Results 1 to 7 of 7
Thread: 2016 A6 2.0TDI REDUCTANT SENSOR FAULT
    Dec 2019
    Ireland
    Lightbulb 2016 A6 2.0TDI REDUCTANT SENSOR FAULT
    hello folks ,was just looking to see if anybody has came across these faults shown in scan
    or has anybody replaced there reductant sensor as i am starting to suspect it is faulty .any help would be great .cheers...
    Thursday,05,December,2019,19:45:56:65251
    VIN: WAUZZZ4G9GN124318   License Plate:
    Chassis Type: 4G-AU57 (4G5)
    Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F
              62 6D 72 AC
    VIN: WAUZZZ4G9GN124318   Mileage: 98563km-61244miles
    Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 FQ    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 1649
       Revision: 85H23---
       Coding: 12254012242401080000
       ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
       ROD: EV_ECM20TDI01104L906021FQ_002.rod
       VCID: F9BAA48B7827318760-80AC
    9646 - Reductant
              P20E9 00 [032] - Pressure too High
                        Mileage: 98530 km
                        Date: 2019.12.04
                        Time: 20:03:17
                        Engine speed: 829.00 /min
                        Normed load value: 34.9 %
                        Coolant temperature: 83 °C
                        Intake air temperature: 51 °C
                        Voltage terminal 30: 13.040 V
                        Unlearning counter according OBD: 38
                        Extern.temp.sens.1 bank 1: raw value: 8.0 °C
                        Pressure sensor for reducing agent: measured pressure: 889 hPa
                        Sensor for reducing agent tank temperature: temperature: 9.1 °C
                        Reducing agent pump: activation: 30.00 %
                        Sensor for reducing agent fill level: voltage: 3100.0 mV
    9658 - Reductant Pressure Sensor Circuit
              P204B 00 [047] - Implausible Signal
                        Mileage: 98526 km
                        Date: 2019.12.04
                        Time: 19:43:37
                        Engine speed: 829.50 /min
                        Normed load value: 27.5 %
                        Coolant temperature: 79 °C
                        Intake air temperature: 43 °C
                        Voltage terminal 30: 14.620 V
                        Extern.temp.sens.1 bank 1: raw value: 7.0 °C
                        Pressure sensor for reducing agent: measured pressure: 925 hPa
                        Reducing agent pump: activation: 0.00 %
                        Sensor for reducing agent fill level: voltage: 3105.0 mV
    Readiness: 0 1 0 0 0
       Part No SW: 4G1 927 153 B    HW: 0CK 927 156 S
       Component: 0CK 20TDI RdW H04 0002
       Revision: --H04---    Serial number: 0000000851
       Coding: 100001
       ASAM Dataset: EV_TCMDL382021 002020
       ROD: EV_TCMDL382021_AU57.rod
       VCID: A91AB4CBC807410750-80FC
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
       Component: V553 MTFP  HB1 0572
       Serial number: 75117051150325000536
       Coding: 06A29E41604579829B00
       ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
       VCID: C1CA0C6B5077A94768-8094
       Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
       Component: BCM2 2.0      H37 0572
       Coding: 01B9704E000000000000
       VCID: FBB6BE837A1B039772-80AE
       Serial number: 3215000180378001
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 26111500040061
       Coding: 34220978210000
       VCID: E386E6E3EAABDB575A-80B6
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Revision: 15020001    Serial number: 00001231228901
       Coding: 0105001440349FE041014083000018000F9DC7082F08020100000894E100140200400024030000
       VCID: F1AA9CAB285779C7D8-80A4
       Component: WWS57X 150919  H38 0080
       Serial number:         151002033303
       Coding: 0045F7
       Serial number: 61001742
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 28 11 2015  00000337
       Serial number: 2EA98CD7000000000001
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P1007LJVL
       Coding: 30333130313630323639554A305234473053
       VCID: BB367E83329BC39732-80EE
       Serial number: 3575HRB40673LPS861P.
