this mindset?
NostraJackASS can be and is indeed an ASShole, even admittedly, will continue to be so & in the spirit/interest of everyone's safety and qualified repairs to be accomplished!
NZDubNurd
New Zealand
C?ID=230482
Your module in the scan suggests it's an AWD (allrad) one:
   Coding: 00000
Without the correct part number, it's unlikely you'll simply be able to "code" it, unless it just happens to conveniently be one that's compatible and has different options, that are also compatible.
When people do work out which ones swap over, it's usually by trial and error, or good investigative guesswork :D VW/Audi have a list of replacement units (that Jack showed). A different suffix on the end isn't a super-cession, it can mean a totally different module compatibility range.
If you really want to get this thing going, find the correct ABS module. Then get it back to it's rightful owner... before that trans explodes ;)
(Or, do a manual conversion, which is probably what your now-fitted ABS part number is compatible with :D)
PIVOT
Canada
C?ID=200803
   Coding: 00000
Correct module is currently in the vehicle, as stated above. The one fitted during the AutoScan was one provided by the customer as his "diag" for the wheel speed sensor signal faults he was dealing with.
Original module is correct part number 8E0 614 517.
Yes we have heard all that, can you now please stop equivocating & post a new complete auto-scan and containing the missing engine control module and existing ABS module of record now regardless of your aforementioned statement?
Did you know that "stated income home loans" often were defaulted on?
Why are you dismissing these simple requests?
PIVOT
Canada
C?ID=200803
You'd think with your attention to detail you'd see that my location (third line under my username) states I'm in Canada, but yes, I'm in Canada and the vehicle is imported from Japan.
As none of the pertinent data required to code the module is listed in 01, I don't see it as an issue.
Ive managed to login with three separate login codes based on vehicle equipment (and suspected brake packages), and have coding not accepted. Ive been through this with VCDS quite a few times before, and the VAS 5052 always managed to perform the function.
Login Codes i have tried thus far
09479
09379
09579
09679
As the PR sticker has been kindly removed by someone, the brake package is unknown (aside from physical measurements). Every local dealer within our surrounding area also has issues sourcing this for reasons unbeknownst to me
09479
09379
09579
09679
And he feels he must PIVOT to continue to equivocate and dismiss the forum requests and post gibberish & as is if he knows, however, is here asking for help being argumentative, why?
Another pattern behavior confirmed........
PIVOT
Canada
C?ID=200803
Cars fixed, so you can save your breath to condescend someone else! appreciate all the "help"
Yeah great I'm proud of you OP what was the solution for it being "fixed"?
What was the scope of the repair or did you use a scope? :p
Please post a complete full auto-scan, you know like you didn't from beginning, right?
PIVOT
Canada
C?ID=200803
I actually just cut all the wires and plugged the scope into them until the waveform correlated to the login code on the rising edge of can high. Super simple, can't believe i didn't think of it earlier
