Results 11 to 20 of 23
Thread: 03 Brake Security Access Code needed
    There are some measuring values related to the steering angle sensor in that ABS, but nothing in terms of Adaptations or Basic Settings.
  2. Likes AudiA32016 liked this post
  3. #12
    Nov 2019
    I just went through my logs, and I'm pretty sure it was the 44 factory reset that screwed up everything, my first scan from 11/9 shows no fault. Only 44 steering fault. It was after I did the factory reset that all these extra faults came about everywhere.
    Then I finally fixed my original problem in steering 44 and have these other things still lingering here.
    I only got rid of 44 steering and backup camera faults I think.
    I dunno am I screwed?
    Should I post my scan from 11/9 that shows much less faults?
    Actually many of these faults are low priority to me, like the sat radio tuner, and park steering assist my car never had. So yea some of these things my car doesn't have and the error is just being disabled or whatever.
    I'm just trying to work from most important first and I think I want to solve this abs and engine faults. They bother me a little more.
    The airbag one is same but my car has a recall for faulty passenger airbag connector anyways.
    It works fine right now and I'm not bringing it to the dealer.
    And again I have zero dash lights coming on, no warnings, no nothing on screen.
  4. #13
    Nov 2019
    Here is today's scan, but it was scanned before I cleared faults, I need to drive it again and scan again to see if they return, but it's raining hard right now.
    I noticed the 55 headlight range returned to OK, it had a fault before I believe
    I went and cleared the codes from all modules, when I got to 03 Brakes they all cleared but 1 fault instantly returned, a databus or message error.
    The one tiny positive thing from this ordeal is that I believe I fixed my rain sensor, it never worked from brand new, I think the reset to factory made it work, just noticed today.
    Wednesday,04,December,2019,17:10:11:63944
    VIN:    License Plate:
    Mileage: 27336km-16985mi   Repair Order:
    Chassis Type: FF-AU37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F 6C BB BC
    VIN:    Mileage: 27336km-16985miles
    Address 01: Engine (J623-CNSB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0004
       Revision: --H13---
       Coding: 0A1D00122424000F2000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM18TFS0208V0906264F 001004
       ROD: EV_ECM18TFS0208V0906264F.rod
       VCID: 3FDB448E07F2207FF0D-806A
    17178 - Databus
              U1123 00 [040] - Received Error Message
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:49
                        Engine speed: 694.75 /min
                        Normed load value: 27.5 %
                        Coolant temperature: 100 °C
                        Intake air temperature: 39 °C
                        Voltage terminal 30: 14.023 V
                        Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                        Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                        Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                        Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                        Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                        Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                        Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                        Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
    Readiness: 0010 0101
       Part No SW: 0D9 300 042 C    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4907
       Revision: 06253104    Serial number: TFK01511142120
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 196FCA16B9162E4F2E9-804C
       Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
       Component: ESC           H42 0623
       Revision: 00000000    Serial number: 63215000001376
       Coding: 13FF6A9234260A74017C020681C929C8562C5080408194B4024100548208
       ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
       VCID: 79AFEA965956CE4F8E9-802C
    0295 - Steering angle sensor
              B1168 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:49
    0297 - Steering angle sensor
              B1168 16 [008] - Voltage Too Low
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:49
    8277 - Databus
              U1122 00 [009] - Implausible Message
              [FCAN: EPS_DSR_Status signal is invalid]
                        Reset counter: 30
                        Date: 2019.12.03
                        Time: 14:12:22
    16412 - Display for Tire Pressure Monitoring
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:59
    16413 - Display for Tire Pressure Monitoring
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:59
       Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
       Component: AC Automat    H14 0060
       Revision: 20028000    Serial number: 00000000804853
       Coding: 03000014010000000000000000001400
       VCID: 323D1DBAC4A0FD170F3-8066
       Serial number: 2C084AD7000000000001
       Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
       Component: BCM MQBAB MNA H24 0175
       Serial number: 01061533101029
       Coding: 04141A42C04122F541C04004511007000000000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 7F5B048E4772E07FB0D-802A
       Component: WWS371 151106  043 0585
       Serial number:         151118183555
       Coding: 0A47F7
       Serial number: 60999007
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
       Serial number: 17 09 2015  00001675
       Component: Sirene, DWA  005 0312
       Serial number: 00000000000034027844
       Sun Roof:
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST000ON2ER00000
       Coding: 101F00
       Revision: --------    Serial number: 39391533008979
       Coding: 0010150011
       VCID: 43D3487E6B1A449F945-8016
    13637426 - Databus
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:49
       Serial number: 003GCR044M24
       Coding: 9DCCFCC0000000005000001AC24800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CB5C6E5F2268BF48D-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34230167A30111541026
