Results 1 to 10 of 17
Thread: Audi S3 8V RS3 Grille Change Parking sensor Fault (What should I do?)
    New User
    Dec 2019
    Jamaica
    Exclamation Audi S3 8V RS3 Grille Change Parking sensor Fault (What should I do?)
    These are all my fault codes:
    Chasis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 22 2B 42 44 47 52 55 5F
    6C A9 BB BC
    A couple weeks after I changed the stock grille to the RS3 some rain fell and it’s been in and out since
    Should I buy a new sensor ???
    The TPMS , Traction Control & ABS Lights comes on when you start up & then it just automatically clears . Sigh its frustration can a faulty sensor cause all of this?? the problem has been intermittent, since the rain now these three lights comes up them automatically clears. HELP!!!
    Sep 2015
    Quote Originally Posted by Synonymous 8V AUDI S3 View Post
    No, they are not. That is just the gateway installation list. Please post the FULL auto-scan so that others can see what's really going on with your car...
    New User
    Dec 2019
    Jamaica
    Thanks bro posting now
    New User
    Dec 2019
    Jamaica
    Monday,02,December,2019,20:04:28:39976
    VCDS Version: 19.6.2.0 (x64)
       License Plate: ALL FAULTS
    Mileage: 36228km-22511mi   Repair Order: Johnathan
    Chassis Type: 8V-AU37 (5Q0)
              6C A9 BB BC
     Mileage: 36228km-22511miles
    Address 01: Engine (J623-CJXF)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 A    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 0A1D1032242600083004
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208V0906259A 001005
       ROD: EV_ECM20TFS0208V0906259A.rod
       VCID: 3E5DC774A1EB9DBF95-806A
    6 Faults Found:
    15240 - ECM Power Relay Control Circuit
              P0687 00 [032] - Short to Plus
    17178 - Databus
              U1123 00 [047] - Received Error Message
                        Fault Frequency: 38
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        Engine speed: 830.25 /min
                        Normed load value: 41.6 %
                        Coolant temperature: 47 °C
                        Intake air temperature: 41 °C
                        Voltage terminal 30: 13.671 V
                        Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                        Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                        Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                        Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                        Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                        Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                        Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                        Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
    21406 - EVAP Emission Control Sys
              P0441 00 [096] - Incorrect Flow
    15237 - System Voltage
              P0562 00 [032] - Too Low
    21322 - Implausible Data Received from ABS Control Module
              U0415 00 [046] - -
                        Fault Frequency: 62
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        Engine speed: 840.75 /min
                        Normed load value: 42.4 %
                        Voltage terminal 30: 13.710 V
                        Engine: operating status: IS
                        ECU_STATE: SYN_ENG_IGK_ON
                        Engine oil temperature: 46.0 °C
                        Time since engine start: 8.6 s
                        T_ES: 0 min
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        STATE_ERR_ABC_PRED: 5
    23130 - Implausible Data Received from ABS Control Module
              U0415 00 [046] - -
                        Fault Frequency: 62
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        Engine speed: 838.75 /min
                        Voltage terminal 30: 13.730 V
                        T_ES: 0 min
       Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4517
       Revision: 03253104    Serial number: TFK01501120728
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 1F631AF00621F4B7BE-804A
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 60195000001705
       Coding: 31F193A254200A6C037B070241CA698CC92A50C0E08296B7024100388208
       ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
       VCID: 48B1A1ACF32FD30F2F-801C
    11 Faults Found:
    0071 - Rear Left Wheel Speed Sensor
              C101C 4A [008] - Incorrect component(s) installed
                        Fault Frequency: 20
                        Reset counter: 204
                        Mileage: 35121 km
