Audi S3 8V RS3 Grille Change Parking sensor Fault (What should I do?)
Synonymous 8V AUDI S3
Jamaica
These are all my fault codes:
Chasis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 22 2B 42 44 47 52 55 5F
6C A9 BB BC
A couple weeks after I changed the stock grille to the RS3 some rain fell and it’s been in and out since
Should I buy a new sensor ???
The TPMS , Traction Control & ABS Lights comes on when you start up & then it just automatically clears . Sigh its frustration can a faulty sensor cause all of this?? the problem has been intermittent, since the rain now these three lights comes up them automatically clears. HELP!!! :(
Mika_M
C?ID=183725
No, they are not. That is just the gateway installation list. Please post the FULL auto-scan so that others can see what's really going on with your car...
Jamaica
Monday,02,December,2019,20:04:28:39976
VCDS Version: 19.6.2.0 (x64)
   License Plate: ALL FAULTS
Mileage: 36228km-22511mi   Repair Order: Johnathan
Chassis Type: 8V-AU37 (5Q0)
          6C A9 BB BC
 Mileage: 36228km-22511miles
Address 01: Engine (J623-CJXF)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 0A1D1032242600083004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259A 001005
   ROD: EV_ECM20TFS0208V0906259A.rod
   VCID: 3E5DC774A1EB9DBF95-806A
6 Faults Found:
15240 - ECM Power Relay Control Circuit
          P0687 00 [032] - Short to Plus
17178 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 38
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    Engine speed: 830.25 /min
                    Normed load value: 41.6 %
                    Coolant temperature: 47 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 13.671 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
21406 - EVAP Emission Control Sys
          P0441 00 [096] - Incorrect Flow
15237 - System Voltage
          P0562 00 [032] - Too Low
21322 - Implausible Data Received from ABS Control Module
          U0415 00 [046] - -
                    Fault Frequency: 62
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    Engine speed: 840.75 /min
                    Normed load value: 42.4 %
                    Voltage terminal 30: 13.710 V
                    Engine: operating status: IS
                    ECU_STATE: SYN_ENG_IGK_ON
                    Engine oil temperature: 46.0 °C
                    Time since engine start: 8.6 s
                    T_ES: 0 min
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    STATE_ERR_ABC_PRED: 5
23130 - Implausible Data Received from ABS Control Module
          U0415 00 [046] - -
                    Fault Frequency: 62
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    Engine speed: 838.75 /min
                    Voltage terminal 30: 13.730 V
                    T_ES: 0 min
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4517
   Revision: 03253104    Serial number: TFK01501120728
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1F631AF00621F4B7BE-804A
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 60195000001705
   Coding: 31F193A254200A6C037B070241CA698CC92A50C0E08296B7024100388208
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   VCID: 48B1A1ACF32FD30F2F-801C
11 Faults Found:
0071 - Rear Left Wheel Speed Sensor
          C101C 4A [008] - Incorrect component(s) installed
                    Fault Frequency: 20
                    Reset counter: 204
                    Mileage: 35121 km
0075 - Rear Left Wheel Speed Sensor
          C101C 07 [008] - Mechanical Failure
                    Fault Frequency: 7
                    Reset counter: 203
                    Mileage: 35366 km
                    Date: 2019.11.15
                    Time: 10:27:45
0079 - Rear Left Wheel Speed Sensor
          C101C 29 [008] - Signal Implausible
                    Fault Frequency: 18
                    Reset counter: 204
                    Mileage: 35293 km
                    Date: 2019.11.06
                    Time: 19:56:28
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 165
                    Mileage: 35378 km
                    Date: 2019.11.15
                    Time: 00:06:35
0374 - Rear Left Wheel Speed Sensor
                    Reset counter: 204
                    Mileage: 35578 km
                    Date: 2019.11.21
                    Time: 06:10:49
4197 - Rear Left Wheel Speed Sensor
          C101C 14 [136] - Open or Short to Ground
                    Fault Frequency: 38
                    Reset counter: 204
                    Mileage: 35378 km
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 202
                    Mileage: 26024 km