       Serial number: 3585HRB40693LPS848M%
       Serial number: 3515JRB40085558A81KG
       Serial number: 3525JRB40085558AMHI2
       Serial number: 3554VRB401G554Q2COS+
       Serial number: 3564VRB400E555N0M9RT
       Revision: C0068538    Serial number: 90862OL2001D7
       Coding: 000035
       VCID: BB367E833A9BC39732-80EE
       Serial number: 22 10 2015  G0063319
       Part No SW: 4G8 920 951 E    HW: 4G8 920 951 E
       Component: MDieGb        H43 0604
       Revision: 29450306    Serial number: 658301115592013
       Coding: 33A612000B412600010000
       ASAM Dataset: EV_RBC7KMID 004050
       ROD: EV_RBC7KMID.rod
       VCID: B22853A7E5D102DFE1-80E6
       Part No SW: 4G5 907 468 F    HW: 4G0 907 468 AC
       Component: J533--Gateway H14 0083
       Revision: --------    Serial number: 00000002071108
       Coding: C0CD074418
       ASAM Dataset: EV_GatewPkoUDS 001028
       VCID: B83C618F03ADE88FDF-80EC
       Serial number: 8471058603
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
       Serial number: 150903000000000003B0
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       Coding: 04028264747464545425363E00
       VCID: E79EF2F31693B77786-80B2
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0112
       Serial number: 26111500041560
       Coding: 22
       VCID: BD32709B2C8FCDA70C-80E8
       Component: SARA 3D       H04 0056
       Revision: --------    Serial number: EJ1BPA720LVUDC
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: B32656A31ACB0BD7EA-80E6
       Coding: 011C16014001620002080002
       VCID: C7DE127376539777A6-8092
       Component: RCevo         H53 0202
       Revision: 00000002    Serial number: 0000419456
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: BA387B873DA1FA9F29-80EE
       Revision: 00002001    Serial number: 0388031400
       Coding: 013B0622A0B93000C320090400010F470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177 A
       Component: Sensor, DWA  005 0002
       VCID: C6C01F7771598E7F5D-8092
       Revision: --------    Serial number: 00000001674214
       ROD: EV_ParkiBrake_VW51.rod
       VCID: AD1240DBFCEF5D27BC-80F8
       Coding: 04FE02102A600200
       VCID: B42455BF1FC50CEFF3-80E0
       Coding: E01E00
       Coding: E01E00
    Address 5F: Information Electr. (J794)       Labels: Redir Fail!
       Part No SW: 4G1 035 192 A    HW: 4G1 035 192 A
       Component: RMC Nav Plus  H61 0139
       Coding: 0101010101415B47082B060301010000000000
       VCID: A10AACEBB837894708-80F4
       Subsystem 1 - Part No: 8X0 919 884 J
       Component: P32-50-15.03  0001
       Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
       Component: DU6 Basic  H43 0084
       Serial number: 9464K10F2741285
       Subsystem 3 - Part No SW: 4G2 919 610 E    HW: 4G2 919 610 E
       Serial number: 90349OKJ0009H
       VCID: C9DA144B60476107B0-809C
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0151
       Revision: 14005001    Serial number: 323501349
       Coding: 093205C010
       ROD: EV_HDSGAu571.rod
       VCID: B6206FB709B91EFFCD-80E2
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 153090520
       ROD: EV_RDCMA00100_008.rod
       VCID: AF2E5AD3F6E32F378E-80FA
    End----------(Elapsed Time: 01:58, VBatt start/end: 14.6V/14.6V)-----------
    I think we've seen pressure too low, but I don't recall one with pressure too high.
    Dec 2019
    Ireland
    Yea man on previous scan it had pressure to low also. Was the outcome a faulty sensor can u recall?
    Indeed it can happen when frozen or the sensor is plugged up with solids.
    Dec 2019
    Ireland
    yea very true it only seemed to start throwing this fault when the weather was dropping below zero.cheers ill let ya know th result when i get to the bottom of it
    Did you know that you can install a heated line in the adblue and or heater in car to plugin and maintain circulation of air in car works well to stop this problem before commenced cold startup?
    Example
    https://ph.parker.com/us/17573/en/sc...r-def-transfer
    http://blog.vossusa.com/electrically...or-cleaner-air
  7. #7
    Dec 2019
    Ireland
    i did not but thanks very much for the info and links ,much appreciated man .
