Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 62
Thread: 08 4.2FSI Q7 Multiple cyl misfire. ROUGH running/ barely idles -at wits end....
    Dec 2019
    looks like the left bank valve cover's coming off.
  2. #12
    Dec 2019
    Removed left cam cover. Cams are turning as expected. Valves are opening as expected. Lobes and followers appear in good working order.
    I would have expected cam correlation codes had the exhaust cam been broken.
    Additionally, the right bank of cylinder's (1-4) new plugs were again, very sooty compared to the left bank (5-8).
    Next: bore scope.
    Just a thought: Would a completely plugged driver's side cat cause high compression values?
    There were no catalyst efficiency codes, but then again, the engine couldn't run long enough to start checking those values???
    I would think even with a plugged cat, with the other cylinders being open (no spark plug) this would release the built up pressure trapped between the exhaust valve and a plugged cat on the tested cylinder....???
    I'll pull the upstream O2 sensor and perform a compression test again on that bank.
  3. #13
    You are getting warmer.............
    Mechanical's always win over OBD, especially for FOD & rooting it out, now I just have to convince this older USAF guy that thinks I sound like his X-WIFE without being the last word!
    https://forums.ross-tech.com/showthr...e-2-160K-miles
    JPPSG
  4. #14
    Dec 2019
    O2 sensor removed, compression checked and -no change.
    Bore scoped cylinders, exhaust valves verified opening.
  5. #15
    Sort timing, broken key-way or taper fit press offset?
  6. #16
    Dec 2019
    I'm sorry, I don't understand.
  7. #17
    Did you verify timing?
    Maybe helps perspective?
    https://forums.ross-tech.com/showthr...l=1#post123510
  8. #18
    Dec 2019
    Ok sigh. Thats an involved job that will require some time from what I'm seeing in my research. I miss the old days when timing could be verified with a light or just checking camshaft alignment vs crank position marks.
    Any quick -n-dirty tips to check cam/crank timing on these 4.2FSI motors without plenum and timing cover(s) removal?
  9. #19
    The RTFB........
    http://wiki.ross-tech.com/wiki/index...ir_Information
  10. #20
    Dec 2019
    I have full access to ShopKeyPro for my service manual.
    I'm a former auto technician with 25yrs experience, now teaching automotive tech, so not my first rodeo.
    Appreciate the suggestions, but looking for some corners to cut, avoiding IF POSSIBLE -(please Lord) motor out timing component replacement.
    Having no codes relating to timing issues frustrates me going down this timing colored road...
