Hi
Anyone knows how to turn off that annoying foglight turning on when taking a corner?
Also how to disable or reverse engine-stop would be much appricated.
Attaching an autoscan
Thursday,15,November,2018,13:06:28:45218
VCDS Version: 18.9.0.2 (x64) HEX-NET CB: 0.4436.4
Dealer/Shop Name: EDT
Workshop Code: 001 00001 000001
VIN: WV1ZZZ2HZKH00xxxx License Plate: xxxxx
Mileage: 950km-590mi Repair Order:
Chassis Type: 2H-VN81 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 25 32 5F 61 65 69 6E 0B
VIN: WV1ZZZ2HZKH002xxx Mileage: 950km-590miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-DDXE) Labels: None
Part No SW: 2H6 907 311 K HW: 059 907 309 J
Component: 3.0l V6 TDI H23 0002
Revision: 9AH23---
Coding: 012A403A233601030001
Shop #: WSC 02776 790 50316
ASAM Dataset: EV_ECM30TDI0112H6907311K 001002
ROD: EV_ECM30TDI0112H6907311K.rod
VCID: B02C6325EB9371CAE5-80E4
Address 02: Auto Trans (J217) Labels:| 0CM-325-025.clb
Part No SW: 2H0 927 158 M HW: 0DR 325 025 B
Component: 0CM 30TDIRdW H22 1001
Revision: --H22---
ASAM Dataset: EV_TCMAL450211 002011
ROD: EV_TCMAL450211.rod
VCID: B73E58390EFDA6F2A4-80E2
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 2H6 907 379 A HW: 2H6 907 379
Component: ESC H06 0310
Revision: 00000000 Serial number: 62128000001331
Coding: 207368B64994B69704A516A892556D85380000
ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
ROD: EV_Brake1ESCCONTIVN817GP_008.rod
VCID: B4246F351F8B4DEA81-80E0
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 26081813470610
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: FEB08D1D614757BA27-80AA
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 2H6 907 040 B HW: 2H6 907 040 B
Component: ClimatronicT5 H04 0613
Revision: 00001K05
Coding: 0000000003
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: A600857DD9572F7A0F-80F2
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 089 C HW: 7E0 937 089 C
Component: BCM PQ25 MMI4 H82 0762
Revision: BB082001 Serial number: 8701 242180487
Coding: 220002380C610400933807316CCB86D4B281654F60CE7160310000030803
Shop #: WSC 66305 000 1453318
VCID: B3266C2912854AD298-80E6
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 150818 05 50 0106
Coding: 0228DD
Subsystem 2 - Part No SW: 6R0 959 801 EE HW: 6R0 959 801 EE Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 023 2332
Serial number: 13102845180816195440
Subsystem 3 - Part No SW: 6R0 959 802 EH HW: 6R0 959 802 EH Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 023 2332
Serial number: 13202846180814150807
Subsystem 4 - Part No: 5C0 951 171
Component: Sensor, DWA 0 005 0502
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 6 - Part No: 5C0 951 171
Subsystem 7 - Part No SW: 2H0 959 442 HW: 2H0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 39180001620000018326
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 P HW: 6R0 959 811 P
Component: J388__TSG_HL 022 1334
Serial number: 13202709180814234648
Subsystem 9 - Part No SW: 6R0 959 812 P HW: 6R0 959 812 P
Component: J389__TSG_HR 022 1334
Serial number: 13202708180814034922
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231822200838
Coding: 31810E
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: F1AAA621201938C2AA-80A4
Part No SW: 2K5 959 655 D HW: 2K5 959 655 D
Component: VW10Airbag018 010 0018
Revision: -------- Serial number: 003EL0032YNE
Coding: 000000000000000000000000000000003138
Shop #: WSC 02774 790 50316
VCID: BD324A112CC18CA27E-80E8
Serial number: 3495RRB40165E1GOIGCV
Serial number: 3505RRB40165E1GODPV3
Serial number: 3555YRB404P5KKNKJ88V
Serial number: 3565YRB40595HHM0KOED
Part No SW: 2H6 920 873 A HW: 2H6 920 873 A
Component: KOMBI H02 2030
Coding: 131E000300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
VCID: AE107D5DF1A7673AF7-80FA
Address 18: Aux. Heat (J364) Labels:| User\7E0-963-272-B.clb
Part No SW: 7E0 963 272 B HW: 7E0 963 272 B
Component: STH-T5GP2 003 0009
Coding: 5133
Shop #: WSC 00001 001 00001
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: AB167449C2B51212D0-80FE
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0402
Serial number: 00000000000000530360
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 089 C
Component: GW-K-CAN TP20 H82 0762
Revision: BB082001
Coding: 742203
VCID: E89CCB451BC3F90AFD-80BC
Component: IMMO H02 2030
Coding: 000002
VCID: EA98B14D0DCFCB1AEB-80BE
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 B HW: 2H0 927 771
Component: Quersperre H04 0018
Revision: 11001001 Serial number: 4DG 24.07.18 00
ASAM Dataset: EV_QuersUDSAAMVN817 002001
ROD: EV_QuersUDSAAMVN817.rod
VCID: AD127A51FCA11C22CE-80F8
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0472
Serial number: VWZAZ2U1000062
Coding: 06180701BE00000011111101008808001F0100D4002001004F
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: A5028271A451246206-80F0
Subsystem 1 - Part No SW: 5NA 919 866 HW: -----------
Component: ECE1 2018/19 --- 1030
Part No SW: 7E0 907 534 HW: 7E0 937 089 C
Component: Batt.regelung H82 0762
Coding: 330B18AF
Shop #: WSC 02776 790 00000
Subsystem 1 - Part No SW: 2H6 915 181 HW: 2H6 915 181
Serial number: 7497540800180821042F
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 2H6 907 273 HW: 5Q0 907 273
Component: RDKBERU30 H04 0003
Serial number: 40000000029104
ASAM Dataset: EV_RDKBERU30 006003
ROD: EV_RDKBERU30_006_VW48.rod
VCID: EC94B755073BD52A99-80B8
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H12 0100
Revision: 3A001001 Serial number: 00000487527452
Coding: 010D000100000000
VCID: B02C6325E39371CAE5-80E4
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W2.clb
Part No SW: 7E5 919 037 J HW: 7E5 919 037 J
Component: Dachdisplay H17 0200
Revision: 1010013S Serial number: 564559
Coding: 000103
VCID: B83C5B050BE3A98AAD-80EC
End----------(Elapsed Time: 02:20, VBatt start/end: 13.3V/13.3V)-----------
Address 17,2H6 920 873 A,channel IDE02494-Automatic door locking,adapted from,Yes ,to,No ,
Address 17,2H6 920 873 A,channel IDE00344-Seat belt warning,adapted from,Version 4 ,to,Version 1 ,
