Sorry, I realized, that this is probably wrong forum. It should have been on repair section I guess
I have weird behavior in my car
I have Octavia 3 1,4 tsi (10/2013) elegance with canton sound system.
I noticed that in latest scans module 47 - amplifier was gone.
After enabling it I get errors
Module 19 - Malfunction
and module 47 - can not be reached
Result is like this when doing autoscan.
When accessing modules itself, then 47 connects fine and shows no error codes.
Module 19 still shows error code and this can not be cleared.
So clearly there is something wrong
Module 47 disappeared between scans at 22.04.2019 at mileage 165584km and 15.06.2019 at 169302km
Is it possible that car will un-tic a module from installed list by itself when communication is lost for long time or does it have to be done manually?
I did have cam belt change done between those mileages and dates.
I did enable the module 47 but get the errors described before.
To my eyes it seems that coding has not been changed and is the same as before when everything worked and no errors were present.
I will add a scan from today with the errors and one from where everything still worked.
Any advise, what to do next to get the errors sorted?
From today:
From when everything was known to work:
From today:
Friday,06,December,2019,10:54:20:03770
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: TMBJC7NE6E0080906 License Plate: 024BVT
Mileage: 179300km-111411mi Repair Order: amp_error
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 47 52 55 5F 69
VIN: TMBJC7NE6E0080906 Mileage: 179300km-111411miles
47-Sound System -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHPA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 F HW: 04E 907 309 A
Component: 1,4l R4 TSI H08 5760
Revision: WAH08---
Coding: 01190032243401080000
Shop #: WSC 19301 003 1048576
ASAM Dataset: EV_ECM14TFS01104E906016F 002008
ROD: EV_ECM14TFS01104E906016F.rod
VCID: 25170D08D561ED8F9A1-8070
Readiness: 1110 0001
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 626430000001D3
Coding: 1C076A912428296C0080060041C9243856249400608224F000230070C002
ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
VCID: 4BC39BB01345FBFF6C5-801E
Part No SW: 5E0 907 044 F HW: 5E0 907 044 F
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 02010004000100011005004010100000
Shop #: WSC 73430 031 12345
VCID: 2809043CA273F0E7A17-807C
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011326304373
Coding: 0C020A46424722FB07A04082B11C07280008000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 77AB17403F4DAF1FF8D-8022
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 130924 041 0570
Serial number: 130925145619
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M09D29H05M29S35S1
Coding: 02805D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY13193258C
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000027890209
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831327502998
Coding: 0001050101
ASAM Dataset: EV_EPHVA14AU3700000 002018
VCID: 3829D47C72D36067317-806C
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 011 0188
Revision: -------- Serial number: 003P4PKPXLJ3
Shop #: WSC 73430 790 00000
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5BFF60177D975FB0D-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 409 13
Serial number: 3576U000000602B8DD0I
Subsystem 2 - Part No SW: ----------- HW: 454 002 109 13
Serial number: 3586U000000C2751DD0J
Subsystem 3 - Part No SW: ----------- HW: 454 802 309 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R1D0C0D02000000/
Subsystem 4 - Part No SW: ----------- HW: 454 801 609 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R7D720202000000X
Subsystem 5 - Part No SW: ----------- HW: 454 800 508 13
Component: FrontSensor_D 114 0149
Serial number: 3556V4F01B101000000/
Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 01101304401830
Coding: 1400
Shop #: WSC 73430 031 00063
Part No SW: 5E0 920 861 A HW: 5E0 920 861 A
Component: KOMBI 204 3390
Coding: 07A50A002980000801087A00040000
ASAM Dataset: EV_DashBoardJCIMQBAB 008011
ROD: EV_DashBoardJCIMQBAB_008.rod
