2012 NMS Passat SEL VR6 Premium Climatronic issues
dingram01
C?ID=387453
Hello everybody,
After many years of hearing about VCDS, I finally have a (new to me) 2012 Passat NMS SEL VR6. First a bit of history: the car has 160k on the clock and was decently maintained (and absolutely beautifully cleaned and waxed regularly) by the prior owner, who had it since new. I took possession of the car a few weeks ago, and quickly noticed the heater output was middling, with different temps on driver and passenger sides.
This is the dual-zone Climatronic.
At the time I hadn't gotten my VCDS yet, but found many posts about clogged heater cores and the relatively easy replacement. So, I ordered a new core and went about installing it. Long story short, I botched it and mangled the heater pipes, so I wound up removing the instrument panel. Out came the air distribution box so I could replace the metal lines, and I put it all together again to find...the same tepid heat!
I'm satisfied that the core is working fine -- both pipes are HOT to the touch, with no detectable difference between them. Coolant level is stable, so I don't think it's air bound.
So, after the work, the performance is the same as it was. I don't think it's changed by the work I did.
Finally got my VCDS last week, and got the codes from the car. There were a number of codes initially, mostly related to the car's confusion after the work I did. I cleared all codes first, then re-ran the Auto-Scan several times. Here's what I'm left with now:
Thursday,28,November,2019,08:41:10:64803
VIN: 1VWCM7A34CC011330   License Plate:
Mileage: 255160km-158549mi   Repair Order: scan2
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
VIN: 1VWCM7A34CC011330   Mileage: 255160km-158549miles
Address 01: Engine (0-32-CDVB)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 023 BF    HW: 03H 907 309 A
   Component: VR6 3.6l FSI  H03 9259
   Revision: MFH03---    Serial number:
   Coding: 001D0012242400008000
   Shop #: WSC 08083 444 00000
   ASAM Dataset: EV_ECM36FSI01103H906023BF 002006
   ROD: EV_ECM36FSI01103H906023BF.rod
   VCID: 678BBC16DFE2060F68D-8032
4344 - Please Check Fault Codes in Control Module for HVAC (J301)
          U1025 00 [039] - -
          [A/C control moduleRead out DTC]
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:49
                    Coolant temperature: 12 ∞C
                    Intake air temperature: 15 ∞C
                    Voltage terminal 30: 11.638 V
                    Median injection timing: 0.000 ms
Readiness: 1110 0101
   Part No SW: 02E 300 057 G    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2701
   Revision: 05351113    Serial number: 00001105130931
   Shop #: WSC 09003 957 00200
   VCID: 1D67DEFE41BE1CDFC21-8048
   Revision: 00H31001
   Coding: C54BC0F5492300FBA30E03E792190041A70000
   VCID: 7BA3F066B3EAB2EF9C5-802E
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 A
   Revision: 00085000    Serial number: 0149074923
   Coding: 130C0C
   ASAM Dataset: EV_KESSYPQ35G A02014
   VCID: 34311B5ADEB4BD971DF-8060
   Part No SW: 561 907 044 D    HW: 561 907 044 D
   Component: Climatronic   H01 0102
   Revision: 00001001
   Coding: 0010001012
   VCID: 1869CFEAA21C79F7117-804C
7 Faults Found:
9471765 - Temperature Sensor for Left Vent
          B1087 15 [009] - Open or Short to Plus
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:42
9472021 - Temperature Sensor for Right Vent
          B1088 15 [009] - Open or Short to Plus
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:42
9481748 - High Pressure Sensor
          B10AE 14 [009] - Open or Short to Ground
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:42
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [009] - Open or Short to Plus
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:46
9496597 - Sunlight Photo Sensor
          B10E8 15 [009] - Open or Short to Plus
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:42
9496613 - Sunlight Photo Sensor
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:42
          B10A4 15 [008] - Open or Short to Plus
                    Reset counter: 210
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:42
   Part No SW: 5K0 937 087 Q    HW: 5K0 937 087 Q
   Component: BCM PQ35 H+   111 0147
   Revision: BL111001
   Coding: 6F200E1B982B08D408880201360085480071008645A00DF064806000BC70
   VCID: 43D348868B9A0A2F945-8016
   Component: RLS 250711 05  54  0403
   Coding: 22300A
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2014.04.20
                    Time: 08:37:28
                        Term 15 On
                    Voltage: 11.45 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003END098B72
