Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Audi S3 8V RS3 Grille Change Parking sensor Fault (What should I do?)
    New User
    Dec 2019
    Jamaica
    Monday,02,December,2019,21:06:34:39976
    VCDS Version: 19.6.2.0 (x64)
    Dealer/Shop Name: XXXX XXXXX
    VIN: WAUZZZ8V8G100XXXX   License Plate:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 22 2B 42 44 47 52 55 5F
              6C A9 BB BC
    VIN: WAUZZZ8V8G100XXXX   Mileage: 36228km-22511miles
    Address 01: Engine (J623-CJXF)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 A    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 0A1D1032242600083004
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208V0906259A 001005
       ROD: EV_ECM20TFS0208V0906259A.rod
       VCID: 3E5DC774A1EB9DBF95-806A
    Readiness: 0010 0000
       Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4517
       Revision: 03253104    Serial number: TFK01501120728
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 1F631AF00621F4B7BE-804A
    21153 - Gear 1
              P072C 00 [002] - Not Selectable
    21159 - Gear R
    10906 - Cooling Oil Valve
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 60195000001705
       Coding: 31F193A254200A6C037B070241CA698CC92A50C0E08296B7024100388208
       VCID: 48B1A1ACF32FD30F2F-801C
       Revision: 00021000    Serial number: 0357528352
       Coding: 030C0C
       VCID: 3A55CB64BDC3B19FA9-806E
       Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
       Component: AC Automat    H13 0060
       Revision: 20027000    Serial number: 00000000546021
       Coding: 03100014110000010000000000001500
       VCID: 3245E34465B349DF61-8066
       Serial number: B3098987000000000001
       Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
       Component: BCM MQBAB H   H18 0137
       Serial number: 01011501501199
       Coding: 07151B42C04122F503804004B11807A00800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 0021798C9B9F2B4FA7-8054
       Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS371 150103  041 0585
       Serial number:         150108150816
       Coding: 0A47F7
       Serial number: 23622790
       Coding: 00006C
       Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
       Serial number: 07 11 2014  00001512
       Serial number: 000000000ZY143282LDY
       Serial number: 00000000000061431386
       Sun Roof:
       Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.404  H02 0003
       Serial number: 0000FST0001Y2TU00000
       Coding: 901E00
       Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0051
       Revision: --------    Serial number: 39391500705289
       Coding: 0010150011
       VCID: 42A5B384D513F95FF1-8016
       Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
       Component: AirbagVW20    014 0385
       Serial number: 003MMR02UCK9
       Coding: 98CCC000000000005C54000000C800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       Subsystem 1 - Part No SW: -----------    HW: 480 001 601 15
       Serial number: 357670000006B1CC811.
       Subsystem 2 - Part No SW: -----------    HW: 480 001 601 15
       Serial number: 35867000000962CC811.