                    Date: 2019.02.19
                    Time: 18:59:59
16412 - Display for Tire Pressure Monitoring
                    Reset counter: 165
                    Mileage: 35378 km
                    Date: 2019.11.15
                    Time: 00:06:44
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 165
                    Mileage: 35378 km
                    Date: 2019.11.15
                    Time: 00:06:44
16417 - Display for Tire Pressure Monitoring
          C1146 02 [136] - Signal Failure
                    Fault Frequency: 35
                    Reset counter: 204
                    Mileage: 35378 km
                    Date: 2019.11.15
                    Time: 00:06:44
32994 - Control Module for Electric Parking Brake
          C10E2 F0 [009] - RPM Sensor Implausble Signal
                    Fault Frequency: 42
                    Reset counter: 164
                    Mileage: 35378 km
   Revision: 00021000    Serial number: 0357528352
   Coding: 030C0C
   VCID: 3A55CB64BDC3B19FA9-806E
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000546021
   Coding: 03100014110000010000000000001500
   VCID: 3245E34465B349DF61-8066
   Serial number: B3098987000000000001
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011501501199
   Coding: 07151B42C04122F503804004B11807A00800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 0021798C9B9F2B4FA7-8054
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150103  041 0585
   Serial number:         150108150816
   Coding: 0A47F7
   Serial number: 23622790
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 07 11 2014  00001512
   Serial number: 000000000ZY143282LDY
   Serial number: 00000000000061431386
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H02 0003
   Serial number: 0000FST0001Y2TU00000
   Coding: 901E00
204546 - Remote key 2
                    Reset counter: 72
                    Time: 00:00:00
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39391500705289
   Coding: 0010150011
   VCID: 42A5B384D513F95FF1-8016
1112369 - Front Right Center Parking Aid Sensor
          B10F9 31 [008] - No Signal
                    Reset counter: 204
                    Mileage: 36084 km
                    Date: 2019.12.01
                    Time: 12:33:58
13637426 - Databus
                    Fault Frequency: 55
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    014 0385
   Serial number: 003MMR02UCK9
   Coding: 98CCC000000000005C54000000C800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   Subsystem 1 - Part No SW: -----------    HW: 480 001 601 15
   Serial number: 357670000006B1CC811.
   Subsystem 2 - Part No SW: -----------    HW: 480 001 601 15
   Serial number: 35867000000962CC811.
   Subsystem 3 - Part No SW: -----------    HW: 480 401 501 15
   Serial number: 35165029F196FF42034J
   Subsystem 4 - Part No SW: -----------    HW: 480 400 701 15
   Serial number: 352650299196FF64036K
   Subsystem 5 - Part No SW: -----------    HW: 480 400 411 14
   Serial number: 3556502A91860BC6322A
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 17011504400165
   Coding: A018
   ROD: EV_SMLSKLOMQB_010_AU37.rod
   VCID: 0A355BA4ADA3611FF9-805E
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
   Part No SW: 8V0 920 871 D    HW: 8V0 920 871 D
   Component: KOMBI         H02 4292
   Coding: 27AD181A2B8000080101A8001000000000000000
   VCID: 3D5FC078ACED86A78C-8068
   Revision: --------    Serial number: 19011510801193
   Coding: 0101000830085A005B0002281C0B00000001010000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72C52344A53309DFA1-8026
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 12 12 2014  E0046153
8526355 - Voltage Drop in Generator Leads too large
          P30DE 00 [008] - -
                    Reset counter: 203
                    Mileage: 29568 km
                    Date: 2019.05.22
                    Time: 09:29:46
                    Supply voltage: Terminal 30: 13.2 V
                    Terminal 15: On
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 8V0 857 511     HW: 8V0 857 511
   Component: FLA           H03 0002
   Revision: AA001001
   Coding: 02028764747464545425363E00
   VCID: 79D71468F8457A87E0-802C
   Serial number: HA1-00027.11.14
   Coding: 0001
   VCID: 46ADAF94F93BC57FDD-8012
16670 - All-Wheel Drive
          C1113 07 [008] - Mechanical Failure
                    Reset counter: 203
                    Mileage: 35884 km
                    Date: 2019.11.30
                    Time: 09:35:24
16656 - Databus
                    Fault Frequency: 59
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:05
