Results 1 to 5 of 5
Thread: 2009 VW Jetta, Replaced ABS Module, new coding giving me trouble
    New User
    Dec 2019
    Hello there fellas, to make long story short i replaced failed ABS module (1k0907375AD) with the new updated module (1k0907375AN). Used long coding that i saved from original module. Getting these fault codes and cant seem to figure out why? since its a different part number it may need a different code? Please help, thank you in advance. Posted log with Vin and codes.
    VIN: 3VWRM71K99M038242   License Plate: 1454555555
    Mileage: 245420km-152496mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWRM71K99M038242   Mileage: 245420km-152496miles
    Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 P    HW: 07K 906 055 M
       Component: 2,5l R5/4V      G   3254
       Revision: G6H02---    Serial number: VWX7Z0H724I0P9
       Coding: 0000075
       VCID: 3B7E25997A849492C0-806E
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 000 -  - Intermittent
                        Mileage: 245424 km
                        Time: 21:29:40
                        Temperature: 68.0C
                        Temperature: 32.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 11.811 V
                   U1017 - 000 -  - Intermittent
                        Mileage: 245424 km
                        Time: 21:30:03
                        Speed: 19.0 km/h
                        Temperature: 68.0C
                        Temperature: 32.0C
                        Voltage: 11.684 V
    050197 - Implausible Data Received from ABS Control Module
                   U0415 - 000 -  - Intermittent
                        Mileage: 245424 km
                        Time: 21:30:04
                        Speed: 255.0 km/h
                        Temperature: 68.0C
                        Temperature: 32.0C
                        Voltage: 11.684 V
    Readiness: 0010 0000
       Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
       Component: AQ 250 6F           1377
       Revision: 00H76000    Serial number:
       Coding: 0000840
       VCID: 7DFAEB8124105AA2BE-8028
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Revision: 00H45001
       Coding: 113B400D49250002880D02E8921B00403000
       Shop #: WSC 09550 758 180955
       VCID: 7EF8EC8DE91641BAA7-802A
                        Reset counter: 40
                        Mileage: 245424 km
                        Count: 3
                        Count: 14
                        Count: 12288
                        Count: 320
                        Count: 41728
                        Fault Status: 01100101
                        Reset counter: 40
                        Mileage: 245424 km
                        Count: 3
                        Count: 14
                        Count: 12288
                        Count: 279
                        Count: 41728
                        Reset counter: 40
                        Mileage: 245424 km
                        Count: 3
                        Count: 14
                        Count: 12288
                        Count: 295
                        Count: 41728
                        Reset counter: 40
                        Mileage: 245424 km
                        Count: 3
                        Count: 14
                        Count: 12288
                        Count: 270
                        Count: 41728
    00003 - Control Module
                        Reset counter: 40
                        Mileage: 245424 km
                        Count: 3
                        Count: 14
                        Count: 12288
                        Count: 143
                        Count: 41728
       Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 7CFCE6853F0A53AA89-8028
       Revision: 00H54000    Serial number: 00000001056923
       Coding: 14058E234004150007140000001400000008730B5C000120000000000000
       VCID: 326008BDADCE55DA13-8066
       Component: Wischer 250808 021  0501
       Coding: 00038805
       Shop #: WSC 00066
       Revision: 00000000    Serial number: AUZ4Z7H0392294
       Coding: 0000100
       VCID: 336E0DB952D45CD218-8066
                        Fault Status: 00101110
                        Reset counter: 243
                        Mileage: 228370 km
                        Time: 14:56:44
                        Reset counter: 204
                        Mileage: 244517 km
                        Time: 16:17:25
       Revision: 05034000    Serial number: 003B6M06EJFA
       Coding: 0013889
       VCID: 6CDCD6C54F6AC32A19-8038
       Subsystem 2 - Serial number: 6332MSME3B33467EM
       Subsystem 3 - Serial number: 6342MSME3B324C05C
