Results 1 to 10 of 14
Thread: 2012 NMS Passat SEL VR6 Premium Climatronic issues
    Nov 2019
    Hello everybody,
    After many years of hearing about VCDS, I finally have a (new to me) 2012 Passat NMS SEL VR6. First a bit of history: the car has 160k on the clock and was decently maintained (and absolutely beautifully cleaned and waxed regularly) by the prior owner, who had it since new. I took possession of the car a few weeks ago, and quickly noticed the heater output was middling, with different temps on driver and passenger sides.
    This is the dual-zone Climatronic.
    At the time I hadn't gotten my VCDS yet, but found many posts about clogged heater cores and the relatively easy replacement. So, I ordered a new core and went about installing it. Long story short, I botched it and mangled the heater pipes, so I wound up removing the instrument panel. Out came the air distribution box so I could replace the metal lines, and I put it all together again to find...the same tepid heat!
    I'm satisfied that the core is working fine -- both pipes are HOT to the touch, with no detectable difference between them. Coolant level is stable, so I don't think it's air bound.
    So, after the work, the performance is the same as it was. I don't think it's changed by the work I did.
    Finally got my VCDS last week, and got the codes from the car. There were a number of codes initially, mostly related to the car's confusion after the work I did. I cleared all codes first, then re-ran the Auto-Scan several times. Here's what I'm left with now:
    Thursday,28,November,2019,08:41:10:64803
    VIN: 1VWCM7A34CC011330   License Plate:
    Mileage: 255160km-158549mi   Repair Order: scan2
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
              52 56 62 72 77
    VIN: 1VWCM7A34CC011330   Mileage: 255160km-158549miles
    Address 01: Engine (0-32-CDVB)       Labels:. 03H-907-309-V1.clb
       Part No SW: 03H 906 023 BF    HW: 03H 907 309 A
       Component: VR6 3.6l FSI  H03 9259
       Revision: MFH03---    Serial number:
       Coding: 001D0012242400008000
       Shop #: WSC 08083 444 00000
       ASAM Dataset: EV_ECM36FSI01103H906023BF 002006
       ROD: EV_ECM36FSI01103H906023BF.rod
       VCID: 678BBC16DFE2060F68D-8032
    4344 - Please Check Fault Codes in Control Module for HVAC (J301)
              U1025 00 [039] - -
              [A/C control moduleRead out DTC]
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:49
                        Coolant temperature: 12 ∞C
                        Intake air temperature: 15 ∞C
                        Voltage terminal 30: 11.638 V
    Readiness: 1110 0101
       Part No SW: 02E 300 057 G    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2701
       Revision: 05351113    Serial number: 00001105130931
       Shop #: WSC 09003 957 00200
       VCID: 1D67DEFE41BE1CDFC21-8048
       Revision: 00H31001
       Coding: C54BC0F5492300FBA30E03E792190041A70000
       VCID: 7BA3F066B3EAB2EF9C5-802E
       Part No SW: 5K0 959 434 B    HW: 5K0 959 434 A
       Revision: 00085000    Serial number: 0149074923
       Coding: 130C0C
       ASAM Dataset: EV_KESSYPQ35G A02014
       VCID: 34311B5ADEB4BD971DF-8060
       Part No SW: 561 907 044 D    HW: 561 907 044 D
       Component: Climatronic   H01 0102
       Revision: 00001001
       Coding: 0010001012
       ROD: EV_ACClimaBHBVW411_VW41.rod
       VCID: 1869CFEAA21C79F7117-804C
    7 Faults Found:
    9471765 - Temperature Sensor for Left Vent
              B1087 15 [009] - Open or Short to Plus
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:42
    9472021 - Temperature Sensor for Right Vent
              B1088 15 [009] - Open or Short to Plus
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:42
    9481748 - High Pressure Sensor
              B10AE 14 [009] - Open or Short to Ground
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:42
    9480469 - Control Circuit for A/C Compressor
              B10A9 15 [009] - Open or Short to Plus
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:46
    9496597 - Sunlight Photo Sensor
              B10E8 15 [009] - Open or Short to Plus
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:42
    9496613 - Sunlight Photo Sensor
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:42
    9479189 - Signal Line for Air Quality Sensor
              B10A4 15 [008] - Open or Short to Plus
                        Reset counter: 210
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:42
       Part No SW: 5K0 937 087 Q    HW: 5K0 937 087 Q
       Component: BCM PQ35 H+   111 0147
       Revision: BL111001