   Revision: 00000000    Serial number: 15000006284003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3449E55C9FA747EF73-8060
13637378 - Databus
                    Fault Frequency: 98
                    Reset counter: 204
                    Mileage: 35121 km
                    Date: 2019.11.02
                    Time: 09:19:16
                    ELV State: 02
                    Information Clamps: 00 00
                    CoCo State: 20 01
                    WFS State: 00 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 6C
                    AD-Value H-bridge: 36
                    Clamp15 flip flop: SSTx: button contacts: 09
                    CAN signals: 00
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Serial number: 221214BJ409083
   Coding: 005D1E205C01040000001002
   Coding: 8102
   VCID: 3753D2508ED1ACF756-8062
19716 - Databus
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 13.50 V
                    Temperature: 88.0 °C
                    KFC: 4D
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 13.64 V
                    uAdSensI_SwitchedKl30_xdu16: 13.63 V
20228 - Databus
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    Motor status: 02
                    KFC: 4F
                    KFA: 00 04
   Part No SW: 8V0 035 465 C    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0410
   Serial number: AUZ8ZAEN900Z1E9
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: 3851D16C83CFA38F5F-806C
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Serial number: 110115BAA0755A
   Coding: 005D16205E01040000001002
   VCID: 41A7BC88D015E247E8-8014
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 200
                    Mileage: 35911 km
                    Date: 2019.11.30
                    Time: 16:02:23
   Coding: 012E000001000000
   VCID: 75CF1858D45D1EE784-8020
13705985 - Databus
                    Fault Frequency: 62
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
   Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
   Component: MU-S--ER      041 0420
   Serial number: A3E01701151068
   Coding: 017301000000000021220002001A00002F0002260100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9EY308E1W
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Serial number: C1000031101400020295
6669 - Optical Data Bus for Digital Sound System
          U10CC 00 [008] - Intermittent Disruption
                    Reset counter: 204
                    Mileage: 35627 km
                    Date: 2019.11.22
                    Time: 19:09:30
                    Voltage terminal 30: 13.7 V
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: 17 °C
                    Temperature of MOST transceiver-Current: 41 °C
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
   Component: MQB RVC Mid   H07 0140
   Coding: 027300010201000300
   ASAM Dataset: EV_2CamSysRearPASE 006016
   ROD: EV_2CamSysRearPASE.rod
   VCID: 3041E94C6BBF7BCF17-8064
13705989 - Databus
                    Fault Frequency: 55
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    CAN communication
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 141212201070
   VCID: 7DDF0078EC6D46A7CC-8028
   Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0028
   Serial number: 080115BA715628
   Coding: 004D16204001040000001002
   Component: TSG HBFS      020 0028
   Serial number: 080115BA715354
End-------------------------(Elapsed Time: 04:37)--------------------------
Address 5F: DTCs cleared
Address 6C: DTCs cleared
Address 55: DTCs cleared
Address 52: DTCs cleared
Address 44: DTCs cleared
Address 2B: DTCs cleared
Address 22: DTCs cleared
Address 19: DTCs cleared
Address 10: DTCs cleared
Address 09: DTCs cleared
Address 03: DTCs cleared
Address 01: DTCs cleared
VCDS Release 19.6.2:  SRI Reset-SRI3.CLB
Control Module Part Number: 8V0 920 871 D       Labels:  .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI         H02 4292, Coding:27AD181A2B8000080101A8001000000000000000
Channel        Description                                                 	Current val.                                                	New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	no warning                                                  	---
IDE00510-ESI: distance driven from inspection                                                       	ESI: Distance since Inspection                              	3657 km                                                     	---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	122 d                                                       	---
