Results 1 to 10 of 14
Thread: 2012 Passat 3C Cruise Control
    Nov 2019
    Czech Republic
    I Have following trouble with my Passat. If I want to activate cruise controll, it's only posible on first and second gear. Till reaching roughly 30km/h. Then it's not possible. I changed the hall sensor on main clutch cylinder, because there were fault code in memory. I tried also to uncode cruise controll and then code it again, but it also didn't help. I also find out, that the gear indicator don't work very well. It shows only first and second gear on low speed. On higher gears/speed it sometimes appears and then disappears. I think it has something to do with cruise controll, but I have no idae how to solve it.
    Nov 2019
    Czech Republic
    So I'm here again with correct vvcds device.
    In the meantime I realized, that sw of car do not correspond with my transmission. Do you have any ideas what to do with it?
    You maybe also realized, I'm using Hexnet in infrastructure mode. Every time I want to do the autoscan it gives me error message about ASAM files. I tried download it several times in both channels. Do you have any idea, what I did wrong?
    And Also I'm not able to view or email the log. Only opportunity I have is to sync it to cloud.
    #hndoc:?docid=00005703&xt=hnh:C313101A72CFD8136FF55F67E1EAFFD72CBDA6C7783FEDC596B6E95419A2D6A3
    VCDS Mobile 0.4513.0.4
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 56 62 72
    08-Auto HVAC -- Status: OK 16000
    09-Cent. Elect. -- Status: OK 16000
    16-Steering wheel -- Status: OK 16000
    17-Instruments -- Status: OK 16000
    25-Immobilizer -- Status: Malfunction 16010
    42-Door Elect, Driver -- Status: OK 16000
    46-Central Conv. -- Status: OK 16000
    52-Door Elect, Pass. -- Status: OK 16000
    62-Door, Rear Left -- Status: OK 16000
    72-Door, Rear Right -- Status: OK 16000
    Address 01: Engine  (CAXA J623)	Labels: 03C-906-016-CAX2.clb
    	Part No SW: 03C 906 016 DK	HW: 03C 907 309 E
    	Component: 1.4l R4 TSI   H15 4771
    	Revision: L5H15---
    	Coding: 00190012002400000000
    	Shop #: WSC 50202 136 100326
    	ASAM Dataset: EV_ECM14TFS01103C906016DK 001004
    	ROD: N/A
    	VCID: 6B9954AF2FEE78538D203D-803E
    	No ASAM data for: "EV_ECM14TFS01103C906016DK"
    No fault codes found.
    Address 03: ABS Brakes	Labels: 3AA-614-109.clb
    	Part No SW: 3AA 614 109 AB	HW: 3AA614109AB
    	Component: J104   C2 450M V486  0022
    	Revision: --H07---	Serial Number: 00000004697964
    	Coding: 0000360
    	Shop #: WSC 05311 000 00000
    	VCID: 6D9D5AB711FAEE63935413-8038
    Address 08: Auto HVAC  (J301)	Labels: 3C8-907-336.clb
    	Part No SW: 7N0 907 426 AM	HW: 7N0 907 426 AM
    	Component: AC Manuell    H19 0304
    	Revision: 00001016
    	Coding: 0000004002
    	Shop #: WSC 00015 115 00000
    	ROD: N/A
    	VCID: 7F4190FF4B96F4F331E8D9-802A
    	No ASAM data for: "EV_ACManueBHBVW36X"
    Address 09: Cent. Elect.  (J519)	Labels: 3AA-937-087.clb
    	Part No SW: 3AA 937 087 C	HW: 3AA 937 087 C
    	Component: BCM PQ47 M    413 0455
    	Revision: BA413001
    	Coding: 000000000000000000180280100000E403016688424D8960648040200040
    	Shop #: WSC 62492 001 1048576
    	VCID: 3A37A1EB103409DB465620-806F
    	Subsystem 1 - 	Part No SW: 3AB-955-419	Labels: 1Kx-955-119.clb
    	Component: Wischer 0108110  0603
    	Coding: 00B795