       Coding: 6F200E1B982B08D408880201360085480071008645A00DF064806000BC70
       VCID: 43D348868B9A0A2F945-8016
       Component: RLS 250711 05  54  0403
       Coding: 22300A
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2014.04.20
                        Time: 08:37:28
                        Voltage: 11.45 V
       Part No SW: 5C0 959 655     HW: 5C0 959 655
       Component: AirbagVW10G   013 0809
       Serial number: 003END098B72
       Coding: 0000354A
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 6FBBD436F712DE4F20D-803A
       Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
       Component: BF-Gewichtss.  H10 0027
       Serial number: 6940000Y1100006BSA0O
       Coding: 303252
       Serial number: 3572MSME6D4B7060ZZZ/
       Serial number: 3582MSME26455360ZZZP
       Serial number: 3516KSME1B4C3711ZZZT
       Serial number: 3526KSME2E633811ZZZS
       Serial number: 3556LSME706C1112ZZZO
       Serial number: 3566LSME09531112ZZZH
       Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
       Revision: FF010040    Serial number: 20110622100041
       Coding: 001A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7DA7FE7EAD7EBCDFA21-8028
       Component: E221__MFL-YVJ  H06 0022
       Coding: E20000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 970 B    HW: 561 920 970 B
       Component: KOMBI         H07 0507
       Coding: 231E01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
       VCID: 196FCAEE591660FF2E9-804C
       Part No SW: 7N0 907 530 K    HW: 1K0 907 951
       Component: J533  Gateway H40 1620
       Revision:   H40       Serial number: 12081101290705
       Coding: 461000
       VCID: 38292F6AC25C59F7317-806C
                        Fault Status: 00101011
                        Reset counter: 210
                        Mileage: 255168 km
                        Date: 2014.04.20
                        Time: 08:33:44
       Component: IMMO          H07 0507
       Coding: 000007
       VCID: 6A8DC522CCF03B67773-803E
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 11000091289005
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E050932309897476BB-807A
       Revision: A1001003    Serial number: 7660673234
       VCID: 290FFA2E09F6F07FBE9-807C
       Part No SW: 561 959 760     HW: 561 959 760
       Component: MEM-FS        H04 0181
       Revision: AA000000    Serial number: 00000011719411
       Coding: 00581B0000000000000021010100202020202120202020
       VCID: 6099A70A3A4C7137A97-8034
       Part No SW: 3C8 035 684 E    HW: 3C0 035 684 E
       Component: RNS-MID       H59 3690
       Revision: AB001001    Serial number: VWZ6Z7L6212026
       Coding: 0409000201000094000B
       VCID: 2D070E3E3D1EEC5F521-8078
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0525
       Revision: 12110009    Serial number: 0003005449
       Coding: 0405FD
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 1C61D3FA562415D735F-8048
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  004 4472
       Coding: 800000
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 290    3201
       Revision: 00H20000
       VCID: 34311B5AD234BD971DF-8060
       Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
       Component: KonzernAmp10K H06 0362
       Revision: --------    Serial number: BP225309709392
       VCID: 3039174A2AAC81B7797-8064
       Component: EZE_2         H40 1620
       Coding: 01030108
       VCID: 6FBBD436F792DE4F20D-803A
       Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
       Component: J245 P05 FFD7  H07 0004
       Serial number: 53388786011105500187
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0002
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0525
       Revision: 14110009    Serial number: 0002688743
       Coding: 0405FC
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 1D67DEFE4D3E1CDFC21-8048
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  004 4472
       Coding: 800000
       Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007660327443
       Coding: 0A11040000010110
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 3537265ED5CEA49F2A1-8060
    End----(Elapsed Time: 01:21, VBatt start/end: 11.6V/11.5V. VIgn 11.4V)-----
    Given the number of sensor codes, plus the engine and central electric codes, am I on the right track thinking this is likely an issue with wiring or a module somewhere? Perhaps the Climatronic control unit itself is on the fritz? Curious what the experienced among you may think. It seems unlikely that both right and left temp sensors, for instance, would both be bad at the same time. But I'll believe anything!