IDE00515-ESI: oil quality        ESI: Oil Quality                                            	poor oil quality                                            	---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                          	0 km                                                        	---
IDE00518-ESI: thermal load        ESI: Thermal Load                                           	8600 km                                                     	---
IDE01153-SIA: maximum value of distance to service                                                  	SIA: Maximum Distance to Service                            	7500 km                                                     	---
IDE01154-SIA: maximum value of time to service                                                      	SIA: Maximum Time to Service                                	365 d                                                       	---
IDE03349-FIX: Max. distance until next mileage-related inspection                                   	FIX: Maximum Distance to Inspection                         	30000 km                                                    	---
IDE03350-FIX: Maximum time until next time-dependent inspection                                     	FIX: Maximum Time to Inspection                             	730 d                                                       	---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                              	FIX: Distance since Inspection                              	10700 km                                                    	---
IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	298 d                                                       	---
myounus
Northwest UK
C?ID=321059
Hi
Please could you clear all the faults and post a new scan. This will allow us to see what faults are actually there.
Jamaica
That's the thing when its clears and is then scanned nothing comes up then once the front parking sensor goes and you hear that loud beep then the light blinks all these things comes up on the dash then disappears. However here it is Kindly see below.
Monday,02,December,2019,20:03:51:39976
          6C A9 BB BC
   Revision: --H13---
6 Faults Found:
17178 - Databus
                    Fault Frequency: 38
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
          U0415 00 [046] - -
                    Fault Frequency: 62
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    T_ES: 0 min
          U0415 00 [046] - -
                    Fault Frequency: 62
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    T_ES: 0 min
11 Faults Found:
                    Fault Frequency: 20
                    Reset counter: 204
                    Mileage: 35121 km
                    Fault Frequency: 7
                    Reset counter: 203
                    Mileage: 35366 km
                    Date: 2019.11.15
                    Time: 10:27:45
                    Fault Frequency: 18
                    Reset counter: 204
                    Mileage: 35293 km
                    Date: 2019.11.06
                    Time: 19:56:28
                    Reset counter: 165
                    Mileage: 35378 km
                    Date: 2019.11.15
                    Time: 00:06:35
                    Reset counter: 204
                    Mileage: 35578 km
                    Date: 2019.11.21
                    Time: 06:10:49
                    Fault Frequency: 38
                    Reset counter: 204
                    Mileage: 35378 km
          C102D 00 [008] - -
                    Reset counter: 202
                    Mileage: 26024 km
                    Date: 2019.02.19
                    Time: 18:59:59
                    Reset counter: 165
                    Mileage: 35378 km
                    Date: 2019.11.15
                    Time: 00:06:44
                    Reset counter: 165
                    Mileage: 35378 km
                    Date: 2019.11.15
                    Time: 00:06:44
                    Fault Frequency: 35
                    Reset counter: 204
                    Mileage: 35378 km
                    Date: 2019.11.15
                    Time: 00:06:44
                    Fault Frequency: 42
                    Reset counter: 164
                    Mileage: 35378 km
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Light switch:
   Sun Roof:
   Coding: 901E00
                    Reset counter: 72
                    Time: 00:00:00
   Coding: 0010150011
                    Reset counter: 204
                    Mileage: 36084 km
                    Date: 2019.12.01
                    Time: 12:33:58
13637426 - Databus
                    Fault Frequency: 55
