Results 1 to 2 of 2
Thread: Amarok V6 2018-2019, disable foglight when cornering
    Sweden
    Question Amarok V6 2018-2019, disable foglight when cornering
    Hi
    Anyone knows how to turn off that annoying foglight turning on when taking a corner?
    Also how to disable or reverse engine-stop would be much appricated.
    Attaching an autoscan
    Thursday,15,November,2018,13:06:28:45218
    VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
    Dealer/Shop Name: EDT
    Workshop Code: 001 00001 000001
    VIN: WV1ZZZ2HZKH00xxxx   License Plate: xxxxx
    Mileage: 950km-590mi   Repair Order:
    Chassis Type: 2H-VN81 (7E0)
    Scan: 01 02 03 04 08 09 10 15 17 18 19 25 32 5F 61 65 69 6E 0B
    VIN: WV1ZZZ2HZKH002xxx   Mileage: 950km-590miles
    6E-Ctrl Head Roof -- Status: OK 0000
    Address 01: Engine (J623-DDXE)       Labels: None
       Part No SW: 2H6 907 311 K    HW: 059 907 309 J
       Component: 3.0l V6 TDI   H23 0002
       Revision: 9AH23---
       Coding: 012A403A233601030001
       Shop #: WSC 02776 790 50316
       ASAM Dataset: EV_ECM30TDI0112H6907311K 001002
       ROD: EV_ECM30TDI0112H6907311K.rod
       VCID: B02C6325EB9371CAE5-80E4
    Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
       Part No SW: 2H0 927 158 M    HW: 0DR 325 025 B
       Component: 0CM  30TDIRdW H22 1001
       Revision: --H22---
       Coding: 000001
       ASAM Dataset: EV_TCMAL450211 002011
       ROD: EV_TCMAL450211.rod
       VCID: B73E58390EFDA6F2A4-80E2
       Part No SW: 2H6 907 379 A    HW: 2H6 907 379
       Component: ESC           H06 0310
       Revision: 00000000    Serial number: 62128000001331
       Coding: 207368B64994B69704A516A892556D85380000
       ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
       ROD: EV_Brake1ESCCONTIVN817GP_008.rod
       VCID: B4246F351F8B4DEA81-80E0
       Component: LENKW.SENSOR  H07 0070
       Serial number: 26081813470610
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: FEB08D1D614757BA27-80AA
    Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
       Part No SW: 2H6 907 040 B    HW: 2H6 907 040 B
       Component: ClimatronicT5 H04 0613
       Revision: 00001K05
       Coding: 0000000003
       ASAM Dataset: EV_ClimatronicT5 A01003
       ROD: EV_ClimaAutoT5Basis.rod
       VCID: A600857DD9572F7A0F-80F2
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 089 C    HW: 7E0 937 089 C
       Component: BCM PQ25 MMI4 H82 0762
       Revision: BB082001    Serial number: 8701 242180487
       Coding: 220002380C610400933807316CCB86D4B281654F60CE7160310000030803
       Shop #: WSC 66305 000 1453318
       VCID: B3266C2912854AD298-80E6
       Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
       Component: RLS 150818 05  50  0106
       Coding: 0228DD
       Subsystem 2 - Part No SW: 6R0 959 801 EE    HW: 6R0 959 801 EE  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  023 2332
       Serial number: 13102845180816195440
       Subsystem 3 - Part No SW: 6R0 959 802 EH    HW: 6R0 959 802 EH  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  023 2332
       Serial number: 13202846180814150807
       Subsystem 4 - Part No: 5C0 951 171
       Component: Sensor, DWA 0  005 0502
       Subsystem 5 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 6 - Part No: 5C0 951 171
       Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H02 0103
       Serial number: 39180001620000018326
       Coding: A4FFFF
       Subsystem 8 - Part No SW: 6R0 959 811 P    HW: 6R0 959 811 P
       Component: J388__TSG_HL  022 1334
       Serial number: 13202709180814234648
       Subsystem 9 - Part No SW: 6R0 959 812 P    HW: 6R0 959 812 P
       Component: J389__TSG_HR  022 1334
       Serial number: 13202708180814034922
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0212
       Revision: --------    Serial number: 28231822200838