    I'm an experienced shadetree mechanic, having learned my way from a couple dozen 90s Saab 9000s, plus a couple E34 BMWs and a few other patients. However, I recognize my limits, and I have gotten away with throwing parts at the problems for the most part. Now I expect it's time for me to learn how to wield a voltmeter and obtain the art of electrical fault-finding! So, any recommended study materials and vids would be most welcome.
    To finish off, the VW is with my parents in Connecticut -- who will be driving it locally for errands -- while I live in Brooklyn, NY. So there will be a long delay before I get to try my next approach. Before I captured this auto-scan, I have cleared all codes a few times, performed the vent adaptation (performed via VCDS and also via the Climatronic unit) successfully, and obtained the reported temp readings from the left and right vent sensors -- 85C (!!!) for both. I also uninstalled/reinstalled the Climatronic unit and double-checked that all connectors were solid, then cleared and rescanned again.
    Again, I suspect nothing is different as a consequence of my work. Everything is connected properly, and I don't think I damaged any wiring during the work. It seems the heat is about as it was before I dug in.
    Sorry for such a long message, but I'm very excited to learn more about VCDS and my Passat! Luckily, there is heat, just not great heat, so my parents won't freeze to death this winter, and I can take a careful and reasoned approach to diagnosis and repair. At least going forward, ha ha!
    Dave
    7 Faults Found:
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:42
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:42
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:42
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:46
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:42
                        Reset counter: 170
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:42
                        Reset counter: 210
                        Mileage: 255168 km
                        Date: 2019.11.28
                        Time: 08:33:42
    Hello and welcome to the VCDS forum OP!
    Did you JPPSG yet?
    Did you know clearing codes doesn't help if there are shorts to ground/open/positive to respective sensors or actuators?
    Time to RTFB the WD and test stuff!
    Wouldn't it be wise to investigate fuses and proper LIN and CAN operation of the chain of sensors?
    https://forums.ross-tech.com/showthr...rstanding-of-!
    Most importantly charging system and battery?
    Revision: BL111001
    Coding: 6F200E1B982B08D408880201360085480071008645A00DF064 806000BC70
    Coding: 22300A
    Coding: 461000
    Reset counter: 210
    Mileage: 255168 km
    Date: 2014.04.20
    Time: 08:33:44
    Nov 2019
    Thanks Jack! I'll review all these links, and was actually reading JPPSG at this very moment!
    I feel so much smarter already...and dumber too.
    That makes two of us, what were we talking about?
    Quote Originally Posted by dingram01 View Post
    While we can't rule out the Climatronic module itself, if it were mine, I'd be study the wiring diagrams for that system and look for a possible common point of failure for those temperature sensors.
    Nov 2019
    Hi all, hope the holidays and new year were good to you! I have finally been back to Connecticut last week, and took a couple tentative steps to further this diagnosis.
    I studied everything I could and got a decent multimeter, and also a logic-safe test light. I downloaded the WD from ERWIN and studied in detail. From the diagram, it appeared there might be a clue: the left & right vent temp sensors and the solar sensor (the ones registering fault codes) all connect to the same green/lilac ground wire, back to the climatronic unit, and also bridged into the AC wiring harness. My hypothesis was that there was a breakage in this common ground and that measuring voltage across the 2-pin connectors to the sensors would perhaps confirm that. If I got no voltage at the connector, I supposed, it might indicate the ground continuity was absent.