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
   Coding: A018
          P30DE 00 [008] - -
                    Reset counter: 203
                    Mileage: 29568 km
                    Date: 2019.05.22
                    Time: 09:29:46
                    Terminal 15: On
   Revision: AA001001
   Coding: 0001
                    Reset counter: 203
                    Mileage: 35884 km
                    Date: 2019.11.30
                    Time: 09:35:24
16656 - Databus
                    Fault Frequency: 59
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:05
13637378 - Databus
                    Fault Frequency: 98
                    Reset counter: 204
                    Mileage: 35121 km
                    Date: 2019.11.02
                    Time: 09:19:16
                    ELV State: 02
                    CoCo State: 20 01
                    WFS State: 00 06
                    Voltage: 6C
                    CAN signals: 00
   Coding: 8102
19716 - Databus
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    Motor status: 02
                    KFC: 4D
                    KFA: 00 04
20228 - Databus
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    Motor status: 02
                    KFC: 4F
                    KFA: 00 04
                    Reset counter: 200
                    Mileage: 35911 km
                    Date: 2019.11.30
                    Time: 16:02:23
13705985 - Databus
                    Fault Frequency: 62
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    Reset counter: 204
                    Mileage: 35627 km
                    Date: 2019.11.22
                    Time: 19:09:30
13705989 - Databus
                    Fault Frequency: 55
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    CAN communication
Jamaica
-Could the parking sensor cause all of this ????? or could it be the brake switch sensor of speed sensor idk??????? :(
myounus
Northwest UK
C?ID=321059
As I previously asked can you delete ALL FAULTS and run a new scan please. This will assist us to help you
Jamaica
SCAN AFTER FAULT CODES WERE CLEARED
Monday,02,December,2019,21:06:34:39976
Dealer/Shop Name: XXXXXX XXXXXX
Workshop Code: 123 12345 XXXXXX
VIN: WAUZZZ8V8G100XXXX   License Plate:
          6C A9 BB BC
VIN: WAUZZZ8V8G100XXXX   Mileage: 36228km-22511miles
   Revision: --H13---
Readiness: 0010 0000
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Light switch:
   Sun Roof:
   Coding: 901E00
   Coding: 0010150011
   Coding: A018
   Revision: AA001001
   Coding: 0001
   Coding: 8102
5275220 - Headlight
                    Reset counter: 164
                    Mileage: 36228 km
                    Date: 2019.12.02
                    Time: 20:30:44
End-------------------------(Elapsed Time: 04:27)--------------------------
Jamaica
Dealer/Shop Name: XXXXX XXXX
          6C A9 BB BC
   Revision: --H13---
6 Faults Found:
17178 - Databus
                    Fault Frequency: 38
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
          U0415 00 [046] - -
                    Fault Frequency: 62
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    T_ES: 0 min
          U0415 00 [046] - -
                    Fault Frequency: 62
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    T_ES: 0 min
11 Faults Found:
                    Fault Frequency: 20
                    Reset counter: 204
                    Mileage: 35121 km
                    Fault Frequency: 7
                    Reset counter: 203
                    Mileage: 35366 km
                    Date: 2019.11.15
                    Time: 10:27:45
                    Fault Frequency: 18
                    Reset counter: 204
                    Mileage: 35293 km
                    Date: 2019.11.06
                    Time: 19:56:28
                    Reset counter: 165
                    Mileage: 35378 km
                    Date: 2019.11.15
                    Time: 00:06:35
                    Reset counter: 204
                    Mileage: 35578 km
                    Date: 2019.11.21
                    Time: 06:10:49
                    Fault Frequency: 38
                    Reset counter: 204
                    Mileage: 35378 km
          C102D 00 [008] - -
                    Reset counter: 202
                    Mileage: 26024 km
                    Date: 2019.02.19
                    Time: 18:59:59
                    Reset counter: 165
                    Mileage: 35378 km
                    Date: 2019.11.15
                    Time: 00:06:44
                    Reset counter: 165
                    Mileage: 35378 km
                    Date: 2019.11.15
