I am trying to access module 1 - Engine in a 2019 VW Tiguan, but I received a message "No Coding Information is Available for this ECU":
Please find below an Auto-Scan:
Tuesday,03,December,2019,16:56:50:38818
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: 3VVHJ65N4KM000000 License Plate:
Mileage: 4160km-2584mi Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 08 09 10 15 17 19 20 29 36 39 42 44 4B 52 5F 65 CA
D6 D7
VIN: 3VVHJ65N4KM000000 Mileage: 4160km-2584miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWLA) Labels: None
Part No SW: 04E 906 027 MB HW: 04E 907 309 BP
Component: R4 1.4l TFS H23 4859
Revision: RDH23---
Coding: 011D003223241D002000
Shop #: WSC 00066 790 00454
ASAM Dataset: EV_ECM14TFS01104E906027MB 001004
ROD: EV_ECM14TFS01104E906027MB.rod
VCID: 70AC2B8BAB34B1CF57-8024
Part No SW: 0D9 300 043 HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5202
Revision: 06454104 Serial number: TFK01811261071
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 57FE70172E9AC6F7B6-8002
P1734 00 [002] - -
Part No SW: 5Q0 614 517 EH HW: 5Q0 614 517 BR
Component: ESC H82 0107
Revision: 00000000 Serial number: 50859000000322
Coding: 0BEE6B9A40241B6C4779060662CB49D0D602D8E2604692712022500852024A0B00002764121A1C230A35351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 7BB60CA7F272C297F2-802E
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NA 907 044 R HW: 5NA 907 044 R
Component: AC Automat H35 4401
Revision: 20K03000 Serial number: 00000D00347385
Coding: 0002002420010001100510000010142A
ASAM Dataset: EV_ACClimaPrehVW37X 002025
ROD: EV_ACClimaPrehVW37X.rod
VCID: 4ED095731140873F65-801A
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
Part No SW: 5Q0 937 086 BQ HW: 5Q0 937 086 BQ
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: C864120419045I
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 0A585963ADA8EB1FF9-805E
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 190201 034 0373
Serial number: 19013021081630
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SBY19M02D27H10M26S24
Coding: 00A8EE
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY190430S1U
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000046612817
Steering Column Switch:
Subsystem 6 - Part No SW: 5Q1 953 521 HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0300150420190C200499
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Serial number: 000137088R19105
Coding: 0471151011
Shop #: WSC 00066 790 00440
VCID: 4CD49F7BE75CB52F0B-8018
Part No SW: 5Q0 959 655 BR HW: 5Q0 959 655 BR
Component: AirbagVW21 006 0403
Serial number: 003FLM00KSBY
Coding: 88CCC000000000005C0000CF000800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 116A4E0FC0FED8C738-8044
Subsystem 1 - Part No SW: ----------- HW: 480 001 802 19
Serial number: 357000000000410DC93E
Subsystem 2 - Part No SW: ----------- HW: 480 000 403 19
Serial number: 35800000000FC07D693
Subsystem 3 - Part No SW: ----------- HW: 480 400 901 19
Component: SideSensor_Dr 003 6149
Serial number: 3510001BD2E6FB15274F
Subsystem 4 - Part No SW: ----------- HW: 480 400 901 19
Component: SideSensor_Pr 004 6149
Serial number: 3520001102BFA0C4649%
Subsystem 5 - Part No SW: ----------- HW: 480 401 403 19
Component: FrontSensor_D 003 6149
Serial number: 35500019B2F282B37176
Part No SW: 5NA 920 750 C HW: 5NA 920 750 C
Component: KOMBI 350 2700
Coding: 07A509882A80000801086B041401000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
VCID: 3E30C5B3A1E017BF95-806A
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 06041900841945
Coding: 030100047F085708FA00024A180F00010001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 6E9035F3B100A73F45-803A
Component: 0-01-13-01-04
Subsystem 2 - Part No SW: 5NA 959 442 A HW: 5NA 959 442 A
Component: E221__MFL-TAT H06 0025
Serial number: 0661904524300501FD2B
Coding: 290000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 6022346500
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 3G0 857 511 AE HW: 3G0 857 511 AE
Component: FLA H10 0003
Revision: AA001001
Coding: 040400EA00000000000000
ASAM Dataset: EV_HighBeamAssisAU33X 001017
ROD: EV_HighBeamAssisAU33X_VW37.rod
VCID: 6B963CE78212521762-803E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
VCID: 45C2AA5FC4364467D4-8010
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0024
Serial number: Y0006SA437394
Coding: 0010000000000500018280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
VCID: 3D32C2BFACE60CA78C-8068
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Part No SW: 5Q4 959 593 M HW: 5Q4 959 593 F
Component: TSG FS 006 0247
Serial number: 42038909902902
Coding: 00310220D200048000001000
VCID: 4FEE8877164A8E376E-801A
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000002141386
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 173 1081
Coding: 011F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 50EC8B0B0B7491CF77-8004
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 15041900840998
Coding: 0000000509001D4A00000F01020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 3522DA9F94D6D4E744-8060
Part No SW: 5Q4 959 592 M HW: 5Q4 959 592 F
Component: TSG BFS 006 0247
Serial number: 46038909200495
Coding: 00310020DE00048000001000
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000002154923
Coding: 090000
Part No SW: 3Q0 035 846 B HW: 3Q0 035 846 B
Component: MU-S-N-ER 853 0890
Coding: 02730603FF00000051220001001828001F0500D401200500CF
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 302CEB8B6BB4F1CF17-8064
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav 252 8130
Serial number: VWZ6ZMW1065238
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000270391
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3424E79B9FACCDEF73-8060
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 40804073260C
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75A21A9FD45694E784-8020
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7P5 941 572 AG HW: 7P5 941 572 A
Component: LED1L H07 0008
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 004C7B4B9B94A14FA7-8054
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H07 0008
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:32, VBatt start/end: 12.4V/12.4V)-----------
