Results 1 to 5 of 5
Thread: 2012 Golf R, ABS coding lost
Hybrid View
    HQ
    The original ABS module was dirty so I purchased a replacement unit and installed it. But I didn't run an Auto-Scan first thing, and I set the original ABS module on fire and then buried it in a shallow grave next to my 1st wife. Anyway, I need help coding this replacement ABS module so I can go cruising this weekend... this is the only reason I purchased VCDS. As per forum rules, here is the current Auto-Scan:
    Wednesday,04,December,2019,10:04:19:51346
    VCDS Version: 19.9.0.0 (x64)  HEX-NET CB: 0.4513.4
    VIN: WVWRF7AJ7CW226401   License Plate:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 4C 52
              55 56
    VIN: WVWRF7AJ7CW226401   Mileage: 124890km-77603miles
    4C-Tire Pressure II -- Status: Cannot be reached 1100
    Address 01: Engine (CRZ)       Labels:. 06F-907-115-CDL.clb
       Part No SW: 5K0 907 115 M    HW: 8P0 907 115 B
       Revision: 5BH20---    Serial number:
       Coding: 0403010A180F0160
       Shop #: WSC 78391 284 419398
       VCID: 342B9F9157F3FDEE6B-8060
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage - MIL ON
                        Fault Status: 11100100
                        Mileage: 124898 km
                        Load: 0.0 %
                        Temperature: 1.0C
                        Temperature: 2.0C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 11.430 V
       Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0120
       Revision: 00H35001
       Shop #: WSC 61160 002 1048576
       VCID: 76AF6599C10FAFFE95-8022
                        Fault Status: 01100101
                        Reset counter: 0
                        Mileage: 124898 km
                        Count: 16387
                        Count: 2
                        Count: 13056
                        Count: 279
                        Count: 40192
                        Count: 57024
                        Count: 21760
                        Reset counter: 0
                        Mileage: 124898 km
                        Count: 16387
                        Count: 2
                        Count: 13056
                        Count: 295
                        Count: 40192
                        Count: 57024
                        Count: 21760
                        Reset counter: 0
                        Mileage: 124898 km
                        Count: 16387
                        Count: 2
                        Count: 13056
                        Count: 270
                        Count: 40192
                        Count: 57024
                        Count: 21760
                        Fault Status: 01101100
                        Reset counter: 0
                        Mileage: 124898 km
                        Date: 2014.04.26
                        Time: 21:49:45
                        Count: 7
                        Count: 2
                        Count: 13056
                        Count: 272
                        Count: 50944
                        Count: 56832
                        Count: 21760
                        Reset counter: 218
                        Mileage: 124898 km
                        Date: 2014.04.26
                        Time: 21:49:45
                        Count: 7
                        Count: 2
                        Count: 13056
                        Count: 195
                        Count: 50944
                        Count: 56832
                        Count: 21760
    01276 - ABS Hydraulic Pump (V64)
                        Reset counter: 218
                        Mileage: 124898 km
                        Date: 2014.04.26
                        Time: 21:48:33
                        Count: 16386
                        Count: 2
                        Count: 13056
                        Count: 107
                        Count: 44288
                        Count: 56832
                        Count: 21760
       Part No SW: 5K0 959 434 B    HW: 5K0 959 434
       Revision: 00085000    Serial number: 0163656723
       Coding: 030C0C
       VCID: 342B9F919FF3FDEE6B-8060
       Part No SW: 5K0 907 044 FE    HW: 5K0 907 044 FE
       Component: Climatronic   H18 1112
       Revision: 00001004
       Coding: 0000001002
       VCID: 73A95C8DDA7DBAD6B2-8026
       Part No SW: 1K0 937 084 G    HW: 1K0 937 084 G
       Component: BCM PQ35  B   110 0651
       Revision: 00110 AC
       Coding: 77190A3FF9272A04108800C171000C6C4A650486774D8DB0E48430248040
       Shop #: WSC 12345 444 12345
       VCID: 322799896DE7F3DE79-8066
       Component: Wischer 21121  26  0512
       Coding: 009795
       Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
       Component: AirbagVW10G   013 0724
       Serial number: 003GVRA17TLG
       Coding: 00003131
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3FC1C0BDA6B52EB686-806A
       Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
       Component: BF-Gewichtss.  006 0001
       Serial number: ---0000R--00002WRX00
       Serial number: 3572MSME5F462168ZZZ/