                    Time: 00:06:44
                    Fault Frequency: 35
                    Reset counter: 204
                    Mileage: 35378 km
                    Date: 2019.11.15
                    Time: 00:06:44
                    Fault Frequency: 42
                    Reset counter: 164
                    Mileage: 35378 km
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Light switch:
   Sun Roof:
   Coding: 901E00
                    Reset counter: 72
                    Time: 00:00:00
   Coding: 0010150011
                    Reset counter: 204
                    Mileage: 36084 km
                    Date: 2019.12.01
                    Time: 12:33:58
13637426 - Databus
                    Fault Frequency: 55
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
   Coding: A018
          P30DE 00 [008] - -
                    Reset counter: 203
                    Mileage: 29568 km
                    Date: 2019.05.22
                    Time: 09:29:46
                    Terminal 15: On
   Revision: AA001001
   Coding: 0001
                    Reset counter: 203
                    Mileage: 35884 km
                    Date: 2019.11.30
                    Time: 09:35:24
16656 - Databus
                    Fault Frequency: 59
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:05
13637378 - Databus
                    Fault Frequency: 98
                    Reset counter: 204
                    Mileage: 35121 km
                    Date: 2019.11.02
                    Time: 09:19:16
                    ELV State: 02
                    CoCo State: 20 01
                    WFS State: 00 06
                    Voltage: 6C
                    CAN signals: 00
   Coding: 8102
19716 - Databus
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    Motor status: 02
                    KFC: 4D
                    KFA: 00 04
20228 - Databus
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    Motor status: 02
                    KFC: 4F
                    KFA: 00 04
                    Reset counter: 200
                    Mileage: 35911 km
                    Date: 2019.11.30
                    Time: 16:02:23
13705985 - Databus
                    Fault Frequency: 62
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    Reset counter: 204
                    Mileage: 35627 km
                    Date: 2019.11.22
                    Time: 19:09:30
13705989 - Databus
                    Fault Frequency: 55
                    Reset counter: 204
                    Mileage: 35212 km
                    Date: 2019.11.02
                    Time: 21:03:06
                    CAN communication
Jamaica
Dealer/Shop Name: XXXX XXXXX
          6C A9 BB BC
   Revision: --H13---
21153 - Gear 1
21159 - Gear R
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Light switch:
   Sun Roof:
   Coding: 901E00
   Coding: 0010150011
   Coding: A018
   Revision: AA001001
   Coding: 0001
   Coding: 8102
5275220 - Headlight
                    Reset counter: 164
                    Mileage: 36228 km
                    Date: 2019.12.02
                    Time: 20:30:44
myounus
Northwest UK
C?ID=321059
This is very strange as the parking sensor connections are water tight and no water ingress should cause the faults shown on the 1st scan. Does it happen as soon as the parking sensors are engaged or when they are measuring distance?
Jamaica
Well Both to be honest and the Rs3 that I bought I removed the license plate holder so the sensor wires are kind of exposed. I also have on the ecs wheel spacers kit and the car is lowered(not sure if this has anything to do with it) , but this all started when the parking sensors started going in and out.
myounus
Northwest UK
C?ID=321059
"Kind of exposed??"
Did you cut them/damage them? The plastic sheath is pretty sturdy and water resistant. Did you expose the copper wire connections? Have you replaced any wires? Please could you advise if the fault happens once the sensors activate or when measuring distance.
Jamaica
No I haven't replaced any wires & the fault occurs when the front sensors are when measuring distance. Also the copper wire connections are somewhat exposed. Im planning to remove the sensor connections and clean with some contact cleaner . I ordered new sensors as well. Sigh
myounus
Northwest UK
C?ID=321059
If when measuring distance then it could be either sensor or wiring fault. Take them off and put them back on one by one and test to see if the error still happens. This way you can diagnose which sensor is faulty. Check the loom for any other breaks and wiring touching / fused together.
