Results 1 to 10 of 13
Thread: Imported VW tiguan from Australia, trying to download UK maps but region issues
    Oct 2019
    Portsmouth, UK
    Lightbulb Imported VW tiguan from Australia, trying to download UK maps but region issues
    hi all!
    got an imported VW Tiguan that ive just picked up which wont accept a uk sd card, it keeps coming up when trying to download
    "the regions do not match (main unit). "Europe" "RoW"
    I have tried manually changing the coding to UK from Australia but this does not work, I have also copied the coding from my pals Tiguan and put it in and that didn't work either.
    here is his coding UK: 02730601FF00000051110101008808001F0109C601200100CF
    here is my coding aus: 02730601FF00000051510001000808001F0106E601200002DF
    anyone got any ideas? is the region in another control unit that I need to also change?
    Friday,06,December,2019,20:00:23:48845
    VIN: WVGZZZ5NZHW375725   License Plate: YN67 GPU
    Mileage: 33473km-20799mi   Repair Order:
    Chassis Type: 5N-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C 42
              44 4B 52 5F 6C 6D A5 BB BC CA CF D6 D7
    VIN: WVGZZZ5NZHW375725   Mileage: 33473km-20799miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5N0 906 259     HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 092500322466050B3000
       ASAM Dataset: EV_ECM20TFS0205N0906259 001003
       ROD: EV_ECM20TFS0205N0906259.rod
       VCID: 72A82BBDA511ECDFA1-8026
    18934 - Oxygen (Lambda) Sensor Signal B1 S2
              P2271 00 [096] - too Rich
                        Mileage: 33455 km
                        Date: 2019.12.05
                        Time: 18:40:59
                        Engine speed: 1203.25 /min
                        Normed load value: 39.2 %
                        Vehicle speed: 61 km/h
                        Coolant temperature: 99 °C
                        Intake air temperature: 24 °C
                        Voltage terminal 30: 14.492 V
    14955 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
              P2097 00 [101] - Too Rich
                        Mileage: 33431 km
                        Date: 2019.12.05
                        Time: 13:43:22
                        Engine speed: 906.50 /min
                        Normed load value: 8.2 %
                        Vehicle speed: 121 km/h
                        Coolant temperature: 93 °C
                        Intake air temperature: 14 °C
                        Voltage terminal 30: 14.707 V
                        Engine: operating status: IS
                        STATE_LS_SAE[1]: OL_INTR
                        T_AST_SAE: 266 s
                        MAP_MES_SAE: 26 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.607 V
                        FAC_TPS_1_SAE: 13.281250 %
                        FUP_H_SAE: 12330.0 kPa
    Readiness: 0000 0001
       Part No SW: 0DL 300 011 P    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2001
       Revision: 00H06V07
       VCID: 3522D0A194FFBBE744-8060
       Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
       Component: ESC           H62 0743
       Revision: 00000000    Serial number: 63256000000674
       Coding: 0AEE939A54272371477E070262C84950C92AC4E2E046927D384250B8C2AA4200002F641A1B13111435351919323200
       VCID: 79BA1C91F8679F87E0-802C
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0424121850
       Coding: 032C2C070F
       VCID: 3C34C585B7D56AAFBB-8068
       Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
       Component: GEB.F.Heckoef  H17 0903
       Serial number: 98100702
       Part No SW: 5NA 907 044 G    HW: 5NA 907 044 G
       Component: AC Automat    H35 4101
       Revision: 20K08000    Serial number: 00000E00312021
       Coding: 0012002420010000110510001210142A
       ASAM Dataset: EV_ACClimaPrehVW37X 002019
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 43C6BE79CA2B1557FA-8016
       Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
       Component: E265KlimaHeck  H02 0201
       Serial number:       04031501850571
    263425 - Air Quality Sensor
              B10AF 04 [008] - Internal System Fault
                        Reset counter: 91
                        Mileage: 33438 km
                        Date: 2019.12.05
                        Time: 13:47:02
                        Outside air temperature: 8.5 °C
                        Voltage terminal 30: 12.9 V
                        System run time-Engine running time: 253 s
                        System run time-Terminal 15 on: 253 s
                        Air quality status: ERROR
       Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H34 0236
       Serial number: 02001632000333
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7F4EF289E643B1B7DE-802A
       Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
       Component: 326 RL 160922  033 0372
       Serial number: 00000001609200303485
       Component: RLHS  042 0105
       Serial number: S7Y16M11D23H16M12S46
       Coding: 00A8DD
    204546 - Remote key 2
                        Reset counter: 50
                        Mileage: 33427 km
                        Date: 2019.12.05
                        Time: 10:48:04
       Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H09 0021
       Serial number: 000111167478010
       Coding: 0331667851
       ASAM Dataset: EV_EPHBO2CVW3260000 010016
       ROD: EV_EPHBO2CVW3260000.rod
       VCID: 3B36C699B2DB6D97B2-806E
       Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H01 0156
       Coding: 320047C358FF8428749C8065303085
       ASAM Dataset: EV_ACCMRRCONTIVW376 001011
       ROD: EV_ACCMRRCONTIVW376_001.rod
       Serial number: 22101641351086
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 383CD99583ED468F5F-806C
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0317
       Serial number: 003TDR2BSVET
       Coding: 98CCC0C00C0000005C540000008800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 106C4135CBDDBECF37-8044