    Address 15: Airbags	Labels: 5N0-959-655.lbl
    	Part No SW: 5N0 959 655 R	HW: 5N0959655R
    	Component: J234__101 VW10 HI    1918
    	Revision: 22014000	Serial Number: 003K0PJGQPUZ
    	Coding: 0012337
    	VCID: 4CDBF7334AA0076BE4EAE6-8019
    	Subsystem 1 - 	Serial Number: 6332MTS644252341
    	Subsystem 2 - 	Serial Number: 6342MTS649822271
    	Subsystem 3 - 	Serial Number: 6351HTS6VJ2SDAKJ
    	Subsystem 4 - 	Serial Number: 6361HTS66O86DAKR
    	Subsystem 5 - 	Serial Number: 00000000000000000
    	Subsystem 6 - 	Serial Number: 00000000000000000
    Address 16: Steering wheel  (J527)	Labels: 3C-16.lbl
    	Part No SW: 3C9 953 501 BP	HW: 5K0 953 569 AA
    	Revision: FF010040
    	Coding: 5180250000
    	ROD: N/A
    	VCID: 78B37BE36EB8C3CB70A28A-802D
    	No ASAM data for: "EV_VW360SteerWheelUDS"
    Address 17: Instruments  (J285)	Labels: 3C8-920-xxx-17.clb
    	Part No SW: 3AA 920 870 C	HW: 3AA 920 870 C
    	Coding: 161F00
    	Shop #: WSC 66222 181 00000
    	ROD: N/A
    	VCID: 322789CBC844E99B8EE688-8067
    	No ASAM data for: "EV_Kombi_UDS_VDD_RM09"
    Address 19: CAN Gateway  (J533)	Labels: 7N0-907-530-V2.clb
    	Part No SW: 7N0 907 530 K	HW: 1K0 907 951
    	Component: J533  Gateway H40 1620
    	Revision:   H40
    	Coding: 462006
    	Shop #: WSC 00000 848 1059554
    	VCID: 3833BBE32E381BCBB022CA-806D
    Address 25: Immobilizer	Labels: 3C0-959-433-25.clb
    	Part No SW: 3AA 959 433	HW: 3AA959433
    	Component:    IMMO         043  0400
    	Revision: 00043000	Serial Number: VWZCZ000000000
    	VCID: F6AFF5DBE4ACADBBE28E34-80A3
    	Subsystem 1 - 	Part No SW: 3C0-905-861-J
    	Component:    ELV          029  0380
    02861 - Electronic Steering Column Lock Check Sum Error
    Address 42: Door Elect, Driver  (J386)	Labels: 3C0-959-70X-GEN4.clb
    	Part No SW: 3AA 959 701	HW: 3C0 959 793 B
    	Component: TUER-SG FT    002 0533
    	Revision: 13110009
    	Coding: 0000B5
    	Shop #: WSC 05311 115 00000
    	ROD: N/A
    	VCID: F4ABCFD3F2D027ABDC9ADE-80A1
    	No ASAM data for: "EV_TSGFPQ35BRFVW46X"
    Address 44: Steering Assist	Labels: 5N1-909-144.clb
    	Part No SW: 5N1 909 144 M	HW: 5N1909148G
    	Component: J500__APA-BS KL.308  1002
    	Revision: 1AH03733	Serial Number: 00112420089601
    	Coding: 0000258
    	VCID: 3C3BA7F31A00B7EB544A36-8069
    Address 46: Central Conv.	Labels: 3C0-959-433-46.clb
    	Component:    KSG PQ47 ELV 043  0634
    	Coding: 0091020052830E763004941570084F0B607C01
    	Subsystem 1 - 	Component:   Sounder n.mounted
    	Subsystem 2 - 	Component:       NGS n.mounted
    	Subsystem 3 - 	Component:      IRUE n.mounted
    Address 4F: Centr. Electr. II  (J520)	Labels: 1K0-907-532.clb
    	Part No SW: 7N0 907 532	HW: 1K0 907 951
    	Component: EZE_2         H40 1620
    	Revision:   H40
    	Coding: 00000008
    	VCID: EFA1C0BF9BF61C732148E9-80BA
    	Subsystem 1 - 	Part No SW: 3AA-919-204-A
    	Component: Analoguhr    004 0003
    Address 52: Door Elect, Pass.  (J387)	Labels: 3C0-959-70X-GEN4.clb
    	Part No SW: 3AA 959 702	HW: 3C0 959 792 B
    	Component: TUER-SG BT    002 0533
    	Revision: 15110009
    	Coding: 0000B4
    	ROD: N/A
    	VCID: F5ADF2D7F9AA3EA3EB842B-80A0
    	No ASAM data for: "EV_TSGBPQ35BRFVW46X"
    Address 53: Parking Brake	Labels: 3AA-907-801.clb
    	Part No SW: 3AA 907 801 G	HW: 3AA907801G
    	Component: J540 EPB4  VW-64783  0009
    	Revision:   H19   	Serial Number: 00000000224557
