Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 62
Thread: 08 4.2FSI Q7 Multiple cyl misfire. ROUGH running/ barely idles -at wits end....
  1. #31
    Thanks PIVOT, motor and tranny assembly already out.
    Jack, thanks, already the entire SSP dl'd
    Next: separation.....
    ...............YAY!
    Pictures!
    Vehicle Identification No. WA1BV74L78D048214
    Model audi q7 qu. 4.2
    AQ7
    Date of production 31.01.2008
    Model year 2008
    Sales type 4LB4EL
    Engine Code BAR
    Transmission Code JXS
    Did you use brass bunches and plastic wedged/hammers for separating covers?.......NOT steel pry bars!
    Did you verify all key pins on adjusters?
  2. #32
  3. Likes Uwe, NZDubNurd liked this post
  4. #33
    Cool school project...........
  5. #34
    Dec 2019
    Jack your definition of cool is definitely different than mine. Students are enjoying it though.
    If I had a dollar for every "LS it" comment.....
    Like the Sealube suggestion... never heard of that stuff. I'll check it out.
    We'll be gentle prying stuff apart...
  6. #35
    Before you pry anything get the hidden bolts on bottom of timing covers, please don't forget them okay?
    Do you have all the special tools to lock everything down?
  7. #36
    Dec 2019
    Tools arrive Wednesday while I'm at work, but won't matter, I won't need them until Thursday.
    https://drive.google.com/open?id=0B2...dvSXhfYlVNZkN3
    https://drive.google.com/open?id=0B2...Y2SjhUMENjOEc0
    https://drive.google.com/open?id=0B2...1JN1VESlF1Nmdn
    Already spotting missing guide material....
  8. #37
    Pivoting in another direction, so much for the scope idea huh?
    Holy sludge FOD apparent in that thing, did you inspect sump pickup yet and take off adjusters to verify all pins or keyways?
  9. #38
    May 2016
    Jack, I know the VAG is some kind of sweet tool. And I know that is what this forum is about not scopes.
    And also I know a guy like you and the team from Ross tech can probably tell what is wrong before opening the hood, I call this empirical studies, experience, just is what it is.
    But with an engine as complex as this, would have done a relative compression and compression wave form back about page one before buying a butt load of parts. As. You note all the lines might look sweet but what if a keyway or other is compromised now what do we trust.
    As you stated with no codes has somebody played with it?., I hate it, makes it really tough for the garage guy when trying to trust the scanner data.
    Again great stuff, have a great new year.
    LARIMORE
  10. #39
    Jun 2014
    Newcastle, England
    Watched that video ‘till the end. Was going so well until he squidged that sealant on like toothpaste from the tube. The whole idea is that the bead of sealant just fills the width of the channel. Well, I suppose it gets them business, as the customer will be back with an ‘unrelated issue’ of oil starvation wrecking the engine - after a snotty string of that sealant blocks an oil way later down the road.
    I’m not a Master Technician, though...
  11. Likes Jack@European_Parts, Uwe liked this post
  12. #40
    Dr. Z. Knows.......
    Sometimes things are posted to show what not to do, huh?
    Seal lube or engines die, you want it on that aluminum wall, you need it on that wall?
