Imported VW tiguan from Australia, trying to download UK maps but region issues
Alexcole1991
Portsmouth, UK
C?ID=339078
hi all!
got an imported VW Tiguan that ive just picked up which wont accept a uk sd card, it keeps coming up when trying to download
"the regions do not match (main unit). "Europe" "RoW"
I have tried manually changing the coding to UK from Australia but this does not work, I have also copied the coding from my pals Tiguan and put it in and that didn't work either.
here is his coding UK: 02730601FF00000051110101008808001F0109C601200100CF
here is my coding aus: 02730601FF00000051510001000808001F0106E601200002DF
anyone got any ideas? is the region in another control unit that I need to also change?
Friday,06,December,2019,20:00:23:48845
VIN: WVGZZZ5NZHW375725   License Plate: YN67 GPU
Mileage: 33473km-20799mi   Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C 42
          44 4B 52 5F 6C 6D A5 BB BC CA CF D6 D7
VIN: WVGZZZ5NZHW375725   Mileage: 33473km-20799miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5N0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 092500322466050B3000
   ASAM Dataset: EV_ECM20TFS0205N0906259 001003
   ROD: EV_ECM20TFS0205N0906259.rod
   VCID: 72A82BBDA511ECDFA1-8026
18934 - Oxygen (Lambda) Sensor Signal B1 S2
          P2271 00 [096] - too Rich
                    Mileage: 33455 km
                    Date: 2019.12.05
                    Time: 18:40:59
                    Engine speed: 1203.25 /min
                    Normed load value: 39.2 %
                    Vehicle speed: 61 km/h
                    Coolant temperature: 99 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 14.492 V
14955 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
          P2097 00 [101] - Too Rich
                    Mileage: 33431 km
                    Date: 2019.12.05
                    Time: 13:43:22
                    Engine speed: 906.50 /min
                    Normed load value: 8.2 %
                    Vehicle speed: 121 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 14.707 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: OL_INTR
                    T_AST_SAE: 266 s
                    MAP_MES_SAE: 26 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.607 V
                    FAC_TPS_1_SAE: 13.281250 %
                    FUP_H_SAE: 12330.0 kPa
Readiness: 0000 0001
   Part No SW: 0DL 300 011 P    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2001
   Revision: 00H06V07
   VCID: 3522D0A194FFBBE744-8060
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 63256000000674
   Coding: 0AEE939A54272371477E070262C84950C92AC4E2E046927D384250B8C2AA4200002F641A1B13111435351919323200
   VCID: 79BA1C91F8679F87E0-802C
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0424121850
   Coding: 032C2C070F
   VCID: 3C34C585B7D56AAFBB-8068
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98100702
   Part No SW: 5NA 907 044 G    HW: 5NA 907 044 G
   Component: AC Automat    H35 4101
   Revision: 20K08000    Serial number: 00000E00312021
   Coding: 0012002420010000110510001210142A
   ASAM Dataset: EV_ACClimaPrehVW37X 002019
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 43C6BE79CA2B1557FA-8016
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Reset counter: 91
                    Mileage: 33438 km
                    Date: 2019.12.05
                    Time: 13:47:02
                    Outside air temperature: 8.5 °C
                    Voltage terminal 30: 12.9 V
                    System run time-Engine running time: 253 s
                    System run time-Terminal 15 on: 253 s
                    Air quality status: ERROR
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001632000333
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F4EF289E643B1B7DE-802A
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 160922  033 0372
   Serial number: 00000001609200303485
   Component: RLHS  042 0105
   Serial number: S7Y16M11D23H16M12S46
   Coding: 00A8DD
204546 - Remote key 2
                    Reset counter: 50
                    Mileage: 33427 km
                    Date: 2019.12.05
                    Time: 10:48:04
   Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0021
   Serial number: 000111167478010
   Coding: 0331667851
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 3B36C699B2DB6D97B2-806E
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320047C358FF8428749C8065303085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001.rod
   Serial number: 22101641351086
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 383CD99583ED468F5F-806C
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2BSVET
   Coding: 98CCC0C00C0000005C540000008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 106C4135CBDDBECF37-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 001 811 16
   Serial number: 357000000005DA650F1R
   Subsystem 2 - Part No SW: -----------    HW: 480 001 811 16
   Serial number: 358000000006DA650F1T
   Subsystem 3 - Part No SW: -----------    HW: 480 402 211 16