       Coding: 31810E
       ASAM Dataset: EV_VW75XParkAssis8K 001012
       ROD: EV_VW75XParkAssis8K_001_VN75.rod
       VCID: F1AAA621201938C2AA-80A4
       Part No SW: 2K5 959 655 D    HW: 2K5 959 655 D
       Component: VW10Airbag018 010 0018
       Revision: --------    Serial number: 003EL0032YNE
       Coding: 000000000000000000000000000000003138
       Shop #: WSC 02774 790 50316
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       VCID: BD324A112CC18CA27E-80E8
       Serial number: 3495RRB40165E1GOIGCV
       Serial number: 3505RRB40165E1GODPV3
       Serial number: 3555YRB404P5KKNKJ88V
       Serial number: 3565YRB40595HHM0KOED
       Part No SW: 2H6 920 873 A    HW: 2H6 920 873 A
       Component: KOMBI         H02 2030
       Coding: 131E000300
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
       VCID: AE107D5DF1A7673AF7-80FA
    Address 18: Aux. Heat (J364)       Labels:| User\7E0-963-272-B.clb
       Part No SW: 7E0 963 272 B    HW: 7E0 963 272 B
       Component: STH-T5GP2     003 0009
       Coding: 5133
       Shop #: WSC 00001 001 00001
       ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
       ROD: EV_AuxilParkiHeateWOST5G2.rod
       VCID: AB167449C2B51212D0-80FE
       Component: R64 D208L  004 0402
       Serial number: 00000000000000530360
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 089 C
       Component: GW-K-CAN TP20 H82 0762
       Revision: BB082001
       Coding: 742203
       VCID: E89CCB451BC3F90AFD-80BC
       Component: IMMO          H02 2030
       Coding: 000002
       VCID: EA98B14D0DCFCB1AEB-80BE
    Address 32: Differential Locks (J647)       Labels:* 2H0-927-771.clb
       Part No SW: 2H0 927 771 B    HW: 2H0 927 771
       Component: Quersperre    H04 0018
       Revision: 11001001    Serial number: 4DG 24.07.18 00
       Coding: 000001
       ASAM Dataset: EV_QuersUDSAAMVN817 002001
       ROD: EV_QuersUDSAAMVN817.rod
       VCID: AD127A51FCA11C22CE-80F8
       Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
       Component: MU-S-ND-ER    H41 0472
       Serial number: VWZAZ2U1000062
       Coding: 06180701BE00000011111101008808001F0100D4002001004F
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: A5028271A451246206-80F0
       Subsystem 1 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
       Part No SW: 7E0 907 534     HW: 7E0 937 089 C
       Component: Batt.regelung H82 0762
       Coding: 330B18AF
       Shop #: WSC 02776 790 00000
       Subsystem 1 - Part No SW: 2H6 915 181     HW: 2H6 915 181
       Serial number: 7497540800180821042F
    Address 65: Tire Pressure (J502)       Labels: None
       Part No SW: 2H6 907 273     HW: 5Q0 907 273
       Component: RDKBERU30     H04 0003
       Serial number: 40000000029104
       ASAM Dataset: EV_RDKBERU30 006003
       ROD: EV_RDKBERU30_006_VW48.rod
       VCID: EC94B755073BD52A99-80B8
       Component: Anhaenger     H12 0100
       Revision: 3A001001    Serial number: 00000487527452
       Coding: 010D000100000000
       VCID: B02C6325E39371CAE5-80E4
    Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
       Part No SW: 7E5 919 037 J    HW: 7E5 919 037 J
       Component: Dachdisplay   H17 0200
       Revision: 1010013S    Serial number: 564559
       Coding: 000103
       VCID: B83C5B050BE3A98AAD-80EC
    End----------(Elapsed Time: 02:20, VBatt start/end: 13.3V/13.3V)-----------
    Address 17,2H6 920 873 A,channel IDE02494-Automatic door locking,adapted from,Yes ,to,No ,
    Address 17,2H6 920 873 A,channel IDE00344-Seat belt warning,adapted from,Version 4 ,to,Version 1 ,
    - VCDS owner since 2003 -
    -- [ VW Amarok V6 2019, VW Transporter 2007, VW Tiguan 2012, Audi S4 1992, Audi A6 1998 ] --
    Try Coding [09-Cent. Elect.], remove check mark, Byte 12 Bit 6
  3. Likes Uwe liked this post
