Results 1 to 3 of 3
Thread: Skoda Octavia VRS Petrol BWA Engine Not Starting
    Jun 2017
    The symptoms is the car will start if i spray some petrol into the injector area it will run for about 25mins then stalls and wont restart even if i spray fuel into the injector area, if I leave the engine to cool down and repeat the procedure it will start and run for 25mins again,the vcds scan reads fuel pressure problems which i will include with this email, I have changed the tank fuel pump and the control relay, the fuel pressure sensor[06e906051k} along with the high pressure fuel pump and cam piston follower and spark plugs, any help would be greatly appreciated?
    VIN: TMBEF21Z672091870   License Plate: KR56SXH
    Mileage: 129650km-80560mi   Repair Order: 04.12.19
    Chassis Type: 1Z (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 76
    VIN: TMBEF21Z672091870   Mileage: 129650km-80560miles
       Part No SW: 1Z0 907 115 A    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0040
       Revision: 5BH16---    Serial number: SKZ7Z0F3875002
       Coding: 0203000318070160
       Shop #: WSC 20026 576 88598
       VCID: 336F65AF5206F8D76A-8066
    6 Faults Found:
    000406 - Engine Oil Temp. Sensor (G8)
                   P0196 - 004 - Implausible Signal
                        Mileage: 129651 km
                        Time: 07:28:08
                        RPM: 2374 /min
                        Load: 32.1 %
                        Temperature: 20.0C
                        Temperature: 2.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 14.478 V
    012555 - Low Pressure Fuel regulation
                   P310B - 002 - Fuel Pressure Outside Specification
                        Fault Status: 01100010
                        Mileage: 129651 km
                        Time: 07:31:33
                        RPM: 3742 /min
                        Load: 12.9 %
                        Temperature: 6.0C
                        Temperature: -1.0C
                        Voltage: 14.351 V
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage - Intermittent
                        Mileage: 129651 km
                        Temperature: 2.0C
                        Temperature: 1.0C
                        Voltage: 11.938 V
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
                   P0087 - 002 - Too Low
                        Mileage: 129651 km
                        Time: 01:23:00
                        RPM: 772 /min
                        Load: 38.8 %
                        Temperature: 90.0C
                        Temperature: 24.0C
                        Voltage: 13.970 V
                   P0087 - 008 - Too Low
                        Mileage: 129651 km
                        Time: 01:23:04
                        RPM: 695 /min
                        Load: 36.5 %
                        Temperature: 91.0C
                        Temperature: 23.0C
                        Voltage: 13.843 V
    Readiness: 0110 0001
       Revision: 00H11001
       Coding: 0004738
       Shop #: WSC 73430 790 00000
       VCID: 73EFA5AF1286B8D7AA-8026
       Part No: 1Z0 907 044 H
       Component: ClimatronicPQ35 084 0305
       VCID: 3B7F4D8F7A563097B2-806E
       Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000004592214
       Coding: 018E0F130004140000110D000000000000087F065C0000
       VCID: 6CDDBED34FB8672F6B-8038
       Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 281106 022  0601
       Coding: 00055223
       Shop #: WSC 73430
       Component: Q4 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD0WKH0W
       Coding: 0020788
       VCID: 3D7B439764423EA78C-8068
       Subsystem 1 - Serial number: 6332MSME1474336CB
       Subsystem 2 - Serial number: 6342MSME15411B3DB
       Part No SW: 1K0 953 549 AK    HW: 1K0 953 549 AK
       Component: J0527           036 0070
       Coding: 0001042
       VCID: 7BFF8D8F3AD6F097F2-802E
       Part No SW: 1Z0 920 912 C    HW: 1Z0 920 912 C
       Component: KOMBIINSTRUMENT VD1 1610
       Revision: V1610057    Serial number: SKZ7Z0F3875002
       Coding: 0007401
       Shop #: WSC 57632 001 1048576
       VCID: 356B5BB75C72E6E744-8060
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H04 0020
       Revision:   H04 02    Serial number: 061206F2000196
       Coding: 7D3F074007001303
       VCID: 2F6769DFBE2EDC370E-807A
       Component: IMMO            VD1 1610
       Shop #: WSC 04766 210 92258
       Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
       Component: Tuer-SG         005 0954
       Coding: 0000756
       VCID: 387552834B601B8F5F-806C
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.074 H07 1806
       Component:    KSG PQ35 G2  020 0203
       Coding: 81801A085283007F3F04850540085F96907CA0
       VCID: 030FF56F42268857BA-8056
       Subsystem 5 - Part No: 1Z0 951 171
       Component: Innenraumueberw.008 4801
       Coding: 00000000
       Shop #: WSC 73430
       Subsystem 6 - Part No: 1K0 951 605 C
       Subsystem 7 - Component:       NGS n.mounted
       Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
       Component: Tuer-SG         005 0944
       Coding: 0000756
       VCID: 39735787706A0287A0-806C
       Part No: 1T0 907 357
       Coding: 0000007
       VCID: 74EDA6B31788BFEFB3-8020
    00496 - Sensor for Vehicle Leveling; Front
                010 - Open or Short to Plus
       Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
       Component: Radio FO3       019 0034
       Revision: 00019000    Serial number: SKZ7Z3F0105426
       Coding: 0000402
       VCID: 2E5974DBB924D53F05-807A
       Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
       Component: Tuer-SG         005 0907
       Coding: 0000144
       Shop #: WSC 73430 790 1012544
       VCID: 377751BF467E14F756-8062
       Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
       Coding: 0000144
    Address 76: Park Assist        Labels: 1Z0-919-283.lbl
       Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
       Component: Parkhilfe 4-Kan H04 0020
    End-------------------------(Elapsed Time: 02:15)--------------------------
                    Address 01: Engine       Labels: 06F-907-115-AXX.clb
    Control Module Part Number: 1Z0 907 115 A    HW: 8P0 907 115 B
      Component and/or Version: 2.0l R4/4V TFSI     0040
               Software Coding: 0203000318070160
                Work Shop Code: WSC 20026 576 88598
    6 Faults Found:
                        Mileage: 129651 km
                        Time: 07:28:08
                        RPM: 2374 /min
                        Load: 32.1 %
                        Temperature: 20.0C
                        Temperature: 2.0C
                        Voltage: 14.478 V
                        Mileage: 129651 km
                        Time: 07:31:33
                        RPM: 3742 /min
                        Load: 12.9 %
                        Temperature: 6.0C
                        Temperature: -1.0C
                        Voltage: 14.351 V
                        Mileage: 129651 km
                        Temperature: 2.0C
                        Temperature: 1.0C
                        Voltage: 11.938 V
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 0.000 V
                        Mileage: 129651 km
                        Time: 01:23:00
                        RPM: 772 /min
                        Load: 38.8 %
                        Temperature: 90.0C
                        Temperature: 24.0C
                        Voltage: 13.970 V
                        Mileage: 129651 km
                        Time: 01:23:04
                        RPM: 695 /min
                        Load: 36.5 %
                        Temperature: 91.0C
                        Temperature: 23.0C
                        Voltage: 13.843 V
    Looks to me like you may have some intermittent electrical problem that underlies this.
    Bad ground/Terminal 30 connection or relay?
    JPPSG
    Did you load light the harness yet and sort FP issues?