    0075 - Rear Left Wheel Speed Sensor
              C101C 07 [008] - Mechanical Failure
                        Fault Frequency: 7
                        Reset counter: 203
                        Mileage: 35366 km
                        Date: 2019.11.15
                        Time: 10:27:45
    0079 - Rear Left Wheel Speed Sensor
              C101C 29 [008] - Signal Implausible
                        Fault Frequency: 18
                        Reset counter: 204
                        Mileage: 35293 km
                        Date: 2019.11.06
                        Time: 19:56:28
    0297 - Steering angle sensor
              B1168 16 [008] - Voltage Too Low
                        Reset counter: 165
                        Mileage: 35378 km
                        Date: 2019.11.15
                        Time: 00:06:35
    0374 - Rear Left Wheel Speed Sensor
                        Reset counter: 204
                        Mileage: 35578 km
                        Date: 2019.11.21
                        Time: 06:10:49
    4197 - Rear Left Wheel Speed Sensor
              C101C 14 [136] - Open or Short to Ground
                        Fault Frequency: 38
                        Reset counter: 204
                        Mileage: 35378 km
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 202
                        Mileage: 26024 km
                        Date: 2019.02.19
                        Time: 18:59:59
    16412 - Display for Tire Pressure Monitoring
                        Reset counter: 165
                        Mileage: 35378 km
                        Date: 2019.11.15
                        Time: 00:06:44
    16413 - Display for Tire Pressure Monitoring
                        Reset counter: 165
                        Mileage: 35378 km
                        Date: 2019.11.15
                        Time: 00:06:44
    16417 - Display for Tire Pressure Monitoring
              C1146 02 [136] - Signal Failure
                        Fault Frequency: 35
                        Reset counter: 204
                        Mileage: 35378 km
                        Date: 2019.11.15
                        Time: 00:06:44
    32994 - Control Module for Electric Parking Brake
              C10E2 F0 [009] - RPM Sensor Implausble Signal
                        Fault Frequency: 42
                        Reset counter: 164
                        Mileage: 35378 km
       Revision: 00021000    Serial number: 0357528352
       Coding: 030C0C
       VCID: 3A55CB64BDC3B19FA9-806E
       Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
       Component: AC Automat    H13 0060
       Revision: 20027000    Serial number: 00000000546021
       Coding: 03100014110000010000000000001500
       VCID: 3245E34465B349DF61-8066
       Serial number: B3098987000000000001
       Component: BCM MQBAB H   H18 0137
       Serial number: 01011501501199
       Coding: 07151B42C04122F503804004B11807A00800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 0021798C9B9F2B4FA7-8054
       Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS371 150103  041 0585
       Serial number:         150108150816
       Coding: 0A47F7
       Serial number: 23622790
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
       Serial number: 07 11 2014  00001512
       Serial number: 000000000ZY143282LDY
       Serial number: 00000000000061431386
       Sun Roof:
       Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.404  H02 0003
       Serial number: 0000FST0001Y2TU00000
       Coding: 901E00
    204546 - Remote key 2
                        Reset counter: 72
                        Time: 00:00:00
       Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0051
       Revision: --------    Serial number: 39391500705289
       Coding: 0010150011
       VCID: 42A5B384D513F95FF1-8016
    1112369 - Front Right Center Parking Aid Sensor
              B10F9 31 [008] - No Signal
                        Reset counter: 204
                        Mileage: 36084 km
                        Date: 2019.12.01
                        Time: 12:33:58
    13637426 - Databus
                        Fault Frequency: 55
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
       Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
       Component: AirbagVW20    014 0385
       Serial number: 003MMR02UCK9
       Coding: 98CCC000000000005C54000000C800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       Subsystem 1 - Part No SW: -----------    HW: 480 001 601 15
       Serial number: 357670000006B1CC811.
       Subsystem 2 - Part No SW: -----------    HW: 480 001 601 15
       Serial number: 35867000000962CC811.