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0001082463
Coding: 030100042B086400EF00064A080F00010001000000000000000000000000
Shop #: WSC 61364 002 1048576
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009.rod
VCID: 3B23CB7043E54B7FDC5-806E
Subsystem 2 - Part No SW: 5E0 919 719 A HW: 5E0 919 719 A
Component: E221__MFL-PR6 H04 0120
Serial number: 000000000B0215230913
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 7403991403
131695 - Digital sound System control module
U106A 00 [009] - No Communication
[Timeout Knoten 0x6F / 47 - Steuergerät für digitales Soundpaket]
Reset counter: 75
Mileage: 179300 km
Date: 2019.12.06
Time: 10:50:00
Terminal 15: On
Part No SW: 5Q4 959 393 HW: 5Q4 959 393
Component: TSG FS 007 0006
Serial number: 0000077331559
Coding: 001400208000020000001100
VCID: 55F77DC8C581BD0FCA1-8000
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000810547
Coding: 010200
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D27C5685DF1454FE21-8068
Address 47: Sound System (J525) Labels:* None
Part No SW: 8V0 035 223 HW: 8V0 035 223
Component: MIBAMP1ALPINE H11 0300
Serial number: SKZ8Z1D76007PR/
Coding: 03730200AA002AAA00
ASAM Dataset: EV_AMPMst16C2ALPI 004016
ROD: EV_AMPMst16C2ALPI_SK37.rod
VCID: 6D8735284D1115CF121-8038
Part No SW: 5Q4 959 392 HW: 5Q4 959 392
Component: TSG BFS 007 0006
Serial number: 0000076999839
Coding: 001400208C00020000001100
Shop #: WSC 73430 790 12345
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000813024
Coding: 190200
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 03CA02003F000000
Shop #: WSC 73430 790 00063
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels:| 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 874 A HW: 5E0 035 874 A
Component: MU-S-ND-ER 040 0490
Serial number: S7F00210131624
Coding: 03730201000000001111120200A800002F0000A40100010046
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 26150A04A867E69793B-8072
Subsystem 1 - Part No SW: 5E0 919 605 D HW: 5E0 919 605 D
Component: ABT_Std_Nav H50 0022
Serial number: SKZ8Z9NK800EEC
Subsystem 2 - Part No SW: 5E0 051 236 G HW: -----------
Component: ECE 2019 --- 0078
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 L HW: 5Q0 907 383 L
Component: Anhaenger H27 0260
Revision: 8C001004 Serial number: 0497673464
Coding: 0101000202000000
VCID: 40D9BC9C2A0328A7897-8014
End----(Elapsed Time: 01:18, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)
Monday,22,April,2019,14:50:44:03770
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
Mileage: 165584km-102889mi Repair Order: enne tulede regulli
VIN: TMBJC7NE6E0080906 Mileage: 165584km-102889miles
Revision: WAH08---
VCID: 25170D08D561ED8FCDB-8070
VCID: 4BC39BB01345FBFF3BF-801E
Revision: 00001K06
ROD: EV_ACClimaBHBVW37X_003_SK37.rod
VCID: 2809043CA273F0E7F6D-807C
329988 - Motor for Defroster Flap
B1090 71 [008] - Actuator stuck
Reset counter: 18
Mileage: 165052 km
Date: 2019.04.19
Time: 18:04:42
Voltage terminal 30: 13.4 V
Outside air temperature: 17.5 °C
Interior temperature: 27.9 °C
Defroster flap: actual value: 0.0 %
Defroster flap: actual value: 5
Defroster flap: specified value: 180
329991 - Position Sensor for Defrost Flap Motor
B1098 15 [008] - Open or Short to Plus
Fault Frequency: 13
Reset counter: 18
Mileage: 163678 km
Date: 2019.03.19
Time: 17:06:15
Voltage terminal 30: 13.9 V
Outside air temperature: 3.0 °C
Interior temperature: 20.1 °C
Defroster flap: actual value: 240
Defroster flap: specified value: 240
VCID: 77AB17403F4DAF1FAF7-8022
Coding: 065DDD
Coding: 02805D
Coding: 0001050101
VCID: 3829D47C72D3606766D-806C
VCID: 7F5BFF60177D975FE77-802A
Coding: 1400
ROD: EV_SMLSKLOMQB_012_AU37.rod
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_Audio_0x31 keine Kommunikation]
Reset counter: 7
Mileage: 164477 km
Date: 2019.04.10
Time: 20:38:59
VCID: 3B23CB7043E54B7F8BF-806E
VCID: 55F77DC8C581BD0F9DB-8000
Coding: 010200
Coding: 81
VCID: 3D27C5685DF1454FB5B-8068
VCID: 6D8735284D1115CF45B-8038
Coding: 190200
Coding: 3E0000
Coding: 3E0000
VCID: 26150A04A867E697C41-8072
VCID: 40D9BC9C2A0328A7DED-8014
End----------(Elapsed Time: 01:25, VBatt start/end: 12.2V/12.2V)