   Coding: 0000354A
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FBBD436F712DE4F20D-803A
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100006BSA0O
   Coding: 303252
   Serial number: 3572MSME6D4B7060ZZZ/
   Serial number: 3582MSME26455360ZZZP
   Serial number: 3516KSME1B4C3711ZZZT
   Serial number: 3526KSME2E633811ZZZS
   Serial number: 3556LSME706C1112ZZZO
   Serial number: 3566LSME09531112ZZZH
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20110622100041
   Coding: 001A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA7FE7EAD7EBCDFA21-8028
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
   Part No SW: 561 920 970 B    HW: 561 920 970 B
   Component: KOMBI         H07 0507
   Coding: 231E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   VCID: 196FCAEE591660FF2E9-804C
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 12081101290705
   Coding: 461000
   VCID: 38292F6AC25C59F7317-806C
                    Fault Status: 00101011
                    Reset counter: 210
                    Mileage: 255168 km
                    Date: 2014.04.20
                    Time: 08:33:44
   Component: IMMO          H07 0507
   Coding: 000007
   VCID: 6A8DC522CCF03B67773-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000091289005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E050932309897476BB-807A
   Revision: A1001003    Serial number: 7660673234
   VCID: 290FFA2E09F6F07FBE9-807C
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000011719411
   VCID: 6099A70A3A4C7137A97-8034
   Part No SW: 3C8 035 684 E    HW: 3C0 035 684 E
   Component: RNS-MID       H59 3690
   Revision: AB001001    Serial number: VWZ6Z7L6212026
   Coding: 0409000201000094000B
   VCID: 2D070E3E3D1EEC5F521-8078
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0525
   Revision: 12110009    Serial number: 0003005449
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1C61D3FA562415D735F-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 290    3201
   Revision: 00H20000
   VCID: 34311B5AD234BD971DF-8060
   Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
   Component: KonzernAmp10K H06 0362
   Revision: --------    Serial number: BP225309709392
   VCID: 3039174A2AAC81B7797-8064
   Component: EZE_2         H40 1620
   Coding: 01030108
   VCID: 6FBBD436F792DE4F20D-803A
   Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
   Component: J245 P05 FFD7  H07 0004
   Serial number: 53388786011105500187
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0002
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0525
   Revision: 14110009    Serial number: 0002688743
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D67DEFE4D3E1CDFC21-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660327443
   Coding: 0A11040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 3537265ED5CEA49F2A1-8060
End----(Elapsed Time: 01:21, VBatt start/end: 11.6V/11.5V. VIgn 11.4V)-----
Given the number of sensor codes, plus the engine and central electric codes, am I on the right track thinking this is likely an issue with wiring or a module somewhere? Perhaps the Climatronic control unit itself is on the fritz? Curious what the experienced among you may think. It seems unlikely that both right and left temp sensors, for instance, would both be bad at the same time. But I'll believe anything!
I'm an experienced shadetree mechanic, having learned my way from a couple dozen 90s Saab 9000s, plus a couple E34 BMWs and a few other patients. However, I recognize my limits, and I have gotten away with throwing parts at the problems for the most part. Now I expect it's time for me to learn how to wield a voltmeter and obtain the art of electrical fault-finding! So, any recommended study materials and vids would be most welcome.
To finish off, the VW is with my parents in Connecticut -- who will be driving it locally for errands -- while I live in Brooklyn, NY. So there will be a long delay before I get to try my next approach. Before I captured this auto-scan, I have cleared all codes a few times, performed the vent adaptation (performed via VCDS and also via the Climatronic unit) successfully, and obtained the reported temp readings from the left and right vent sensors -- 85C (!!!) for both. I also uninstalled/reinstalled the Climatronic unit and double-checked that all connectors were solid, then cleared and rescanned again.
Again, I suspect nothing is different as a consequence of my work. Everything is connected properly, and I don't think I damaged any wiring during the work. It seems the heat is about as it was before I dug in.