       Subsystem 3 - Part No SW: -----------    HW: 480 401 501 15
       Serial number: 35165029F196FF42034J
       Subsystem 4 - Part No SW: -----------    HW: 480 400 701 15
       Serial number: 352650299196FF64036K
       Subsystem 5 - Part No SW: -----------    HW: 480 400 411 14
       Serial number: 3556502A91860BC6322A
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 17011504400165
       Coding: A018
       ROD: EV_SMLSKLOMQB_010_AU37.rod
       VCID: 0A355BA4ADA3611FF9-805E
    No ASAM data for: "EV_SMLSKLOMQB" (AU37)
       Part No SW: 8V0 920 871 D    HW: 8V0 920 871 D
       Component: KOMBI         H02 4292
       Coding: 27AD181A2B8000080101A8001000000000000000
       VCID: 3D5FC078ACED86A78C-8068
       Revision: --------    Serial number: 19011510801193
       Coding: 0101000830085A005B0002281C0B00000001010000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72C52344A53309DFA1-8026
       Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 12 12 2014  E0046153
    8526355 - Voltage Drop in Generator Leads too large
              P30DE 00 [008] - -
                        Reset counter: 203
                        Mileage: 29568 km
                        Date: 2019.05.22
                        Time: 09:29:46
                        Supply voltage: Terminal 30: 13.2 V
                        Terminal 15: On
    Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
       Part No SW: 8V0 857 511     HW: 8V0 857 511
       Component: FLA           H03 0002
       Revision: AA001001
       Coding: 02028764747464545425363E00
       VCID: 79D71468F8457A87E0-802C
       Serial number: HA1-00027.11.14
       Coding: 0001
       VCID: 46ADAF94F93BC57FDD-8012
    16670 - All-Wheel Drive
              C1113 07 [008] - Mechanical Failure
                        Reset counter: 203
                        Mileage: 35884 km
                        Date: 2019.11.30
                        Time: 09:35:24
    16656 - Databus
                        Fault Frequency: 59
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:05
       Revision: 00000000    Serial number: 15000006284003
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3449E55C9FA747EF73-8060
    13637378 - Databus
                        Fault Frequency: 98
                        Reset counter: 204
                        Mileage: 35121 km
                        Date: 2019.11.02
                        Time: 09:19:16
                        ELV State: 02
                        Information Clamps: 00 00
                        CoCo State: 20 01
                        WFS State: 00 06
                        Vehicle speed: 0.00 km/h
                        Voltage: 6C
                        AD-Value H-bridge: 36
                        Clamp15 flip flop: SSTx: button contacts: 09
                        CAN signals: 00
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 221214BJ409083
       Coding: 005D1E205C01040000001002
       Coding: 8102
       VCID: 3753D2508ED1ACF756-8062
    19716 - Databus
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        Motor status: 02
                        System status: Driving mode
                        Supply voltage: 13.50 V
                        Temperature: 88.0 °C
                        KFC: 4D
                        KFA: 00 04
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 13.64 V
                        uAdSensI_SwitchedKl30_xdu16: 13.63 V
    20228 - Databus
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        Motor status: 02
                        KFC: 4F
                        KFA: 00 04
       Part No SW: 8V0 035 465 C    HW: 8V0 035 465
       Component: MIBAMP1ALPINE H11 0410
       Serial number: AUZ8ZAEN900Z1E9
       Coding: 01030300AAAA2AAA01
       ASAM Dataset: EV_AMPMst16C1ALPI 004024
       ROD: EV_AMPMst16C1ALPI_004_AU37.rod
       VCID: 3851D16C83CFA38F5F-806C
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 110115BAA0755A
       Coding: 005D16205E01040000001002
       VCID: 41A7BC88D015E247E8-8014
              B1487 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 200
                        Mileage: 35911 km
                        Date: 2019.11.30
                        Time: 16:02:23
       Coding: 012E000001000000
       VCID: 75CF1858D45D1EE784-8020
    13705985 - Databus
                        Fault Frequency: 62
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
       Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
       Component: MU-S--ER      041 0420
       Serial number: A3E01701151068
       Coding: 017301000000000021220002001A00002F0002260100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9EY308E1W
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
       Serial number: C1000031101400020295
