Wife complains that now when headlight switch turned to Auto, the instrument panel lights stay off even when it gets dark and the headlights come on.
Ran a full scan and got this (full scan appended):
02382 - Sensor for Light Detection (G399)
014 - Defective
Fault Status: 01101110
Fault Frequency: 98
Reset counter: 53
Mileage: 247792 km
Date: 2019.11.04
Time: 07:57:00
It appears this is related to the sensor that sits in the center front of the dash, up top by the windshield. Its not cheap. So before I replace it only to find nothing changes, is there any way to use VCDS to report the output in real time, so I could try covering it and then shining a bright lignt on it, to see if it reacts?
David
014 - Defective
Fault Frequency: 98
Reset counter: 53
Mileage: 247792 km
Date: 2019.11.04
Time: 07:57:00
David
Thursday,05,December,2019,11:49:06:11064
VCDS Version: 17.1.3.0
VIN: WAUKG74F66N034772 License Plate:
Mileage: 248620km-154485mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 42 46 47 4F 52 53 55
56 61 62 65 6D 72 77
VIN: WAUKG74F66N034772 Mileage: 248620km-154485miles
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 F HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0050
Revision: --H15--- Serial number:
Coding: 010D0106190F0120
Shop #: WSC 03738 444 38140
VCID: 2E591F2BB93C7D314B-807A
008304 - Intake Manifold Tuning Valve (Bank 1)
P2070 - 006 - Stuck Open - Intermittent
Fault Status: 00100001
Reset counter: 20
Mileage: 248294 km
Date: 2019.11.25
Time: 08:11:49
RPM: 736 /min
Mass Air / Rev.: 125.4 mg/str
Temperature: 81.0∞C
Idle
Absolute Pres.: 372.4 mbar
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 P HW: 09L 927 156 A
Component: AG6 09L 3,2 FSI USA 0010
Revision: --H01--- Serial number: 4042926
Shop #: WSC 02325 785 00200
VCID: 31630457A80262C956-8064
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Coding: 0020895
VCID: 2D5B1827B43A062972-8078
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0160
Revision: 27100401 Serial number: 10600300181659
Coding: 0000139
Shop #: WSC 02323 785 00200
VCID: 63CFBE1FA27E805994-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H44 0070
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H39 0040
00955 - Key 1
Fault Status: 00110010
Reset counter: 40
Mileage: 231509 km
Date: 2018.07.13
Time: 12:31:37
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 303FC057501703
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 2143F417F8E2D249C6-8074
Component: Bedienteil MMIC6H07 0050
Subsystem 2 - Serial number: 00000000175950
Subsystem 3 - Serial number: 0109.06.050000000100010077ˇ
Subsystem 4 - Serial number: 010077ˇ
01964 - Control Module for Seat & Steering Column Memory (J136)
Reset counter: 54
Mileage: 248006 km
Date: 2019.11.18
Time: 08:01:54
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000030027802
Coding: 0524582
VCID: 5BBF86FF9A0EB899DC-800E
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H15 0080
Coding: 0013123
VCID: 66C9A70B514CF57173-8032
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00152621
Shop #: WSC 02335
014 - Defective
Fault Frequency: 98
Reset counter: 53
Mileage: 247792 km
Date: 2019.11.04
Time: 07:57:00
02747 - Solenoid for Bi-Xenon Shutter; Right
Fault Frequency: 98
Reset counter: 53
Mileage: 247792 km
Date: 2019.11.04
Time: 07:57:00
Reset counter: 53
Mileage: 219780 km
Date: 2017.08.24
Time: 14:41:00
Reset counter: 53
Mileage: 219780 km
Date: 2017.08.24
Time: 14:41:00
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7183772
VCID: 1B3FC6FFDA8EF8991C-804E
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH29 0300
Revision: 10H29000 Serial number: 00359D08CLRC
Coding: 0013878
Shop #: WSC 40329 444 53665
VCID: 2A51133B85D4111197-807E
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME0A266372/
