Results 1 to 10 of 18
Thread: JDM import B6 A4 Avant 5.7ABS CODING INFO
    Dec 2019
    Canada
    Hoping this forum can reach someone with more info on this type of thing than I. Have this JDM imported 03 A4 2.0L N/A CVT/FWD which has presented an odd problem. Two modules were gifted to me with instructions to "make it work". Neither module has any softcoding present (00000), and so far aside from vcds, I've attempted coding with vas5052, auto logic..... The login codes/coding I've tried have resulted in no coding being saved. I can't post autoscan now, but only two faults are the obvious: module incorrectly coded and g85 no/incorrect basic settings.
    Any help is appreciated!!
    VIN: WAUZZZ8E64A111246   License Plate:
    Mileage: 98860km-61428mi   Repair Order:
              67 69 75 76 77
    VIN: WAUZZZ8E64A111246   Mileage: 98860km-61428miles
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 8E0 910 155 E    HW: 01J 927 156 JK
       Component: V30 01J 2.0l 5V RdW 3120
       Revision: 00000008    Serial number: 00000002102755
       Shop #: WSC 63016 001 1048576
       VCID: 275D03BB95E0A977C6-5140
    18259 - Powertrain Data Bus
                P1851 - 000 - Missing Message from ABS Controller - Intermittent
       Part No: 8E0 614 517 A
       Component: ABS/ESP allrad      3429
       Coding: 00000
       VCID: 26430EBFC2EAB07FFD-5140
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                30-00 - Open or Short to Plus
    18256 - Please check DTC Memory of Engine Controller
                P1848 - 35-10 -  - Intermittent
                66-10 - Not Matched - Intermittent
                35-00 - -
       Part No: 8E0 820 043 AC
       Component:   A4 Klimaautomat   1424
       Coding: 00000
       Shop #: WSC 79800
       VCID: 62CB52AFEE420C5FD1-5122
    01273 - Fresh Air Blower (V2)
                53-10 - Supply Voltage Too Low - Intermittent
    00532 - Supply Voltage B+
    01312 - Powertrain Data Bus
                79-00 - Please Check Fault Codes
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  RDW 0517
       Coding: 00011
       VCID: 3561D9F30F4CCBE744-4B02
                57-00 - Electric Circuit Failure
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 B
       Component: Airbag 8.4EP        3002
       Coding: 0010702
       Shop #: WSC 63251 000 00000
       VCID: 3663DEFF424AC0FF4D-5140
       Part No: 8E0 953 549 S
       Component: Lenksáulenmodul     0611
       Coding: 01012
       Shop #: WSC 63251
       VCID: 4385B72B51986557FA-4B02
       Part No: 8E0 920 900 L
       Component: KOMBI+WEGFAHRS. RB4 D37
       Coding: 02500
       Shop #: WSC 60462
       VCID: 2D51F193E71C83273C-5140
       WAUZZZ8E64A111246     AUZ6Z0C0283970
    01039 - Coolant Temperature Sensor (G2)
    01304 - Radio
                49-00 - No Communications
       Part No: 8E0 959 433 BB
       Component: Komfortgerát T7B    1411
       Coding: 07104
       Shop #: WSC 07130
       VCID: 72EB22EF3EA29CDFA1-4B02
       Subsystem 1 - Part No: 8E2959802
       Component: Tőrsteuer.FS BRM 0003
       Subsystem 2 - Part No: 8E2959801
       Component: Tőrsteuer.BF BRM 0003
       Subsystem 3 - Part No: 8E0959801A
       Component: Tőrsteuer.HL BRM 0004
       Subsystem 4 - Part No: 8E0959802A
       Component: Tőrsteuer.HR BRM 0004
    7 Faults Found:
    00956 - Key 2
                35-00 - -
    01705 - Selection Switch for Mirror-Adjust (E48)
       Part No: 4Z7 907 357
       Coding: 00060
       Shop #: WSC 63251
       VCID: 040774371416A26F83-4B34
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
    01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
    End-------------------------(Elapsed Time: 05:53)--------------------------
    Welcome to the VCDS forum.