    6669 - Optical Data Bus for Digital Sound System
              U10CC 00 [008] - Intermittent Disruption
                        Reset counter: 204
                        Mileage: 35627 km
                        Date: 2019.11.22
                        Time: 19:09:30
                        Voltage terminal 30: 13.7 V
                        Temperature of MOST transceiver-max.value: -50 °C
                        Temperature of MOST transceiver-min.value: 17 °C
                        Temperature of MOST transceiver-Current: 41 °C
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
       Component: MQB RVC Mid   H07 0140
       Coding: 027300010201000300
       ASAM Dataset: EV_2CamSysRearPASE 006016
       ROD: EV_2CamSysRearPASE.rod
       VCID: 3041E94C6BBF7BCF17-8064
    13705989 - Databus
                        Fault Frequency: 55
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        CAN communication
       Part No SW: 8V0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0012
       Serial number: 141212201070
       VCID: 7DDF0078EC6D46A7CC-8028
       Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
       Component: TSG HFS       020 0028
       Serial number: 080115BA715628
       Coding: 004D16204001040000001002
       Component: TSG HBFS      020 0028
       Serial number: 080115BA715354
    End-------------------------(Elapsed Time: 04:37)--------------------------
    Address 5F: DTCs cleared
    Address 6C: DTCs cleared
    Address 55: DTCs cleared
    Address 52: DTCs cleared
    Address 44: DTCs cleared
    Address 2B: DTCs cleared
    Address 22: DTCs cleared
    Address 19: DTCs cleared
    Address 10: DTCs cleared
    Address 09: DTCs cleared
    Address 03: DTCs cleared
    Address 01: DTCs cleared
    VCDS Release 19.6.2:  SRI Reset-SRI3.CLB
    Control Module Part Number: 8V0 920 871 D       Labels:  .*5G0-920-XXX-17.clb-SRI3
    Component:KOMBI         H02 4292, Coding:27AD181A2B8000080101A8001000000000000000
    Channel        Description                                                 	Current val.                                                	New val.
    IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	no warning                                                  	---
    IDE00510-ESI: distance driven from inspection                                                       	ESI: Distance since Inspection                              	3657 km                                                     	---
    IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	122 d                                                       	---
    IDE00515-ESI: oil quality        ESI: Oil Quality                                            	poor oil quality                                            	---
    IDE00517-ESI: soot entry        ESI: Soot Quantity                                          	0 km                                                        	---
    IDE00518-ESI: thermal load        ESI: Thermal Load                                           	8600 km                                                     	---
    IDE01153-SIA: maximum value of distance to service                                                  	SIA: Maximum Distance to Service                            	7500 km                                                     	---
    IDE01154-SIA: maximum value of time to service                                                      	SIA: Maximum Time to Service                                	365 d                                                       	---
    IDE03349-FIX: Max. distance until next mileage-related inspection                                   	FIX: Maximum Distance to Inspection                         	30000 km                                                    	---
    IDE03350-FIX: Maximum time until next time-dependent inspection                                     	FIX: Maximum Time to Inspection                             	730 d                                                       	---
    IDE03351-FIX: Distance covered since last mileage-dependent inspection                              	FIX: Distance since Inspection                              	10700 km                                                    	---
    IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	298 d                                                       	---
    Oct 2017
    Northwest UK
    Hi
    Please could you clear all the faults and post a new scan. This will allow us to see what faults are actually there.
    New User
    Dec 2019
    Jamaica
    That's the thing when its clears and is then scanned nothing comes up then once the front parking sensor goes and you hear that loud beep then the light blinks all these things comes up on the dash then disappears. However here it is Kindly see below.
