Results 1 to 8 of 8
Thread: Change ACC to standard CC 2014 Audi S7
    Dec 2019
    Louisiana, USA
    Has anybody disabled their ACC, and enabled regular CC? I don't feel like spending $500 for the second time to align the radars. Does anyone have any guide? I've seen some people attempted but the forum threads were never completed. It looks a little difficult as a ACC code is in many modules. I understand the coding format as I am an embedded programmer myself, but I am new to Ross Tech, so any help would be appreciated. Thanks!
    Hi and welcome.
    I doubt anyone has made a guide for this for your exact car.
    Let's start with an Auto-Scan please, so people can see how your particular car is equipped.
    If it were looking to do this, after I did an Auto-Scan in stock condition, I'd disconnect the ACC sensor(s), remove them from the Gateway Installation list, and then see what other modules complain about it.
    Jan 2019
    In VW PQ25/PQ35 this is possible.
    In addition to what Uwe said, you need to change the MFSW from ACC one to the CCS one.
    And do some coding changes.
    I would think that this will be simmilar @ Audi, too.
    Dec 2019
    Louisiana, USA
    Thank you! I feel welcomed. Here's the auto-scan. What's weird is the motor mounts and some other problems came up, I have no check engine light!
    Friday,06,December,2019,16:19:47:13606
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
              46 47 52 53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90 A9 BA
    BA-Motor Mounts -- Status: Malfunction 0010
    Address 01: Engine (------CEUC)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 906 014 E    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H62 0006
       Revision: NCH62---
       Coding: 1A2500326546000E1000
       Shop #: WSC 01931 004 1048576
       ASAM Dataset: EV_ECM40TFS0114G0906014E 001006
       ROD: EV_ECM40TFS0114G0906014E.rod
       VCID: 2411EB361E58AD478DF-8070
       Part No SW: 4G9 927 156 C    HW: 0B5 927 156 K
       Component: 0B5 40TFSINAR H02 0002
       Revision: --H02---
       Shop #: WSC 02391 785 00200
       ROD: EV_TCMDL501021.rod
       VCID: 35372672A5C224CF2A1-8060
       Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
       Component: ESP PREMIUM   H09 0450
       Coding: 65B65703A66DEAC04B00
       VCID: 3B23304A83E6F2BFDC5-806E
       Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 DR
       Component: BCM2 2.0      H35 0510
       Coding: 0D8A2046000000000000
       VCID: 7CA1F356C6E8358795F-8028
       Serial number: 0213000329385013
       Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
       Component: KLIMA 4 ZONEN H13 0088
       Serial number: 02101300040875
       Coding: 680320784D
       ASAM Dataset: EV_AirCondiComfoUDS 002043
       VCID: 629DAD2E44CCE377BF3-8036
       Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
       Revision: 11012002    Serial number: 00000001788065
       Coding: 0D07A091053E9FE2AF0008C7A0003820CF9CD208A2090221800308457B00
       Shop #: WSC 12345 123 61029
       VCID: 6FBBD41A879E5E1F20D-803A
       Component: WWS57X 130909  H36 0080
       Serial number:         130924150241
       Coding: 0045F7
       Serial number: 21800684
       Coding: 02006E
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 27 09 2013  00000006
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R7PP703
       Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
       Component: A31 LED Mod1L  H02 0002
       Serial number: 00000000001309110374
       Subsystem 6 - Part No SW: 4G0 907 472     HW: 4G0 907 472
       Component: A27 LED Mod1R  H02 0002
       Serial number: 00000000001311140552
       Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA106970000004793180
       Coding: 020300
       Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 25F84EC6000000000001
       Subsystem 9 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
       Component: A32 LED Mod2L  H02 0002
       Serial number: 00000000001309181555
       Subsystem 10 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
       Component: A28 LED Mod2R  H02 0002
       Serial number: 00000000001401242331
       Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
       Revision: 11001001    Serial number: 61031327700671
       Coding: A8E909
       VCID: 71BFD262912A48EF369-8024
       Part No SW: 4G0 907 561 A    HW: 4G0 907 561
       Component: ACC3          H19 0410
       Coding: 7601010101
       Shop #: WSC 11506 001 1048576
       VCID: 2809FF0662704927A17-807C
    10240 - Sensor for Automatic Distance Control
              [FAULT_BLR_BLK8_31]
                        Reset counter: 62
                        Mileage: 153155 km
                        Date: 2019.12.04
                        Time: 19:31:01
                        Control Module temperature: 24 °C
                        Voltage terminal 15: 14.339 V
