Hi All
I bought my VCDS setup from Mashalls Industrial here in the UK at the weekend following the purchase of a new family bus in the shape of a 2012 VW Caravelle Executive T5.1 140 DSG that arrived last week.
Beyond permitting me to perform a service indicator reset after each intervention, I'm sure that there are numerous things that our vehicle can be coded to support and here starts day 1 of my new school learning.
I'm certain that the MFD/DIS should be able to do more than just show basic trip computer settings (it's the colour version and a previous '07 Touareg displayed NAV and all sorts in the DIS), I'd like to enable drive-away locking, the RNS510 is currently using Eastern European maps and won't play DVD's so I'm wondering if the region setting is not compatible with the UK for some reason, and I've bought the VW bluetooth kit to add phone connectivity and I will need to code this once installed.
I'm also considering adding the MFSW button pack to our steering wheel and would love to get flappy paddles to work if that's at all possible, but for now I guess that it's learn to walk before I run!
As requested / suggested when I registered, here's my first scan log for your amusement and comment:
Thanks for reading!
Ian
Thursday,05,December,2019,17:05:09:34006
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
VIN: WV2ZZZ7HZCH073817 License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 25 37 56 78 0B
VIN: WV2ZZZ7HZCH073817 Mileage: 122490km-76111miles
0D-Slide Door, Left -- Status: OK 0000
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CCHA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 DH HW: 03L 907 309 K
Component: R4 2,0L EDC X43 9133
Revision: 26X43--- Serial number: 00000000000000
Coding: 0125401A232400080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
ROD: EV_ECM20TDI01103L906019DG.rod
VCID: 74B1DE2B5E3362C7DDF-8020
Part No SW: 0BT 300 045 M HW: 0BH 927 711 C
Component: DSG DQ500-7F H05 1712
Revision: 00H05V01
ROD: EV_TCMDQ500021_VW36.rod
VCID: 3FDB410727F5F19FF0D-806A
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 H HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0107
Revision: 00H43001
Coding: 108724AD09AB089824AA9072AA6510
Shop #: WSC 02756 790 49152
VCID: 372B29270F45C9DF38D-8062
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E5 907 040 N HW: 7E5 907 040 N
Component: ClimatronicT5 H11 0304
Revision: 00001003
Coding: 0004000102
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 33331D371BBD25FF045-8066
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 B HW: 7E5 907 049 B
Component: Heckbedienung H10 0202
Serial number: BHB-0012111110015138
9582193 - Positioning Motor for Rear Air Disrtibution Flap 2
B1236 71 [008] - Actuator stuck
Fault Frequency: 113
Reset counter: 250
Mileage: 120824 km
Date: 2019.11.27
Time: 14:27:05
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 H HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0251
Revision: BO047001 Serial number: 0429 318111212
Coding: A0B2793A0E612413932088106C2B8ED40080410F60840000300003000000
Shop #: WSC 02756 790 00000
VCID: 392F2F1F3951DFAFCE9-806C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 261111 05 54 0403
Coding: 02302E
Subsystem 2 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 003 3311
Coding: 050000
Subsystem 3 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 003 3311
Coding: 040000
Subsystem 4 - Part No: 7E1 951 171
Subsystem 5 - Part No: 1K0 951 605 C
Subsystem 6 - Part No: 7E1 951 171
03303 - Response Closing Status of Rear Left Door
Fault Frequency: 45
Reset counter: 248
Mileage: 121061 km
Date: 2014.04.19
Time: 19:54:20
Address 0D: Slide Door, Left Labels: Redir Fail!
Part No: 7E0 959 243 D
Component: Schiebetuer-SG 407 0328
VCID: 3039123BE62B1EE7797-8064
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 E HW: 7E0 919 475 A
Component: PARKHILFE 8K H11 0013
Revision: -------- Serial number: 47401129200427
Coding: 108102
ASAM Dataset: EV_VW75XParkAssis8K A01005
ROD: EV_VW75XParkAssis8K_A01.rod
VCID: 34311E2B1EB322C71DF-8060
Part No SW: 7E0 959 655 C HW: 7E0 959 655 C
Component: VW10Airbag00P H06 0013
Revision: -------- Serial number: 003HM001KY1C
Coding: 000000000000000000000000000000003050
Shop #: WSC 02754 790 50316
VCID: 3635242308CF30D723B-8062
Serial number: 3495ZRB40670IAMCAPVO
Serial number: 3505ZRB40690IAMC4HIY
Part No SW: 7E0 920 980 E HW: 7E0 920 980 E
Component: KOMBI H03 0306
Coding: 460F00
VCID: 2D070B4FFD99730F521-8078
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 B
Component: J737__Standheizung 0605
Revision: 00085000 Serial number: 09019275F00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 2411EE6BA2D3B2478DF-8070
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H47 0251
Revision: BO047001
Coding: 042300
VCID: 70B9D23B2AAB5EE7397-8024
Component: IMMO H03 0306
VCID: 6A8DC0530CF7A437773-803E
Part No SW: 7F0 035 680 A HW: 7F0 035 680 A
Component: RNS-MID H61 3976
Revision: AB001001 Serial number: VWZ6Z7L7318036
Coding: 04000402040000A00014
Shop #: WSC 02754 790 00000
VCID: 2411EE6BAED3B2478DF-8070
Address 78: Slide Door, Right Labels: Redir Fail!
End----------(Elapsed Time: 02:10, VBatt start/end: 13.5V/13.5V)-----------
Thanks for reading!
Ian