    Monday,02,December,2019,20:03:51:39976
              6C A9 BB BC
       Revision: --H13---
    6 Faults Found:
    17178 - Databus
                        Fault Frequency: 38
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
              U0415 00 [046] - -
                        Fault Frequency: 62
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        T_ES: 0 min
              U0415 00 [046] - -
                        Fault Frequency: 62
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        T_ES: 0 min
    11 Faults Found:
                        Fault Frequency: 20
                        Reset counter: 204
                        Mileage: 35121 km
                        Fault Frequency: 7
                        Reset counter: 203
                        Mileage: 35366 km
                        Date: 2019.11.15
                        Time: 10:27:45
                        Fault Frequency: 18
                        Reset counter: 204
                        Mileage: 35293 km
                        Date: 2019.11.06
                        Time: 19:56:28
                        Reset counter: 165
                        Mileage: 35378 km
                        Date: 2019.11.15
                        Time: 00:06:35
                        Reset counter: 204
                        Mileage: 35578 km
                        Date: 2019.11.21
                        Time: 06:10:49
                        Fault Frequency: 38
                        Reset counter: 204
                        Mileage: 35378 km
              C102D 00 [008] - -
                        Reset counter: 202
                        Mileage: 26024 km
                        Date: 2019.02.19
                        Time: 18:59:59
                        Reset counter: 165
                        Mileage: 35378 km
                        Date: 2019.11.15
                        Time: 00:06:44
                        Reset counter: 165
                        Mileage: 35378 km
                        Date: 2019.11.15
                        Time: 00:06:44
                        Fault Frequency: 35
                        Reset counter: 204
                        Mileage: 35378 km
                        Date: 2019.11.15
                        Time: 00:06:44
                        Fault Frequency: 42
                        Reset counter: 164
                        Mileage: 35378 km
       Coding: 030C0C
       Coding: 0A47F7
       Coding: 00006C
       Light switch:
       Sun Roof:
       Coding: 901E00
                        Reset counter: 72
                        Time: 00:00:00
       Coding: 0010150011
                        Reset counter: 204
                        Mileage: 36084 km
                        Date: 2019.12.01
                        Time: 12:33:58
    13637426 - Databus
                        Fault Frequency: 55
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
       Coding: A018
              P30DE 00 [008] - -
                        Reset counter: 203
                        Mileage: 29568 km
                        Date: 2019.05.22
                        Time: 09:29:46
                        Terminal 15: On
       Revision: AA001001
       Coding: 0001
                        Reset counter: 203
                        Mileage: 35884 km
                        Date: 2019.11.30
                        Time: 09:35:24
    16656 - Databus
                        Fault Frequency: 59
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:05
    13637378 - Databus
                        Fault Frequency: 98
                        Reset counter: 204
                        Mileage: 35121 km
                        Date: 2019.11.02
                        Time: 09:19:16
                        ELV State: 02
                        CoCo State: 20 01
                        WFS State: 00 06
                        Voltage: 6C
                        CAN signals: 00
       Coding: 8102
    19716 - Databus
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        Motor status: 02
                        KFC: 4D
                        KFA: 00 04
    20228 - Databus
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        Motor status: 02
                        KFC: 4F
                        KFA: 00 04
                        Reset counter: 200
                        Mileage: 35911 km
                        Date: 2019.11.30
                        Time: 16:02:23
    13705985 - Databus
                        Fault Frequency: 62
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        Reset counter: 204
                        Mileage: 35627 km
                        Date: 2019.11.22
                        Time: 19:09:30
    13705989 - Databus
                        Fault Frequency: 55
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        CAN communication
  7. #7
    New User
    Dec 2019
    Jamaica
    -Could the parking sensor cause all of this ????? or could it be the brake switch sensor of speed sensor idk???????
  8. #8
    Oct 2017
    Northwest UK
    As I previously asked can you delete ALL FAULTS and run a new scan please. This will assist us to help you
  9. Likes Uwe liked this post
  10. #9
    New User
    Dec 2019
    Jamaica
    SCAN AFTER FAULT CODES WERE CLEARED
    Monday,02,December,2019,21:06:34:39976
    Dealer/Shop Name: XXXXXX XXXXXX
    Workshop Code: 123 12345 XXXXXX
    VIN: WAUZZZ8V8G100XXXX   License Plate:
              6C A9 BB BC
    VIN: WAUZZZ8V8G100XXXX   Mileage: 36228km-22511miles
       Revision: --H13---
    Readiness: 0010 0000
    21153 - Gear 1
              P072C 00 [002] - Not Selectable
    21159 - Gear R
              P072B 00 [002] - Not Selectable