                        Velocity_vehicle_reference: 8.91 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.01 m/s²
       Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
       Component: Airbag10.43   H33 0033
       Revision: --------    Serial number: 003D8003GKXA
       Coding: 303145313131303030324A55304C34473853
       VCID: 3333186AABB63AFF045-8066
       Component: BF-Gewichtss.  H15 0046
       Serial number: 6940000Y130000XZML0$
       Serial number: 3575HRB400E50LFCC8MG
       Serial number: 3585HRB401I50HLAHGV1
       Serial number: 3515JRB400650N8AHGVJ
       Serial number: 3525JRB400850N8APHSS
       Serial number: 3554VRB400M50MBM5P3X
       Serial number: 3564VRB400650NQQFGQJ
       Revision: --------    Serial number: 90372MJ20005G
       Coding: 0000FC
       VCID: 372B2C7ABF4ED6DF38D-8062
       Serial number: 05 08 2013  C0316586
       Part No SW: 4G8 920 985 H    HW: 4G8 920 985 H
       Component: TBenUsaAccNv  H58 0621
       Revision: 29460233    Serial number: 658280913596045
       Coding: 03C701079F53CF05020300
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 3C21335686E8F587D5F-8068
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001117897
       Coding: 00E1034800
       VCID: 72BDDD6E942C73F7CF3-8026
       Serial number: 3762481403
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H16 0013
       Serial number: 000610130001609
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
       VCID: 270BFC3A6F6E465FA8D-8072
       Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
       Component: KLIMA FOND    H07 0088
       Serial number: 01101300041428
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002021
       VCID: 3635217EB8C42FD723B-8062
       Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
       Coding: 008002
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2E05091E409417176BB-807A
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000075475740
       Coding: 00581B0000002001000001010101102030303232203232
       VCID: 77ABEC7AFFCE16DFF8D-8022
       Component: SARA 6D red   H03 0056
       Revision: --------    Serial number: EJ1BPA7E00P8NS
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 372B2C7ABFCED6DF38D-8062
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4G0 907 566 J    HW: 4G0 907 566
       Component: J769  SWA MasterH04 0060
       Revision: 00H04000    Serial number: 6PZ 010 287-08
       Coding: 0000003
       VCID: 3635217EB4442FD723B-8062
       Subsystem 1 - Part No: 4G0 907 568 J
       Component: J770  SWA Slave H04 0060
       Subsystem 2 - Serial number: 6PZ 010 287-28
       Subsystem 3 - Serial number: 5F02.10.1300H04000AMS14871˙
       Subsystem 4 - Serial number: S14871˙
       Component: TSG FA        H04 0507
       Coding: 011F5F025E00628002000413
       VCID: 45D756B2F5A2B44FBA1-8010
       Component: RCEPS         H38 0010
       Revision: 00001000    Serial number: 0021881454
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323D1D6E54AC33F70F3-8066
       Revision: 00002001    Serial number: 0316908568
       Coding: 0126063A20FAF08580B00A8002030D000000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000181222
       Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
       Component: J245 PS40.039  H01 0008
       Serial number:     WOO2443930%
       Coding: 101F00
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00004378053
       Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H11 0029
       Serial number: WA106975000004641406
       Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93070494
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 22
                        Mileage: 153168 km
                        Date: 2019.12.04
                        Time: 19:46:40
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 22
                        Mileage: 153168 km
                        Date: 2019.12.04
                        Time: 19:49:20
       Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
       Component: BOSE-G3C7-ANC H02 0540
       Revision: CJ002700    Serial number: 00000000003241
       Coding: 030000
       VCID: 1C61D3D626A8958735F-8048
       Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
       Component: TSG BF        H04 0507
       Coding: 011F5F025E00628002000402
       VCID: 44D14BB6FE988D47ADF-8010
       Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
       Component: EPB-4         H03 0014
       Revision: --------    Serial number: 00000000839605
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2C0103167688650745F-8078
       Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
       Serial number: 131009-0004-004
       Coding: 12236F601002A400
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2D070E124D926C0F521-8078
       Revision: AB001007    Serial number: 156J40D7915185
       Coding: 020007010000000001
       VCID: 2411EB361ED8AD478DF-8070