Sorry for such a long message, but I'm very excited to learn more about VCDS and my Passat! Luckily, there is heat, just not great heat, so my parents won't freeze to death this winter, and I can take a careful and reasoned approach to diagnosis and repair. At least going forward, ha ha!
Dave
7 Faults Found:
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:42
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:42
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:42
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:46
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:42
                    Reset counter: 170
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:42
                    Reset counter: 210
                    Mileage: 255168 km
                    Date: 2019.11.28
                    Time: 08:33:42
Hello and welcome to the VCDS forum OP!
Did you JPPSG yet?
Did you know clearing codes doesn't help if there are shorts to ground/open/positive to respective sensors or actuators?
Time to RTFB the WD and test stuff!
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
Wouldn't it be wise to investigate fuses and proper LIN and CAN operation of the chain of sensors?
https://forums.ross-tech.com/showth...you-should-have-a-baseline-understanding-of-!
Most importantly charging system and battery?
Revision: BL111001
Coding: 22300A
Coding: 461000
Reset counter: 210
Mileage: 255168 km
Date: 2014.04.20
Time: 08:33:44
dingram01
C?ID=387453
Thanks Jack! I'll review all these links, and was actually reading JPPSG at this very moment!
I feel so much smarter already...and dumber too. :)
While we can't rule out the Climatronic module itself, if it were mine, I'd be study the wiring diagrams for that system and look for a possible common point of failure for those temperature sensors.
dingram01
C?ID=387453
Hi all, hope the holidays and new year were good to you! I have finally been back to Connecticut last week, and took a couple tentative steps to further this diagnosis.
I studied everything I could and got a decent multimeter, and also a logic-safe test light. I downloaded the WD from ERWIN and studied in detail. From the diagram, it appeared there might be a clue: the left & right vent temp sensors and the solar sensor (the ones registering fault codes) all connect to the same green/lilac ground wire, back to the climatronic unit, and also bridged into the AC wiring harness. My hypothesis was that there was a breakage in this common ground and that measuring voltage across the 2-pin connectors to the sensors would perhaps confirm that. If I got no voltage at the connector, I supposed, it might indicate the ground continuity was absent.
(On returning the car, I did an autoscan. Much the same as the previous, only now with the floor vent sensors added to the mix with the same "short to zero". Also a can bus code, no communication with the climatronic module. Heat symptoms still the same, no other operational issues evident. The rear bulb code was due to a blown tail light bulb that was replaced. I cleared all the fault codes before beginning my work. Here it is below:)
Sunday,12,January,2020,12:51:56:64803
VIN: 1VWCM7A34CC011330   License Plate: 594WEO
Mileage: 255640km-158847mi   Repair Order:
          52 56 62 72 77
VIN: 1VWCM7A34CC011330   Mileage: 255640km-158847miles
08-Auto HVAC -- Status: Malfunction 1010
4629 - ECM Power Relay Load Circuit
          P068A 00 [040] - Opens Too Early
                    Coolant temperature: 77 °C
                    Intake air temperature: 53 °C
                    Voltage terminal 30: 10.648 V
                    Unlearning counter according OBD: 9
                    Power steering pump desired actual moment for idling control: 0.0 Nm
                    Generator: load signal: 0.00 %
                    Generator power: 0 W
                    Torque request: sum of auxiliary aggregate: 0.0 Nm
                    Status of starter activation-Bits 0-7: 0
10434 - Catalyst System; Bank 1
          P0420 00 [096] - Efficiency Below Threshold
                    Mileage: 255227 km
                    Date: 2019.11.30
                    Time: 10:08:29
                    Engine speed: 1765.00 /min
                    Normed load value: 25.9 %
                    Vehicle speed: 54 km/h
                    Coolant temperature: 99 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 13.829 V
                    Unlearning counter according OBD: 13
                    Rear cat conv temp main cat conv model value: 657.46 °C
10435 - Catalyst System; Bank 2
          P0430 00 [096] - Efficiency Below Threshold
                    Mileage: 255256 km
                    Date: 2019.12.04
                    Time: 14:41:15
                    Engine speed: 1498.50 /min
                    Normed load value: 33.7 %
                    Vehicle speed: 61 km/h
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 13.546 V