       Subsystem 1 - Part No SW: -----------    HW: 480 001 811 16
       Serial number: 357000000005DA650F1R
       Subsystem 2 - Part No SW: -----------    HW: 480 001 811 16
       Serial number: 358000000006DA650F1T
       Subsystem 3 - Part No SW: -----------    HW: 480 402 211 16
       Serial number: 35100019F22EA2A4F6BO
       Subsystem 4 - Part No SW: -----------    HW: 480 402 211 16
       Serial number: 3520001A7231F2C5830-
       Subsystem 5 - Part No SW: -----------    HW: 480 402 111 16
       Serial number: 3550001BF22F9766868N
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 401 301 17
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001BF2404066124P
       Subsystem 7 - Part No SW: -----------    HW: 480 401 301 17
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001C124040621508
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 401 301 17
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001BF240406576BY
       Subsystem 9 - Part No SW: -----------    HW: 480 001 010 16
       Serial number: I0M00000000957A84E1C
       Subsystem 10 - Part No SW: -----------    HW: 480 001 310 16
       Serial number: I0N0000000084A30D812
       Part No SW: 3Q0 953 521 DM    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20161124300333
       Coding: 0C10
       ASAM Dataset: EV_SMLSVALEOMQB 001016
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 7EB00F8DE149B8BFD5-802A
       Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
       Component: KOMBI         407 2160
       Coding: 27A510187F88040801886B0B1401000000000000
       Shop #: WSC 38100 381 12345
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
       VCID: 41CAB471D0370747E8-8014
       Component: GW MQB High   418 4286
       Revision: --------    Serial number: 0005618369
       Coding: 030500347F085900FB07225A9E0F00010001050000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 2F2EE2C976A381370E-807A
       Serial number: 29160002326130086453
       Coding: 2DFFFF
       Serial number: 8134692204
    9175296 - Function Restriction due to Driver Fatigue Recognition
              B130E 00 [008] - -
              [Funktionseinschränkung Pausenempfehlung - Ausfall CAN-MSG Prio2]
                        Reset counter: 91
                        Mileage: 33440 km
                        Date: 2019.12.05
                        Time: 13:48:25
                        Supply voltage: Terminal 30: 12.6 V
                        Terminal 15: On
       Serial number: HA1-00028.10.16
       Coding: 0101
       VCID: 4AD8935DED01C41F39-801E
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH07 0014
       VCID: 45C2A061C41F2B67D4-8010
       Serial number: 16000304056008
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71AA24B1A017D7C758-8024
       Component: Sitzmemory    H08 0020
       Serial number: Y0006PJS15750
       Coding: 0014000000000500018281808181000000008181000000F400
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 C    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0310
       Revision: --------
       Coding: 44C002
       ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
       Serial number: 130916EIC11334
       Coding: 003F1B20D201040000000000
    65799 - Door Warning / Entry Lighting
              B1775 01 [009] - Electrical Failure
                        Reset counter: 50
                        Mileage: 33427 km
                        Date: 2019.12.05
                        Time: 10:21:32
       Part No SW: 5QF 909 144     HW: 5QF 909 144 _
       Component: EPS_MQB_ZFLS  506 5572
       Coding: 9307
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 075E6A69BE93F977E6-8052
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
       Component: FCM MQB Low   001 0285
       Serial number: 09111610520624
       Coding: 000000050100085607000F010A0000000000000000000000000000000000
       Serial number: 251016EJM36679
       Coding: 003F1120DE01040000000000
       VCID: 42C8BB7DD5311C5FF1-8016
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 3G0 035 045 D    HW: 3G0 035 045
       Component: MU-H-N-RW     H51 0814
       Serial number: A688K0G2509834
       Coding: 02730601FF00000051510001000808001F0106E601200002DF
       VCID: 1F0E1209060311B7BE-804A
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZJT3646500
       Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
       Component: ROW 2017  --- 0062
       Component: Gracenote2---  --- 4009
              B201A 00 [009] - -
                        Reset counter: 55
                        Mileage: 33473 km
                        Date: 2019.12.06
                        Time: 19:56:50
                        Voltage terminal 30: 13.4 V
                        Status_Software_Version_Management-module_name: MDUV612/Main
       Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
       Component: Areaview 2    H13 0607
       Serial number: C854707JG007196
       Coding: 01230600A20F200000204094
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
       Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0261
       Revision: --------    Serial number: 30963171000000
       Coding: 0A28
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 24111612P22573
       Coding: 000307060000010100022346C050490084000E200000
       Shop #: WSC 08852 002 1048576
       Serial number: 151116EKE28138
       Coding: 002A11200100040000000000
       Serial number: 151116EKE16154
       Component: SAD_STG_1     013 0005
       Coding: 108040732602
       VCID: 3D32C881ACCF63A78C-8068
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 C    HW: 3Q0 907 590
       Revision: --------
       Coding: 44C002
       ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
       VCID: 1660372DE93950FF6D-8042
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
    End----------(Elapsed Time: 02:23, VBatt start/end: 13.3V/13.3V)-----------
    RETROFITS...........