Subsystem 3 - Serial number: 6342CSME0A300A73
Subsystem 4 - Serial number: 6352QSME022217595
Subsystem 5 - Serial number: 6362QSME014835054
Subsystem 6 - Serial number: 63734SME02133E7B%
Subsystem 7 - Serial number: 63834SME02391C6D5
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenks‰ulenmodul H07 0230
Revision: 00H07000 Serial number: 90026051530016
Coding: 0002022
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H10 0630
Revision: 00900000 Serial number: 4R8703845
Coding: 0083263
Shop #: WSC 61847 001 1048576
VCID: 1E39CFEBC99CEDB1FB-804A
Address 19: CAN Gateway Labels: 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 120080560282B7
Coding: 6CFE73CD1B1106
Shop #: WSC 01115 444 54714
VCID: 2757EA0F96C62C7988-8072
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 61C3B417B862924986-8034
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00-00000
Coding: 0036587
Shop #: WSC 02327 785 00200
VCID: 2953EC3780D21A099E-807C
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 B HW: 4F0 907 289 B
Component: Komfortgeraet H18 0130
Revision: 01300018 Serial number: 01004703410000
Coding: 7764541
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 A HW: 4F0 035 223 A
Component: DSP-High C6 H09 0140
Revision: PROD_01 Serial number: 00000000791217
Coding: 0000116
VCID: 1C3DC5E3DF80FFA115-8048
Reset counter: 81
Mileage: 248474 km
Date: 2019.12.01
Time: 11:29:59
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000002110
Coding: 0002114
VCID: 5EB98FEB891CADB1BB-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00-00000
Coding: 0036587
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
VCID: 5DBB88E7841AB6A9A2-8008
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Coding: 0000016
VCID: 2649E70B91CC3571B3-8072
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394F$057557178
VCID: 234FFE1FE2FEC059D4-8076
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000050776
Shop #: WSC 02445 823 62659
Subsystem 1 - Part No: 4F0 915 105 E
Component: von VA0 1506090014
Coding: 344630393135313035452056413031353036303930303134
Shop #: WSC 00000 384 00290
02276 - Quiescent Current Stage 5
Fault Frequency: 12
Mileage: 219783 km
Date: 2017.08.24
Time: 14:17:11
Fault Frequency: 12
Mileage: 219783 km
Date: 2017.08.24
Time: 14:17:11
02274 - Quiescent Current Stage 3
Fault Frequency: 11
Mileage: 219783 km
Date: 2017.08.24
Time: 14:24:55
Fault Frequency: 11
Mileage: 219783 km
Date: 2017.08.24
Time: 14:24:55
02256 - Quiescent Current
Fault Status: 00110001
Fault Frequency: 54
Reset counter: 91
Mileage: 244884 km
Date: 2019.08.06
Time: 17:34:55
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H11 0030
Coding: 0036394
VCID: 69D3AC374052DA095E-803C
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 HW: 4F0 907 273
Component: Reifendruck 3 H04 0080
Revision: 00040080 Serial number: 00000700006980
Coding: 0062221
Shop #: WSC 02334 785 00200
VCID: 60C5B113B3689B4189-8034
02214 - Tire Pressure Warning
Reset counter: 84
Mileage: 248488 km
Date: 2019.12.01
Time: 15:38:15
(no units): 55.0
Temperature: 1.0∞C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 B
Component: ValeoHeckdeckel H14 0280
Revision: --H14001 Serial number: E5030000B
Shop #: WSC 23250 431 715754
VCID: 6CDDD5234FA0CF2125-8038
Subsystem 1 - Part No: 4F9 910 592
Subsystem 3 - Serial number: KK02.06.05--H14001001A0037ˇ
Subsystem 4 - Serial number: 1A0037ˇ
00317 - Rear Lid Control Module (J605)
Reset counter: 93
Mileage: 229482 km
Date: 2018.05.20
Time: 21:17:40
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H11 0030
Coding: 0036394
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H11 0440
Revision: 00000000 Serial number: 00000007502536
Coding: 0010900
VCID: 2241FB1BFDE4C951DF-8076
End-------------------------(Elapsed Time: 03:17)--------------------------