   Serial number: 35100019F22EA2A4F6BO
   Subsystem 4 - Part No SW: -----------    HW: 480 402 211 16
   Serial number: 3520001A7231F2C5830-
   Subsystem 5 - Part No SW: -----------    HW: 480 402 111 16
   Serial number: 3550001BF22F9766868N
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 301 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001BF2404066124P
   Subsystem 7 - Part No SW: -----------    HW: 480 401 301 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001C124040621508
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 401 301 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001BF240406576BY
   Subsystem 9 - Part No SW: -----------    HW: 480 001 010 16
   Serial number: I0M00000000957A84E1C
   Subsystem 10 - Part No SW: -----------    HW: 480 001 310 16
   Serial number: I0N0000000084A30D812
   Part No SW: 3Q0 953 521 DM    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20161124300333
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7EB00F8DE149B8BFD5-802A
   Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
   Component: KOMBI         407 2160
   Coding: 27A510187F88040801886B0B1401000000000000
   Shop #: WSC 38100 381 12345
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 41CAB471D0370747E8-8014
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0005618369
   Coding: 030500347F085900FB07225A9E0F00010001050000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 2F2EE2C976A381370E-807A
   Serial number: 29160002326130086453
   Coding: 2DFFFF
   Serial number: 8134692204
9175296 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
          [Funktionseinschränkung Pausenempfehlung - Ausfall CAN-MSG Prio2]
                    Reset counter: 91
                    Mileage: 33440 km
                    Date: 2019.12.05
                    Time: 13:48:25
                    Supply voltage: Terminal 30: 12.6 V
                    Terminal 15: On
   Serial number: HA1-00028.10.16
   Coding: 0101
   VCID: 4AD8935DED01C41F39-801E
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH07 0014
   VCID: 45C2A061C41F2B67D4-8010
   Serial number: 16000304056008
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AA24B1A017D7C758-8024
   Component: Sitzmemory    H08 0020
   Serial number: Y0006PJS15750
   Coding: 0014000000000500018281808181000000008181000000F400
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 C    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0310
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   Serial number: 130916EIC11334
   Coding: 003F1B20D201040000000000
65799 - Door Warning / Entry Lighting
          B1775 01 [009] - Electrical Failure
                    Reset counter: 50
                    Mileage: 33427 km
                    Date: 2019.12.05
                    Time: 10:21:32
   Part No SW: 5QF 909 144     HW: 5QF 909 144 _
   Component: EPS_MQB_ZFLS  506 5572
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 075E6A69BE93F977E6-8052
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Component: FCM MQB Low   001 0285
   Serial number: 09111610520624
   Coding: 000000050100085607000F010A0000000000000000000000000000000000
   Serial number: 251016EJM36679
   Coding: 003F1120DE01040000000000
   VCID: 42C8BB7DD5311C5FF1-8016
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 3G0 035 045 D    HW: 3G0 035 045
   Component: MU-H-N-RW     H51 0814
   Serial number: A688K0G2509834
   Coding: 02730601FF00000051510001000808001F0106E601200002DF
   VCID: 1F0E1209060311B7BE-804A
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJT3646500
   Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
   Component: ROW 2017  --- 0062
   Component: Gracenote2---  --- 4009
          B201A 00 [009] - -
                    Reset counter: 55
                    Mileage: 33473 km
                    Date: 2019.12.06
                    Time: 19:56:50
                    Voltage terminal 30: 13.4 V
                    Status_Software_Version_Management-module_name: MDUV612/Main
   Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
   Component: Areaview 2    H13 0607
   Serial number: C854707JG007196
   Coding: 01230600A20F200000204094
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 30963171000000
   Coding: 0A28
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 24111612P22573
   Coding: 000307060000010100022346C050490084000E200000
   Shop #: WSC 08852 002 1048576
   Serial number: 151116EKE28138
   Coding: 002A11200100040000000000
   Serial number: 151116EKE16154
   Component: SAD_STG_1     013 0005
   Coding: 108040732602
   VCID: 3D32C881ACCF63A78C-8068
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 C    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
   VCID: 1660372DE93950FF6D-8042
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:23, VBatt start/end: 13.3V/13.3V)-----------
RETROFITS...........
Nope. I see no parts that have been added that don't come with the car. But the car ain't broken either. So Tweaks is where this belongs. :)
Moving it there.
What do you have in this Adaptation channel?