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34230168A30111551108
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001F0WAY
       Coding: 303332
       Subsystem 4 - Part No SW: -----------    HW: 480 000 411 15
       Serial number: 357000000001C599371J
       Subsystem 5 - Part No SW: -----------    HW: 480 000 411 15
       Serial number: 358000000004D84C971V
       Subsystem 6 - Part No SW: -----------    HW: 480 401 711 15
       Serial number: 3510002991E34431513P
       Subsystem 7 - Part No SW: -----------    HW: 480 402 411 15
       Serial number: 35200029B1E2431592B+
       Subsystem 8 - Part No SW: -----------    HW: 480 401 509 15
       Serial number: 3550002A31CB0C21A3C6
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 401 509 15
       Serial number: 3560002A31CB0C23D10+
    1050117 - Databus
              [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:49
       Part No SW: 8V0 953 521 EP    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 26111504220022
       Coding: A018
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 0C41A34206C4CBE7A5F-8058
       Part No SW: 8V0 920 960 M    HW: 8V0 920 960 M
       Component: KOMBI         H03 6423
       Coding: 0BF419092B80D7050200A8001800000000000000
       VCID: 45D75666652E7AAFBA1-8010
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 24111510520552
       Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
       ROD: EV_GatewConti_013.rod
       Serial number: 23 11 2015  F0068820
       Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
       Serial number: 171015BJH0224A
       Coding: 00100B204000048000000002
       VCID: 41DF42767106568F869-8014
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 0002
       VCID: 44D14B626E1443A7ADF-8010
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 111015BJA06092
       Coding: 001003204000048000000002
       VCID: 40D947727A0C5F87897-8014
       Coding: 011A000101000000
       VCID: 75B7E6A6754EAA2FEA1-8020
       Part No SW: 8V0 035 844 C    HW: 8V0 035 844
       Component: MU-S-S-US     014 0660
       Serial number: A7A00112150557
       Coding: 01730100FF0A000011220001001A00002F0001440100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE.rod
       VCID: 392F2A9619D60E4FCE9-806C
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9FY30EKHH
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Serial number: C1000007101500030138
              B11CF 53 [009] - Deactivated
                        Reset counter: 30
                        Mileage: 27288 km
                        Date: 2019.12.03
                        Time: 14:10:55
                        Voltage terminal 30: 12.0 V
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
       Component: MQB RVC Mid   H07 0140
       Coding: 027300010201000300
       ASAM Dataset: EV_2CamSysRearPASE 006016
       ROD: EV_2CamSysRearPASE.rod
       VCID: 303917B2CAACCF07797-8064
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 071115BK70245C
       Coding: 000003204000048000000002
       Serial number: 071115BK702741
    End----------(Elapsed Time: 01:33, VBatt start/end: 12.3V/12.3V)-----------
    Address 10: DTCs cleared
                    Address 03: ABS Brakes       Labels: 5Q0-907-379-IPB-V1.clb
    Control Module Part Number: 3Q0 907 379 AA    HW: 3Q0 907 379 F
      Component and/or Version: ESC           H42 0623
               Software Coding: 13FF6A9234260A74017C020681C929C8562C5080408194B4024100548208
                Work Shop Code: WSC 06385 790 00016
                  ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036 (AU37)
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:49
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:49
    8277 - Databus
                        Reset counter: 30
                        Date: 2019.12.03
                        Time: 14:12:22
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:59
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:59
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:49
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:49
    8277 - Databus
                        Reset counter: 30
                        Date: 2019.12.03
                        Time: 14:12:22
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:59
                        Reset counter: 71
                        Mileage: 27291 km
                        Date: 2019.12.03
                        Time: 16:38:59
    Address 03: DTCs cleared
    Address 01: DTCs cleared
    Address 15: DTCs cleared
    Address 5F: DTCs cleared
    I also poked around 03 ABS Basic settings and there is no G85/SAS option there. So I'm stumped if this fault returns.
  5. #14
    Nov 2019
    Ok so I think most of them are gone but I barely drove the car and there is still a pesky ABS message databus error.
    Friday,06,December,2019,16:46:46:63944
    VIN:    License Plate:
    Mileage: 27357km-16998mi   Repair Order:
    VIN:    Mileage: 27357km-16998miles
       Revision: --H13---
    8277 - Databus
                        Reset counter: 32
                        Date: 2019.12.04
                        Time: 17:19:31
       Coding: 0A47F7
       Coding: 00006C
       Light switch:
       Sun Roof:
       Coding: 101F00
       Coding: 0010150011
       Coding: 333135
       Coding: 333135
       Occupant Detection:
       Coding: 303332
       Coding: A018
       Coding: 0002
                        Reset counter: 32
                        Mileage: 27336 km
                        Date: 2019.12.04
                        Time: 17:22:46
                        Voltage terminal 30: 12.2 V
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.3V/12.3V)-----------
    8277 - Databus
                        Reset counter: 32
                        Date: 2019.12.04
                        Time: 17:19:31
    8277 - Databus
                        Reset counter: 32
                        Date: 2019.12.04
                        Time: 17:19:31
    So yea most of the codes didn't return, thanks for the tip. But this ABS error is still bothering me.
