Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 62
Thread: 08 4.2FSI Q7 Multiple cyl misfire. ROUGH running/ barely idles -at wits end....
  1. #51
    Dec 2019
    Yes, I noted that guide was missing a piece when I pulled the left upper cover. I removed it entirely before it dropped any more.
  2. #52
    Am I referencing a chain guide here, I think not?
    Did you see the possible pins that can break "inside" the adjusters themselves to permit a hydraulic freewheel and rely on nothing but oil PSI to hold a base/max position being negated?
  3. #53
    Dec 2019
    Thought you were...
    Simple answer. no, I don't think so. I honestly don't understand what you're referring to. Are you talking about the "pins" that were referenced in that video link I posted earlier or something else? I don't currently have a penta-star socket (seems different than a Torx) to disassemble the cam adjuster -if THAT is where this pin is you're referring to.
  4. #54
    Dec 2019
    Canada
    Take a look at the JHM motorsport video about the old adjusters, it'll give you a good visualization of the aforementioned pins
  5. Likes Jack@European_Parts liked this post
  6. #55
    Dec 2019
    Thats what I thought too, but these require a pentalobe (like torx) bit to disassemble -which I don't have (yet).
    https://drive.google.com/open?id=0B2...Z4YXM1OFF6Qlo0
  7. Likes Jack@European_Parts liked this post
  8. #56
    Dec 2019
  9. Likes Jack@European_Parts liked this post
  10. #57
  11. #58
    Jun 2014
    Newcastle, England
    Sometimes things are posted to show what not to do, huh?
    Definitely.
    Quote Originally Posted by imquattro View Post
    We heard some additional clicks as we were turning the motor (CW) over...
    Eeergh...
    Found #6 cylinder's exhaust cam trying to open valves while piston was coming up.
    Iím cringing. But itís great to find the root cause.
    I had a turbo let go on a 1.8T years ago. It first sounded like a screeching bird when trying to boost. So in my diagnosis, I pulled the inlet hose to the turbo; and the compressor impeller looked intact and spun freely. I nearly started looking elsewhere, but something in my gut told me itís definitely the turbo - and just get the thing off for a proper look.
    Well, turbo had sheared itís shaft; and the turbine was free to move in an x, y and z axis. The oil feed pipe on those 1.8Ts ran round the rear of the engine then under a heat shield above the exhaust manifold. The oil was so caked in that pipe I couldnít budge it with 100 bar hydraulic pressure from our test rig.
    Feels satisfying when youíre done and itís ticking over smoothly as youíre tidying up and doing your final check for leaks.
  12. Likes Jack@European_Parts, Uwe liked this post
  13. #59
    The oil was so caked in that pipe I couldn’t budge it with 100 bar hydraulic pressure from our test rig.
    Again why I think all turbo cars should have a bifurcated sump, pump and after cooler to operate when shut down with water circulation.
    Engines would be far better off!
  14. Likes Zenerdiode, PetrolDave liked this post
  15. #60
    Dec 2019
    Because there is a complete vacuum of information on these newer camshaft adjusters to support NOT taking them apart to check their operation and literally found NO pictures of the insides, I disassembled mine to investigate/clean.
    Looks like Audi fixed their earlier cam adjuster style issues -note the hardened ring for the pin to lock into.
    https://drive.google.com/open?id=0B2...pvNW55dmpIeHpv
    https://drive.google.com/open?id=0B2...hQX0k0NVlVd29n
    Now we all know why there's nothing notable mentioned about them.
    ---no news is sometimes good news---
  16. Likes Uwe, Jack@European_Parts liked this post