    10731 - Valve 3 in Transmission Part 1
              P174A 00 [002] - Electrical malfunction
    10906 - Cooling Oil Valve
              P179D 00 [002] - Electrical Malfunction
       Coding: 030C0C
       Coding: 0A47F7
       Coding: 00006C
       Light switch:
       Sun Roof:
       Coding: 901E00
       Coding: 0010150011
       Coding: A018
       Revision: AA001001
       Coding: 0001
       Coding: 8102
    5275220 - Headlight
                        Reset counter: 164
                        Mileage: 36228 km
                        Date: 2019.12.02
                        Time: 20:30:44
    End-------------------------(Elapsed Time: 04:27)--------------------------
  11. #10
    New User
    Dec 2019
    Jamaica
    Dealer/Shop Name: XXXXX XXXX
              6C A9 BB BC
       Revision: --H13---
    6 Faults Found:
    17178 - Databus
                        Fault Frequency: 38
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
              U0415 00 [046] - -
                        Fault Frequency: 62
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        T_ES: 0 min
              U0415 00 [046] - -
                        Fault Frequency: 62
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        T_ES: 0 min
    11 Faults Found:
                        Fault Frequency: 20
                        Reset counter: 204
                        Mileage: 35121 km
                        Fault Frequency: 7
                        Reset counter: 203
                        Mileage: 35366 km
                        Date: 2019.11.15
                        Time: 10:27:45
                        Fault Frequency: 18
                        Reset counter: 204
                        Mileage: 35293 km
                        Date: 2019.11.06
                        Time: 19:56:28
                        Reset counter: 165
                        Mileage: 35378 km
                        Date: 2019.11.15
                        Time: 00:06:35
                        Reset counter: 204
                        Mileage: 35578 km
                        Date: 2019.11.21
                        Time: 06:10:49
                        Fault Frequency: 38
                        Reset counter: 204
                        Mileage: 35378 km
              C102D 00 [008] - -
                        Reset counter: 202
                        Mileage: 26024 km
                        Date: 2019.02.19
                        Time: 18:59:59
                        Reset counter: 165
                        Mileage: 35378 km
                        Date: 2019.11.15
                        Time: 00:06:44
                        Reset counter: 165
                        Mileage: 35378 km
                        Date: 2019.11.15
                        Time: 00:06:44
                        Fault Frequency: 35
                        Reset counter: 204
                        Mileage: 35378 km
                        Date: 2019.11.15
                        Time: 00:06:44
                        Fault Frequency: 42
                        Reset counter: 164
                        Mileage: 35378 km
       Coding: 030C0C
       Coding: 0A47F7
       Coding: 00006C
       Light switch:
       Sun Roof:
       Coding: 901E00
                        Reset counter: 72
                        Time: 00:00:00
       Coding: 0010150011
                        Reset counter: 204
                        Mileage: 36084 km
                        Date: 2019.12.01
                        Time: 12:33:58
    13637426 - Databus
                        Fault Frequency: 55
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
       Coding: A018
              P30DE 00 [008] - -
                        Reset counter: 203
                        Mileage: 29568 km
                        Date: 2019.05.22
                        Time: 09:29:46
                        Terminal 15: On
       Revision: AA001001
       Coding: 0001
                        Reset counter: 203
                        Mileage: 35884 km
                        Date: 2019.11.30
                        Time: 09:35:24
    16656 - Databus
                        Fault Frequency: 59
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:05
    13637378 - Databus
                        Fault Frequency: 98
                        Reset counter: 204
                        Mileage: 35121 km
                        Date: 2019.11.02
                        Time: 09:19:16
                        ELV State: 02
                        CoCo State: 20 01
                        WFS State: 00 06
                        Voltage: 6C
                        CAN signals: 00
       Coding: 8102
    19716 - Databus
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        Motor status: 02
                        KFC: 4D
                        KFA: 00 04
    20228 - Databus
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        Motor status: 02
                        KFC: 4F
                        KFA: 00 04
                        Reset counter: 200
                        Mileage: 35911 km
                        Date: 2019.11.30
                        Time: 16:02:23
    13705985 - Databus
                        Fault Frequency: 62
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        Reset counter: 204
                        Mileage: 35627 km
                        Date: 2019.11.22
                        Time: 19:09:30
    13705989 - Databus
                        Fault Frequency: 55
                        Reset counter: 204
                        Mileage: 35212 km
                        Date: 2019.11.02
                        Time: 21:03:06
                        CAN communication