    Nope. I see no parts that have been added that don't come with the car. But the car ain't broken either. So Tweaks is where this belongs.
    Moving it there.
    What do you have in this Adaptation channel?
    IDE03471-ENG138660 -- Vehicle configuration - SDS_Region_Flag
    ^^^^ hmm.......... here's a more readable form of the long-code strings on your first post:
    Name	UK		         AUS
    Byte	Hex	Binary	        Hex	Binary
    0	02	00000010	02	00000010
    1	73	01110011	73	01110011
    2	06	00000110	06	00000110
    3	01	00000001	01	00000001
    4	FF	11111111	FF	11111111
    5	00	00000000	00	00000000
    6	00	00000000	00	00000000
    7	00	00000000	00	00000000
    8	51	01010001	51	01010001
    9	11	00010001	51	01010001
    10	01	00000001	00	00000000
    11	01	00000001	01	00000001
    12	00	00000000	00	00000000
    13	88	10001000	08	00001000
    14	08	00001000	08	00001000
    15	00	00000000	00	00000000
    16	1F	00011111	1F	00011111
    17	01	00000001	01	00000001
    18	09	00001001	06	00000110
    19	C6	11000110	E6	11100110
    20	01	00000001	01	00000001
    21	20	00100000	20	00100000
    22	01	00000001	00	00000000
    23	00	00000000	02	00000010
    24	CF	11001111	DF	11011111
    I'm not quite sure about the Antipodean code-string because according to how SATNAV was set-up in my cars, Byte 3 had the value hex08 like this:
    But in any event - Byte 3 is correctly coded for the country that holds Australia's head-of-state!
    As for why you are experiencing your problem, my understanding is that the SWAP license for SATNAV is region specific alas - the SVM error in the hex5F module in your auto-scan kind-of tends to suggests (to me at least) that the SATNAV FEC in the factory Aussie module is incompatible with the hex01 value in Byte 3 - I think!!
    Oct 2019
    Portsmouth, UK
    Name	UK		         AUS
    Ok so is this a dealer only coding issue I need to take it there to be done?
    If it's a SWAP license, then it's definitely dealer only. But it's not entirely clear to me whether a dealer will be able to change that. It depends whether VW has configured their servers to allow it.
  10. Likes PetrolDave, DV52 liked this post
  11. #8
    ^^^ Alex: I sense a degree of doubt from the B. Dictator (not a good thing) - you could test my understanding by setting Byte3 to hex08 (i.e. Binary 0000 1000), If my understanding correct, the region code in hex5F module should then re-align again with the factory set region in the SATNAV license - and you should be able to clear the hex5F DTC - I think - I hope - perhaps?
  12. Likes Uwe liked this post
  13. #9
    Oct 2019
    Portsmouth, UK
    I sent it to VW where my pal works and he sent a DISS with a technical query, he text me this:
    Yeah man technical got all funny and said it was a issue for the original importer (aus)and that discover pro 2 wasn’t available in the format you have in Europe, cos yours looks like discover media but it’s discover pro , parts technical said basically the same thing and they can get you a maps card but it’ll only be for aus and Southern Asia 🤦🏻*♂️, think basically , either you gotta , contact Vw aus or get someone like Paul in car guy to have a fiddle who’s a bit savvy with vagcom, someone must be able to do it but I think the whole importer issue between euro and aus is what’s making them not wanna touch it
    So now I’m really stuck what to do...
  14. #10
    Oct 2019
    Portsmouth, UK
    I will give this a go! Shall I do that in long coding helper but edit and put in the above 00001000 manually?