       Subsystem 3 - Part No SW: -----------    HW: 480 401 501 15
       Serial number: 35165029F196FF42034J
       Subsystem 4 - Part No SW: -----------    HW: 480 400 701 15
       Serial number: 352650299196FF64036K
       Subsystem 5 - Part No SW: -----------    HW: 480 400 411 14
       Serial number: 3556502A91860BC6322A
       Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 17011504400165
       Coding: A018
       VCID: 0A355BA4ADA3611FF9-805E
       Part No SW: 8V0 920 871 D    HW: 8V0 920 871 D
       Component: KOMBI         H02 4292
       Coding: 27AD181A2B8000080101A8001000000000000000
       VCID: 3D5FC078ACED86A78C-8068
       Revision: --------    Serial number: 19011510801193
       Coding: 0101000830085A005B0002281C0B00000001010000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72C52344A53309DFA1-8026
       Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 12 12 2014  E0046153
    Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
       Part No SW: 8V0 857 511     HW: 8V0 857 511
       Component: FLA           H03 0002
       Revision: AA001001
       Coding: 02028764747464545425363E00
       ASAM Dataset: EV_HighBeamAssisAU37X 001009
       ROD: EV_HighBeamAssisAU37X.rod
       VCID: 79D71468F8457A87E0-802C
       Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7082
       Serial number: HA1-00027.11.14
       Coding: 0001
       ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
       VCID: 46ADAF94F93BC57FDD-8012
       Revision: 00000000    Serial number: 15000006284003
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3449E55C9FA747EF73-8060
       Serial number: 221214BJ409083
       Coding: 005D1E205C01040000001002
       Coding: 8102
       VCID: 3753D2508ED1ACF756-8062
       Part No SW: 8V0 035 465 C    HW: 8V0 035 465
       Component: MIBAMP1ALPINE H11 0410
       Serial number: AUZ8ZAEN900Z1E9
       Coding: 01030300AAAA2AAA01
       VCID: 3851D16C83CFA38F5F-806C
       Serial number: 110115BAA0755A
       Coding: 005D16205E01040000001002
       VCID: 41A7BC88D015E247E8-8014
       Coding: 012E000001000000
       VCID: 75CF1858D45D1EE784-8020
    5275220 - Headlight
              C107E 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 164
                        Mileage: 36228 km
                        Date: 2019.12.02
                        Time: 20:30:44
    Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
       Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
       Component: MU-S--ER      041 0420
       Serial number: A3E01701151068
       Coding: 017301000000000021220002001A00002F0002260100010002
       ROD: EV_MUStd4CPASE_VW37.rod
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9EY308E1W
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
       Component: ControlUnit_B  H41 0054
       Serial number: C1000031101400020295
       Coding: 027300010201000300
       ROD: EV_2CamSysRearPASE.rod
       VCID: 3041E94C6BBF7BCF17-8064
       Part No SW: 8V0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0012
       Serial number: 141212201070
       VCID: 7DDF0078EC6D46A7CC-8028
       Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
       Component: TSG HFS       020 0028
       Serial number: 080115BA715628
       Coding: 004D16204001040000001002
       Component: TSG HBFS      020 0028
       Serial number: 080115BA715354
    End-------------------------(Elapsed Time: 04:27)--------------------------
  2. #12
    Oct 2017
    Northwest UK
    This is very strange as the parking sensor connections are water tight and no water ingress should cause the faults shown on the 1st scan. Does it happen as soon as the parking sensors are engaged or when they are measuring distance?
  3. #13
    New User
    Dec 2019
    Jamaica
    Well Both to be honest and the Rs3 that I bought I removed the license plate holder so the sensor wires are kind of exposed. I also have on the ecs wheel spacers kit and the car is lowered(not sure if this has anything to do with it) , but this all started when the parking sensors started going in and out.
  4. #14
    Oct 2017
    Northwest UK
    Quote Originally Posted by Synonymous 8V AUDI S3 View Post
    "Kind of exposed??"
    Did you cut them/damage them? The plastic sheath is pretty sturdy and water resistant. Did you expose the copper wire connections? Have you replaced any wires? Please could you advise if the fault happens once the sensors activate or when measuring distance.
    Thanks
  5. #15
    New User
    Dec 2019
    Jamaica
    No I haven't replaced any wires & the fault occurs when the front sensors are when measuring distance. Also the copper wire connections are somewhat exposed. Im planning to remove the sensor connections and clean with some contact cleaner . I ordered new sensors as well. Sigh
  6. #16
    Oct 2017
    Northwest UK
    If when measuring distance then it could be either sensor or wiring fault. Take them off and put them back on one by one and test to see if the error still happens. This way you can diagnose which sensor is faulty. Check the loom for any other breaks and wiring touching / fused together.
  7. Likes Uwe liked this post
  8. #17
    New User
    Dec 2019
    Jamaica
    Thanks bro will do & get back to you with the results *fingers crossed*