    OP could you please post a complete auto-scan and part numbers of what it is you are doing?
    Did you follow the RTFB or wiki procedure?
    Sure sounds like FOD huh?
  3. Likes Uwe liked this post
    Dec 2019
    Canada
    I'll add the ABS module info ASAP.
    If the routine coding procedures had worked, I wouldn't be posting this!
    Clever acronyms aside Jack, I'm simply looking for help from users regarding a login as VCDS only lists NAR options for login this vehicle (if i'm assuming correctly).
    AutoScan will be added momentarily; note module in autoscan is original
    Vehicle Identification No. WAUZZZ8E64A111246
    Model audi a4 av. 2.0
    A4
    Date of production 06.10.2003
    Model year 2004
    Sales type 8E50BH
    Engine Code ALT
    Transmission Code GHV
    Emission standard 7GE Emission standard EU4 for Japan
    PART NUMBER DESCRIPTION REMARK MODEL
    8H0998375 repair kit 8E0614517
    8E0614517L
    LEGACY
    fr.wheel drv -------------------------------------------------------------------------------
    Dec 2019
    Canada
    A4
    Model year 2004
    Sales type 8E50BH
    Engine Code ALT
    8E0614517L
    LEGACY
    I'm not quite sure how this is helping.....
    It should help considering you have the wrong part number installed in your scan & the correct part numbers have been given to you including legacy numbers, no?
    How does this not help you?
    Are you saying you are looking to retrofit a wrong module?
    Why is the engine config missing from the scan?
  8. Likes Uwe, NZDubNurd liked this post
    Dec 2019
    Canada
    The module that is currently installed is without a suffix as earlier stated, part number 8EO614517. Autoscan was performed with the "module that was originally installed" according to the owner (obviously not).
    Again, with the run of the mill login/coding module will not accept coding with any of the login codes I've used, and the vehicle RPO sticker is missing (par for the course). You're not aware of any login codes that pertain to the Japanese market vehicles? I dont see why they would be any different, as EU vehicles were equipped with the same options.
    EDIT: My apologies, i did not add the info in the original reply notifying that the module installed in the vehicle RIGHT NOW is a 8E0 614517
  10. #8
    Again, could you please post a complete auto-scan and including the correct part numbers and engine ECU which is currently vacant in the aforementioned vehicle scan?
    Is your true location Canada or Japan and indeed you know I am aware, I'm just not sharing & until you comport with basic procedures, isn't that fair?
    Did you JPPSG yet?
    Agreed, however, why purport to perpetuate this mindset?
    NostraJackASS can be and is indeed an ASShole, even admittedly, will continue to be so & in the spirit/interest of everyone's safety and qualified repairs to be accomplished!
  11. #9
    Nov 2014
    New Zealand
    Your module in the scan suggests it's an AWD (allrad) one:
       Coding: 00000
    Without the correct part number, it's unlikely you'll simply be able to "code" it, unless it just happens to conveniently be one that's compatible and has different options, that are also compatible.
    When people do work out which ones swap over, it's usually by trial and error, or good investigative guesswork VW/Audi have a list of replacement units (that Jack showed). A different suffix on the end isn't a super-cession, it can mean a totally different module compatibility range.
    If you really want to get this thing going, find the correct ABS module. Then get it back to it's rightful owner... before that trans explodes
    (Or, do a manual conversion, which is probably what your now-fitted ABS part number is compatible with )
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  12. Likes Jack@European_Parts, Uwe liked this post
  13. #10
    Dec 2019
    Canada
    Quote Originally Posted by NZDubNurd View Post
       Coding: 00000
    Correct module is currently in the vehicle, as stated above. The one fitted during the AutoScan was one provided by the customer as his "diag" for the wheel speed sensor signal faults he was dealing with.
    Original module is correct part number 8E0 614 517.