    (On returning the car, I did an autoscan. Much the same as the previous, only now with the floor vent sensors added to the mix with the same "short to zero". Also a can bus code, no communication with the climatronic module. Heat symptoms still the same, no other operational issues evident. The rear bulb code was due to a blown tail light bulb that was replaced. I cleared all the fault codes before beginning my work. Here it is below
    Sunday,12,January,2020,12:51:56:64803
    VIN: 1VWCM7A34CC011330   License Plate: 594WEO
    Mileage: 255640km-158847mi   Repair Order:
              52 56 62 72 77
    VIN: 1VWCM7A34CC011330   Mileage: 255640km-158847miles
    08-Auto HVAC -- Status: Malfunction 1010
    4629 - ECM Power Relay Load Circuit
              P068A 00 [040] - Opens Too Early
                        Coolant temperature: 77 C
                        Intake air temperature: 53 C
                        Voltage terminal 30: 10.648 V
                        Unlearning counter according OBD: 9
                        Power steering pump desired actual moment for idling control: 0.0 Nm
                        Generator: load signal: 0.00 %
                        Generator power: 0 W
                        Torque request: sum of auxiliary aggregate: 0.0 Nm
                        Status of starter activation-Bits 0-7: 0
    10434 - Catalyst System; Bank 1
              P0420 00 [096] - Efficiency Below Threshold
                        Mileage: 255227 km
                        Date: 2019.11.30
                        Time: 10:08:29
                        Engine speed: 1765.00 /min
                        Normed load value: 25.9 %
                        Vehicle speed: 54 km/h
                        Coolant temperature: 99 C
                        Intake air temperature: 12 C
                        Voltage terminal 30: 13.829 V
                        Unlearning counter according OBD: 13
                        Rear cat conv temp main cat conv model value: 657.46 C
    10435 - Catalyst System; Bank 2
              P0430 00 [096] - Efficiency Below Threshold
                        Mileage: 255256 km
                        Date: 2019.12.04
                        Time: 14:41:15
                        Engine speed: 1498.50 /min
                        Normed load value: 33.7 %
                        Vehicle speed: 61 km/h
                        Intake air temperature: 18 C
                        Voltage terminal 30: 13.546 V
                        Rear cat conv temp main cat conv model value: 650.57 C
       Revision: 00H31001
       Coding: 130C0C
       Revision: 00001001
       Coding: 0010001012
    7 Faults Found:
    9470741 - Temperature Sensor for Left Footwell Vent
              B1083 15 [008] - Open or Short to Plus
                        Reset counter: 245
                        Mileage: 255632 km
                        Date: 2020.01.11
                        Time: 15:11:29
    9470997 - Temperature Sensor for Right Footwell Vent
              B1084 15 [008] - Open or Short to Plus
                        Reset counter: 245
                        Mileage: 255632 km
                        Date: 2020.01.11
                        Time: 15:11:29
              B1087 15 [008] - Open or Short to Plus
                        Reset counter: 245
                        Mileage: 255632 km
                        Date: 2020.01.11
                        Time: 15:25:49
              B1088 15 [008] - Open or Short to Plus
                        Reset counter: 245
                        Mileage: 255632 km
                        Date: 2020.01.11
                        Time: 15:34:59
    9472533 - Temperature Sensor for Evaporator Vent
              B108A 15 [008] - Open or Short to Plus
                        Reset counter: 245
                        Mileage: 255632 km
                        Date: 2020.01.11
                        Time: 15:11:29
              B10E8 15 [008] - Open or Short to Plus
                        Reset counter: 245
                        Mileage: 255632 km
                        Date: 2020.01.11
                        Time: 15:45:27
                        Reset counter: 245
                        Mileage: 255632 km
                        Date: 2020.01.11