    The 5F information electronics doesn't bother me too much as I don't subscribe to sat radio.
    Maybe if I fix the ABS I can come back to focus on it but it's really not something I'd cry about if I never fixed it.
    I guess I might have to wait until they figure out more about the ABS security codes, I have a feeling I might need to do something in there in order for the fault to disappear.
    It always returns instantly when I try to clear the ABS code.
    Not too bad overall now though eh? haha it was so messed up before lol.
    https://www.golfmk7.com/forums/index...isable.359687/
    I found this on a forum, but I'm not sure what DSR means, I assume it's something related to ESC or electric steering....
    And they never found a solution it seems.
    But the issue seems identical to mine....even the 5F fault sat radio is the same.
    They don't know how it happened on their cars. They were poking around I guess.
    Oh wait on the first post "When I clear the code, it immediately comes back. When I reactivate DSR and clear the code, it goes away and never comes back. So I assume it has something to do with ABS brake module, ESP and DSR not playing well together when it is disabled. I have seen a couple people disable DSR on the forum, but no one mentions this? Anyone else seeing this code?"
    So he says when he "reactivates DSR and clear the code, it goes away and never come back".
    So my question is, What is DSR? And Where do I go in VCDS to mess with it or activate it? I suppose its supposed to be activated? Maybe it got deactivated when I did the factory to reset?
    Edit:
    https://www.audiworld.com/forums/q5-...sable-2896894/
    So I found this that explains DSR, and most people prefer it turned off it seems.
    However I need to know how to turn it on and off if it can clear my fault code.
  6. #15
    There's only one way to get rid of "Tuner for Satellite Radio -- Deactivated" and that is to activate it, i.e. buy a subscription.
    I would guess that DSR = Driver Steering Recommendation. As to why your ABS thinks it's getting an implausible message, I don't know.
  7. #16
    Nov 2019
    I found the instructions. For a different model I think. But it says 2013 and newer with electric steering.
    44 steering assist
    coding
    long coding
    byte 0
    bit 4
    (uncheck box for Driver Steering Recommendation)
    That's what it says on audizine, I guess I'll have a look, if it's a part of steering 44, then maybe it got messed with with factory reset.
  8. #17
    On your car, Driver Steering Recommendation should be in 44's coding, Byte 0, Bit 0. However, it's already Off...
  9. #18
    Feb 2018
    SLC
    If I were to hazard a guess, and it is most definitely a guess, there is a bit in you ABS Module (Byte 23, Bit 7) that I have seen labelled as "DSR", That might be where the error is coming from.
    You can try deselecting that bit, clearing codes in the ABS module, and see if that solves your issue.
    If you are curious about the MK100 ABS controller's Bits and Bytes >>MK100 ABS Coding (Google Drive)<< NOT 100% ACCURATE, INFORMATION ONLY
  10. Likes Uwe liked this post
  11. #19
    Feb 2018
    SLC
    As an addendum to my post above^^^:
    I took a look at my own vehicle and found that Byte 23 Bit 7 is unrelated to that error message. The DSR fault shows up even if that bit is deselected.
    On the bright side, now we know!
  12. Likes Uwe, Jack@European_Parts liked this post
  13. #20
    Nov 2019
    A3 201
    This is correct, I finally got around to doing this because I couldn't align my car properly.
    So this is full instructions for activating/deactivating Driver Steering Recommendation on Audi A3 2016 (8V)
    1. Put in Security Code for coding
    The one provided by the helper balloon for coding 28183 I think....
    2. Go to Coding
    3. Window pops up with current code to save, write it down or save it
    4. DSR is the first code in hex 00 is off and 01 is turned on
    There is helper box for the coding to just intuitively click it on and when you close window it will input the hex code for you
    5. Press Do it!
    Should say Code accepted
    DONE
    I left it off because I read a lot of reviews raving about it. But personally.... I think it's a bad idea to turn it off.
    It turned itself off when I did the reset to factory and I left it off because I assumed people knew what they were talking about and all saying its superior....but I disagree, I like it turned on, I think it literally changes the alignment somehow....
  14. Likes Jack@European_Parts liked this post