                    Unlearning counter according OBD: 37
                    Rear cat conv temp main cat conv model value: 650.57 °C
   Revision: 00H31001
   Coding: 130C0C
   Revision: 00001001
   Coding: 0010001012
7 Faults Found:
9470741 - Temperature Sensor for Left Footwell Vent
          B1083 15 [008] - Open or Short to Plus
                    Reset counter: 245
                    Mileage: 255632 km
                    Date: 2020.01.11
                    Time: 15:11:29
9470997 - Temperature Sensor for Right Footwell Vent
          B1084 15 [008] - Open or Short to Plus
                    Reset counter: 245
                    Mileage: 255632 km
                    Date: 2020.01.11
                    Time: 15:11:29
          B1087 15 [008] - Open or Short to Plus
                    Reset counter: 245
                    Mileage: 255632 km
                    Date: 2020.01.11
                    Time: 15:25:49
          B1088 15 [008] - Open or Short to Plus
                    Reset counter: 245
                    Mileage: 255632 km
                    Date: 2020.01.11
                    Time: 15:34:59
9472533 - Temperature Sensor for Evaporator Vent
          B108A 15 [008] - Open or Short to Plus
                    Reset counter: 245
                    Mileage: 255632 km
                    Date: 2020.01.11
                    Time: 15:11:29
          B10E8 15 [008] - Open or Short to Plus
                    Reset counter: 245
                    Mileage: 255632 km
                    Date: 2020.01.11
                    Time: 15:45:27
                    Reset counter: 245
                    Mileage: 255632 km
                    Date: 2020.01.11
                    Time: 15:45:27
   Revision: BL111001
   Coding: 22300A
                    Reset counter: 245
                    Mileage: 255632 km
                    Date: 2014.06.03
                    Time: 15:02:38
                        Term 15 Off
                    Voltage: 12.40 V
02742 - Bulb for Brake/Turn Signal Light; Left
                    Fault Status: 00101010
                    Reset counter: 222
                    Mileage: 255276 km
                    Date: 2014.04.27
                    Time: 12:57:38
                        Term 15 On
                    Voltage: 13.60 V
   Coding: 0000354A
   Coding: 303252
   Coding: 001A140000
   Coding: E20000
   Coding: 231E01
   Coding: 461000
                    Fault Status: 00110100
                    Reset counter: 245
                    Mileage: 255632 km
                    Date: 2014.06.03
                    Time: 15:02:36
   Coding: 000007
                    Fault Frequency: 64
                    Reset counter: 205
                    Mileage: 255264 km
   Coding: 0405FD
   Slave Driver:
   Coding: 800000
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [008] - Electrical Failure
                    Reset counter: 214
                    Mileage: 255216 km
                    Date: 2019.11.30
                    Time: 09:14:43
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 212
   Revision: 00H20000
   Coding: 01030108
   Coding: 181100
   Coding: 0405FC
   Slave Passenger:
   Coding: 800000
                    Reset counter: 212
                    Fault Frequency: 64
                    Reset counter: 205
                    Mileage: 255264 km
   ROD: UHVNA.rod
End----(Elapsed Time: 01:27, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
As my first step, I removed the right and left dash vent sensors, unplugged the connectors, and measured the voltage across the pins. For both right and left sensors, solid 4.9 volts present. Didn't fit with my hypothesis. Planned to do a similar test on the solar sensor, which was shown to have a 6-pin connector in the diagram, but in fact has a 4-pin connector. (???!!!!) So abandoned any testing there.
I then measured the resistance of the right and left sensors, and found they were about the same, and that both resistances dropped at about the same rate when I held them in my fingers to warm them up. I can't find my notes now to indicate what the ohm readings were now...grrr.
Next I reinstalled the temp sensors, this time swapping sides, to see if the tepid heat would follow the moving sensor, and drove the car. The weak heat was still on the passenger side, so it didn't follow the sensor.
Now I cleared the codes and drove the car for a bit, fiddling with the temp settings, then autoscanned afterwards. No codes whatsoever. I repeated this several times with the same result, no codes.
Lastly, I looked at the measuring blocks for the 4 temp sensors, and got the readings below. Notice that the left footwell sensor seems to be reading higher than the rest, and in the last reading they're all completely nuts. Does "MUX Ausblastemperatur" mean something specific, and why is only this sensor labeled this way?