       Subsystem 4 - Serial number: 6351HSME173F022C9
       Subsystem 5 - Serial number: 6361HSME174A4F6FU
       Subsystem 6 - Serial number: 63727SME16710725W
       Subsystem 7 - Serial number: 63827SME167D74076
    01312 - Powertrain Data Bus
                014 - Defective - Intermittent - MIL ON
    00532 - Supply Voltage B+
       Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
       Coding: 0010021
       VCID: 030E9D7942F42C52C8-8056
    00576 - Terminal 15
    00885 - Ignition Switch (D) Terminal 50
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
       Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
       Component: KOMBIINSTRUMENT 3HL 1222
       Revision: V0003000    Serial number: VWX7Z0H724I0P9
       Coding: 0023203
       Shop #: WSC 00066 067 57207
       VCID: 3C7C26857F8A93AAC9-8068
                        Reset counter: 80
                        Mileage: 245424 km
                        Time: 21:29:40
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 010708F2002166
       Coding: ED807F070003021002
       VCID: 356A33A15CA042E236-8060
                        Mileage: 244526 km
                        Time: 09:49:21
                        Reset counter: 80
                        Mileage: 245424 km
                        Time: 21:29:42
       Component: IMMO            3HL 1222
       Revision: 72009005    Serial number: 00000527488807
       Coding: 0001205
       VCID: 6FE6C1C97E7C38323C-803A
                        Reset counter: 40
                        Reset counter: 40
                        Mileage: 244517 km
                        Fault Frequency: 146
                        Reset counter: 80
                        Mileage: 244517 km
       Part No: 1K0 909 144 C
       Revision: 00H15000
       VCID: 2A5010DD851E1D1AAB-807E
                        Reset counter: 90
                        Mileage: 245424 km
                        Time: 21:32:03
                        Voltage: 11.88 V
                            DD
                        Temperature: 27.0C
                        Fault Status: 00101101
                        Reset counter: 90
                        Mileage: 245424 km
                        Time: 21:30:03
                        Voltage: 11.88 V
                            DU
                        Temperature: 27.0C
                        Speed: 50.0 km/h
                        Speed: 50.0 km/h
                        Reset counter: 90
                        Mileage: 245424 km
                        Time: 21:30:05
                        Voltage: 11.88 V
                            DU
                        Temperature: 27.0C
                        Speed: 44.0 km/h
                        Speed: 44.0 km/h
       Coding: 13900F880186281B0904058FB0880F0488DCA0
       VCID: 040C9E6547FA2B6AF1-8050
       Revision: 72009005    Serial number: 00000272488808
       Coding: 0001204
       VCID: 70E4C2B5634227CA25-8024
                        Reset counter: 40
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
                        Reset counter: 40
                        Fault Frequency: 134
                        Reset counter: 80
                        Mileage: 244517 km
       Component: Radio DE2       016 0020
       Revision: 00016000    Serial number: VWZ4Z7H2221863
       Coding: 0010400
       VCID: 2952EFD180181602A2-807C
                014 - Defective
       Revision: 12006001    Serial number: 00000003361177
       Coding: 0001168
       VCID: 76E8F4AD012609FAFF-8022
       Coding: 0100101
    00625 - Vehicle Speed Signal
                        Reset counter: 80
                        Mileage: 245424 km
                        Time: 21:32:05
       Revision: 12006001    Serial number: 00000003353835
       Coding: 0001168
       VCID: 77F6F9A9062C70F2E4-8022
    End-------------------------(Elapsed Time: 02:30)--------------------------
    Sep 2016
    Riga, Latvia
    Hi and welcome!
    First of all post full unedited autoscan, in [code] tags would be excellent.
    Second - why did You replace old module? What was wrong with it?
    New User
    Dec 2019
    Quote Originally Posted by MartinsX View Post
    Hi and welcome!
    I didnt edit anything in the log but ill see if i can get you another copy!
    Replaced it because it started malfunctioning - not showing speed was one of the problems. I tried to find a used one and none of them matched up, this vehicle takes only one part number(or updated part number).
    It looks like it needs some of the Basic Settings described on this page.
    New User
    Dec 2019
    Thanks for the reply Uwe! Ill follow the procedure described in the link. Will let you guys know if it worked
