Results 1 to 7 of 7
Thread: Need adaptation map from Passat US with Virtual Pedal
    Jan 2017
    Portugal
    I would like to retrofit virtual pedal and would like to compare my adaptation map with one from Passat US. Passat US has PQ35 Kessy module, like my car.
    Address 05: Acc/Start Auth. (J518) Labels:* None
    Part No SW: 5K0 959 434 K HW: 5K0 959 434
    Component: VWKESSYPQ35GP 093 1403
    Revision: 00093000 Serial number: 0194946513
    Coding: 030C0C
    Shop #: WSC 12345 123 01234
    ASAM Dataset: EV_KESSYPQ35G A02721
    VCID: 3D26CF192DFDF1EFE21-8068
    Thank you
    What the heck is a "Virtual Pedal"?
    Jan 2017
    Portugal
    It's the Easy Open of boot.
    https://www.youtube.com/watch?v=f2Li28zsjKY
    To have it's necessary Kessy module with VIP.
    The car in the link has that, you can see the Slave module.
    https://forums.ross-tech.com/showthr...at-sel-premuim
    Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
    Part No SW: 5K0 959 434 F HW: 5K0 959 434
    Component: VWKESSYPQ35GP 093 1202
    Revision: 00093000 Serial number: 0402168773
    Coding: 130C0C
    Shop #: WSC 09003 957 00200
    ROD: EV_KESSYPQ35G.rod
    VCID: B875013403E15282D6-80EC
    Slave 1:
    Component: GEB.F.Heckoef H16 0811
    Serial number: 93821207
  4. Likes Uwe liked this post
    Jun 2017
    What exactly is your problem?
    Nov 2014
    New Zealand
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  7. Likes PetrolDave, DV52, m87a, Uwe liked this post
    Jan 2017
    Portugal
    I want to be prepared for Virtual pedal installation and it would be great if I could have adaptation map to compare with mine. I haven't installed the system yet, only the Kessy module with VIP.
    Apr 2019
    Quote Originally Posted by n4s View Post
    I helped my brother code his easy open(virtual pedal) system on US 2016 CC but his car uses PQ47 Kessy Module.
    All we had to do is change byte21 value from hex24 to hex37(binary 00110111). There was no Long Coding helper for it.
    Here is 46 module with the change
    Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
       Part No SW: 3AA 959 799 G    HW: 3AA 959 799 G
       Component:    KESSY PQ47   091 0414
       Revision: 00091000    Serial number: VWZCZ000000000
       Coding: 1B910F8001860E7E1202143FF08A8F0E10780203043798
       Shop #: WSC 05311 123 08193
       VCID: 4CC164057AC3DA4765F-8018
       Subsystem 4 - Part No: 3AA 962 243 D
       Component: GEB.F.Heckoef       0811
    I also retrofired easy open on a MQB Tiguan. I wrote DYI for it here:
    https://forums.ross-tech.com/showthr...ight=easy+open
    Sorry dont know much about PQ35 systems