                        Time: 15:45:27
       Revision: BL111001
       Coding: 22300A
                        Reset counter: 245
                        Mileage: 255632 km
                        Date: 2014.06.03
                        Time: 15:02:38
                            Term 15 Off
                        Voltage: 12.40 V
    02742 - Bulb for Brake/Turn Signal Light; Left
                        Fault Status: 00101010
                        Reset counter: 222
                        Mileage: 255276 km
                        Date: 2014.04.27
                        Time: 12:57:38
                        Voltage: 13.60 V
       Coding: 0000354A
       Coding: 303252
       Coding: 001A140000
       Coding: E20000
       Coding: 231E01
       Coding: 461000
                        Fault Status: 00110100
                        Reset counter: 245
                        Mileage: 255632 km
                        Date: 2014.06.03
                        Time: 15:02:36
       Coding: 000007
                        Fault Frequency: 64
                        Reset counter: 205
                        Mileage: 255264 km
       Coding: 0405FD
       Slave Driver:
       Coding: 800000
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [008] - Electrical Failure
                        Reset counter: 214
                        Mileage: 255216 km
                        Date: 2019.11.30
                        Time: 09:14:43
    131584 - Motor for Rear Window Regulator
              B11EE 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 212
       Revision: 00H20000
       Coding: 01030108
       Coding: 181100
       Coding: 0405FC
       Slave Passenger:
       Coding: 800000
                        Reset counter: 212
                        Fault Frequency: 64
                        Reset counter: 205
                        Mileage: 255264 km
       ROD: UHVNA.rod
    End----(Elapsed Time: 01:27, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
    As my first step, I removed the right and left dash vent sensors, unplugged the connectors, and measured the voltage across the pins. For both right and left sensors, solid 4.9 volts present. Didn't fit with my hypothesis. Planned to do a similar test on the solar sensor, which was shown to have a 6-pin connector in the diagram, but in fact has a 4-pin connector. (???!!!!) So abandoned any testing there.
    I then measured the resistance of the right and left sensors, and found they were about the same, and that both resistances dropped at about the same rate when I held them in my fingers to warm them up. I can't find my notes now to indicate what the ohm readings were now...grrr.
    Next I reinstalled the temp sensors, this time swapping sides, to see if the tepid heat would follow the moving sensor, and drove the car. The weak heat was still on the passenger side, so it didn't follow the sensor.
    Now I cleared the codes and drove the car for a bit, fiddling with the temp settings, then autoscanned afterwards. No codes whatsoever. I repeated this several times with the same result, no codes.
    Lastly, I looked at the measuring blocks for the 4 temp sensors, and got the readings below. Notice that the left footwell sensor seems to be reading higher than the rest, and in the last reading they're all completely nuts. Does "MUX Ausblastemperatur" mean something specific, and why is only this sensor labeled this way?
    Sunday,12,January,2020,13:16:45:64803
    Mileage: 255650km-158853mi   Repair Order: Climatronic Adv
    Control Module Part Number: 561 907 044 D
      Component and/or Version: Climatronic   H01 0102
               Software Coding: 0010001012
                Work Shop Code: WSC 09003
    Advanced Identification/FAZIT
         Identification: YWU-001
         Revision: 00001001
         Date: 03.08.11
         Manufacturer number: 0009
         Test stand number: 0153
    Flash Status
         Programming Attempts(application): 1/0
         Successful Attempts(application): 1/0
         Programming Status: 00000000
         Flash Date: 10.03.31
    Software
         BAP: 01.04.00
         UDS: 01.02.14
         Diag: 01.02.05
         CAN: 01.41.00
         ISO15765: 01.02.15
         OSEK Net: 03.70.03
    Misc.