       Part No SW: 4G0 035 746 E    HW: 4G0 035 746 E
       Component: H-BNT-NA      H40 0735
       Revision: --------    Serial number: 194J30D7558404
       Coding: 0A0200040203F9EF7D12CB3E00000003100001000000000000
       VCID: 290FFA0279FA702FBE9-807C
       Subsystem 1 - Part No: 8R0 060 884 BD
       Component: NAR 2013/2014  0802
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDDD002PLYO
       Serial number: 90349PBP000D8
       Component: CD-Database  5298
                        Reset counter: 20
                        Mileage: 153155 km
                        Date: 2019.12.04
                        Time: 16:18:37
                        Text: KBD_FC7,KBD,A,fa,cc,1
       Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
       Coding: 010F1F024000628002000002
       VCID: 47CB5CBACFAEA65F48D-8012
       Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
       Component: TopView       H05 0220
       Revision: 11001001    Serial number: 82330JF0108570
       Coding: 0206000001010100000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
       ROD: EV_CamerSysteTopViewAUDI_007_AU57.rod
       Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
       Component: HDSG-Modul    H13 0043
       Revision: 12013001    Serial number: 261300777
       Coding: 0A3305C102
       ASAM Dataset: EV_HDSGAu573 001022
       ROD: EV_HDSGAu571.rod
       VCID: 44D14BB6FE188D47ADF-8010
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H26 0038
       Coding: EA060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2615F13E68645F5793B-8072
       Part No SW: 4G0 907 541 A    HW: 4G0 907 541
       Component: ACC3          H19 0400
       Coding: 7601010101
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H32 0041
       Serial number: 005000122509137
       Coding: 03C19A1A0111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313F126251AA08EF769-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
    Address A9: Struct. Borne Sound        Labels:
       VCID: 55F786F2058204CFCA1-8000
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145     HW: 4H0 907 145
       Component: AEM - LEAR    H07 0006
       Revision: 00001001    Serial number: 97809002446000
       ASAM Dataset: EV_AEMLearAU64X 002014
       ROD: EV_AEMLearAU64X_AU57.rod
       VCID: 6695B13EA8E49F5753B-8032
    1294 - Actuator 1 for Drivetrain Mounts
              C1131 07 [009] - Mechanical Failure
                        Reset counter: 20
                        Mileage: 153155 km
                        Date: 2019.12.04
                        Time: 16:32:48
    End----------(Elapsed Time: 03:33, VBatt start/end: 12.1V/12.1V)-----------
    Dec 2019
    Louisiana, USA
    This would require me physically installing a CCS stalk?? I've read someone was got ACC CCS working without replacing stalk
  6. #6
    Quote Originally Posted by Jamespie View Post
    The Check Engine light is for things that might effect emissions. I don't think the motor mount will.
    On you specific car, I do not know. I have seen some cars (e.g. a 2015 Touareg, which is systems wise is much closer to an Audi than a VW) with regular cruise that had identical controls to one with ACC.
    Now looking at your Auto-Scan, I see that only one of the two sensors is throwing a fault, and that fault is a "limited visibility" fault rather than a "misalignment" fault. Have you physically inspected / cleaned the radar sensors?
  7. #7
    Dec 2019
    Louisiana, USA
    Well by "check engine" light, I just mean any dash warning. It seems like if any fault code comes up, it should definitely give a warning on the dash.
    So this is crazy. The first time my car threw the code, I made sure sensors were clean. I even removed the two radar grills to fully inspect them. I gave each radar a wiggle to make sure they weren't loose. Well just now, I took the grills off to unplug the radars and I notice that one of the radar's adjustment screw had partially come out of the plastic socket. There are three adjustment screws that hold the radar to a bracket. On the bracket side, these screws have a rounded head and sit in a plastic socket, much like..... I don't know..... a ball and socket? Well that screw popped out the socket. Snapped it back in, just went out for a test drive while looking at live data from radar measurements. Everything is great. Less than 0.05 degree angle offset. Glad I did this, Audi would have charged atleast $200 for this. Paid for my HEX-V2 already!
  8. Likes Uwe liked this post
  9. #8
    Nope, things don't work that way. If there was a warning light or other notification for every fault code in the typical modern car, there would almost always be a warning light glowing or notification being displayed. It's pretty rare to see a scan from any such car, even brand-new just off the dealer's lot, that has not fault codes at all.
  10. Likes PetrolDave liked this post