Sunday,12,January,2020,13:16:45:64803
Mileage: 255650km-158853mi   Repair Order: Climatronic Adv
Control Module Part Number: 561 907 044 D
  Component and/or Version: Climatronic   H01 0102
           Software Coding: 0010001012
            Work Shop Code: WSC 09003
Advanced Identification/FAZIT
     Identification: YWU-001
     Revision: 00001001
     Date: 03.08.11
     Manufacturer number: 0009
     Test stand number: 0153
Flash Status
     Programming Attempts(application): 1/0
     Successful Attempts(application): 1/0
     Programming Status: 00000000
     Flash Date: 10.03.31
Software
     BAP: 01.04.00
     UDS: 01.02.14
     Diag: 01.02.05
     CAN: 01.41.00
     ISO15765: 01.02.15
     OSEK Net: 03.70.03
Misc.
     Hardware number: 561 907 044 D
     Workshop System Name: J255
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A01001
VCDS Info:
       Labels: 5K0-907-044.clb
                Address 08: Auto HVAC  (561 907 044 D)
13:27:26
  IDE00976   Left front vent temperature 14.0 °C
  IDE00977   Right front vent temperature 16.7 °C
  IDE00979-ENG101755   Left footwell vent temperature-MUX Ausblastemperatur 18.7 °C
  IDE00980   Right footwell vent temperature 16.0 °C
13:27:28
  IDE00976   Left front vent temperature 14.3 °C
  IDE00977   Right front vent temperature 16.3 °C
  IDE00979-ENG101755   Left footwell vent temperature-MUX Ausblastemperatur 19.0 °C
  IDE00980   Right footwell vent temperature 15.3 °C
13:27:30
  IDE00977   Right front vent temperature 16.0 °C
  IDE00979-ENG101755   Left footwell vent temperature-MUX Ausblastemperatur 19.3 °C
13:27:35
  IDE00976   Left front vent temperature 14.7 °C
  IDE00977   Right front vent temperature 15.3 °C
  IDE00979-ENG101755   Left footwell vent temperature-MUX Ausblastemperatur 20.0 °C
  IDE00980   Right footwell vent temperature 14.7 °C
13:27:40
  IDE00977   Right front vent temperature 14.7 °C
  IDE00980   Right footwell vent temperature 14.3 °C
13:27:41
  IDE00979-ENG101755   Left footwell vent temperature-MUX Ausblastemperatur 20.3 °C
13:29:12
  IDE00976   Left front vent temperature 13.3 °C
  IDE00977   Right front vent temperature 24.7 °C
  IDE00980   Right footwell vent temperature 32.0 °C
This was all I had time for before I had to return to Brooklyn. Again, the heat is working, just not as expected, and weak on the passenger side. I can't believe I'd have FOUR BAD temp sensors. Could there be a resistance issue in the ground circuit that allowed my voltage test to show misleading results? Did I do the wrong test? Or, does the somewhat random temp sensor readings indicate the Climatronic unit needs to be replaced?
Another thought raised by Jack from my original Autoscan in November: maybe the car's battery is weak. Back then the fault code, I think, was due to me running several scans, "key on engine off" and door open, with dome lights -- and headlights -- on the whole time. I haven't seen the battery code in subsequent scans, so I suspect it's fine. Still, maybe a weak battery is interfering with the temp sensor readings? But why only this heat-related symptom and not other freaked out systems? And if I replace the battery, are there other special steps I must take, like you do with modern BMWs (I know, RTFM dummy!)?
I hope my ramblings make some sense, and I did SOMETHING right, SORT OF, at least! Happily the car is driving great, and it's just this non-fabulous heat issue. I'm enjoying learning how to do these diagnostics, and super appreciative of everyone's time and help. And I'm content to do a little here, a little there, aiming not to break anything along the way. Hopefully I'll have a new set of steps to try next time I'm at the car!
Measuring voltage on a circuit with no load on it doesn't mean a whole lot. Put a load on the circuit. One comparable to the temperature sensors' lowest value. If there's a ground wire, measure resistance from its terminus at the sensor back to a known good ground.
dingram01
C?ID=387453
Thanks Uwe! For providing this resistance, do you recommend a decade box or similar? Or, if it's just a matter of finding a bulb or something, I can guess at the resistance, but I'm not positive of the parameters of the temp sensors. Does the wiring diagram, or some other ERWIN material, give the resistance of various components?