IDE03471-ENG138660 -- Vehicle configuration - SDS_Region_Flag
DV52
C?ID=194404
^^^^ hmm.......... here's a more readable form of the long-code strings on your first post:
Name	UK		         AUS
Byte	Hex	Binary	        Hex	Binary
0	02	00000010	02	00000010
1	73	01110011	73	01110011
2	06	00000110	06	00000110
3	01	00000001	01	00000001
4	FF	11111111	FF	11111111
5	00	00000000	00	00000000
6	00	00000000	00	00000000
7	00	00000000	00	00000000
8	51	01010001	51	01010001
9	11	00010001	51	01010001
10	01	00000001	00	00000000
11	01	00000001	01	00000001
12	00	00000000	00	00000000
13	88	10001000	08	00001000
14	08	00001000	08	00001000
15	00	00000000	00	00000000
16	1F	00011111	1F	00011111
17	01	00000001	01	00000001
18	09	00001001	06	00000110
19	C6	11000110	E6	11100110
20	01	00000001	01	00000001
21	20	00100000	20	00100000
22	01	00000001	00	00000000
23	00	00000000	02	00000010
24	CF	11001111	DF	11011111
I'm not quite sure about the Antipodean code-string because according to how SATNAV was set-up in my cars, Byte 3 had the value hex08 like this:
But in any event - Byte 3 is correctly coded for the country that holds Australia's head-of-state!
As for why you are experiencing your problem, my understanding is that the SWAP license for SATNAV is region specific alas - the SVM error in the hex5F module in your auto-scan kind-of tends to suggests (to me at least) that the SATNAV FEC in the factory Aussie module is incompatible with the hex01 value in Byte 3 - I think!!
Alexcole1991
Portsmouth, UK
C?ID=339078
Name	UK		         AUS
Ok so is this a dealer only coding issue I need to take it there to be done?
If it's a SWAP license, then it's definitely dealer only. But it's not entirely clear to me whether a dealer will be able to change that. It depends whether VW has configured their servers to allow it.
DV52
C?ID=194404
^^^ Alex: I sense a degree of doubt from the B. Dictator (not a good thing) - you could test my understanding by setting Byte3 to hex08 (i.e. Binary 0000 1000), If my understanding correct, the region code in hex5F module should then re-align again with the factory set region in the SATNAV license - and you should be able to clear the hex5F DTC - I think - I hope - perhaps?
Alexcole1991
Portsmouth, UK
C?ID=339078
I sent it to VW where my pal works and he sent a DISS with a technical query, he text me this:
Yeah man technical got all funny and said it was a issue for the original importer (aus)and that discover pro 2 wasn’t available in the format you have in Europe, cos yours looks like discover media but it’s discover pro , parts technical said basically the same thing and they can get you a maps card but it’ll only be for aus and Southern Asia 🤦🏻*♂️, think basically , either you gotta , contact Vw aus or get someone like Paul in car guy to have a fiddle who’s a bit savvy with vagcom, someone must be able to do it but I think the whole importer issue between euro and aus is what’s making them not wanna touch it
So now I’m really stuck what to do...
Alexcole1991
Portsmouth, UK
C?ID=339078
I will give this a go! Shall I do that in long coding helper but edit and put in the above 00001000 manually?
Spacewalker
Poland
C?ID=159607
leave coding ......EU map is different region that AU map
2 options
1) Only dealer can enable proper region, however ODIS will see that VIN was made for AU and will allow only restore AU (this is what I am thinking)
2) Open AU map and EU , you will see 2 catalogs at the begining
One of the catalog is a region, so change name of that catalog to that name what AU map use
keep contents this same, only change name E0 .... is like that
Alexcole1991
Portsmouth, UK
C?ID=339078
2 options
Can you private message me, so I can understand what your saying clearer and ask some more questions? Kind regards
VWT6
C?ID=295527
As Spacewalker suggests - in the link a tweak to use maps the other way round for Discovery Media (Europe) ---> https://www.t6forum.com/threads/how...system-in-non-eu-countries-e-g-morocco.10331/
Basically the tweak is just to rename the directory containing "wrong/needed" maps. Perhaps something similar works for you.
It seems that MY17 Tiguan can have either Discover Media or Discover Pro Infotainment System installed. Have a look at map updates ---> https://webspecial.volkswagen.de/vwinfotainment/int/en/index/downloads/maps-download#/
There are separate sets of maps for each type.
Discover Media accepts only OEM SD cards but my impression is that in Discover Pro any SD card can be used.