    	Coding: 0022157
    	VCID: 352DB2D7392A66A3AB04EB-8060
    Address 56: Radio  (J503)	Labels: 5M0-035-1xx-56.clb
    	Part No SW: 5K0 035 156 A	HW: 5K0 035 156 A
    	Component: Radio         553 0555
    	Revision: R0553006
    	Coding: 0100020002
    	Shop #: WSC 05314 000 00000
    	VCID: 250D6297898A96231B643B-8070
    End--(Elapsed Time: 01:37, VBatt start/end: 11.7/11.7 Vign: 0.0)-
  3. Likes Uwe, Dana liked this post
    For any problem(s) with the car: Use VCDS rather than VCDS-Mobile to get us a scan.
    What kind of transmission does this car have? The CAN gatewaty doesn't seem to think it has one either.
    Issues with VCDS-Mobile should be taken up in a separate thread here.
  5. Likes AIB Wolfgang liked this post
  6. #4
    Nov 2016
    Replaced your gearbox at some point?
  7. Likes AIB Wolfgang liked this post
  8. #5
    Jul 2014
    Tallinn, Estonia
    If no gearbox in scan, then its usually a manual box
    Factory gearbox code (3 letters) can be found from the vehicle data sheet near spare wheel in trunk and beginning of service handbook. The 1.4 TSI on RoW Passat B7 should have one of the following 6-speed manual boxes: LHY, LNY, NBW, NBX, PRG or PRJ. Check on the gearbox case between the selector tower and engine block which gearbox code you have. If it's not one of them, someone has probably fitted a wrong box for this vehicle.
  9. Likes AIB Wolfgang liked this post
  10. #6
    Nov 2019
    Czech Republic
    It's manual. And the thing is i bought this car as is with changed transmission. The original one should be NBW. On the housing there is this code brushed away. Is there any opportunity to fix that? My idea was to try in software of the car change the gear ratios, but I don't know if this is possible/how it works.
    I will try to explain its behavior. On first and second gear it works normal. On third and higher it behaves like when I depress accelerator it shows me the gear in gear indicator, but when I press it it disappears. It makes me think, that the gar ratio is slightly different than the sw data.
  11. #7
    Remove FOD, replace with factory configuration parts, problem solved!
  12. Likes AIB Wolfgang liked this post
  13. #8
    United States
    Although the gear ratio and speedometer accuracy shouldn't be ruled out I would also want to log wheel speed data in 03-ABS. The VSS (vehicle speed sensor/speedometer) should be calculated based on wheel speed data from 03 so a rusted wheel bearing or flaky WSS might be responsible (and unrelated to the trans swap).
  14. Likes Jack@European_Parts liked this post
  15. #9
    Nov 2019
    Czech Republic
    Dana: Thank you for your reply. I didn't tried exactly this method. I don't have the car with me right now. I had it in car service and they agreed it!s problem of sw of car.
    Is there anybody, who can advise me, how to modify the sw of the car to have properly working cruise control?
  16. #10
    Jul 2014
    Tallinn, Estonia
    Perhaps first step is to find out from which donor car the gearbox is from and/or the gearbox code, in order to find out it's gear ratios. If the markings on the bell housing are ground down, then perhaps the other markings aren't? See picture...
    Alternative method to get an idea of ratios is to tell us how many rpm-s are in 6th gear at 90kmh?
  17. Likes MartinVW liked this post