I'll be at the car again this weekend and will do a little more exploring, though probably not a resistance check again. I'm thinking I'll go back to Jack's original reply, and take a better look at the battery condition and other fundamentals to ensure the overall system is in good order (which I expect it should be).
Besides checking battery voltage at the terminals, and a look at the VCDS readouts, any other basics to recommend?
Thanks!
I would start by just measuring resistance of the wires.
For providing a load within the range of the sensor, a decade box is indeed ideal.
JPPSG
I5TXGZc5cx3J1ZXNFpGYopy4p81vjgMq84NqQzuONtFQ_XRZ8y5ofnh1Dmo_6SrCMmLUVU9gN65T3pMzIyUBi3P9FjsYomYv2-EZ1g
dingram01
C?ID=387453
Hello again everybody. Not much to update you with -- no measurements on the ground wire I'm interested in. I need to understand better where the ground actually passes through before I measure its resistance. It appears from the WD that it's a common ground shared with some AC components in a different diagram, and I'm still trying to find time to scrutinize so I understand where that is. I don't want to fry something.
But in my last visit, I did take another autoscan, which produced NO codes whatsoever. This after the car was being driven consistently. Heat issue still present as before. Interesting.
I then measured the battery with my voltmeter, and got the following results:
Car off: 11.79 volts
Cranking: 9.8 volts
Running: 13.79 volts
I see from my very first autoscan it reported 11.6/11.4. My later autoscan, a couple weeks later, reported 11.8/11.8.
Is this a healthy battery? I wonder if a reboot would help, regardless.
But I'm beginning to think the whole thing is really just a clogged heater core. Meaning the system has enough muck in it from the prior neglected coolant, that it promptly clogged up the new core as soon as I installed it. Despite my best efforts to flush the system.
One of these weekends it'll be time for its 10K mile service, and I will do another coolant flush then, and maybe we'll find out.
That doesn't sound like a healthy battery to me. Have you tried charging it?
However, I doubt that a weak battery is causing the problems you cited when you started this thread.
Are the heater hoses hot in and out with temp gun if measured?
Can you manipulate blend doors manually to make heat?
Are you sure cooling system is without air bound issue?
Have you checked the flow of core with a garden hose or attempted a reverse hook up to flush?
Post a complete auto-scan please.
Any battery sitting 15 minutes after being fully charged and less than 12.5 volts static is junk!
dingram01
C?ID=387453
Thanks for the additional feedback.
Couple challenges to answering your thoughts Jack:
1. No heat gun in my possession. But my earlier fingertip test of the metal pipes under the dash registered that they're both hot. The core could be partially plugged or air bound, as you point out, so maybe coolant passes through the pipes like we'd expect, but not the whole core.
2. I haven't removed the lower dash to look at the blend door activation to confirm movement, or manipulate them manually. Running the calibration steps seems to make all the right noises, and completes satisfactorily according to the VCDS. I'll check that next time too.
3. Air bound is certainly possible. As with heat gun, I'm not equipped to do a vacuum fill of the system, so I'd have to pay someone to do a flush and vacuum fill for me to find out. Can a Mighty Vac get the job done? I assume not.
Maybe there's an air leak in one of the hose unions too, admitting air?
4. I have to do a timing chain/guide job later this summer, and I'll be including a complete cooling system check including pressure test. And a definite reverse flush with garden hose.
5. I have no autoscan to offer for the latest go-round -- I keep transferring back and forth between my Mac and PC, and don't have the PC handy in my Lockdown Shanty here in Brooklyn (car's in Connecticut, safe from the zombies). But the general concept is, no trouble codes from HVAC.
6. Good to know on the battery. I'll plan to replace the battery as soon as I can. I'm aware of the coding requirements.
I am still expecting the core to be clogged. You should have seen the calcium crap that came out of the heater pipes when I was handling that repair.
Thanks for the patience at my bass-ackwards approach to this diagnosis...and the slow pace. I am definitely learning, and enjoying the process.