         Hardware number: 561 907 044 D
         Workshop System Name: J255
         End of Line Equipment Level: ------------------
         ASAM Dataset Revision: A01001
    VCDS Info:
           Labels: 5K0-907-044.clb
                    Address 08: Auto HVAC  (561 907 044 D)
    13:27:26
      IDE00976   Left front vent temperature 14.0 C
      IDE00977   Right front vent temperature 16.7 C
      IDE00979-ENG101755   Left footwell vent temperature-MUX Ausblastemperatur 18.7 C
      IDE00980   Right footwell vent temperature 16.0 C
    13:27:28
      IDE00976   Left front vent temperature 14.3 C
      IDE00977   Right front vent temperature 16.3 C
      IDE00979-ENG101755   Left footwell vent temperature-MUX Ausblastemperatur 19.0 C
      IDE00980   Right footwell vent temperature 15.3 C
    13:27:30
      IDE00977   Right front vent temperature 16.0 C
      IDE00979-ENG101755   Left footwell vent temperature-MUX Ausblastemperatur 19.3 C
    13:27:35
      IDE00976   Left front vent temperature 14.7 C
      IDE00977   Right front vent temperature 15.3 C
      IDE00979-ENG101755   Left footwell vent temperature-MUX Ausblastemperatur 20.0 C
      IDE00980   Right footwell vent temperature 14.7 C
    13:27:40
      IDE00977   Right front vent temperature 14.7 C
      IDE00980   Right footwell vent temperature 14.3 C
    13:27:41
      IDE00979-ENG101755   Left footwell vent temperature-MUX Ausblastemperatur 20.3 C
    13:29:12
      IDE00976   Left front vent temperature 13.3 C
      IDE00977   Right front vent temperature 24.7 C
      IDE00980   Right footwell vent temperature 32.0 C
    This was all I had time for before I had to return to Brooklyn. Again, the heat is working, just not as expected, and weak on the passenger side. I can't believe I'd have FOUR BAD temp sensors. Could there be a resistance issue in the ground circuit that allowed my voltage test to show misleading results? Did I do the wrong test? Or, does the somewhat random temp sensor readings indicate the Climatronic unit needs to be replaced?
    Another thought raised by Jack from my original Autoscan in November: maybe the car's battery is weak. Back then the fault code, I think, was due to me running several scans, "key on engine off" and door open, with dome lights -- and headlights -- on the whole time. I haven't seen the battery code in subsequent scans, so I suspect it's fine. Still, maybe a weak battery is interfering with the temp sensor readings? But why only this heat-related symptom and not other freaked out systems? And if I replace the battery, are there other special steps I must take, like you do with modern BMWs (I know, RTFM dummy!)?
    I hope my ramblings make some sense, and I did SOMETHING right, SORT OF, at least! Happily the car is driving great, and it's just this non-fabulous heat issue. I'm enjoying learning how to do these diagnostics, and super appreciative of everyone's time and help. And I'm content to do a little here, a little there, aiming not to break anything along the way. Hopefully I'll have a new set of steps to try next time I'm at the car!
  8. Likes Uwe liked this post
    Measuring voltage on a circuit with no load on it doesn't mean a whole lot. Put a load on the circuit. One comparable to the temperature sensors' lowest value. If there's a ground wire, measure resistance from its terminus at the sensor back to a known good ground.
  11. #8
    Nov 2019
    Thanks Uwe! For providing this resistance, do you recommend a decade box or similar? Or, if it's just a matter of finding a bulb or something, I can guess at the resistance, but I'm not positive of the parameters of the temp sensors. Does the wiring diagram, or some other ERWIN material, give the resistance of various components?
    I'll be at the car again this weekend and will do a little more exploring, though probably not a resistance check again. I'm thinking I'll go back to Jack's original reply, and take a better look at the battery condition and other fundamentals to ensure the overall system is in good order (which I expect it should be).
    Besides checking battery voltage at the terminals, and a look at the VCDS readouts, any other basics to recommend?
    Thanks!
  12. #9
    I would start by just measuring resistance of the wires.
    For providing a load within the range of the sensor, a decade box is indeed ideal.
  13. Likes Jack@European_Parts liked this post
  14. #10
    JPPSG
