Results 1 to 4 of 4
Thread: 2013 T5 Transporter 180 bi-turbo tdi. Senor reference fault?
    Aug 2014
    uk
    Hi Guys
    I have This Vw transporter 2013 bi-turbo 180 tdi with a Sensor reference fault, it also displays in the instrument cluster change air filter which ive never seen before.
    Can anyone help as I'm not sure what sensor/sensors to check or replace??
    Thanks in advance,
    Friday,06,December,2019,08:55:57:52053
    Dealer/Shop Name: Wagenworx LTD
    VIN: WV1ZZZ7HZDH105713   License Plate:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 03 04 08 09 10 15 17 19 25 56 69 0B
    VIN: WV1ZZZ7HZDH105713   Mileage: 121690km-75614miles
    56-Radio -- Status: Malfunction 1110
    Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
       Part No SW: 03L 906 019 GN    HW: 03L 907 309 L
       Component: R4 2,0L EDC   H38 6326
       Revision: 22H38---    Serial number: 00000000000000
       Coding: 01194012233400080000
       Shop #: WSC 00168 210 93958
       ASAM Dataset: EV_ECM20BTD01103L906019GN 003005
       ROD: EV_ECM20BTD01103L906019GK_003.rod
       VCID: FDB2A4F36C3ABBA74C-80A8
    4123 - Sensor Reference Voltage A
              P0641 00 [175] - Open Circuit
                        Mileage: 121137 km
                        Date: 2019.11.09
                        Time: 11:10:54
                        Engine speed: 1994.00 /min
                        Vehicle speed: 104 km/h
                        Coolant temperature: 91 C
                        Intake air temperature: 19 C
                        Voltage terminal 30: 14.180 V
                        Exh.gas temp.sen 1: 280.1 C
                        Exh.gas temp.sen 2: -0.0 C
                        Exh.gas temp.sen 3: 325.6 C
                        Exh.gas temp.sen 4: 308.1 C
                        Shut-off timer: last engine shut-off time: 206 s
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0110
       Revision: 00H43001
       Coding: 108764AD09A4089A26A99072AA6110
       Shop #: WSC 02756 790 49152
       VCID: BA386FEF35944C9F29-80EE
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 104
                        Mileage: 120735 km
                        Date: 2014.03.16
                        Time: 08:27:55
                        Count: 23808
                        Count: 1
                        Count: 8241
                        Count: 764
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E5 907 047 BF    HW: 7E5 907 047 BF
       Component: Climatic-T5   H20 0506
       Revision: 00001010
       Coding: 0000000002
       Shop #: WSC 02756 790 50316
       ROD: EV_ClimaT5Basis.rod
       VCID: F4A481D75F70FAEF33-80A0
       Part No SW: 7H0 937 087 K    HW: 7H0 937 087
       Component: BCM T5GP H+4  H32 0407
       Revision: BO032001    Serial number: 0533 054130723
       Coding: A0B0793A0A612413922048106C2B8CD40080410F60844000320000000000
       Shop #: WSC 93958 288 02691
       VCID: BC3469F73FA072AF3B-80E8
       Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  002 3313
       Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  002 3313
       Subsystem 3 - Part No: 7E1 951 172
       Subsystem 5 - Part No: 7E1 951 172
    03789 - Terminal 75 Limp Mode Active
                        Reset counter: 132
                        Mileage: 120872 km
                        Date: 2014.03.16
                        Time: 16:49:47
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 L    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0106
       Revision: --------    Serial number: 28261301500002
       Coding: 118001
       ASAM Dataset: EV_VW75XParkAssis8K 001003
       ROD: EV_VW75XParkAssis8K_001_VN75.rod
       VCID: BB366AEB32AE759732-80EE
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H07 0013
       Revision: --------    Serial number: 003HL00GBJEF
       Shop #: WSC 02754 790 50316
       VCID: B5227CD3148AA3E7C4-80E0
       Part No SW: 7E0 920 970 G    HW: 7E0 920 970 G
       Component: KOMBI         H06 0605
       Coding: 160A01
       VCID: AE1053BFF1DC903F85-80FA
       Part No SW: 6N0 909 901     HW: 7H0 937 087
       Component: GW-K-CAN TP20 H32 0407
       Revision: BO032001
       Coding: 042300
       VCID: F0AC8DC72368C6CFD7-80A4
    01304 - Radio
                        Reset counter: 137
                        Mileage: 112806 km
                        Date: 2013.05.02
                        Time: 13:00:37
       Component: IMMO          H06 0605
       VCID: EA989FAF0DB43C1F99-80BE
    Address 56: Radio
       Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
       Component: Anhaenger     H10 0110
       Revision: 3B001001    Serial number: 00000192852466
       Coding: 410D000101000000
       Shop #: WSC 02756 790 00000
       VCID: B12A48C3E8E28FC798-80E4
    End----------(Elapsed Time: 01:55, VBatt start/end: 14.3V/14.2V)-----------
    If I understand this correctly, the ECU outputs a 5V reference signal used by some of the sensors and the "open circuit" indicates that no current is being drawn from it. Got wiring diagrams for this vehicle?
    Aug 2014
    uk
    Yes I have wiring diagrams via Elsa win.
    I forgot to say engine light on, glow plug light flashing and limp mode active. What I have noticed in the auto scan exhaust gas temp sensor 2 reads -0.0?
    Did you check for the 5 volt ref at component directly?
    Did you know all shared sensors on the BUS must be tested?
    Did you check feed grounds and power sources that must also be verified by bifurcation first?
    Did you try unplugging engine bay side to ECU harness & then scan car and clear fault to see if the sensor ref range voltage DTC vacates & if does did you know the issue is on that side most likely or respective sensors and if DTC stays it's on other feed side of ECU?