       Serial number: 3582MSME67582268ZZZ
       Serial number: 3512QSME4619681FZZZ+
       Serial number: 3522QSME442E667BZZZ3
       Serial number: 35527SME29027129ZZZ8
       Serial number: 35627SME340F7129ZZZI
    9483008 - Seat Occupied Recognition
              B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                        Reset counter: 3
                        Mileage: 124898 km
                        Date: 2019.12.04
                        Time: 21:48:49
       Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
       Revision: FF010040    Serial number: 20111215300770
       Coding: 100A160002
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7DBD7AB5EC39FCA6D4-8028
       Subsystem 1 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H09 0013
       Coding: 820000
       Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
       Component: KOMBI         H04 0617
       Coding: 470F01
       VCID: 3833ABA1839B198E47-806C
       Part No SW: 7N0 907 530 M    HW: 1K0 907 951
       Component: J533  Gateway H42 1623
       Revision:   H42       Serial number: 191211F2002176
       Coding: 350000
       VCID: 3A37B1A9B5970B9EB1-806E
    03109 - Tire Pressure Monitoring Control Module 2 (J793)
                        Reset counter: 218
                        Mileage: 124898 km
                        Date: 2014.04.26
                        Time: 21:48:37
       Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
       Component: Haldex 4Motion      3018
       Coding: 0000005
       VCID: 45CDD2550C697466CC-8010
       Component: IMMO          H04 0617
       Coding: 000007
       VCID: 6A9741E98DB77B1E01-803E
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 11000280347002
       Coding: 0100000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E1F8DF971DFD73E1D-807A
       Revision: A1001003    Serial number: 7661503010
       Coding: 020000
       VCID: 29157EE54031B006C8-807C
       Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
       Component: RNS315-NAR    H34 0265
       Serial number: VWZAZ2M8488725
       Coding: 04050001010005000000100A
       ASAM Dataset: EV_RNS315NARV2UDS A01004
       ROD: EV_RNS315NARV2UDS.rod
       VCID: 23096CCD2A1D6A5682-8076
       Subsystem 1 - Part No: 3AA 919 866 B
       Component: NAR_V2  0002
    1048669 - Tuner for Satellite Radio
              B11CF 53 [009] - Deactivated
                        Reset counter: 184
                        Mileage: 124039 km
                        Date: 2019.10.28
                        Time: 00:06:12
    1048642 - Internal Control Module Memory Check Sum Error
              B2000 42 [009] - General memory failure
              [ECU defect data memory failure]
                        Mileage: 102618 km
                        Date: 2018.03.01
                        Time: 20:11:04
       Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
       Component: Tuer-SG         009 2103
       Coding: 0001332
       Shop #: WSC 12345 444 00000
       VCID: 3731A89D468516F64E-8062
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 251    3501
       Revision: 00H20000
       Shop #: WSC 58566 000 1048576
       VCID: 3935AEA570910086B8-806C
       Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
       Component: KonzernAmp 8K H07 0368
       Revision: --------    Serial number: EAA085A0009562
       VCID: 29157EE54831B006C8-807C
       Component: Tuer-SG         009 2117
       Coding: 0001340
       VCID: 32279989ADE7F3DE79-8066
       Coding: 1479708
       Component: AFS-Lst.-Modul l    0005
       Coding: 00000022
       Component: AFS-Lst.-Modul r    0005
       Coding: 00000022
    End----(Elapsed Time: 01:04, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
    Jef
  2. Likes Jack@European_Parts liked this post
  3. #2
    United States
    Hello Jef,
    Make sure you checked both of these folders to see if a factory condition scan was saved at any point prior to replacing the ABS module:
    C:\Ross-Tech\VCDS\Logs
    C:\Ross-Tech\VCDS\Scans
    If not, I believe the factory condition 03-ABS coding of WVWRF7AJ7CW226401 was: 144B800C49248000280F01E4921A0141B70400
    Copy and Paste that directly into the New Coding followed by clicking [Do It!] After the coding is accepted, complete the first 4 Basic Setting operations on this page before exiting the module:
    VW Golf (1K) Brake Electronics (MK60EC1)
    The Replacement section at the bottom of that page should be helpful. If you encounter difficulty please see the MK60EC1 ABS FAQ .
  4. Likes Jack@European_Parts liked this post
  5. #3
  7. #4
    I can't but help feel your pain Jef I was there myself.
    So did Dana's code function as needed?
  8. #5
    HQ
    Dana, the ABS module is coded. One quick question, real simple. In the ABS module in measuring block group 273, field 3 reads O11O1OOO when I'm driving in reverse at 3MPH, but then reads 1OO1O111 when doing 3.5MPH in reverse. On my other VW, a 1997 Golf, the ABS module doesn't have group 273. What is wrong with VCDS?
    Jef
