Results 1 to 10 of 14
Thread: B7 Instrument Cluster - Backlit Scales not working with Headlights OFF
    Sep 2016
    Battery went dead on my B7 RS4 since I haven't driven it in a couple months. After getting the battery charged up and the car going again my cluster dash lights (scales) are not showing up unless it's sunny outside. The first day it was overcast and I only had the needles lit up, which was different for me.
    I have never had this issue in the past. My dash lights are always on and I never run with the headlight switch in the "Auto" position, it is always in the "OFF" position. When I open the door all the lights come on in the cluster (Scales & Needles) but after I shut the door they fade back to just the needles lit up, which I think is just the overheard lights affecting the sensor. If I shine a light into the light sensor on the cluster then the scales light up.
    Of course when I turn on the headlights or parking lights the scales do light up but like I said I never had this issue in the past. I could be sitting in a parking lot at night with the engine running, no lights on and all my dash lights were on (Scales & Needles). It is awkward to start the car at night and only have the needles lit up.
    I double checked with Vag-Com and my code was already set to 31300
    17-Instruments:
    Mode 0: Nothing lit until ext. light on
    Mode 1: Pointers lit all the time
    Mode 2: Scales lit all the time
    Mode 3: Pointers and Scales lit all the time
    Changing the first number had the desired effect for 0,1,2 but when I switched back to 31300 I still only see the needles light up. It seems as though adding the "3" in the front doesn't have any effect at all. Even though my car was already set to "3" it now all of the sudden after the battery going dead, do I have this issue.
    Can't figure out WTF is going on here since I have never had an issue with the cluster before now??? Do I have any issue with the cluster or maybe the headlight switch is messed up. Everything else seems to function normally, parking lights, headlights, front fog and rear fog.
    Thanks,
    Bimmerod
    Near Philadelphia, PA, USA
    Hi Bimmerod. Thanks for your post but for us to provide ideas and help, we need a autoscan from the car. Can you post one up please?
    How to post an Auto-Scan
  3. Likes Uwe, Jack@European_Parts liked this post
    Sep 2016
    Auto-Scan
    Quote Originally Posted by Bruce View Post
    Here you go.....
              67 69 75 76 77
    VIN: WUARU98E37N9xxxxx   Mileage: 57630km-35809miles
    Address 01: Engine        Labels:. 079-910-560-BNS1.lbl
       Part No SW: 8E1 910 560 A    HW: 8E1 907 560
       Component: 4.2L V8/4V FSI     0040
       Revision: 57H13---    Serial number: XXXXXXXXXXXXXX
       Coding: 01040009180F0160
       Shop #: WSC 22164 444 83638
       VCID: 244759DBE723166FE3-8070
                        Load: 0.0 %
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    006435 - Please Check DTC Memory of ECU Number 2
                   P1923 - 008 -
                        Fault Status: 01101000
                        Mileage: 57634 km
                        Load: 0.0 %
                        Temperature: 22.0C
                        Temperature: 21.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 11.938 V
       Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
       Component: ESP8 quattro    H06 0150
       Coding: 0004533
       Shop #: WSC 06335 000 00000
       VCID: 2B55B2E78AFDD91722-807E
                        Fault Frequency: 6
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x4222
                        Hex Value: 0x0024
                        Hex Value: 0x018A
                        Hex Value: 0x0001
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2833
       Coding: 00000
       VCID: 6DD17CFF276917277C-5104
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  ECE 0907
       Coding: 01031
       VCID: 3D718CBF378947A78C-4AD0
       Part No SW: 8E0 035 593 F    HW:
       Component: SDAR SIRIUS
       Revision:             Serial number: AUZ4Z7M0622032
       VCID: 2C57B1FB8CF3DE2F2B-515C
    Address 11: Engine II        Labels:. 079-910-560-BNS2.lbl
                        Load: 0.0 %
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 0.000 V
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H12 3840
       Revision: 91H12384    Serial number: 0036N0G0D3L%
       Coding: 0432707
       VCID: 3C7781BB7F934EAFBB-8068
       Subsystem 1 - Part No: 8E0 910 339 B
       Component: BF-Gewichtsens. 002 0070
       Subsystem 2 - Serial number: 3ASR4
       Subsystem 3 - Serial number: 0001.01.00000020000000000063
       Subsystem 4 - Serial number: 0000006332DRB403DC109BW63
       Subsystem 5 - Serial number: C109BW6342DRB403CA512FW63
       Subsystem 6 - Serial number: A512FW6352ARB401B071FFW63
       Subsystem 7 - Serial number: 071FFW6362ARB401B0770BK63
       Subsystem 8 - Serial number: 0770BK63729RB401AECF6FD63
       Subsystem 9 - Serial number: ECF6FD63829RB401AECF496
       Subsystem 10 - Serial number: ECF496
    Address 16: Steering wheel        Labels: 8E0-953-549-T.lbl
       Part No: 8E0 953 549 T
       Component: Lenksulenmodul     0301
       Coding: 04441
       Shop #: WSC 06335
       VCID: 4487F95B5463366FC3-4AE8
       Part No SW: 8E0 920 981 S    HW: 8E0 920 981 S
       Component: KOMBI+WFS 4     H14 0050
       Revision: 0050        Serial number: 00000000000000
       Coding: 0023001
       VCID: 3D718CBF678947A78C-5122
       Coding: 0023001
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       VCID: 71E9608F3B51F3C758-4AE8
       Part No SW: 8E0 035 192 J    HW: 8E0 035 192 J
       Component: RNS-E US3       H72 0200
       Revision:      03S    Serial number: AUZBZ7F2486906
       Coding: 0309637
       VCID: 2B55B2E789FDD91722-5140
                        Reset counter: 91
                        Date: 2005.08.26
                        Time: 00:00:30
                        Voltage: 10.60 V
                        Mileage: 655350 km
                        Count: 2808
                        Clock: 21:46
       Part No: 8E0 959 433 CG
       Component: Komfortgert T7B    4135
       Coding: 11852
       Shop #: WSC 06335
       VCID: 78FF5DAB582BA28F9F-4AE8
       Component: Trsteuer.FS BRM 0706
       Subsystem 2 - Part No: 8E1959802G
       Component: Trsteuer.BF BRM 0706
       Component: Trsteuer.HL BRM 0606
       Component: Trsteuer.HR BRM 0606
       Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
       Coding: 0000019
       VCID: 295948EF8001CB07D0-807C
       Component: AFS-Modul links H03 0020
       Component: AFS-Modul rechtsH03 0020
       Coding: 0309637
       VCID: 2B55B2E789FDD91722-515C
                        Reset counter: 91
                        Date: 2005.08.26
                        Time: 00:00:30
                        Voltage: 10.60 V
                        Mileage: 655350 km
                        Count: 2808
                        Clock: 21:46
    Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
       Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
       Component: Reifendruck 3   H04 0130
       Coding: 0062523
       Shop #: WSC 02197 785 00200
       VCID: 2A5BB7E38607C01FD9-5104
    Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
       Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
       Component: Parkhilfe 4-Kan H06 0010
       Revision: 00H06000    Serial number: 00067802020626
       Coding: 0000304
       VCID: 3169A08FABD1B3C718-5122
       Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
       Component: FSE_255x BT     H26 0290
       Revision: 00000000    Serial number: 00000005010392
       Coding: 0011877
    End-------------------------(Elapsed Time: 05:34)--------------------------
    Bimmerod
  5. Likes Uwe liked this post
    Lots of low voltage errors on many modules, and some very strange subsystem part numbers under #15 Airbags?
    First thing is to clear all the DTCs and see which come back to get rid of the historical DTCs caused by the low battery - you never know that may fix some of the problems?
    BTW great choice of a B7 RS4 - I owned one for 10 years until retirement forced me to downsize
  7. Likes Uwe, Jack@European_Parts liked this post
  8. #5
    Sep 2016
    What I am saying is that my cluster was never like that before the dead battery/jump start. For some reason the cluster is not accepting the coding for the third option which would turn the Scales & Needles on with the ignition on.
    I have tried to unhook the battery and reset everything but it is still not accepting the "3" coding to the cluster. All of the other ones make the desired changes so I don't know??? I have even driven it around for a few hours to make sure it was fully charged and all modules were reset after the Auto-Scan.
    Doesn't make any sense ???
    Bimmerod
  9. #6
    Did you save old auto-scan with configurations if so review them and why would you let an rs4 battery go flat or jump start it?
  10. #7
    Quote Originally Posted by Bimmerod View Post
    In VCDS go to 'Options', 'User Interface and Identification' what values do you have in the Code(WSC), VZ/Importer and Equipment Number fields?
  11. Likes Jack@European_Parts liked this post
  12. #8
    Sep 2016
    I have an old auto-scan, not sure what you mean "with configurations" though ???
    Obviously life got in the way of making sure my battery did not die, it wasn't intentional. Car is covered in the garage and either I periodically drive it or hook it up to the trickle charger. Seems as though neither one of those happened before the juice ran out
    Here is screeen shots from those screens:
    Not sure if they are all supposed to be Zeros ???
    Let me know,
    Bimmerod
  13. #9
    Yes, that's their default condition. When they're all zeros, VCDS tries to operate as stealthily as possible, but this is not always compatible with some changes.
    Try this:
    * Set WSC to your ZIP code (or '0' followed by the last four digits of your ZIP code if it's over 65535)
    * Set Importer to 444 (that's USA).
    * Set Equipment number to the '0' followed by the last four digits of your interface serial number.
    * Click [Save]
    * Exit VCDS and then re-start it.
  14. Likes Jack@European_Parts, PetrolDave liked this post
  15. #10
    Sep 2016
    Try this:
    * Click [Save]
    Updated those fields with the information you gave. Now those fields are greyed out and not changeable anymore. Not sure if I need to change them back to 00000 ???
    From Ross-Tech:
    https://www.ross-tech.com/vcds/tour/option_screen.php
    Note: If you are an individual user or independent mechanic, just leave the number set to "00000".
    Restarted VCDS and the attempted to recode channel 19 with the "3" option without success. It is still not changing both scales and needles, it only behaves like option "1" where just needles are lit with Ignition ON. Option "2" turns on scales without Needles. It's just option "3" that only changes it back to Needles only, no Scales come on.
    The ambient light sensor does work but I prefer to have it back to how it has been for the past 13 years, Scales & Needles ON with Ignition on all the time.
    Bimmerod
